ICS08, ICB12, ICB18 and ICB30 4-wire DC
Proximity inductive sensors with complementary output function
Benefits
Description
• A complete family. Available in M8, M12, M18 and M30
housings with an operating distance from 2 to 22 mm.
• Less machine downtime. Lower risk of mechanical
damage thanks to the extended range sensors with 2
times the standard operating distance.
• Easy to install. ICB sensors have a milled section for
wrench grip and two different thread lengths. The user
can choose between 2 m PVC cable and M12-disconnect
plug versions.
• High precision. The onboard advanced microcontroller
ensures better stability with respect to environmental
influences, with highly repeatable measurements
between -25 and +70°C (up to +80°C for ICS).
• Easy customization to specific OEM requests.
Special sensing distance and timing functions or pigtail solutions with special cables and connectors are
possible on request.
• Product traceability. Permanently legible part number
and serial number, laser engraved on the plastic cap,
guarantee the traceability of every sensor.
A complete family of high performance inductive
sensors and represents Carlo Gavazzi standard
solution for industrial automation equipments.
It is available in 4 diameters: M8, M12, M18 and
M30, in standard and extended sensing ranges,
long and short rugged housings.
Main functions
• Non contact detection of metal objects in general position-sensing and presence-sensing in industrial applications
• Particularly suitable for rotational speed monitoring thanks to the high operating frequency
• Simultaneous availability of both make and break switching functions with maximum connection flexibility to the control
unit
• Integrated diagnostic function with flashing LED in the event of a short circuit or overload
14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN
Carlo Gavazzi Automation S.p.A.
1
References
Order code
IC
A
Enter the code, replacing the symbol
Code
I
C
A
Option
B
S
08
12
18
30
S30
L45
L50
F
N
02
04
05
08
10
14
15
22
N
P
M5
M1
with the selected option (e.g.: ICB12S30F04NAM1).
Description
Inductive sensor
Cylindrical housing
Nickel-plated brass housing
Stainless steel housing
M8 housing
M12 housing
M18 housing
M30 housing
Short housing with thread length of 30 mm
Long housing with thread length of 45 mm
Long housing with thread length of 50 mm
Flush
Non-flush
Sensing distance: 2mm
Sensing distance: 4mm
Sensing distance: 5mm
Sensing distance: 8mm
Sensing distance: 10mm
Sensing distance: 14mm
Sensing distance: 15mm
Sensing distance: 22mm
NPN
PNP
Output: N.O. and N.C.
2 m cable
M8 plug
M12 plug
Additional characters can be used for customized versions.
2
Type selection
M8 Extended range
Connection
Body style
Detection
principle
Flush
Cable
Short
Plug
Non-flush
Flush
Non-flush
Flush
Cable
Long
Plug
Non-flush
Flush
Non-flush
Output
type
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
Ordering no.
Extended range
ICS08S30F02NA
ICS08S30F02PA
ICS08S30N04NA
ICS08S30N04PA
ICS08S30F02NAM5
ICS08S30F02PAM5
ICS08S30N04NAM5
ICS08S30N04PAM5
ICS08L45F02NA
ICS08L45F02PA
ICS08L45N04NA
ICS08L45N04PA
ICS08L45F02NAM5
ICS08L45F02PAM5
ICS08L45N04NAM5
ICS08L45N04PAM5
Output
type
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
Ordering no.
Standard range
ICB12S30F02NA
ICB12S30F02PA
ICB12S30N04NA
ICB12S30N04PA
ICB12S30F02NAM1
ICB12S30F02PAM1
ICB12S30N04NAM1
ICB12S30N04PAM1
ICB12L50F02NA
ICB12L50F02PA
ICB12L50N04NA
ICB12L50N04PA
ICB12L50F02NAM1
ICB12L50F02PAM1
ICB12L50N04NAM1
ICB12L50N04PAM1
M12 Standard and extended range
Connection
Body style
Flush
Cable
Short
Plug
Non-flush
Flush
Non-flush
Flush
Cable
Long
Plug
Detection
principle
Non-flush
Flush
Non-flush
Ordering no.
Extended range
ICB12S30F04NA
ICB12S30F04PA
ICB12S30N08NA
ICB12S30N08PA
ICB12S30F04NAM1
ICB12S30F04PAM1
ICB12S30N08NAM1
ICB12S30N08PAM1
ICB12L50F04NA
ICB12L50F04PA
ICB12L50N08NA
ICB12L50N08PA
ICB12L50F04NAM1
ICB12L50F04PAM1
ICB12L50N08NAM1
ICB12L50N08PAM1
3
M18 Standard and extended range
Connection
Body style
Detection
principle
Flush
Cable
Short
Plug
Non-flush
Flush
Non-flush
Flush
Cable
Long
Plug
Non-flush
Flush
Non-flush
Output
type
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
Ordering no.
Standard range
ICB18S30F05NA
ICB18S30F05PA
ICB18S30N08NA
ICB18S30N08PA
ICB18S30F05NAM1
ICB18S30F05PAM1
ICB18S30N08NAM1
ICB18S30N08PAM1
ICB18L50F05NA
ICB18L50F05PA
ICB18L50N08NA
ICB18L50N08PA
ICB18L50F05NAM1
ICB18L50F05PAM1
ICB18L50N08NAM1
ICB18L50N08PAM1
Ordering no.
Extended range
ICB18S30F08NA
ICB18S30F08PA
ICB18S30N14NA
ICB18S30N14PA
ICB18S30F08NAM1
ICB18S30F08PAM1
ICB18S30N14NAM1
ICB18S30N14PAM1
ICB18L50F08NA
ICB18L50F08PA
ICB18L50N14NA
ICB18L50N14PA
ICB18L50F08NAM1
ICB18L50F08PAM1
ICB18L50N14NAM1
ICB18L50N14PAM1
Output
type
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
NPN
PNP
Ordering no.
Standard range
ICB30S30F10NA
ICB30S30F10PA
ICB30S30N15NA
ICB30S30N15PA
ICB30S30F10NAM1
ICB30S30F10PAM1
ICB30S30N15NAM1
ICB30S30N15PAM1
ICB30L50F10NA
ICB30L50F10PA
ICB30L50N15NA
ICB30L50N15PA
ICB30L50F10NAM1
ICB30L50F10PAM1
ICB30L50N15NAM1
ICB30L50N15PAM1
Ordering no.
Extended range
ICB30S30F15NA
ICB30S30F15PA
ICB30S30N22NA
ICB30S30N22PA
ICB30S30F15NAM1
ICB30S30F15PAM1
ICB30S30N22NAM1
ICB30S30N22PAM1
ICB30L50F15NA
ICB30L50F15PA
ICB30L50N22NA
ICB30L50N22PA
ICB30L50F15NAM1
ICB30L50F15PAM1
ICB30L50N22NAM1
ICB30L50N22PAM1
M30 Standard and extended range
Connection
Body style
Flush
Cable
Short
Plug
Non-flush
Flush
Non-flush
Flush
Cable
Long
Plug
Detection
principle
Non-flush
Flush
Non-flush
4
Structure
ICS08
Element
A
B
Component
Sensing face
2 nuts
C
LED
D
M8, 4 pin, male connector
Function
Flush or non-flush
For sensor mounting
Yellow LED: Output flashing: short circuit or
overload indication
For plug versions only
ICB12
A
B
C
D
E
A
B
C
D
A
B
D
C
E
Element
A
B
C
Component
Sensing face
2 nuts
Milled section
D
LED
E
M12 x 1, 4 pin, male connector
Function
Flush or non-flush
For sensor mounting
For wrench grip
overload indication
5
ICB18
A
B
C
D
A
E
B
C
A
D
B
C
D
E
Element
A
B
C
Component
Sensing face
2 nuts
Milled section
D
LED
E
Function
Flush or non-flush
For sensor mounting
For wrench grip
overload indication
ICB30
A
B
D
E
A
B
D
A
B
D
E
Element
A
B
Component
Sensing face
2 nuts
D
LED
E
Function
Flush or non-flush
For sensor mounting
overload indication
6
Sensing
Detection
Rated operating distance Sn
Reference target
Assured operating sensing distance (Sa)
Effective operating distance (Sr)
Usable operating distance (Su)
Hysteresis (H)
2 to 22 mm: depending on housing diameter and version (flush or nonflush; standard or extended range)
The operating distance is measured according to IEC 60947-5-2, using a standard target moving axially.
This target is square shape 1 mm thickness, made of steel e.g. type Fe
360 as defined in ISO 630 and it shall be of the rolled finish.
The length of the side of the square is equal to
– the diameter of the circle inscribed on the active surface of the sensing face, or
– three times the rated operating distance Sn whichever is greater
0 ≤ Sa ≤ 0.81 x Sn (e.g. with Sn of 15 mm, Sa is 0 ... 12.15 mm)
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.9 x Sr ≤ Su ≤ 1.1 x Sr
1...20%
Correction factors
The specific operating distance Sn refers to defined measuring conditions. The following data have to be
considered as general guidelines.
Fe360 : Steel
CrNi : Chrome-nickel
CuZn : Brass
Al : Aluminium
Cu : Copper
Sr : Effective operating distance
Fig. 1 The rated operating distance is reduced by
the use of metals and alloys other than Fe360. The
most important reduction factors for inductive proximity sensors are shown in the figure.
Accuracy
Repeat accuracy (R)
ICB: ≤ 10%
ICS: < 5% (Sr)
7
Features
Power Supply
Rated operational voltage (Ub)
Ripple (Urpp)
No load supply current (Io)
Power ON delay (tv)
10 to 36 VDC (ripple included)
≤ 10%
ICB: ≤ 16 mA
ICS: ≤ 15 mA
ICB: ≤ 50 ms
ICS: ≤ 20 ms
Outputs
Output functions
Output configuration
Output current (Ie)
OFF-state current (Ir)
NPN or PNP by sensor type
Open collector
N.O. and N.C.
Complementary
≤ 200 mA @ 50°C; ≤ 150 mA @ 50...70°C
≤ 50 μA
ICB: Max. 2.5 VDC @ 200 mA
ICS: Max. 1.6 VDC @ 200 mA
Short-circuit, reverse polarity and transients
1 kV/0.5 J
Voltage drop (Ud)
Protection
Voltage transient
Response times
≤ 2000 Hz
≤ 1500 Hz
≤ 1000 Hz
Operating frequency (f)
ICS08, ICB12
ICB18
ICB30
Indication
Yellow LED
Output
OFF
OFF
ON
ON
Blinking (f = 2 Hz)
Description
N.O. output, target not present
N.C. output, target present
N.O. output, target present
N.C. output, target not present
Short-circuit or overload
8
Environmental
Ambient temperature
ICS
Ambient temperature
ICB
Ambient temperature
ICB30 plug version only
Vibration
Shock
Degree of protection
Operating: -25° to +80°C, (-13° to +176°F)
Storage: -30° to +80°C (-22° to +176°F)
Operating: -25° to +70°C (-13° to +158°F)
Operating: -40° to +70°C (-40° to +158°F)
Storage: -40° to +80°C (-40° to +176°F)
10 to 55 Hz, amplitude 1.0 mm; sweep
IEC 60068-2-6
cycle 5 min; in X, Y and Z direction
30 G /11 ms. 10 shocks in X, Y and Z diIEC 60068-2-27
rection
IP67
IEC 60529; EN 60947-1
Compatibility and conformity
EMC protection
MTTFd
IEC 61000-4-2 Electrostatic dis- 8 kV air discharge
charge
4 kV contact discharge
IEC 61000-4-3 Radiated radiofre3 V/m
quency
IEC 61000-4-4 Burst immunity
2 kV
IEC 61000-4-6 Conducted radio
3V
frequency
IEC 61000-4-8 Power frequency
30 A/m
magnetic fields
M8: 2813 years @ 50°C (122°F);
M12: 750 years @ 50°C (122°F);
M18, M30: 850 years @ 50°C (122°F)
Approvals
CCC is not required for products rated ≤ 36 V
Mechanical data
Weight (including 2 nuts) max.
Mounting
Material
Max tightening torque
Cable version: M8 49 g; M12 120 g; M18 150 g; M30 185 g
Plug version: M8 19 g; M12 30 g; M18 70 g, M30 195 g
Flush or non flush mountable
ICB: Housing: Nickel-plated brass
ICS: Housing: stainless steel AISI304
Front cap: Grey thermoplastic polyester
ICS08: 7 Nm
ICB12: 10 Nm
ICB18 Non-flush version: 25 Nm; Flush version: from 0 to 7 mm: 20
Nm; > 7 mm: 25 Nm
ICB30: 25 Nm
9
Electrical connection
Cable
Plug
ICS: 2m grey PVC, oil proof, laser write, 4x0.14mm2
ICB12 & ICB18: 2m, 4 x 0.25 mm2, Ø4.4 mm, PVC, grey, oil proof
ICB30: 2m, 4 x 0.34 mm2, Ø5.2 mm, PVC, grey, oil proof
ICS: M8 x 1, 4 pin, male connector
ICB: M12 x 1, 4 pin, male connector
10
Connection Diagrams
Colour code
BN
Brown
1BN
1BN
2WH
4BK
4BK
2WH
3BU
3BU
Fig. 2 NPN
Fig. 3 PNP
WH
White
BK
Black
BU
Blue
Wire colors in accordance with EN 60947-5-2
4
3
2
1
Fig. 4 ICS
4
1
3
2
Fig. 5 ICB
11
Dimensions
ICS08 [mm]
LED
M8X1
M8X1
LED
3
30
31
Fig. 6 Short body, flush version, cable
30
34
Fig. 7 Short body, non-flush version, cable
Ø2 LEDx4
M8X1
M8X1
Ø2 LEDx4
3
7
29
40
Fig. 8 Short body, flush version, plug
29
43
7
Fig. 9 Short body, non-flush version, plug
LED
M8X1
M8X1
LED
45
46
Fig. 10 Long body, flush version, cable
3
45
49
Fig. 11 Long body, non-flush version, cable
Ø2 LEDx4
M8X1
M8X1
Ø2 LEDx4
44
55
7
Fig. 12 Long body, flush version, plug
3
44
58
7
Fig. 13 Long body, non-flush version, plug
12
ICB12 [mm]
7.5
M12x1
M12x1
7.5
30.0
14.3
4.0
30.0
14.3
50.8
46.8
Fig. 14 Short body, flush version, cable
Fig. 15 Short body, non-flush version, cable
7.5
M12x1
M12x1
7.5
30.0
11.2
4.0
50.2
30.0
11.2
54.2
Fig. 16 Short body, flush version, plug
Fig. 17 Short body, non-flush version, plug
7.5
M12x1
M12x1
7.5
50.0
4.0
50.0
70.8
66.8
Fig. 18 Long body, flush version, cable
Fig. 19 Long body, non-flush version, cable
7.5
M12x1
M12x1
7.5
50.0
4.0
70.2
Fig. 20 Long body, flush version, plug
50.0
74.2
Fig. 21 Long body, non-flush version, plug
13
ICB18 [mm]
7.5
M18x1
M18x1
7.5
30.0
20.1
10.0
30.0
53.0
20.1
63.0
Fig. 22 Short body, flush version, cable
Fig. 23 Short body, non-flush version, cable
7.5
M18x1
M18x1
7.5
30.0
10.0
54.0
30.0
64.0
Fig. 24 Short body, flush version, plug
Fig. 25 Short body, non-flush version, plug
7.5
M18x1
M18x1
7.5
50.0
10.0
50.0
73.1
83.1
Fig. 26 Long body, flush version, cable
Fig. 27 Long body, non-flush version, cable
7.5
M18x1
M18x1
7.5
50.0
10.0
74.0
Fig. 28 Long body, flush version, plug
50.0
84.0
Fig. 29 Long body, non-flush version, plug
14
ICB30 [mm]
59
M30x1.5
M30x1.5
71
30
12
10,6
Fig. 30 Short body, flush version, cable
30
10,6
Fig. 31 Short body, non-flush version, cable
67
M30x1.5
M30x1.5
55
30
12
9,8
Fig. 32 Short body, flush version, plug
30
9,8
Fig. 33 Short body, non-flush version, plug
79
M30x1.5
M30x1.5
91
10,6
50
12
Fig. 34 Long body, flush version, cable
10,6
50
Fig. 35 Long body, non-flush version, cable
87
M30x1.5
M30x1.5
75
50
9,8
Fig. 36 Long body, flush version, plug
12
50
9,8
Fig. 37 Long body, non-flush version, plug
15
Installation
M8, M12, M18 and M30 flush
d
≥ 3 x Sn
d
d
d
Fig. 38 Flush sensor, when installed in damping
material
Fig. 39 Flush sensors, when installed together in
damping material
M8, M12 and M18 non-flush
≥ 2 x Sn
≥ 3 x Sn
≥3xd
d
Fig. 40 Non-flush sensor, when installed in damping
material
d
d
2xd
d
d
Fig. 41 Non-flush sensors, when installed together in
damping material
16
M30 non-flush
≥ 2 x Sn
≥ 3 x Sn
≥4xd
d
d
Fig. 42 Non-flush sensor, when installed in damping
material
d
4xd
d
d
Fig. 43 Non-flush sensor, when installed together in
damping material
Sensors installed opposite each other
≥ 6 x Sn
Fig. 44 For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed
** Free zone or non-damping material
Sn: nominal sensing distance
d : sensor diameter (8 mm for ICS08, 12 mm for ICB12, 18 mm for ICB18, 30 mm for ICB30)
17
Delivery contents and compatible components
Delivery contents
• Inductive proximity switch
• 2 nuts
• Packaging: plastic bag
CARLO GAVAZZI compatible components
• Mounting bracket AMB... to be purchased separately
• Connector type: CO..14NF... series to be purchased separately
COPYRIGHT ©2019
Content subject to change. Download the PDF: www.productselection.net
18
