FIT0658
FIT0658
    DFROBOT
    Module
    FIT0658
FIT0658 数据手册
5V Metal Proximity Switch SKU:FIT0658 INTRODUCTION The proximity switch usually possesses the characteristics of travel switch, micro switch and sensor. This is a small 5V metal proximity switch with 27*10*6mm size, which can be easily mounted in tight space. It features NPN (normally open) output, 4mm detection distance, 1000Hz switching frequency. The response time is less than 1ms, quick and stable. These sensors are IP67 rated, which can withstand a temperature range of -20℃~65℃. So, this sensor can be used indoor and outdoor regardless of the weather. This proximity switch should be operated at 5V. It can be used not only in machinery automation, security equipment, car anti-theft and other operations, but also in the hands of makers with various controller boards for robot runway conversion, speed detection, etc. SPECIFICATION Voltage: 5V Current: 30mA Detection Distance: 4mm Output: NPN (normally open) Detection Target: metal Wire Length: about 2m Sensing Type: inductive Protection: IP67 Operating Temperature: -20℃~65℃ Switching Frequency: 1000Hz Response Time: <1ms Dimension: 27*10*6mm/1.06*0.39*0.24” SHIPPING LIST 5V Metal Proximity Switch x1 \ https://www.dfrobot.com/product-2025.html/5-28-20
FIT0658 价格&库存
很抱歉,暂时无法提供与“FIT0658”相匹配的价格&库存,您可以联系我们找货
