MM12-90APS-ZCO
MM12-90APS-ZCO
    SICK
    Cylinder,Threaded-M12
    SENSOR PROX 5-90MM IP67 CYLINDER
MM12-90APS-ZCO 数据手册
Product data sheet MM12-90APS-ZC0 MM MAGNETIC PROXIMITY SENSORS MM12-90APS-ZC0 | MM MAGNETIC PROXIMITY SENSORS A B C D E F Ordering information Type Part no. MM12-90APS-ZC0 1029950 Included in delivery: BEF-MU-M12 (1) Other models and accessories www.sick.com/MM Illustration may differ Detailed technical data Features H I J K L M N O P Q R S T Housing Cylindrical thread design Housing Advanced Thread size M12 x 1 Diameter Ø 12 mm Sensing range Sn 5 mm ... 90 mm 1) Safe sensing range Sa 72.9 mm Magnetic sensitivity ≤ 0.6 mT Switching frequency 1,000 Hz Connection type Male connector M12, 4-pin Switching output PNP Output function NO Electrical wiring DC 3-wire Magnetic alignment Axial Enclosure rating IP67 2) 1) 2)  Sensing range based on installation in non-magnetic material using Magnet MAG-3010-B (M4.0).  According to EN 60529. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Ripple ≤ 10 % 1) Voltage drop ≤ 2.2 V 2) Current consumption 10 mA 3) 1) 2) 3) 4) 5) 2  Of VS.  At Ia max.  Without load.  Von Sr (VS und Ta constant).  Pulsed. PROXIMITY SENSORS | SICK Product data sheet | 2021-07-20 15:18:31 Subject to change without notice MM12-90APS-ZC0 | MM MAGNETIC PROXIMITY SENSORS Time delay before availability ≤ 30 ms Hysteresis ≤ 25 % Reproducibility ≤ 1 % 4) Temperature drift (of Sr) ± 10 % EMC According to EN 60947-5-2 Continuous current Ia ≤ 200 mA Short-circuit protection ✔ 5) Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance 30 g, 11 ms / 10 ... 55 Hz, 1 mm Ambient operating temperature –25 °C ... +75 °C Housing material Metal, Nickel-plated brass Housing length 62.5 mm Thread length 40 mm Tightening torque, max. ≤ 7 Nm Items supplied Mounting nut, brass, nickel-plated (2x) 1) 2) 3) 4) 5)  Of VS.  At Ia max.  Without load.  Von Sr (VS und Ta constant).  Pulsed. Safety-related parameters MTTFD 2,519 years DCavg 0 % Classifications ECl@ss 5.0 27270104 ECl@ss 5.1.4 27270104 ECl@ss 6.0 27270104 ECl@ss 6.2 27270104 ECl@ss 7.0 27270104 ECl@ss 8.0 27270104 ECl@ss 8.1 27270104 ECl@ss 9.0 27270104 ECl@ss 10.0 27270104 ECl@ss 11.0 27270104 ETIM 5.0 EC002544 ETIM 6.0 EC002544 ETIM 7.0 EC002544 ETIM 8.0 EC002544 UNSPSC 16.0901 39122230 2021-07-20 15:18:31 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 3 MM12-90APS-ZC0 | MM MAGNETIC PROXIMITY SENSORS Connection diagram Cd-011 BN 1 BK 4 BU 3 WH 2 + (L+) NO - (M) not connected Dimensional drawing (Dimensions in mm (inch)) MM12, connector, Standard housing 3 2 1 40 (1.57) H I J K L M N O P Q R S T 62.5 (2.46) M12 x 1 A B C D E F ①  Connection ②  Display LED ③  Fastening nuts (2x); width across 17, metal Recommended accessories Other models and accessories www.sick.com/MM Brief description Type Part no. Magnet without mounting hole, Ø 6 mm, height 25 mm MAG-0625-A 7901783 Magnet without mounting hole, Ø 10 mm, height 3 mm MAG-1003-S 7901782 Magnet with mounting hole for M4 countersunk screw, Ø 20 mm, height 6.5 mm MAG-2006-B 7901784 Magnet without mounting hole, Ø 30 mm, height 10 mm MAG-3010-B 7901785 Magnet with mounting hole for M5 flat head screw, Ø 31 mm, height 15 mm MAG-3015-B 7901786 Magnet with mounting hole for M5 flat head screw, Ø 36 mm, height 19.5 mm MAG-3515-B 7902086 Magnets 4 PROXIMITY SENSORS | SICK Product data sheet | 2021-07-20 15:18:31 Subject to change without notice MM12-90APS-ZC0 | MM MAGNETIC PROXIMITY SENSORS Brief description Type Part no. BEF-KHS-N05 2051611 Plate N05N for universal clamp bracket, M12, Stainless steel 1.4571 (sheet), Stainless steel 1.4408 (clamp), Universal clamp (5322626), mounting hardware BEF-KHS-N05N 2051621 Mounting bar, straight, 200 mm, stainless steel, Stainless steel (1.4571) BEF-MS12G-NA 4058914 Mounting plate for M12 sensors, steel, zinc coated, without mounting hardware BEF-WG-M12 5321869 Mounting bracket for M12 sensors, steel, zinc coated, without mounting hardware BEF-WN-M12 5308447 Clamping block for round sensors M12, without fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included BEF-KH-M12 2051479 Clamping block for round sensors M12, with fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included BEF-KHF-M12 2051480 Universal bar clamp systems Plate N05 for universal clamp bracket, M12, Zinc plated steel (sheet), Zinc die cast (clamping bracket), Universal clamp (5322626), mounting hardware Mounting brackets and plates Terminal and alignment brackets 2021-07-20 15:18:31 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 5 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
MM12-90APS-ZCO 价格&库存
很抱歉,暂时无法提供与“MM12-90APS-ZCO”相匹配的价格&库存,您可以联系我们找货
