NBB0.8-4M25-E2
NBB0.8-4M25-E2
    PEPPERL+FUCHS(倍加福)
    Cylinder
    INDUCTIVE SEN 0.8MM PNP
NBB0.8-4M25-E2 数据手册
Inductive sensor NBB0,8-4M25-E2 < 0.8 mm flush Dimensions 25 16 ∅4 Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 053378_eng.pdf LED Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation flush Output polarity Assured operating distance 0.8 mm DC sa 0 ... 0.648 mm Reduction factor rAl 0.45 Reduction factor rCu 0.4 Reduction factor r304 0.77 Output type 3-wire Nominal ratings Operating voltage UB 10 ... 30 V Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB0,8-4M25-E2 Technical Data Switching frequency f 0 ... 3000 Hz Hysteresis H typ. 5% Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.1 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 10 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 1400 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.14 mm2 Housing material Stainless steel 1.4305 / AISI 303 Sensing face PC Degree of protection IP67 Cable Cable diameter 3 mm - 0.2 mm Bending radius > 12 x cable diameter Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 053378_eng.pdf Connection BN L+ BK BU L- Mounting 8 ... 23 P max. 0.2 Nm M3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB0,8-4M25-E2 Accessories Mounting flange, 4 mm Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 053378_eng.pdf BF 4 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB0.8-4M25-E2
物料型号:NBB0,8-4M25-E2
器件简介:这是一款0.8毫米平齐安装的电感式传感器。
引脚分配:文档中提到了三个引脚:BN(棕色),L+(蓝色),BK(黑色)。
参数特性: - 切换功能:常开(NO) - 输出类型:PNP - 额定操作距离:0.8mm - 安装方式:平齐 - 输出极性:直流 - 保证操作距离:0...0.648mm - 各种减小因子:rN 0.45, rcu 0.4, r304 0.77 - 输出类型:三线 - 额定电压:10...30V - 开关频率:0...3000 Hz - 滞后性:典型值5% - 防反接保护:具有防反接保护 - 短路保护:脉冲式 - 电压降:≤3V - 工作电流:0...200 mA - 关闭状态电流:0...0.1 mA,典型值0.1 A在25°C - 无负载供电电流:≤10mA - 状态指示:LED,黄色
功能详解:传感器具备高频率开关能力,滞后性保证稳定运行,具有防反接和短路保护,以及低电压降和低工作电流。
应用信息:适用于需要高频率开关和高稳定性能的工业自动化环境。
封装信息:传感器采用不锈钢1.4305/AISI 303材料,感应面为PC塑料,防护等级为IP67,连接类型为2米PVC电缆,芯线截面积0.14 mm²,电缆直径3 mm,最小弯曲半径为电缆直径的12倍。
NBB0.8-4M25-E2 价格&库存
很抱歉,暂时无法提供与“NBB0.8-4M25-E2”相匹配的价格&库存,您可以联系我们找货
