IME2S18-05B4DC0
IME2S18-05B4DC0
    SICK
    Cylinder,Threaded-M18
    SENSOR PROX INDUCTIVE
IME2S18-05B4DC0 数据手册
Product data sheet IME2S18-05B4DC0 IME2S NON-CONTACT SAFETY SWITCHES IME2S18-05B4DC0 | IME2S NON-CONTACT SAFETY SWITCHES A B C D E F Ordering information Type Part no. IME2S18-05B4DC0 1091949 Other models and accessories www.sick.com/IME2S Detailed technical data Features H I J K L M N O P Q R S T Sensor principle Inductive Number of safe outputs 2 Housing diameter M18 Sensing range Sn 5 mm 1) Safe switch on distance Sao 4 mm 1) Safe switch off distance Sar 7.5 mm 1) Active sensor surfaces 1 Actuation frequency ≤ 100 Hz 1)  Values apply for steel (FE360). Safety-related parameters Safety integrity level SIL2 (IEC 61508) SILCL2 (EN 62061) Category Category 2 (ISO 13849-1) Performance level PL d (ISO 13849-1) PFHD (mean probability of a dangerous failure per hour) 6.0 x 10-8 (IEC 61508) 1) TM (mission time) 20 years (ISO 13849-1) Type Type 3 (ISO 14119-1) Actuator coding level Uncoded (EN ISO 14119) Safe state in the event of a fault At least one safety-related semiconductor output (OSSD) is in the OFF state. 1)  At 40 °C and 1000 m above sea level. Functions Safe series connection With Flexi Loop (with diagnostics) Interfaces Connection type 2 SAFETY SWITCHES | SICK Male connector M12, 4-pin Product data sheet | 2021-08-04 15:20:56 Subject to change without notice IME2S18-05B4DC0 | IME2S NON-CONTACT SAFETY SWITCHES Diagnostics indicator ✔ Status display ✔ Electrical data Protection class III (IEC 61140) Rated insulation voltage Ui 28.8 V Rated impulse withstand voltage Uimp 1,500 V Supply voltage Vs 24 V DC (19.2 V DC ... 28.8 V DC) Power consumption ≤ 20 mA Type of output Self-monitoring semiconductor outputs (OSSDs) Response time ≤ 1 ms Enable time ≤ 2 ms Risk time ≤ 20 ms Switch-on time ≤ 1 s Mechanical data Design Cylindrical Housing diameter M18 Housing length 69 mm Thread length 44.2 mm Material Housing Nickel-plated brass Sensor surface VISTAL® Installation type Flush Ambient data Enclosure rating IP67 (IEC 60529) Ambient operating temperature –25 °C ... +70 °C Storage temperature –25 °C ... +70 °C Relative humidity 50 %, at 70 °C (IEC 60947-5-2) Vibration resistance 10 Hz ... 55 Hz, 1 mm (IEC 60947-5-2) EMC IEC 60947-5-2 IEC 60947-5-3 IEC 61000-6-7 Classifications ECl@ss 5.0 27272401 ECl@ss 5.1.4 27272401 ECl@ss 6.0 27272401 ECl@ss 6.2 27272401 ECl@ss 7.0 27272401 ECl@ss 8.0 27272401 ECl@ss 8.1 27272401 ECl@ss 9.0 27272401 ECl@ss 10.0 27272401 2021-08-04 15:20:56 | Product data sheet  Subject to change without notice SAFETY SWITCHES | SICK 3 IME2S18-05B4DC0 | IME2S NON-CONTACT SAFETY SWITCHES 27272401 ETIM 5.0 EC001818 ETIM 6.0 EC001818 ETIM 7.0 EC001818 ETIM 8.0 EC001818 UNSPSC 16.0901 39122205 Dimensional drawing (Dimensions in mm (inch)) 69 (2.7) 56.3 (2.2) 6.5 44.2 (0.25) (1.7) M18 x 1 H I J K L M N O P Q R S T ECl@ss 11.0 M12 x 1 A B C D E F LED 2 x 180° 24 4 (0.94) (0.16) Response range 1 23 4 OSSD ON 5 OSSD OFF ①  Safety switch ②  Safe switch on distance Sao ③  Sensing range Sn ④  Safe switch off distance Sar ⑤  Actuator Pin assignment 4 2 1 3 4 Pin Designation Description 1 +24 V DC 24 V DC voltage supply 2 OSSD 1 OSSD 1 output SAFETY SWITCHES | SICK Product data sheet | 2021-08-04 15:20:56 Subject to change without notice IME2S18-05B4DC0 | IME2S NON-CONTACT SAFETY SWITCHES Pin Designation Description 3 0 V DC 0 V DC voltage supply 4 OSSD 2 OSSD 2 output For details see operating instructions Recommended accessories Other models and accessories www.sick.com/IME2S Brief description Type Part no. BEF-WN-M18 5308446 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m YF2A14-050VB3XLEAX 2096235 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 10 m YF2A14-100VB3XLEAX 2096236 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 15 m YF2A14-150VB3XLEAX 2096237 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 20 m YF2A14-200VB3XLEAX 2096238 BEF-KH-M18 2051481 Mounting brackets and plates Mounting bracket for M18 sensors, steel, zinc coated, without mounting hardware Plug connectors and cables Terminal and alignment brackets Clamping block for round sensors M18, without fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included 2021-08-04 15:20:56 | Product data sheet  Subject to change without notice SAFETY SWITCHES | SICK 5 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
IME2S18-05B4DC0 价格&库存
很抱歉,暂时无法提供与“IME2S18-05B4DC0”相匹配的价格&库存,您可以联系我们找货
