EI1202TBOSL
EI1202TBOSL
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 2MM CYLIND
EI1202TBOSL 数据手册
Proximity Sensors Inductive Stainless Steel Housing Types EI, AC, M12, M18, M30 • Stainless steel housing, cylindrical • Diameter: M12, M18, M30 • Sensing distance: 2 to 15 mm • Power supply: 20 to 250 VAC • Output: SCR, make or break switching • Protection: Overvoltage • LED-indication for output ON • Long or short housing • 2 m cable or plug M12 (double keyed) Product Description Ordering Key AC proximity switches constructed in stainless steel (1.4301) housings. Sizes available are M12, M18 and M30. Length of housing is selectable with 30 mm thread or 50 Type Housing diameter (mm) Rated operating dist. (mm) Output type Housing material Body style Plug mm thread. Bright LED ring utilizing a yellow LED clearly gives indication of output status. Protection rating IP 67 ensures environmental compatibility. EI 1202 TBOSL-6 Type Selection AC Types, Cable and M12 Plug Housing diameter Body style Connection Rated operating dist. (Sn) Ordering no. SCR Make switching Ordering no. SCR Break switching M12 M12 M12 M12 Long Long Long Long Cable Plug Cable Plug 2 mm 1) 2 mm 1) 4 mm 2) 4 mm 2) EI 1202 TBOSL EI 1202 TBOSL-6 EI 1204 TBOSL EI 1204 TBOSL-6 EI 1202 TBCSL EI 1202 TBCSL-6 EI 1204 TBCSL EI 1204 TBCSL-6 M18 M18 M18 M18 M18 M18 M18 M18 Short Short Long Long Short Short Long Long Cable Plug Cable Plug Cable Plug Cable Plug 5 mm 1) 5 mm 1) 5 mm 1) 5 mm 1) 8 mm 2) 8 mm 2) 8 mm 2) 8 mm 2) EI 1805 TBOSS EI 1805 TBOSS-6 EI 1805 TBOSL EI 1805 TBOSL-6 EI 1808 TBOSS EI 1808 TBOSS-6 EI 1808 TBOSL EI 1808 TBOSL-6 EI 1805 TBCSS EI 1805 TBCSS-6 EI 1805 TBCSL EI 1805 TBCSL-6 EI 1808 TBCSS EI 1808 TBCSS-6 EI 1808 TBCSL EI 1808 TBCSL-6 M30 M30 M30 M30 M30 M30 M30 M30 Short Short Long Long Short Short Long Long Cable Plug Cable Plug Cable Plug Cable Plug 10 mm 1) 10 mm 1) 10 mm 1) 10 mm 1) 15 mm 2) 15 mm 2) 15 mm 2) 15 mm 2) EI 3010 TBOSS EI 3010 TBOSS-6 EI 3010 TBOSL EI 3010 TBOSL-6 EI 3015 TBOSS EI 3015 TBOSS-6 EI 3015 TBOSL EI 3015 TBOSL-6 EI 3010 TBCSS EI 3010 TBCSS-6 EI 3010 TBCSL EI 3010 TBCSL-6 EI 3015 TBCSS EI 3015 TBCSS-6 EI 3015 TBCSL EI 3015 TBCSL-6 Short = 30 mm thread Long = 50 mm thread Make switching = Normally Open (NO) Break switching = Normally Closed (NC) 1) 2) For flush mounting in metal For non-flush mounting in metal Specifications are subject to change without notice (20.08.01) 1 EI, AC, M12, M18, M30 Specifications Rated operational volt. (Ue) (UB) Rated operational current (Ie) Continuous Short-time Minimum load current OFF-state current (Ir) Voltage drop (Ud) Protection Transient voltage Power ON delay Frequency of operating cycles (f) Indication for output ON Assured operating dist. (Sa) Repeat accuracy (R) Hysteresis (H) (Differential travel) Effective operating dist. (Sr) 24 to 240 VAC, 20 to 265 VAC, 50 to 60 Hz 10 - 500 mA ≤ 2.5 A, max. 20 ms 10 mA ≤ 2 mA ≤ 8 VAC at max. load Transients Level 3, 2.5 kV, acc. to IEC 60255-5 (500 Ω, 0.5 J) (prepared) ≤ 100 ms 25 Hz LED, yellow 0 ≤ Sa ≤ 0.81 Sn ≤ 5% 3 to 20% of sensing distance 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr Usable operating dist. (S) Ambient temperature Operating Storage Degree of protection Housing material Body Front Back Connection Cable -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IP 67 (Nema 1, 3, 4, 6, 13) Stainless steel (1.4301) Grey thermoplastic polyester Black thermoplastic polyester 2 m, 2 x 0.50 mm2, grey PVC, oil proof M12 x 1 (double keyed) CONH6A-xx EI 12 80 g EI 18 130 g EI 30 200 g EI 12 7.5 Nm (x) 17.5 Nm (y) EI 18 27.5 Nm EI 30 100.0 Nm UL, CSA Yes Plug Cables for plug (-6) Weight (cable excluded) Tightening torque Approvals CE-marking Dimensions Type EI 1202 TB..L EI 1202 TB..L-6 EI 1204 TB..L EI 1204 TB..L-6 EI 1805 TB..S EI 1805 TB..S-6 EI 1805 TB..L EI 1805 TB..L-6 EI 1808 TB..S EI 1808 TB..S-6 EI 1808 TB..L EI 1808 TB..L-6 A B mm C mm 66 74.5 70 78.5 57 55 77 75 65 63 85 83 0 0 4 4 0 0 0 0 8 8 8 8 M 12 x 1 x 50 M 12 x 1 x 50 M 12 x 1 x 50 M 12 x 1 x 50 M 18 x 1 x 30 M 18 x 1 x 30 M 18 x 1 x 50 M 18 x 1 x 50 M 18 x 1 x 30 M 18 x 1 x 30 M 18 x 1 x 50 M 18 x 1 x 50 Type EI 3010 TB..S EI 3010 TB..S-6 EI 3010 TB..L EI 3010 TB..L-6 EI 3015 TB..S EI 3015 TB..S-6 EI 3015 TB..L EI 3015 TB..L-6 A B mm C mm 59 55.5 79 75.5 87.5 67.5 91 71 0 0 0 0 12 12 12 12 M 30 x 1.5 x 30 M 30 x 1.5 x 30 M 30 x 1.5 x 50 M 30 x 1.5 x 50 M 30 x 1.5 x 30 M 30 x 1.5 x 30 M 30 x 1.5 x 50 M 30 x 1.5 x 50 A A 3 1 2 M12x1 B Cable type 2 C LED B C LED Plug type Specifications are subject to change without notice (20.08.01) EI, AC, M12, M18, M30 Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Wiring Diagrams Power Supplies Power supplies VAC: 2 BN 2 BN 3 BU 3 BU TBCS > SS 110 TBOS Specifications are subject to change without notice (20.08.01) 3
EI1202TBOSL
物料型号:CARLO GAVAZZI 接近传感器,包括多种型号,如EI 1202 TBOSL、EI 1204 TBOSL等,具体型号取决于安装方式(电缆或插头)和感应距离。
器件简介:这些接近传感器采用不锈钢外壳,直径有M12、M18、M30可选,感应距离为2到15毫米,适用于多种工业应用。
引脚分配:文档中未明确列出引脚分配,但提到了输出类型为SCR,即固态继电器,通常用于控制高功率设备的开关。
参数特性:包括额定工作电压(20至250 VAC)、额定工作电流(连续短时10-500mA,最大2.5A,20毫秒)、最小负载电流(10mA)、关闭状态下电流(≤2mA)等。
功能详解:接近传感器具有过电压保护、LED指示输出状态、重复精度(≤5%)、滞后(3至20%的感应距离)等功能。
应用信息:适用于需要检测金属物体接近的工业环境,如自动化设备、机器人等。
封装信息:传感器有长型和短型外壳,提供2米电缆或M12插头选项,保护等级为IP 67,确保环境兼容性。
EI1202TBOSL 价格&库存
很抱歉,暂时无法提供与“EI1202TBOSL”相匹配的价格&库存,您可以联系我们找货
