MM08-60APO-ZUA
MM08-60APO-ZUA
    SICK
    Cylinder,Threaded-M8
    SENSOR PROX 60MM IP67 CYLINDER
MM08-60APO-ZUA 数据手册
Product data sheet MM08-60APO-ZUA MM MAGNETIC PROXIMITY SENSORS MM08-60APO-ZUA | MM MAGNETIC PROXIMITY SENSORS A B C D E F Ordering information Type Part no. MM08-60APO-ZUA 1042425 Included in delivery: BEF-MU-M08 (1) Other models and accessories www.sick.com/MM Detailed technical data Features H I J K L M N O P Q R S T Housing Cylindrical thread design Housing Short-body Thread size M8 x 1 Diameter Ø 8 mm Sensing range Sn 0 mm ... 60 mm 1) Safe sensing range Sa 48.6 mm Magnetic sensitivity ≤ 1 mT Switching frequency 1,000 Hz Connection type Cable, 3-wire, 3 m Switching output PNP Output function NC Electrical wiring DC 3-wire Magnetic alignment Axial Enclosure rating IP67 2) 1) 2)  Sensing range based on installation in non-magnetic material using Magnet MAG-3010-B (M4.0).  According to EN 60529. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Ripple ≤ 10 % 1) Voltage drop ≤ 2 V 2) Current consumption 10 mA 3) 1) 2) 3) 4) 5) 2  Of VS.  At Ia max.  Without load.  Von Sr (VS und Ta constant).  Pulsed. PROXIMITY SENSORS | SICK Product data sheet | 2021-07-20 15:18:31 Subject to change without notice MM08-60APO-ZUA | MM MAGNETIC PROXIMITY SENSORS Time delay before availability ≤ 20 ms Hysteresis 1 % ... 10 % Reproducibility ≤ 1 % 4) Temperature drift (of Sr) ± 10 % EMC According to EN 60947-5-2 Continuous current Ia ≤ 200 mA Cable material PUR/PVC Short-circuit protection ✔ 5) Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance 30 g, 11 ms / 10 ... 55 Hz, 1 mm Ambient operating temperature –25 °C ... +75 °C Housing material Metal, Nickel-plated brass Housing length 48 mm Thread length 29.5 mm Tightening torque, max. 6 Nm Items supplied Mounting nut, brass, nickel-plated (2x) 1) 2) 3) 4) 5)  Of VS.  At Ia max.  Without load.  Von Sr (VS und Ta constant).  Pulsed. Safety-related parameters MTTFD 2,339 years DCavg 0 % Classifications ECl@ss 5.0 27270104 ECl@ss 5.1.4 27270104 ECl@ss 6.0 27270104 ECl@ss 6.2 27270104 ECl@ss 7.0 27270104 ECl@ss 8.0 27270104 ECl@ss 8.1 27270104 ECl@ss 9.0 27270104 ECl@ss 10.0 27270104 ECl@ss 11.0 27270104 ETIM 5.0 EC002544 ETIM 6.0 EC002544 ETIM 7.0 EC002544 ETIM 8.0 EC002544 UNSPSC 16.0901 39122230 2021-07-20 15:18:31 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 3 MM08-60APO-ZUA | MM MAGNETIC PROXIMITY SENSORS A B C D E F Installation note installation in magnetizable material Ø A A M (mm) (Nm) M8 10 < 6 Connection diagram Cd-003 BN + (L+) BK NC BU H I J K L M N O P Q R S T installation in non-magnetizable material - (M) Sensing range diagram Sensing range 1 2 3 4 5 6 0 68 0 68 0 60 0 36 0 24 0 23 0 20 (0.79) 40 (1.57) 60 80 (2.36) (3.15) Distance in mm (inch) Max. sensing range Sn, flush or non-flush installation, non-magnetizable material Magnet type Part no. 1 MAG-3315-B (M 5.1) 2 MAG-3015-B (M 5.0) 3 MAG-3010-B (M 4.0) 4 MAG-2006-B (M 3.0) 5 MAG-0625-A (M 2.0) 6 MAG-1003-S (M 1.0) 7902086 4 PROXIMITY SENSORS | SICK 7901786 7901785 7901784 7901783 7901782 Product data sheet | 2021-07-20 15:18:31 Subject to change without notice MM08-60APO-ZUA | MM MAGNETIC PROXIMITY SENSORS Dimensional drawing (Dimensions in mm (inch)) MM08, cable, short-body housing 1 29.5 (1.16) M8 x 1 3 2 48 (1.89) ①  Connection ②  Display LED ③  Fastening nuts (2 x); width across 13, plastic Recommended accessories Other models and accessories www.sick.com/MM Brief description Type Part no. Magnet without mounting hole, Ø 6 mm, height 25 mm MAG-0625-A 7901783 Magnet without mounting hole, Ø 10 mm, height 3 mm MAG-1003-S 7901782 Magnet with mounting hole for M4 countersunk screw, Ø 20 mm, height 6.5 mm MAG-2006-B 7901784 Magnet without mounting hole, Ø 30 mm, height 10 mm MAG-3010-B 7901785 Magnet with mounting hole for M5 flat head screw, Ø 31 mm, height 15 mm MAG-3015-B 7901786 Magnet with mounting hole for M5 flat head screw, Ø 36 mm, height 19.5 mm MAG-3515-B 7902086 Mounting plate for M8 sensors, steel, zinc coated, without mounting hardware BEF-WG-M08 5321722 Mounting bracket for M8 sensors, steel, zinc coated, without mounting hardware BEF-WN-M08 5321721 Clamping block for round sensors M8, without fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included BEF-KH-M08 2051477 Clamping block for round sensors M8, with fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included BEF-KHF-M08 2051478 Magnets Mounting brackets and plates Terminal and alignment brackets 2021-07-20 15:18:31 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 5 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
MM08-60APO-ZUA 价格&库存
很抱歉,暂时无法提供与“MM08-60APO-ZUA”相匹配的价格&库存,您可以联系我们找货
