ICB30L50F10PO
ICB30L50F10PO
    CARLOGAVAZZI
    Cylinder,Threaded-M30
    SENSOR PROX INDUCTIVE 10MM CYL
ICB30L50F10PO 数据手册
ICB, M30 Proximity Inductive Sensors Standard Range, Nickel-Plated Brass Housing Types ICB, M30 • Sensing distance: 10 to 15 mm • Flush or non-flush types • Short or long body versions • Rated operational voltage (Ub): 10 - 36 VDC • Output: DC 200 mA, NPN or PNP • Normally open or Normally closed • LED indication for output ON, short-circuit and overload • Protection: reverse polarity, short circuit, transients • Cable or M12 plug versions • According to IEC 60947-5-2 • Laser engraved on front cap, permanently legible • CSA certified for Hazardous Locations Product Description A family of inductive proximity switches in industrial standard nickel-plated brass housings. They are able to handle applications where high sensing range is requested. Ordering Key Output is open collector NPN or PNP transistors. Type Housing style Housing material Housing size Housing length Thread length Detection principle Sensing distance Output type Output configuration Connection ICB30S30F10NOM1 Type Selection Connec- Body tion style Rated operating distance Sn Ordering no. NPN, Normally open Cable Cable Plug Plug Cable Cable Plug Plug 10 mm 1) 15 mm 2) 10 mm 1) 15 mm 2) 10 mm 1) 15 mm 2) 10 mm 1) 15 mm 2) ICB30S30F10NO ICB30S30F10PO ICB30S30N15NO ICB30S30N15PO ICB30S30F10NOM1 ICB30S30F10POM1 ICB30S30N15NOM1 ICB30S30N15POM1 ICB30L50F10NO ICB30L50F10PO ICB30L50N15NO ICB30L50N15PO ICB30L50F10NOM1 ICB30L50F10POM1 ICB30L50N15NOM1 ICB30L50N15POM1 1) Short Short Short Short Long Long Long Long For flush mounting in metal 2) Ordering no. PNP, Normally open Ordering no. NPN, Normally closed Ordering no. PNP, Normally closed ICB30S30F10NC ICB30S30F10PC ICB30S30N15NC ICB30S30N15PC ICB30S30F10NCM1 ICB30S30F10PCM1 ICB30S30N15NCM1 ICB30S30N15PCM1 ICB30L50F10NC ICB30L50F10PC ICB30L50N15NC ICB30L50N15PC ICB30L50F10NCM1 ICB30L50F10PCM1 ICB30L50N15NCM1 ICB30L50N15PCM1 For non-flush mounting in metal Specifications Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.) Ripple ≤ 10% Output current (Ie) ≤ 200 mA @ 50°C (≤ 150 mA @ 50-70°C) OFF-state current (Ir) ≤ 50 μA No load supply current (Io) ≤ 15 mA Voltage drop (Ud) Max. 2.5 VDC @ 200 mA Protection Reverse polarity, short-circuit, transients Voltage transient 1 kV/0.5 J Power ON delay (tv) 300 ms Operating frequency (f) ≤ 1000 Hz Specifications are subject to change without notice (01.06.16) Indication for output ON Activated LED, yellow NO version Target present NC version Target not present Indication for short circuit/ overload LED blinking (f = 2 Hz) Assured operating sensing distance (Sa) 0 ≤ Sa ≤ 0.81 x Sn Effective operating distance (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating distance (Su) 0.85 x Sr ≤ Su ≤ 1.1 x Sr Repeat accuracy (R) ≤ 5% Differential travel (H) (Hysteresis) 1 to 20% of sensing dist. 1 ICB, M30 Specifications (cont.) Ambient temperature Operating Cable Plug Storage Shock and vibration Housing material Body Front cap Connection Cable Plug Degree of protection Weight (cable/nuts included) ICB30 S ICB30 L Dimensions Tightening torque Approvals cULus -25° to +70°C (-13° to +158°F) -40° to +70°C (-40° to +158°F) -40° to +80°C (-40° to +176°F) IEC 60947-5-2/7.4 Nickel-plated brass Grey thermoplastic polyester Approvals (cont.) cCSAus Note: The terminal connector (version ...M1) was not evaluated. The suitability of the terminal connector should be determined in the end-use application. Ø5.2 x 2 m, 3 x 0.34 mm2, grey PVC, oil proof M12 x 1 IP 67 Max. 185 g Max. 195 g See diagrams below 25 Nm (UL508) EMC protection IEC 61000-4-2 (ESD) IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-6 IEC 61000-4-8 MTTFd As Process Control Equipment for Hazardous Locations. - Class I, Division 2, Groups A, B, C and D. - T5 up to 150 mA, T4A for a load current > 150 mA and up to 200 mA, Enclosure Type 4. Ambient temperature Ta: -25° to +60°C. CCC is not required for products with a maximum operating voltage of ≤ 36 V According to IEC 60947-5-2 8 KV air discharge, 4 KV contact discharge 12 V/m 4 kV 10 V 30 A/m 850 years @ 50°C (122°F) Dimensions (mm) 71 M30x1.5 M30x1.5 59 LED 30 10,6 LED 12 Short body, flush version, cable 30 10,6 Short body, non-flush version, cable 67 1 4 2 3 M30x1.5 M30x1.5 55 LED (4 x 90°) 30 30 2 3 9,8 Short body, non-flush version, plug 79 M30x1.5 M30x1.5 91 LED LED 50 10,6 Long body, flush version, cable 2 4 LED (4 x 90°) 12 9,8 Short body, flush version, plug 1 12 50 10,6 Long body, non-flush version, cable Specifications are subject to change without notice (01.06.16) ICB, M30 Dimensions (mm) (cont.) 87 1 4 2 3 M30x1.5 M30x1.5 75 LED (4 x 90°) 50 9,8 Long body, flush version, plug 1 4 2 3 LED (4 x 90°) 12 50 9,8 Long body, non-flush version, plug Installation Flush sensor, when installed in damping material, must be according to Picture 1A. Picture 1A Non-flush sensor, when installed in damping material, must be according to Picture 1B. Picture 1B ≥ 3 x Sn Free zone or non-damping material ≥4xd d ≥ 3 x Sn ≥ 2 x Sn d Free zone or non-damping material Sn : nominal sensing distance d : sensor diameter (30 mm) Sn : nominal sensing distance d : sensor diameter (30 mm) Flush sensors, when installed together in damping material, must be according to Picture 2A. Picture 2A Non-flush sensors, when installed together in damping material, must be according to Picture 2B. Picture 2B d d d d : sensor diameter (30 mm) d 4xd d d : sensor diameter (30 mm) For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed (See Picture 3). Picture 3 ≥ 6 x Sn Sn : nominal sensing distance Specifications are subject to change without notice (01.06.16) 3 ICB, M30 Wiring Diagram 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 2 BK 2 BK 4 BK 3 BU 3 BU - NPN - Normally open - NPN - Normally closed Reduction Factors The rated operating distance is reduced by the use of metals and alloys other than Fe360. Picture 4 3 BU PNP - Normally open - 3 BU - PNP - Normally closed Accessories for Plug Versions The most important reduction factors for inductive proximity sensors are shown in Picture 4. Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance 3-wire angled connector, 2 m cable 3-wire angled connector, 5 m cable 3-wire angled connector, 10 m cable 3-wire straight connector, 2 m cable 3-wire straight connector, 5 m cable CONM13NF-A2 CONM13NF-A5 CONM13NF-A10 CONM13NF-S2 CONM13NF-S5 For any additional information or different options, please refer to the “General Accessories” datasheets. Delivery Contents • Inductive proximity switch ICB. • 2 nuts NPB • Packaging: plastic bag 4 Specifications are subject to change without notice (01.06.16)
ICB30L50F10PO 价格&库存
很抱歉,暂时无法提供与“ICB30L50F10PO”相匹配的价格&库存,您可以联系我们找货
