CBN5-F46-E2
CBN5-F46-E2
    PEPPERL+FUCHS(倍加福)
    CAPACITIVE SEN 5MM PNP
CBN5-F46-E2 数据手册
Capacitive sensor CBN5-F46-E2 < < < < < 5 mm non-flush 3-wire DC Flat housing Mounting slots for cable ties Thru-holes for screw mounting Dimensions 20 5 5 10 2 20 5 50 (42 ± 0.1) LED 1.6 3.2 Release date: 2020-05-07 Date of issue: 2020-05-07 Filename: 051974_eng.pdf 7 Technical Data General specifications Switching function Normally open (NO) Output type PNP Rated operating distance sn Installation non-flush Output polarity Assured operating distance Output type 5 mm DC sa 0 ... 3.5 mm 3-wire Nominal ratings Installation conditions B 0 mm C 10 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Capacitive sensor CBN5-F46-E2 Technical Data F 20 mm / 50 mm Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 10 Hz Hysteresis H 1 ... 10 typ. 5 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤2V Operating current IL 0 ... 100 mA Lowest operating current Im 0 mA Off-state current Ir 0 ... 0.5 mA typ. 0.01 mA Off-state current TU =40 °C, switching element off ≤ 100 µA No-load supply current I0 ≤ 15 mA Time delay before availability tv ≤ 50 ms Switching state indicator LED, yellow Functional safety related parameters MTTFd 1200 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Release date: 2020-05-07 Date of issue: 2020-05-07 Filename: 051974_eng.pdf Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.14 mm2 Housing material PBT Sensing face PBT Degree of protection IP67 Cable Cable diameter 3.5 mm ± 0.2 mm Bending radius > 10 x cable diameter Connection BN L+ BK BU L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Capacitive sensor CBN5-F46-E2 Installation B F sensing face C metal-free zone Release date: 2020-05-07 Date of issue: 2020-05-07 Filename: 051974_eng.pdf support Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
CBN5-F46-E2 价格&库存
很抱歉,暂时无法提供与“CBN5-F46-E2”相匹配的价格&库存,您可以联系我们找货
CBN5-F46-E2
  • 1+735.99794
库存:44
