IG12FSF04DO
IG12FSF04DO
    CARLOGAVAZZI
    Module
    SENSOR PROX INDUCTIVE 4MM MODULE
IG12FSF04DO 数据手册
Proximity Sensors Inductive Extended Range, Aluminium Micro Switch Housing Type IG12FSF04DO, DC, 2-wire • • • • • • • • Sensing distance: 4 mm Flush type Power supply: 10 to 40 VDC Output: Transistor Make or Break switching Protection: Reverse polarity, short-circuit and transients 2 m cable - PUR/PVC Dimensions: Body: 30 x 19 x 15 mm Tip: Ø12 x 16 mm Product Description Ordering Key Flush mountable inductive proximity switch in micro switch aluminium housing with 2 m PUR cable. This type of sensor can replace mechanical limit switches. Ind. proximity switch Housing style Sensing surface size Housing material Housing length Detection principle Sensing distance Output type Output configuration The sensor has an extreme low No-load supply current of typical 0.3 mA. Mounting with 4 mm captive screws or 3 mm screws (front mounted). IG12FSF04DO Type Selection Housing dimensions Connection Rated operating dist. (Sn) Ordering no. 2 wire DC, Normally open Ordering no. 2 wire DC, Normally closed 30 x 19 x 15 mm Cable 4 mm 1) IG 12 FSF 04 DO IG 12 FSF 04 DC 1) For flush mounting in metal Specifications Rated operational volt. (Ue) (UB) Ripple Rated operational current (Ie) Continuous No-load supply current (I) Voltage drop (Ud) Protection 12 to 36 VDC 10 to 40 VDC (ripple included) ≤ 10% ≤ 5-100 mA ≤ 0.4 mA ≤ 3 VDC at max. load Reverse polarity, short-circuit, transients Transient voltage ≤ 1 kV/500 Ω Power ON delay < 100 ms Frequency of op. cycles (f) 1 kHz Repeat accuracy (R) ≤ 10% Hysteresis (H) (Differential travel) 1 to 20% of sensing distance Assured operating dist. (Sa) 0 ≤ Sa ≤ 0.81 Sn Effective operating dist. (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating dist. (Sm) 0.9 x Sr ≤ Su ≤ 1.1 x Sr Ambient temperature Operating -25° to +70°C (-13° to +158°F) Storage -30° to +80°C (-22° to +176°F) Specifications are subject to change without notice (07.03.05) Degree of protection Housing material Body Front Connection Cable Mounting Weight (cable included 2 m) IP 67 (Nema 1, 3, 4, 6, 13) Anodized Aluminium, type EN AW-6802 Anodized Aluminium and grey thermoplastic polyester (CPBT) 2 m, 2 x 0.34 mm2, Ø5.1 mm grey PUR/PVC, oil proof 2 x M4 screws for side mounting or 2 x M3 screws for front mounting Approx. 85 g 1 IG12FSF04D., DC, 2-wire Dimensions Wiring Diagram 5 5 LOAD 16 BN + BU - 9 51 19 15 30 7.5 6 12 Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Delivery Contents Inductive proximity switch IG12FSF04D. Packaging: plastic bag 2 Specifications are subject to change without notice (07.03.05)
IG12FSF04DO 价格&库存
很抱歉,暂时无法提供与“IG12FSF04DO”相匹配的价格&库存,您可以联系我们找货
