NBN15-30GK60-AR-3M
NBN15-30GK60-AR-3M
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    INDUCTIVE SEN 15MM SPDT
NBN15-30GK60-AR-3M 数据手册
Inductive sensor NBN15-30GK60-AR-3M < < < < Relay output Sensing range 15 mm SPDT output Switch load currents to 6 Amps Dimensions 60 5 M30 x 1.5 36 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 904970_eng.pdf LED(s) Technical Data General specifications Switching function change-over contact Output type Rated operating distance relay sn 15 mm Installation non-flush Output polarity DC Reduction factor rAl 0.4 Reduction factor rCu 0.37 Reduction factor r304 0.73 Output type Relay output Mechanical life No load: 2 x 107 operations Full load: 1 x 105 switching cycles Nominal ratings Operating voltage UB 10 ... 30 V DC Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBN15-30GK60-AR-3M Technical Data Switching frequency f 20 Hz Hysteresis H approx. 10 % Reverse polarity protection yes Short-circuit protection no Operating current IL Switching state indicator ≤ 50 mA LED, yellow Output Switching voltage max 28 V DC Switching current 6 A DC resistive load Switching power max 180 W Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose Ambient conditions Ambient temperature -40 ... 70 °C (-40 ... 158 °F) Mechanical specifications Connection type 3-meter cable, PVC heavy jacket, 5-conductor, #18 AWG Core cross-section 0.75 mm2 Housing material PBT Sensing face PBT Degree of protection IP68 Connection RD L+ WH OR BU BK L- Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 904970_eng.pdf Accessories BF 30 Mounting flange, 30 mm AB-30 Mounting aid Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBN15-30GK60-AR-3M 价格&库存
很抱歉,暂时无法提供与“NBN15-30GK60-AR-3M”相匹配的价格&库存,您可以联系我们找货
