CM18-08BPP-TW0
CM18-08BPP-TW0
    SICK
    Cylinder,Threaded-M18
    SENSOR PROX CAP 3-8MM IP67 CYL
CM18-08BPP-TW0 数据手册
Product data sheet CM18-08BPP-TW0 CM PTFE CAPACITIVE PROXIMITY SENSORS CM18-08BPP-TW0 | CM PTFE CAPACITIVE PROXIMITY SENSORS A B C D E F Ordering information Type Part no. CM18-08BPP-TW0 6026195 Other models and accessories www.sick.com/CM_PTFE Illustration may differ Detailed technical data Features H I J K L M N O P Q R S T Housing Cylindrical thread design Thread size M18 x 1 Diameter Ø 18 mm Sensing range Sn 3 mm ... 8 mm Safe sensing range Sa 5.76 mm Installation type Flush Switching frequency 30 Hz Connection type Cable, 4-wire, 2 m 1) Switching output PNP Output function Complementary Electrical wiring DC 4-wire Adjustment Potentiometer, 270° (Sensitivity) Enclosure rating IP67 2) 1) 2)  Do not bend below 0 °C.  According to EN 60529. Mechanics/electronics Supply voltage 10 V DC ... 36 V DC Ripple ≤ 10 % 1) Voltage drop ≤ 2.5 V DC 2) Current consumption 10 mA 3) 1) 2) 3) 4) 5) 6)  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  In EMC critical applications, conducted interference levels may lie within the frequency range of the oscillator. This can cause changes to the output signal. (See operating instructions.). 2 PROXIMITY SENSORS | SICK Product data sheet | 2021-07-02 11:05:04 Subject to change without notice CM18-08BPP-TW0 | CM PTFE CAPACITIVE PROXIMITY SENSORS Time delay before availability ≤ 100 ms Hysteresis 4 % ... 20 % Reproducibility ≤ 5 % 4) 5) Temperature drift (of Sr) ± 10 % EMC According to EN 60947-5-2 6) Continuous current Ia ≤ 200 mA Cable material PVC Conductor size 0.34 mm² Short-circuit protection ✔ Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance 30 g, 11 ms / 10 ... 55 Hz, 1 mm Ambient operating temperature –25 °C ... +60 °C Housing material PTFE coating, PTFE Housing length 71.5 mm Thread length 46.5 mm Tightening torque, max. ≤ 2.6 Nm Items supplied Mounting nut, PTFE plastic (2x) Screwdriver for potentiometer adjustment (1 x) 1) 2) 3) 4) 5) 6)  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  In EMC critical applications, conducted interference levels may lie within the frequency range of the oscillator. This can cause changes to the output signal. (See operating instructions.). Safety-related parameters MTTFD 897 years DCavg 0 % TM (mission time) 20 years Reduction factors Note The values are reference values which may vary Metal 1 Water 1 PVC Approx. 0.4 Oil Approx. 0.25 Glass 0.6 Ceramics 0.5 Alcohol 0.7 Wood 0.2 ... 0.7 Installation note Remark 2021-07-02 11:05:04 | Product data sheet  Subject to change without notice Associated graphic see "Installation" PROXIMITY SENSORS | SICK 3 CM18-08BPP-TW0 | CM PTFE CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T B 18 mm C 18 mm D 24 mm Classifications ECl@ss 5.0 27270102 ECl@ss 5.1.4 27270102 ECl@ss 6.0 27270102 ECl@ss 6.2 27270102 ECl@ss 7.0 27270102 ECl@ss 8.0 27270102 ECl@ss 8.1 27270102 ECl@ss 9.0 27270102 ECl@ss 10.0 27270102 ECl@ss 11.0 27270102 ETIM 5.0 EC002715 ETIM 6.0 EC002715 ETIM 7.0 EC002715 ETIM 8.0 EC002715 UNSPSC 16.0901 39122230 Installation note Flush installation F B C D Connection diagram Cd-005 4 BN + (L+) BK NO WH NC BU - (M) PROXIMITY SENSORS | SICK Product data sheet | 2021-07-02 11:05:04 Subject to change without notice CM18-08BPP-TW0 | CM PTFE CAPACITIVE PROXIMITY SENSORS Dimensional drawing (Dimensions in mm (inch)) CM18 PTFE, flush, cable 4 M18 x 1 23 1 46.5 (1.83) 15.5 71.5 (2.81) (0.61) ①  Connection ②  Display LED ③  Potentiometer ④  Fastening nuts (2 x); 34 mm hex, plastic Recommended accessories Other models and accessories www.sick.com/CM_PTFE Brief description Type Part no. BEF-KHS-N06N 2051622 BEF-MS12G-NA 4058914 • Description: Mounting plate for M18 sensors • Material: Stainless steel • Items supplied: Without mounting hardware BEF-WG-M18N 5320948 • Description: Mounting bracket for M18 sensors • Material: Stainless steel • Items supplied: Without mounting hardware BEF-WN-M18N 5320947 • • • • Connection type head A: Female connector, M12, 4-pin, straight Connection type head B: Authorizations: UL Description: Unshielded, Head A: female connector, M12, 4-pin, straight, unshielded, for power supply, for cable diameter 4 mm ... 6 mm Head B: • Connection systems: Screw-type terminals • Permitted cross-section: ≤ 0.75 mm² DOS-1204-G 6007302 • • • • DOS-1204-W 6007303 Universal bar clamp systems • • • • Description: Plate N06N for universal clamp bracket, M18 Material: Stainless steel, stainless steel Items supplied: Universal clamp (5322627), mounting hardware Usable for: MH15, MH15V, V180-2, V18V, W15, GR18, GR18S, GR18 Inox, V18, V18 Laser, V12-2, SimpleSense, SureSense, M18 round sensors • Description: Mounting bar, straight, 200 mm, stainless steel • Material: Stainless steel Mounting brackets and plates Plug connectors and cables Connection type head A: Female connector, M12, 4-pin, angled Connection type head B: Authorizations: UL Description: Unshielded, Head A: female connector, M12, 4-pin, angled, unshielded, for power supply, for cable diameter 3 mm ... 6.5 mm Head B: • Connection systems: Screw-type terminals • Permitted cross-section: ≤ 0.75 mm² 2021-07-02 11:05:04 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 5 CM18-08BPP-TW0 | CM PTFE CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Brief description Type Part no. • • • • • • Connection type head A: Male connector, M12, 4-pin, straight Connection type head B: Authorizations: UL Description: Unshielded Connection systems: Screw-type terminals Permitted cross-section: ≤ 0.75 mm² STE-1204-G 6009932 • • • • • • Connection type head A: Male connector, M12, 4-pin, angled Connection type head B: Authorizations: UL Description: Unshielded Connection systems: Screw-type terminals Permitted cross-section: ≤ 0.75 mm² STE-1204-W 6022084 BEF-WN-M18-ST02 5312973 Terminal and alignment brackets 6 • • • • Description: Mounting bracket with ball-and-socket Material: Plastic Items supplied: Mounting hardware included Suitable for: GR18, MH15V, V180-2, V18 • • • • Description: Clamping block for round sensors M18, without fixed stop Material: Plastic Items supplied: Mounting hardware included Suitable for: GR18, MH15V, V180-2, V18 BEF-KH-M18 2051481 • • • • Description: Clamping block for round sensors M18, with fixed stop Material: Plastic Items supplied: Mounting hardware included Suitable for: GR18, MH15V, V180-2, V18 BEF-KHF-M18 2051482 PROXIMITY SENSORS | SICK Product data sheet | 2021-07-02 11:05:04 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
CM18-08BPP-TW0 价格&库存
很抱歉,暂时无法提供与“CM18-08BPP-TW0”相匹配的价格&库存,您可以联系我们找货
