NBN2-F581-160S6-E8-V1
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE CLAMP SEN 2MM PNP 2XNO
NBN2-F581-160S6-E8-V1 数据手册
Inductive power clamp sensor NBN2-F581-160S6-E8-V1 < < < < Extremely bright triple luminous band indication M12 plug can be rotated 0°, 45°, or 90° For use in direct- and alternating-field welding systems Completely halogen and silicon free Dimensions M12 x 1 YE GN RD LEDs 7 13 20 6.5 18 18 -0.2 14 20 35 0° (45°, 90°) 47 23.5 17.2 8.6 Ø 2.2 5 18 5.3 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 906154_eng.pdf 9.5 5.25 Technical Data General specifications Switching function 2 x normally open (NO) Output type PNP Rated operating distance sn Installation non-flush Output polarity Assured operating distance 2 mm DC sa 0 ... 1.62 mm Reduction factor rAl 0.45 Reduction factor rCu 0.35 Reduction factor r304 0.75 Output type 4-wire Nominal ratings Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive power clamp sensor NBN2-F581-160S6-E8-V1 Technical Data Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 25 Hz Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 100 mA Off-state current Ir ≤ 10 µA No-load supply current I0 Constant magnetic field B 100 mT Alternating magnetic field B 100 mT ≤ 15 mA Functional safety related parameters MTTFd 1445 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means LED POWER LED, green Switching state "Closed" = LED red (S02)/C "Open" = LED yellow (S01)/O Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 906154_eng.pdf Mechanical specifications Connection type Connector plug M12 x 1 , 4-pin Flexible lead, housing-sensor (160 ± 5) mm, PUR (halogen-free) Housing material amplifier; PBT, PA6 + GD-ZN AL4 oscillators; PBT Degree of protection IP65 Connection 1 C O C O 4 2 3 L+ L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive power clamp sensor NBN2-F581-160S6-E8-V1 Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Female cordset single-ended M12 A-coded 4-pin, TPE cable welding-bead resistant orange Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 906154_eng.pdf V1-G-OR2M-POC Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBN2-F581-160S6-E8-V1 价格&库存
很抱歉,暂时无法提供与“NBN2-F581-160S6-E8-V1”相匹配的价格&库存,您可以联系我们找货
