IA08BLN25NOM5
IA08BLN25NOM5
    CARLOGAVAZZI
    Cylinder,Threaded-M8
    SENSOR PROX INDUCTIVE 2.5MM CYL
IA08BLN25NOM5 数据手册
Proximity Sensors Inductive Long Body, Stainless Steel Types IA, M8 • Miniature stainless steel housing (cable or M8/M12 plug) • Long body • Sensing distance: 1,5 mm or 2,5 mm • Power supply: 10 to 30 VDC • Output: Transistor NPN/PNP, normally open or normally closed • Protection: Short-circuit • LED-indication for output ON • 2 m PVC cable, M8 or M12 plug Product Description Ordering Key IA 08 BLF 15 NO M5 Inductive with long figuration both NO Type: Ind. prox. switch Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection proximity sensor body. Output confor NPN/PNP with and NC types as standard. M8 stainless steel housing with 2 m PVC cable or M8/M12 plug. Type Selection Rated Conn. operating type dist. (Sn) Or­der­ing no. Transistor PNP Normally open Or­der­ing no. Transistor PNP Normally closed 1.5 mm 1) Cable IA 08 BLF 15 NO IA 08 BLF 15 NC 1.5 mm 1) Plug M8 IA 08 BLF 15 NO M5 IA 08 BLF 15 PO  IA 08 BLF 15 PO M5  IA 08 BLF 15 PC IA 08 BLF 15 PC M5 Cable IA 08 BLN 25 NO IA 08 BLN 25 NC Plug M8 IA 08 BLN 25 NO M5 IA 08 BLN 25 PO  IA 08 BLN 25 PO M5  IA 08 BLN 25 PC IA 08 BLN 25 PC M5 IA 08 BLF 15 PO M1  IA 08 BLN 25 PO M1  IA 08 BLF 15 PC M1 IA 08 BLN 25 PC M1 2.5 mm 2.5 mm Or­der­ing no. Tran­sis­tor NPN Normally open 1.5 mm 1) Plug M12 IA 08 BLF 15 NO M1 2.5 mm Plug M12 IA 08 BLN 25 NO M1 1) Or­der­ing no. Tran­sis­tor NPN Normally closed IA 08 BLF 15 NC M1 IA 08 BLN 25 NC M1 For flush mounting in metal Specifications Rated operational volt. (UB) 10 to 30 VDC (ripple in­clud­ed) Ripple ≤ 10% Rated operational current (Ie) Continuous ≤ 200 mA @ + 25°C (+75°F) No-load supply current (Io) ≤ 10 mA (ON) Voltage drop (Ud) < 2,5 V (@ Imax) Protection Short circuit Frequency of operating cycles (f) 2000 Hz Indication for output ON LED, yellow Repeat Accuracy ≤ 5% Effective operating dist. (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating dist. (Su) 0.85 x Sr ≤ Su ≤ 1.15 x Sr Specifications are subject to change without notice (20.02.18) Ambient temperature Operating -25° to +70°C (-13° to +158°F) Storage -30° to +75°C (-22° to +167°F) Degree of protection IP 67 (Nema 1, 3, 4, 6, 13) Housing material Stainless steel, AISI 303 CE-marking Yes Connection IA08BL....O/C Cable, 2 m, PVC, AWG 26, oil proof IA08BL....O/C M5 Plug M8, CONB53 series IA08BL....O/C M1 Plug M12, CONB1 series Weight (cables/nuts included) AI... 36 g AI...M1/M5 11 g 1 IA, M8 Dimensions 4 1 4 1 3 4 1 3 4 1 3 2 M8 x 1 x 43 42 .. ..BLF15.. 45 37 60 60 4 x LED 4 x LED LED M8 x 1 M8 x 1 .. ..BLN25.. .. ..BLF15..M5 .. ..BLN25..M5 LED 3 3 40 45 M8 x 1 x 40 M8 x 1 M8 x 1 M8 x 1 M8 x 1 3 2 4 x LED 70 70 4 x LED M12 x 1 M12 x 1 .. ..BLF15..M1 .. ..BLN25..M1 Wiring Di­a­grams IA08BL..... - IA08BL.....M5 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 4 BK 4 BK 4 BK 3 BU 3 BU - NPN - Normally open 3 BU - NPN - Normally closed 3 BU - PNP - Normally open - PNP - Normally closed IA08BL.....M1 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 2 BK 2 BK 4 BK 3 BU 3 BU - NPN - Normally open 3 BU - NPN - Normally closed 3 BU - PNP - Normally open - PNP - Normally closed Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (20.02.18)
IA08BLN25NOM5 价格&库存
很抱歉,暂时无法提供与“IA08BLN25NOM5”相匹配的价格&库存,您可以联系我们找货
