NBB8-18GM50-E0-V1-M
NBB8-18GM50-E0-V1-M
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 8MM NPN
NBB8-18GM50-E0-V1-M 数据手册
Inductive sensor NBB8-18GM50-E0-V1-M < 8 mm flush < Extended temperature range -40 ... +85 °C < E1-Type approval < Increased noise immunity 100 V/m < With increased sealing, protection class IP68 / IP69K < Highly shock and vibration resistant Dimensions 51 4 M18 x 1 65 24 8 LED M12 x 1 Technical Data Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 240168_eng.pdf General specifications Switching function Normally open (NO) Output type Rated operating distance NPN sn Installation flush Output polarity Assured operating distance 8 mm DC sa 0 ... 6.48 mm Reduction factor rAl 0.4 Reduction factor rCu 0.3 Reduction factor r304 0.7 Reduction factor rBrass 0.45 Output type 3-wire Nominal ratings Operating voltage UB 5 ... 60 V Switching frequency f 0 ... 1500 Hz Hysteresis H typ. 5 % Reverse polarity protection reverse polarity protected Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB8-18GM50-E0-V1-M Technical Data Short-circuit protection pulsing Inductive overvoltage protection yes Surge suppression yes Voltage drop Ud ≤2V Rated insulation voltage UBIS 60 V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 7 mA Time delay before availability tv ≤ 220 ms Switching state indicator Multihole-LED, yellow Functional safety related parameters MTTFd 1085.5 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates EAC conformity TR CU 020/2011 UL approval cULus Listed, General Purpose, Class 2 Power Source CSA approval cCSAus Listed, General Purpose, Class 2 Power Source CCC approval Certified by China Compulsory Certification (CCC) E1 Type approval 10R-04 Ambient conditions Ambient temperature -40 ... 85 °C (-40 ... 185 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type Connector plug M12 x 1 , 3-pin Housing material brass, nickel-plated Sensing face PBT Degree of protection IP68 / IP69K Mass 46 g Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 240168_eng.pdf Connection 1 L+ 4 3 L- Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB8-18GM50-E0-V1-M Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Mounting Interference immunity in accordance with DIN ISO 11452-2: 100 V/m Frequency band 20 MHz up to 2 GHz Mains-borne interference in accordance with ISO 7637-2: Pulse 1 2a 2b 3 a 3b 4 5 Severity level III III III III III III III Failure criterion C A C A A A B EN 61000-4-2: Severity level EN 61000-4-3: Severity level EN 61000-4-4: Severity level EN 61000-4-6: Severity level EN 55011: CD: 8 kV / AD: 15 kV IV IV 30 V/m (80...2500 MHz) IV 2 kV III 10 V (0.01...80 MHz) III Class A Accessories Quick mounting bracket with dead stop BF 18 Mounting flange, 18 mm V1-W-2M-PUR Female cordset single-ended M12 angled A-coded, 4-pin, PUR cable grey V1-G-2M-PUR Female cordset single-ended M12 straight A-coded, 4-pin, PUR cable grey Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 240168_eng.pdf EXG-18 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB8-18GM50-E0-V1-M 价格&库存
很抱歉,暂时无法提供与“NBB8-18GM50-E0-V1-M”相匹配的价格&库存,您可以联系我们找货
