Q7MB W/100
Q7MB W/100
    BANNER(邦纳)
    Module
    RANGE: VARIES DEPENDING ON APPLI
Q7MB W/100 数据手册
M-GAGE Q7M Flat-Pak Datasheet • • • • • • • Capable of detecting vehicles that have stopped within the sensor's sensing field 3-axis magnetoresistive-based technology; senses 3-dimensional changes to the Earth’s magnetic field caused by the presence of ferrous objects Easy sensor installation Compact, robust one-piece, self-contained sensor package replaces inductive-loop sensing technology; no external controller needed Designed to minimize the effects of temperature swings and destabilizing magnetic fields Sensor learns ambient background and stores settings; sensor will not lose configuration or range when power is cycled US Patent # 6,546,344 B1 WARNING: • Appropriate use for vehicle detection—The mechanical opening, braking, and reversing systems of the door will not respond in sufficient time to prevent moving trucks, cars, or material handling vehicles, even those traveling at low speeds, from coming in contact with the door. In addition, the detection zone of the device may fluctuate due to changes in the local magnetic environment. • Failure to follow these procedures may result in serious injury or death. • All vehicles should approach doors at speeds that allow the operator to ensure the door is operating properly and in an open position. WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Model Cable 1 Q7MB 1.98 m (6.5 ft) cable Q7MB W/15 4.57 m (15 ft) cable Q7MB W/30 9.14 m (30 ft) cable Q7MB W/50 15.2 m (50 ft) cable Q7MB W/100 30.5 m (100 ft) cable Q7MBQ 150 mm (5.9 in) cable with a 5-pin 26 gage/5-wire cable with M12 quick disconnect PVC jacket Cable Type 26 gage/5-wire shielded cable with 4 mm (0.160 in) diameter polyethylene jacket Supply Voltage 10 to 30 V DC Output Type Range Bipolar NPN/ PNP 2 Range varies depending on application and target being sensed. See Typical Target Excess Gain Curves on p. 6. 1 Other cable lengths are available - up to 61 m (200 ft); consult factory for more information. A model with a QD connector requires a mating cable; see Cordsets on p. 7. 2 Consult factory for other output options. Original Document 117172 Rev. F 24 June 2021 117172 M-GAGE Q7M Flat-Pak Overview The Q7M sensors implement a passive sensing technology to detect large ferrous objects. The sensor measures the change in the Earth’s natural magnetic field (the ambient magnetic field) caused by the introduction of a ferromagnetic object. The Q7M sensors provide an alternative to inductive loop systems. Mount the Q7M above-ground . Figure 1. Baseline Magnetic Field Theory of Operation The sensor uses three mutually perpendicular magnetoresistive transducers. Each transducer detects magnetic field changes along one axis. By incorporating three sensing elements, maximum sensor sensitivity is achieved. A ferrous object will alter the local (ambient) magnetic field surrounding the object. The magnitude of this magnetic field change is dependent both on the object (size, shape, orientation, and composition) and on the ambient magnetic field (strength and orientation). During a simple programming procedure, the Q7M measures the ambient magnetic field. When a large ferrous object (for example, a truck, automobile, or rail car) alters that magnetic field, the sensor detects the magnetic field changes (anomalies). When the degree of magnetic field change reaches the sensor’s threshold, the sensor’s discrete outputs switch. A. Baseline magnetic field, with slight disturbances caused by permanent ferrous-metal Sensor Field of View and Range objects within or near the sensor. The sensor range depends on three variables: 1. The local magnetic environment (including nearby ferrous material) Figure 2. Introduction of Large Steel Object 2. The magnetic properties of the object to be sensed 3. Sensor settings The Q7M can detect changes in the ambient magnetic field in all directions. As with other sensors, the range will depend on the target. The strong disturbance of a large ferrous object decreases as the distance from the sensor increases, and the magnitude and shape of the disturbance is dependent on the object’s shape and content. The sensor can be programmed to react to magnetic field disturbances of greater or lesser intensity using two adjustments: background condition and sensitivity level. Once background condition and sensitivity level are set, the sensor is ready to detect the target object. Both settings are stored in non-volatile memory. Note: The Q7M will continue to sense a vehicle in its sensing field, even when the vehicle is stopped. B. After a large steel target object is introduced, the sensor detects the differential (magnetic strength and orientation) between fields A and B. If the differential is greater than the sensitivity threshold, the sensor’s outputs conduct. Tip: Sensor may be mounted inside a non-ferrous architectural detail for cosmetic or security reasons. It is important that, wherever it is mounted, the sensor is securely attached during configuration and all later use. If the sensor moves after being taught, detection errors may occur and sensor must be re-taught. If a sensor appears to lose its taught settings, it may be a result of having shifted position after setup. 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 117172 Rev. F M-GAGE Q7M Flat-Pak Installation The Q7M is non-directional, and can be mounted in any position. The sensor may be mounted inside a non-ferrous architectural detail for cosmetic or security reasons. The end caps provide mounting holes at either end of the sensor. The sensor can be mounted to any desired surface (for example, cement or metal). Select a location as close as possible to the vehicle(s) to be detected. Figure 3. Installation using the mounting holes in the sensor's end caps In applications where the sensor is mounted to the side of the vehicle traffic lane (for example, in a kiosk, menu board, or gate control box), consideration must be made for movement of metallic objects within a few feet of the sensor on the opposite side of the traffic lane, even if the activity is not visible (for example, behind a wall or inside a building). Consult Banner Applications Engineer for further information. When mounting a QD-cable model, it is recommended to route the cable through conduit for protection from environmental conditions. The integral cable does not need such protection. Verify the sensor is securely attached during configuration and operation. If the sensor moves after being taught, detection errors may occur and the sensor must be re-taught. If a sensor appears to lose its taught settings, the sensor may have shifted position after configuration. Install the Sensor Above Ground Restriction: The models listed in this datasheet are not intended to be installed below ground because of inherent installation and environmental variability. Contact Banner Engineering for models designed for below ground installations. Installation Placement Considerations Figure 4. Example good sensor placement P/N 117172 Rev. F Good Placement Figure 4 on p. 3 shows an example of appropriate MGAGE sensor placement for vehicle detection. The sensor is placed at the edge of a traffic lane to detect the vehicle in the near lane. This type of placement is often used for a kiosk, menu board, or gate control box. www.bannerengineering.com - Tel: + 1 888 373 6767 3 M-GAGE Q7M Flat-Pak Figure 5. Example bad sensor placement Bad Placement Figure 5 on p. 4 depicts a potential problem installation. While mounting the sensor at the side of a lane may be successful, this mounting location increases the potential for detection problems. To reliably detect a vehicle from the side, the sensor sensitivity must be increased in order to see objects further away in the lane of interest. Unfortunately, this enables the sensor to also detect another object operating behind the sensor or vehicles in adjacent lanes, which will cause false counts. Place the M-GAGE sensor at the edge of a traffic lane only if there is no possibility of other objects being detected by the sensor. A good practice is to ensure that no vehicles will be within 3.05 m (10 ft) of the sensor on the non-traffic side. Sensor Configuration The sensor is configured via its gray Remote wire. The gray wire is always active and the sensor may be re-configured at any time. For optimum performance, secure the sensor so that it will not move either during or following the configuration. Power blue ON LED (common) wire with a normally Programming pulses may be executed by connecting the sensor's gray wire to the sensor's open mechanical button connected between them, or as a low (< 2 V DC) signal from a programmable logic controller (PLC), or Configuration/ using the model DPB1 Portable Programming Box, as shown. When a PLC is used for configuration, theOutput pulses ON LEDare acknowledged via the sensor output signal. Push Button When the DPB1 is used, the pulses are accomplished by clicking the DPB1 TEACH push button (0.04 seconds ≤ click ≤ 0.8 seconds). The sensor's output status is reflected by the DPB1 Output indicator LED. Figure 6. Sensor features Figure 7. Connecting to the model DPB1 Portable Programming Box Brown Blue Gray White or Black Configuration/ Output ON LED (Red/ Yellow) Power ON LED (Green) Push the TEACH button to pulse the remote wire. Configuration Set Background Condition (No Vehicle Present) Wire the M-GAGE™ sensor as directed. Remove all vehicles and all other metal objects that are temporarily in the sensing area before setting the background condition. 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 117172 Rev. F M-GAGE Q7M Flat-Pak Configuration (0.04 ≤ T ≤ 0.8 seconds) Set Background Result Single-pulse the remote wire. Sensor learns background. Output indicator LED flashes approximately 12 times while the background is taught. T Sensor returns to Run mode. Set Sensitivity Level Level 1 = least sensitive, Level 6 = most sensitive. Configuration (0.04 ≤ T ≤ 0.8 seconds) Result Access Sensitivity Double-pulse the remote wire. Mode T Red output LED flashes every 2 seconds to indicate the current sensitivity level; the sensor always begins at sensitivity level 1. T T Adjust Sensitivity To increase the sensitivity incrementally, single-pulse the remote wire again; continue until the desired sensitivity level is reached. Output LED flashes from 1 to 6 times every 2 seconds to indicate the sensor’s sensitivity level (for example, two flashes indicates level 2). T Double-pulse the remote wire to save the setting. T Sensor returns to Run mode. T T Test Operation Drive a vehicle past the sensor to trip the output. Use a small/light vehicle to ensure larger vehicles will be detected later. Verify Output LED comes On as expected. Adjust the sensitivity as needed. Prepare for Operation Disconnect DPB1 or other temporary switch used for configuration and connect the sensor to a permanent power supply/ output device (user-supplied). See Wiring on p. 5. Wiring Cabled Model bn bu wh bk gy Load Load Remote Program Shield P/N 117172 Rev. F + 10 - 30V dc – 100 mA max. load Quick-Disconnect Model bn bu wh Load bk Load gy + 10 - 30V dc – 100 mA max. load Remote Program Shield www.bannerengineering.com - Tel: + 1 888 373 6767 Pinout 1 2 3 4 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray 5 M-GAGE Q7M Flat-Pak Specifications Supply Voltage 10 V DC to 30 V DC (10% maximum ripple) at 43 mA, exclusive of load Above +50° C (+122° F), supply voltage is 10 V DC to 24 V DC (10% maximum ripple) Sensing Range See Typical Target Excess Gain Curves on p. 6 Sensing Technology Passive three-axis magnetoresistive transducer Supply Protection Circuitry Protected against reverse polarity and transient voltages Adjustments Configuration of Background Condition and Sensitivity Level may be set by pulsing the gray wire remotely via the portable programming box Indicators Two indicators Power Indicator: Green Configuration/Output Indicator: Red/Yellow Construction Lightpipes: Acrylic Housing: Anodized aluminum End Caps: Thermoplastic polyester Output Configuration Two SPST solid-state outputs conduct when object is sensed; one NPN (current sinking) and one PNP (current sourcing) Output Protection Protected against short-circuit conditions Output Ratings 100 mA maximum (each output) NPN saturation: < 200 mV at 10 mA and < 600 mV at 100 mA NPN OFF-state leakage current: < 200 microamps PNP saturation: < 1.2 V at 10 mA and < 1.6 V at 100 mA PNP OFF-state leakage current: < 5 microamps Output Response Time 20 milliseconds Certifications Required Overcurrent Protection Delay at Power-Up 0.5 seconds WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Temperature Effect < 0.5 milligauss / ºC Remote TEACH Input Impedance 12K ohms (low ≤ 2 V DC) Connections Shielded 5-conductor (with drain) polyethylene jacketed attached cable or 5pin M12 quick-disconnect PVC pigtail Patent U.S. Patent 6,546,344 B1 Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) Environmental Rating Leak proof design is rated IEC IP69K; NEMA 6P 20 5.0 22 3.0 Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements method 201A (vibration: 10 to 60 Hz maximum, double amplitude 0.06 inch, maximum acceleration 10G). Also meets IEC 947-5-2: 30G 11 ms duration, half sine wave. 24 2.0 26 1.0 28 0.8 30 0.5 Operating Conditions –40 °C to +70 °C (–40 °F to +158 °F) 100% maximum relative humidity Typical Target Excess Gain Curves After the sensor has been securely mounted and configured, it is ready to operate. The following example application shows typical responses for the M-GAGE™ sensor. This example depicts mounting the M-GAGE™ 1 meter (3.3 ft) above the ground to sense an automobile. The graph shows the excess gain for a typical car. Excess gain is a measure of the amount of extra signal detected by the sensor over and above the Level needed to detect the target. This example assumes a Level 5 sensitivity threshold. The table at right compares the change in excess gain if the sensitivity Level changes. If the sensitivity is at Level 6, then the excess gain at a given distance would be 1.3 times larger than for a Level 5 sensitivity. Conversely, if the sensitivity threshold is Level 1, then the excess gain would be one third as big as for Level 5. Table 1: Excess Gain vs Sensitivity Level (Assumes Level 5) 6 Level Excess Gain Multiplier 1 0.33 2 0.4 3 0.5 4 0.66 5 1.0 (default) 6 1.3 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 117172 Rev. F M-GAGE Q7M Flat-Pak Figure 8. Application example: Sensor mounted 1 meter (3.3 ft) above ground M-GAGE 8 (5) Excess Gain (Sensitivity Level) 7 6 Output ON Distance from vehicle 5 4 (3) 3 2 Threshold 1 Side View Output OFF Top View 0 0 M-GAGE NOTE: Sensor orientation is not a factor. 0.5 m (1.6') 1.0 m (3.2') 1.5 m (4.8') 2.0 m (6.4') 2.5 m (8.0') Distance from Vehicle Side Dimensions 4.0 mm (0.16") 69.0 mm (2.72") Cable or QD Pigtail 19 mm (0.75") 9.0 mm (0.35") Clearance for M3.5/#6 pan head screws (x2) 5.0 mm (0.20") 77.0 mm (3.03") 7.5 mm (0.30") Maximum Allowable Torque: 7 in - lbs 10.0 mm (0.39") 60.0 mm (2.36") Accessories IR COMM. ACTIVE PC POWER TEACH O U T P U T R E M O T E PORTABLE PROGRAMMING BOX D C B SENSOR VOLTAGE + - A SP-DPB1 PROGRAM Handheld Portable Programming Box, used for configuring sensor when push button is not accessible P N P DPB1 N P N Description 15-24 VDC Model Optional 115V ac power supply for DPB1 Handheld Portable Programming Box Cordsets Quick-disconnect cordsets are not suitable for buried applications. P/N 117172 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 7 M-GAGE Q7M Flat-Pak 5-Pin Threaded M12 Cordsets with Shield—Single Ended Model Length MQDEC2-506 2 m (6.56 ft) MQDEC2-515 5 m (16.4 ft) MQDEC2-530 9 m (29.5 ft) MQDEC2-550 15 m (49.2 ft) MQDEC2-506RA 2 m (6.56 ft) MQDEC2-515RA 5 m (16.4 ft) MQDEC2-530RA 9 m (29.5 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 15 m (49.2 ft) 1 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDEC2-550RA Pinout (Female) 2 3 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray M12 x 1 ø 14.5 [0.57"] Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
Q7MB W/100 价格&库存
很抱歉,暂时无法提供与“Q7MB W/100”相匹配的价格&库存,您可以联系我们找货
