NBB15-30GM60-A2-V1
NBB15-30GM60-A2-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    INDUCTIVE SEN 15MM PNP
NBB15-30GM60-A2-V1 数据手册
Inductive sensor NBB15-30GM60-A2-V1 < 15 mm flush < Increased operating distance < Extended temperature range Dimensions 60 70 48 5 M30x1,5 36 6 LED Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 085978_eng.pdf M12x1 Technical Data General specifications Switching function complementary Output type Rated operating distance PNP sn Installation flush Output polarity Assured operating distance 15 mm DC sa 0 ... 12.15 mm ( -25 ... 70 °C (-13 ... 158 °F) ) 0 ... 11.4 mm ( -40 ... -25 °C (-40 ... -13 °F) ) Reduction factor rAl 0.3 Reduction factor rCu 0.3 Reduction factor r304 0.75 Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 200 Hz Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB15-30GM60-A2-V1 Technical Data Hysteresis H Reverse polarity protection typ. 5% reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 25 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 1000 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -40 ... 70 °C (-40 ... 158 °F) Mechanical specifications Connection type Connector M12 x 1 , 4-pin Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Connection 1 L+ 4 2 3 Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 085978_eng.pdf L- Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB15-30GM60-A2-V1 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Mounting flange, 30 mm EXG-30 Quick mounting bracket with dead stop V1-G-2M-PUR Female cordset, M12, 4-pin, PUR cable V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 085978_eng.pdf BF 30 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB15-30GM60-A2-V1 价格&库存
很抱歉,暂时无法提供与“NBB15-30GM60-A2-V1”相匹配的价格&库存,您可以联系我们找货
