ICB12L50N04PO
ICB12L50N04PO
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 4MM CYLIND
ICB12L50N04PO 数据手册
ICB, M12 Proximity Inductive Sensors Standard Range, Nickel-Plated Brass Housing Types ICB, M12 • Sensing distance: 2 to 4 mm • Flush or non-flush types • Short or long body versions • Rated operational voltage (Ub): 10 - 36 VDC • Output: DC 200 mA, NPN or PNP • Normally open or Normally closed • LED indication for output ON • Protection: reverse polarity, short circuit, transients • Cable or M12 plug versions • According to IEC 60947-5-2 • Laser engraved on front cap, permanently legible • CSA certified for Hazardous Locations Product Description A family of inductive proximity switches in industrial standard nickel-plated brass housings. They are able to handle applications where high sensing range is requested. Ordering Key Output is open collector NPN or PNP transistors. Type Housing style Housing material Housing size Housing length Thread length Detection principle Sensing distance Output type Output configuration Connection ICB12S30F02NOM1 Type Selection Connec- Body tion style Rated operating distance Sn Ordering no. NPN, Normally open Cable Cable Plug Plug Cable Cable Plug Plug 2 mm 1) 4 mm 2) 2 mm 1) 4 mm 2) 2 mm 1) 4 mm 2) 2 mm 1) 4 mm 2) ICB12S30F02NO ICB12S30F02PO ICB12S30N04NO ICB12S30N04PO ICB12S30F02NOM1 ICB12S30F02POM1 ICB12S30N04NOM1 ICB12S30N04POM1 ICB12L50F02NO ICB12L50F02PO ICB12L50N04NO ICB12L50N04PO ICB12L50F02NOM1 ICB12L50F02POM1 ICB12L50N04NOM1 ICB12L50N04POM1 1) Short Short Short Short Long Long Long Long For flush mounting in metal 2) Ordering no. PNP, Normally open Ordering no. NPN, Normally closed Ordering no. PNP, Normally closed ICB12S30F02NC ICB12S30F02PC ICB12S30N04NC ICB12S30N04PC ICB12S30F02NCM1 ICB12S30F02PCM1 ICB12S30N04NCM1 ICB12S30N04PCM1 ICB12L50F02NC ICB12L50F02PC ICB12L50N04NC ICB12L50N04PC ICB12L50F02NCM1 ICB12L50F02PCM1 ICB12L50N04NCM1 ICB12L50N04PCM1 For non-flush mounting in metal Specifications Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.) Ripple ≤ 10% Output current (Ie) ≤ 200 mA @ 50°C (≤ 150 mA @ 50-70°C) OFF-state current (Ir) ≤ 50 μA No load supply current (Io) ≤ 15 mA Voltage drop (Ud) Max. 2.5 VDC @ 200 mA Protection Reverse polarity, short-circuit, transients Voltage transient 1 kV/0.5 J Power ON delay (tv) ≤ 20 ms Operating frequency (f) ≤ 2000 Hz Indication for output ON Activated LED, yellow NO version Target present NC version Target not present Specifications are subject to change without notice (10.01.17) Indication for short circuit/ overload LED blinking (f = 2 Hz) Assured operating sensing distance (Sa) 0 ≤ Sa ≤ 0.81 x Sn Effective operating distance (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating distance (Su) 0.9 x Sr ≤ Su ≤ 1.1 x Sr Repeat accuracy (R) ≤ 10% Differential travel (H) (Hysteresis) 1 to 20% of sensing dist. Ambient temperature Operating -25° to +70°C (-13° to +158°F) Storage -30° to +80°C (-22° to +176°F) Shock and vibration IEC 60947-5-2/7.4 1 ICB, M12 Specifications (cont.) Housing material Body Front Connection Cable Plug Degree of protection Weight (cable/nuts included) Cable Plug Dimensions Tightening torque Approvals cULus cCSAus Note: The terminal connector (version ...M1) was not evaluated. The suitability of the terminal connector should be determined in the end-use application. Nickel-plated brass Grey thermoplastic polyester Ø4.1 x 2 m, 3 x 0.25 mm2, grey PVC, oil proof M12 x 1 IP 67 Max. 120 g Max. 30 g See diagrams below 10 Nm (UL508) Approvals (cont.) EMC protection IEC 61000-4-2 (ESD) IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-6 IEC 61000-4-8 MTTFd CCC is not required for products with a maximum operating voltage of ≤ 36 V According to IEC 60947-5-2 8 KV air discharge, 4 KV contact discharge 3 V/m 2 kV 3V 30 A/m 750 years @ 50°C (122°F) As Process Control Equipment for Hazardous Locations. - Class I, Division 2, Groups A, B, C and D. - T5, Enclosure Type 4. Ambient temperature Ta: -25° to +60°C Dimensions (mm) LED M12x1 30.0 14.3 4.0 30.0 14.3 50.8 46.8 Short body, flush version, cable Short body, non-flush version, cable LED (4 x 90°) 30.0 LED (4 x 90°) 7.5 4 3 1 2 M12x1 M12x1 7.5 4.0 11.2 30.0 4 3 1 2 11.2 54.2 50.2 Short body, flush version, plug Short body, non-flush version, plug LED 7.5 LED M12x1 M12x1 7.5 50.0 4.0 66.8 Long body, flush version, cable 2 LED 7.5 M12x1 7.5 50.0 70.8 Long body, non-flush version, cable Specifications are subject to change without notice (10.01.17) ICB, M12 Dimensions (mm) (cont.) LED (4 x 90°) LED (4 x 90°) 7.5 4 3 1 2 50.0 M12x1 M12x1 7.5 4.0 4 3 1 2 50.0 74.2 70.2 Long body, flush version, plug Long body, non-flush version, plug Installation Flush sensor, when installed in damping material, must be according to Picture 1A. Picture 1A Non-flush sensor, when installed in damping material, must be according to Picture 1B. Picture 1B ≥ 3 x Sn Free zone or non-damping material Free zone or non-damping material ≥3xd d ≥ 3 x Sn ≥ 2 x Sn d Sn : nominal sensing distance d : sensor diameter (12 mm) Sn : nominal sensing distance d : sensor diameter (12 mm) Flush sensors, when installed together in damping material, must be according to Picture 2A. Picture 2A Non-flush sensors, when installed together in damping material, must be according to Picture 2B. Picture 2B d d d d : sensor diameter (12 mm) d d 2xd d d d : sensor diameter (12 mm) For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed (See Picture 3). Picture 3 ≥ 6 x Sn Sn : nominal sensing distance Specifications are subject to change without notice (10.01.17) 3 ICB, M12 Wiring Diagram 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 2 BK 2 BK 4 BK 3 BU 3 BU - NPN - Normally open - NPN - Normally closed Reduction Factors The rated operating distance is reduced by the use of metals and alloys other than Fe360. Picture 4 3 BU PNP - Normally open - 3 BU - PNP - Normally closed Accessories for Plug Versions The most important reduction factors for inductive proximity sensors are shown in Picture 4. Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance 3-wire angled connector, 2 m cable 3-wire angled connector, 5 m cable 3-wire angled connector, 10 m cable 3-wire angled connector, 15 m cable 3-wire straight connector, 2 m cable 3-wire straight connector, 5 m cable 3-wire straight connector, 10 m cable 3-wire straight connector, 15 m cable PVC PUR CONB13NF-A2 CONB13NF-A2P CONB13NF-A5 CONB13NF-A5P CONB13NF-A10 CONB13NF-A10P CONB13NF-A15 CONB13NF-A15P CONB13NF-S2 CONB13NF-S2P CONB13NF-S5 CONB13NF-S5P CONB13NF-S10 CONB13NF-S10P CONB13NF-S15 CONB13NF-S15P For any additional information or different options, please refer to the “General Accessories Connector Cables -Type CONB1...” datasheets. Delivery Contents • Inductive proximity switch ICB. • 2 nuts NPB • Packaging: plastic bag 4 Specifications are subject to change without notice (10.01.17)
ICB12L50N04PO 价格&库存
很抱歉,暂时无法提供与“ICB12L50N04PO”相匹配的价格&库存,您可以联系我们找货
