NBB15-U1-Z2
NBB15-U1-Z2
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 15MM NO/NC
NBB15-U1-Z2 数据手册
Inductive sensor NBB15-U1-Z2 < Sensor head bidirectional and rotatable < 15 mm flush < 2 LEDs indicator for 360° visibility Dimensions 40 LED ye LED ye M20 x 1.5 118 46 60 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 203011_eng.pdf 40 30 5.3 LED ye LED ye Technical Data General specifications Switching function Normally open/closed (NO/NC) Output type Two-wire Rated operating distance sn 15 mm Installation flush Output polarity DC Assured operating distance sa 0 ... 12.15 mm Actual operating distance sr 13.5 ... 16.5 mm typ. 15 mm Reduction factor rAl 0.3 Reduction factor rCu 0.3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB15-U1-Z2 Technical Data Reduction factor r304 0.7 Output type 2-wire Nominal ratings Operating voltage UB 5 ... 60 V Switching frequency f 0 ... 400 Hz Hysteresis H typ. 5 % Reverse polarity protection reverse polarity tolerant Short-circuit protection yes Voltage drop Ud ≤5V Ud ... 5 V Operating current IL 2 ... 200 mA Off-state current Ir 0 ... 0.5 mA Voltage drop at IL Voltage drop IL = 100 mA, switching element on Switching state indicator 2 LED, yellow Functional safety related parameters MTTFd 1133 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates EAC conformity TR CU 020/2011 UL approval cULus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 85 °C (-13 ... 185 °F) Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 203011_eng.pdf Mechanical specifications Connection type screw terminals Information for connection A maximum of two conductors with the same core cross section may be mounted on one terminal connection! tightening torque 1.2 Nm + 10 % Core cross-section up to 2.5 mm2 Minimum core cross-section without wire end ferrule 0.5 mm2 , with connector sleeves 0.34 mm2 Maximum core cross-section without wire end ferrule 2.5 mm2 , with connector sleeves 1.5 mm2 Housing material PA/metal with epoxy powder coating Sensing face PA Housing base plastic Degree of protection IP68 / IP69K Mass 225 g Note Tightening torque: 1.8 Nm (housing) Connection 1 3 L+ 2 4 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB15-U1-Z2 Accessories Modular mounting bracket V1-M20-80 Receptacles, M12/M20; plastic version Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 203011_eng.pdf MHW 01 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB15-U1-Z2 价格&库存
很抱歉,暂时无法提供与“NBB15-U1-Z2”相匹配的价格&库存,您可以联系我们找货
