NJ15-M1K-A2
NJ15-M1K-A2
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 15MM PNP
NJ15-M1K-A2 数据手册
Inductive sensor NJ15-M1K-A2 < 15 mm non-flush < 4-wire DC 15 Dimensions LEDs 4,3x5,3 30 20/22 30 M16 x 1,5 41 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 222494_eng.pdf 91 Technical Data General specifications Switching function complementary Output type PNP Rated operating distance sn 15 mm Installation non-flush Output polarity DC Assured operating distance sa 0 ... 12.15 mm Reduction factor rAl 0.39 Reduction factor rCu 0.36 Reduction factor r304 0.73 Output type 4-wire Nominal ratings Operating voltage UB 10 ... 60 V DC Switching frequency f 0 ... 200 Hz Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NJ15-M1K-A2 Technical Data Hysteresis H Reverse polarity protection typ. 5 % yes Short-circuit protection pulsing Voltage drop Ud ≤ 2.5 V Operating current IL 0 ... 200 mA No-load supply current I0 ≤ 14.5 mA Time delay before availability tv ≤ 50 ms Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 932 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type screw terminals Information for connection A maximum of two conductors with the same core cross section may be mounted on one terminal connection! tightening torque 1.2 Nm + 10 % Core cross-section up to 2.5 mm2 Minimum core cross-section without wire end ferrule 0.5 mm2 , with connector sleeves 0.34 mm2 Maximum core cross-section without wire end ferrule 2.5 mm2 , with connector sleeves 1.5 mm2 Housing material PBT Sensing face PBT Degree of protection IP67 Connection 1 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 222494_eng.pdf L+ 4 2 3 L- Accessories MH 04-3742A Mounting aid for VariKont and -M1K- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NJ15-M1K-A2 价格&库存
很抱歉,暂时无法提供与“NJ15-M1K-A2”相匹配的价格&库存,您可以联系我们找货
