ICB, M18
Proximity
Inductive Sensors
Standard Range, Nickel-Plated Brass Housing
Types ICB, M18
• Sensing distance: 5 to 8 mm
• Flush or non-flush types
• Short or long body versions
• Rated operational voltage (Ub): 10 - 36 VDC
• Output: DC 200 mA, NPN or PNP
• Normally open or Normally closed
• LED indication for output ON
• Protection: reverse polarity, short circuit, transients
• Cable or M12 plug versions
• According to IEC 60947-5-2
• Laser engraved on front cap, permanently legible
• CSA certified for Hazardous Locations
Product Description
A family of inductive proximity switches in industrial standard nickel-plated
brass housings. They are
able to handle applications
where high sensing range is
requested.
Ordering Key
Output is open collector
NPN or PNP transistors.
Type
Housing style
Housing material
Housing size
Housing length
Thread length
Detection principle
Sensing distance
Output type
Output configuration
Connection
ICB18S30F05NOM1
Type Selection
Connec- Body
tion
style
Rated
operating
distance Sn
Ordering no.
NPN,
Normally open
Cable
Cable
Plug
Plug
Cable
Cable
Plug
Plug
5 mm 1)
8 mm 2)
5 mm 1)
8 mm 2)
5 mm 1)
8 mm 2)
5 mm 1)
8 mm 2)
ICB18S30F05NO
ICB18S30F05PO
ICB18S30N08NO
ICB18S30N08PO
ICB18S30F05NOM1 ICB18S30F05POM1
ICB18S30N08NOM1
ICB18S30N08POM1
ICB18L50F05NO
ICB18L50F05PO
ICB18L50N08NO
ICB18L50N08PO
ICB18L50F05NOM1
ICB18L50F05POM1
ICB18L50N08NOM1
ICB18L50N08POM1
1)
Short
Short
Short
Short
Long
Long
Long
Long
For flush mounting in metal
2)
Ordering no.
PNP,
Normally open
Ordering no.
NPN,
Normally closed
Ordering no.
PNP,
Normally closed
ICB18S30F05NC
ICB18S30F05PC
ICB18S30N08NC
ICB18S30N08PC
ICB18S30F05NCM1 ICB18S30F05PCM1
ICB18S30N08NCM1
ICB18S30N08PCM1
ICB18L50F05NC
ICB18L50F05PC
ICB18L50N08NC
ICB18L50N08PC
ICB18L50F05NCM1
ICB18L50F05PCM1
ICB18L50N08NCM1
ICB18L50N08PCM1
For non-flush mounting in metal
Specifications
Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.)
Ripple ≤ 10%
Output current (Ie) ≤ 200 mA @ 50°C
(≤ 150 mA @ 50-70°C)
OFF-state current (Ir)
≤ 50 μA
No load supply current (Io) ≤ 15 mA
Voltage drop (Ud) Max. 2.5 VDC @ 200 mA
Protection Reverse polarity,
short-circuit, transients
Voltage transient 1 kV/0.5 J
Power ON delay (tv) ≤ 20 ms
Operating frequency (f) ≤ 1500 Hz
Indication for output ON Activated LED, yellow
NO version Target present
NC version Target not present
Indication for short circuit/
overload LED blinking (f = 2 Hz)
Assured operating
sensing distance (Sa) 0 ≤ Sa ≤ 0.81 x Sn
Effective operating
distance (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn
Usable operating distance (Su) 0.9 x Sr ≤ Su ≤ 1.1 x Sr
Repeat accuracy (R) ≤ 10%
Differential travel (H)
(Hysteresis) 1 to 20% of sensing dist.
Ambient temperature
Operating -25° to +70°C (-13° to +158°F)
Storage -30° to +80°C (-22° to +176°F)
Shock and vibration IEC 60947-5-2/7.4
Housing material
Body Nickel-plated brass
Front Grey thermoplastic polyester
Specifications are subject to change without notice (16.01.2017)
1
ICB, M18
Specifications (cont.)
Connection
Cable
Plug
Degree of protection
Weight (cable/nuts included)
Cable
Plug
Dimensions
Tightening torque
Non-flush version
Flush version
From 0 to 7 mm
> 7 mm
Approvals
cULus
cCSAus
Note: The terminal connector
(version ...M1) was not
evaluated. The suitability of
the terminal connector should
be determined in the end-use
application.
Ø4.1 x 2 m, 3 x 0.25 mm2,
grey PVC, oil proof
M12 x 1
IP 67
Approvals (cont.)
EMC protection
IEC 61000-4-2 (ESD)
IEC 61000-4-3
IEC 61000-4-4
IEC 61000-4-6
IEC 61000-4-8
MTTFd
Max. 150 g
Max. 70 g
See diagrams below
25 Nm
20 Nm
25 Nm
(UL508)
Ambient temperature
Ta: -25° to +60°C
CCC is not required for
products with a maximum
operating voltage of ≤ 36 V
8 KV air discharge,
4 KV contact discharge
3 V/m
2 kV
3V
30 A/m
850 years @ 50°C (122°F)
As Process Control
Equipment for Hazardous
Locations.
- Class I, Division 2,
Groups A, B, C and D.
- T5 up to 150 mA, T4A for a
load current > 150 mA and
up to 200 mA, Enclosure
Type 4.
Dimensions (mm)
LED
M18x1
30.0
20.1
10.0
30.0
53.0
20.1
63.0
Short body, flush version, cable
Short body, non-flush version, cable
LED (4 x 90°)
4
3
1
2
30.0
10.0
54.0
3
1
2
30.0
Short body, non-flush version, plug
LED
7.5
LED
M18x1
M18x1
4
64.0
Short body, flush version, plug
7.5
LED (4 x 90°)
7.5
M18x1
M18x1
7.5
50.0
10.0
73.1
Long body, flush version, cable
2
LED
7.5
M18x1
7.5
50.0
83.1
Long body, non-flush version, cable
ICB, M18
Dimensions (mm) (cont.)
LED (4 x 90°)
4
3
1
2
50.0
LED (4 x 90°)
7.5
M18x1
M18x1
7.5
10.0
4
3
1
2
50.0
74.0
84.0
Long body, flush version, plug
Long body, non-flush version, plug
Installation
Flush sensor, when installed in damping material, must be
according to Picture 1A.
Picture 1A
Non-flush sensor, when installed in damping material, must
be according to Picture 1B.
Picture 1B
≥ 3 x Sn
Free zone or
non-damping
material
Free zone or
non-damping
material
≥3xd
d
≥ 3 x Sn
≥ 2 x Sn
d
Sn : nominal sensing distance
d : sensor diameter (18 mm)
Flush sensors, when installed together in damping material,
must be according to Picture 2A.
Picture 2A
Non-flush sensors, when installed together in damping
material, must be according to Picture 2B.
Picture 2B
d
d
d
d
d
2xd
d
d
For sensors installed opposite each other, a minimum space
of 6 x Sn (the nominal sensing distance) must be observed
(See Picture 3).
Picture 3
≥ 6 x Sn
3
ICB, M18
Wiring Diagram
1 BN
1 BN
1 BN
1 BN
4 BK
2 BK
2 BK
4 BK
3 BU
3 BU
NPN - Normally open
NPN - Normally closed
Reduction Factors
The rated operating distance
is reduced by the use of
metals and alloys other than
Fe360.
Picture 4
PNP - Normally open
3 BU
PNP - Normally closed
Accessories for Plug Versions
The most important reduction factors for inductive
proximity sensors are shown
in Picture 4.
Fe360 : Steel
CrNi : Chrome-nickel
CuZn : Brass
Al : Aluminium
Cu : Copper
Sr : Effective operating distance
Delivery Contents
• Inductive proximity switch ICB.
• 2 nuts NPB
• Packaging: plastic bag
4
3 BU
3-wire angled connector,
2 m cable
5 m cable
10 m cable
15 m cable
3-wire straight connector,
2 m cable
5 m cable
10 m cable
15 m cable
PVC PUR
CONB13NF-A2 CONB13NF-A2P
CONB13NF-A5 CONB13NF-A5P
CONB13NF-A10 CONB13NF-A10P
CONB13NF-A15 CONB13NF-A15P
CONB13NF-S2 CONB13NF-S2P
CONB13NF-S5 CONB13NF-S5P
CONB13NF-S10 CONB13NF-S10P
CONB13NF-S15 CONB13NF-S15P
For any additional information
or different options,
please refer to the
“General Accessories Connector Cables -Type CONB1...”
datasheets.
