NMB3-8GM35-E2-C-150MM-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M8
    IND SEN 3MM PNP XYLAN COATED SS
NMB3-8GM35-E2-C-150MM-V1 数据手册
Inductive sensor NMB3-8GM35-E2-C-150MM-V1 < < < < 3 mm flush Stainless steel sensing face Increased operating distance Weld Immune Dimensions M12 x 1 13 25 35 4 M8x1 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 912288_eng.pdf LED 150 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn 3 mm Installation flush Output polarity DC Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NMB3-8GM35-E2-C-150MM-V1 Technical Data Assured operating distance sa 0 ... 2.43 mm Reduction factor rAl 0.3 Reduction factor rCu 0.2 Reduction factor r304 0.7 Reduction factor rSt37 1 Output type 3-wire Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 5 Hz Hysteresis H 5 ... 15 typ. 10 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤2V Operating current IL 0 ... 100 mA Off-state current Ir 0 ... 10 µA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 10 mA Switching state indicator LED, red Mag. Field strength, AC fields 250 mT Mag. Field strength, DC fields 250 mT Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 75 °C (-13 ... 167 °F) Mechanical specifications Connection type Cable connector M12 x 1 , TPE cable Jacket: 150 mm Housing material Xylan coated - Stainless steel 1.4305 / AISI 303 Sensing face Xylan coated - Stainless steel 1.4305 / AISI 303 Degree of protection IP67 Cable Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 912288_eng.pdf Cable diameter 3 mm ± 0.25 mm Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NMB3-8GM35-E2-C-150MM-V1 Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Mounting flange, 8 mm EXG-08 Quick mounting bracket with dead stop V1-G-OR2M-POC Female cordset single-ended M12 A-coded 4-pin, TPE cable welding-bead resistant orange Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 912288_eng.pdf BF 8 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NMB3-8GM35-E2-C-150MM-V1 价格&库存
很抱歉,暂时无法提供与“NMB3-8GM35-E2-C-150MM-V1”相匹配的价格&库存,您可以联系我们找货
