NBN4-F29-E2
NBN4-F29-E2
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 4MM PNP
NBN4-F29-E2 数据手册
Inductive sensor NBN4-F29-E2 < 4 mm non-flush < 3-wire DC Dimensions 27 6 21.65 7.2 5 2.4 10 LED 3 10.2 Release date: 2020-05-07 Date of issue: 2020-05-07 Filename: 087175_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation non-flush Output polarity Assured operating distance 4 mm DC sa 0 ... 3.24 mm Reduction factor rAl 0.4 Reduction factor rCu 0.3 Reduction factor r304 0.7 Output type 3-wire Nominal ratings Operating voltage UB 4.75 ... 30 V DC Switching frequency f 0 ... 1000 Hz Hysteresis H typ. 5 % Reverse polarity protection reverse polarity protected Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBN4-F29-E2 Technical Data Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 100 mA Off-state current Ir 0 ... 0.5 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 10 mA Time delay before availability tv ≤ 5 ms Switching state indicator LED, yellow Functional safety related parameters MTTFd 1680 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.14 mm2 Housing material PPS Sensing face PPS Degree of protection IP67 Cable Cable diameter 3.5 mm ± 0.2 mm Bending radius > 10 x cable diameter Connection BN Release date: 2020-05-07 Date of issue: 2020-05-07 Filename: 087175_eng.pdf L+ BK BU L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBN4-F29-E2 价格&库存
很抱歉,暂时无法提供与“NBN4-F29-E2”相匹配的价格&库存,您可以联系我们找货
