M18M2-NC
M18M2-NC
    MERCURY(玛居礼)
    Cylinder,Threaded-M18
    INDUCT PROX SENSOR LOW PWR NC 2W
M18M2-NC 数据手册
Micro Power Inductive Proximity Sensor M18M2 Series MERCURY 2-Wire True-Off™ Industry’s Lowest 3 µA (typ.) Leakage Current and 2.5V DC Supply Voltage Technology: Output Type: Sensing Distance: Supply Voltage: Residual Current: Shielding Quick Selection Guide Inductive. Output Responsive to metal Options: proximity. NPN Connection: 4 mm Housing Body: +2.3V to +27V Package / Case 5 µA max. Interface: Shielded Indicator: Since 1973 Normally Closed (NC) or Normally Open (NO) Cable leads. 2-Wire Metal Cylinder, threaded, M18 None None Description: M18M2 series 2-wire True-Off™ LPS(Inductive Proximity Sensor)operates at the industry’s lowest off-state leakage current or residual current (3 µA) level and lowest power supply voltage levels (+2.3V to +27V), making it ideal for low current portable/battery operated applications. The low minimum operating voltage of +2.5V also makes this sensor directly compatible with most types of computers for portable robotics, motor controls, and automation. Utilizing CMOS IC sensor technology, this sensor provides excellent results, even with difficult-to-detect objects, e.g. small or thin parts, or bright metals. Features: PATENTED USA 9,140,579  Ultra-low off-state leakage current: 3 µA typ. Outperform competitors’ 456 µA. As the name implies, It is a True-Off™ when off. To see the video demonstration, please search “M18M2” at YouTube.  Ultra-low on-state holding current: 20 µA min.  Low power supply voltage: +2.3V to +27V MERCURY www.MercuryUnited.com U.S.A.: TEL (1)-909-466-0427, e-mail: sales-us@MercuryUnited.com Mercury Page 1 of 4 Oct. 30, 2019 Ver.3.0 Micro Power Inductive Proximity Sensor M18M2 Series MERCURY 2-Wire True-Off™ Industry’s Lowest 3 µA (typ.) Leakage Current and 2.5V DC Supply Voltage Since 1973 Absolute Maximum Ratings Power Supply Voltage VDD 0 V min; +30 V max. D.C. Output Voltage 0 V min.; +30 V max. Output Current 0.03 A max. Temperature -40°C min.; +85°C max. Wiring Diagram: Red,+V Load CONTROL Black, Ground Specifications: Ta=+25°C unless otherwise specified Package / Case Target Correction Factors Note 1 Mercury Plastic Cylinder. Threaded. M18. 24 x 24 x 1 mm Aluminum. See correction factor table below for other metals. Ferrous metal: The sensing distance decreases with ferrous or high permittivity metal. Metal Correction Factors Aluminum 1.00 Copper 0.89 Brass 0.88 Stainless steel 0.63 Iron 0.40 Page 2 of 4 Oct. 30, 2019 Ver.3.0 Micro Power Inductive Proximity Sensor M18M2 Series MERCURY 2-Wire True-Off™ Industry’s Lowest 3 µA (typ.) Leakage Current and 2.5V DC Supply Voltage Power supply voltage (Operating Voltage Range) Power Supply Current Consumption Since 1973 +2.3 ~ +27 V D.C. 5 µA max. Output Types note 2 NC (Normally Closed) or NO (Normally Open) Shielding Shielded Output Voltage 27V max. Output Leakage Current (off) 6 µA max. Output Load Current (on) 0.020 mA min. Output Voltage Drop 2.6 V max. Sensing Distance note 3 4 mm ±10% at +25⁰C Response Frequency 5 KHz (200 µ sec.) typical Hysteresis Yes Protection Circuit None Ambient Humidity Operating: 35% to 95%, Storage: 35% to 95% Temperature Influence ±5% typical over -20⁰C to +60⁰C Referenced to sensing distance at +23⁰C Supply Voltage Influence ±1% max. of sensing distance in rated voltage range Operating Temperature Range -20⁰C to +60⁰C Storage Temperature Range -40⁰C to 85⁰C (with no icing or condensation) Ingress Protection IP65 Termination Style Pre-wired. 2 m cable leads. 2 conductors. 22 AWG. Conductor strand: 7/304. Indicator No indicator to 20 mA max. Note 1 Correction Factors -A percentage of the rated operating distance (Al) that represents the operating distance for targets constructed from materials other than Aluminum. Deviations maybe due to variations in the oscillator frequency, alloy compositions, purity & target geometry. Note 2 Normally Closed (“NC”): The output is OFF when the target is detected by the sensor. Note 3 Sensing Distance: A distance at which the target approaching the sensing face, along the reference axis, causes the output signal to change. Mercury Page 3 of 4 Oct. 30, 2019 Ver.3.0 Micro Power Inductive Proximity Sensor M18M2 Series MERCURY 2-Wire True-Off™ Industry’s Lowest 3 µA (typ.) Leakage Current and 2.5V DC Supply Voltage Since 1973 How to Order: Part Number: Normally Closed: LPS-M18M2-NC Outline Dimensions (mm) Warranty: Mercury United does not assume any liability arising out of the application or use of any product or circuit described herein. Our products are not authorized for use as components in devices used for life support or other critical application where failure can cause death or bodily injury. In the case of this product being defective in manufacturing, labeling, packaging or shipping, it will be replaced with a satisfactory unit or the purchase price refunded. This is the exclusive remedy, even if the defect or damage is caused by negligence or other fault. Mercury Page 4 of 4 Oct. 30, 2019 Ver.3.0
M18M2-NC 价格&库存
很抱歉,暂时无法提供与“M18M2-NC”相匹配的价格&库存,您可以联系我们找货
