ICB, M18
Proximity
Inductive Sensors
Increased Operating Distance,
Nickel-Plated Brass Housing - Types ICB, M18
• Sensing distance: 12 to 20 mm
• Quasi-flush or non-flush mountable
• Short or long body versions
• Rated operational voltage (Ub): 10 - 36 VDC
• Output: DC 200 mA, NPN or PNP
• Normally open or Normally closed
• LED indication for output ON, short-circuit and
overload
• Protection: reverse polarity, short circuit, transients
• Cable or M12 plug versions
• According to IEC 60947-5-2
• Setup indicator
• Laser engraved on front cap, permanently legible
• CSA certified for Hazardous Locations
Product Description
A family of inductive proximity switches in industrial
standard nickel-plated brass
housings. They are able to
handle applications where
very long operating distance
is requested.
Ordering Key
Output is open collector
NPN or PNP transistors.
Less machine downtime
thanks to lower risk of
mechanical damage.
Type
Housing style
Housing material
Housing size
Housing length
Thread length
Detection principle
Sensing distance
Output type
Output configuration
Connection
ICB18S30F12NOM1
Type Selection
Connec- Body
tion
style
Rated
operating
distance Sn
Ordering no.
NPN,
Normally open
Cable
Cable
Plug
Plug
Cable
Cable
Plug
Plug
12 mm 1)
20 mm 2)
12 mm 1)
20 mm 2)
12 mm 1)
20 mm 2)
12 mm 1)
20mm 2)
ICB18S30F12NO
ICB18S30F12PO
ICB18S30N20NO
ICB18S30N20PO
ICB18S30F12NOM1 ICB18S30F12POM1
ICB18S30N20NOM1
ICB18S30N20POM1
ICB18L50F12NO
ICB18L50F12PO
ICB18L50N20NO
ICB18L50N20PO
ICB18L50F12NOM1
ICB18L50F12POM1
ICB18L50N20NOM1
ICB18L50N20POM1
1)
Short
Short
Short
Short
Long
Long
Long
Long
For quasi-flush mounting in metal
2)
Ordering no.
PNP,
Normally open
Ordering no.
NPN,
Normally closed
Ordering no.
PNP,
Normally closed
ICB18S30F12NC
ICB18S30F12PC
ICB18S30N20NC
ICB18S30N20PC
ICB18S30F12NCM1 ICB18S30F12PCM1
ICB18S30N20NCM1
ICB18S30N20PCM1
ICB18L50F12NC
ICB18L50F12PC
ICB18L50N20NC
ICB18L50N20PC
ICB18L50F12NCM1
ICB18L50F12PCM1
ICB18L50N20NCM1
ICB18L50N20PCM1
For non-flush mounting in metal
Specifications
Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.)
Ripple ≤ 10%
Output current (Ie) ≤ 200 mA @ 50°C
(≤ 150 mA @ 50-70°C)
OFF-state current (Ir)
≤ 50 μA
No load supply current (Io) ≤ 15 mA
Voltage drop (Ud) Max. 2.5 VDC @ 200 mA
Protection Reverse polarity,
short-circuit, transients
Voltage transient 1 kV/0.5 J
Power ON delay (tv) ≤ 20 ms
Operating frequency (f) ≤ 1500 Hz
Specifications are subject to change without notice (16.01.2017)
Indication for output ON Activated LED, yellow
NO version Target present
NC version Target not present
Indication for short circuit/
overload LED blinking (f = 2 Hz)
Assured operating
sensing distance (Sa) 0 ≤ Sa ≤ 0.81 x Sn
Effective operating
distance (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn
Usable operating distance (Su) 0.9 x Sr ≤ Su ≤ 1.1 x Sr
Repeat accuracy (R) ≤ 10%
Differential travel (H)
(Hysteresis) 1 to 20% of sensing dist.
1
ICB, M18
Specifications (cont.)
Ambient temperature
Operating
Storage
Shock and vibration
Housing material
Body
Front
Connection
Cable
Plug
Degree of protection
Weight (cable/nuts included)
Cable
Plug
Dimensions
Tightening torque
Distance from sensing face
from 0 mm to 9 mm
> 9 mm
Setup function
NO version
LED flashing (f=0.67 Hz)
LED lights continuously
NC version
LED OFF
-25° to +70°C (-13° to +158°F)
-30° to +80°C (-22° to +176°F)
IEC 60947-5-2/7.4
Nickel-plated brass
Grey thermoplastic polyester
Ø4.1 x 2 m, 3 x 0.25 mm2,
grey PVC, oil proof
M12 x 1
IP 67
Max. 150 g
Max. 80 g
See diagrams below
15 Nm
25 Nm
0.8 Sn < Sr ≤ Sn
0 ≤ Sr ≤ 0.8 Sn (*)
Approvals
cULus
(UL508)
cCSAus
As Process Control
Equipment for Hazardous
Locations.
Note: The terminal connector - Class I, Division 2,
(version ...M1) was not
Groups A, B, C and D.
evaluated. The suitability of
- T5 up to 150mA, T4A for a
the terminal connector should load current > 150mA and
be determined in the end-use up to 200 mA, Enclosure
application.
Type 4.
Ambient temperature
Ta: -25° to +60°C
CCC is not required for
products with a maximum
operating voltage of ≤ 36 V
EMC protection According to IEC 60947-5-2
IEC 61000-4-2 (ESD) 8 KV air discharge,
4 KV contact discharge
IEC 61000-4-3 3 V/m
IEC 61000-4-4 2 kV
IEC 61000-4-6 3 V
IEC 61000-4-8 30 A/m
MTTFd 850 years @ 50°C (122°F)
0.8 Sn < Sr ≤ Sn
0 ≤ Sr ≤ 0.8 Sn (*)
(*): safer installation
Dimensions (mm)
LED
1.0
30.0
LED
30.0
20.1
10.0
53.0
Short body, quasi-flush version, cable
20.1
53.0
Short body, non-flush version, cable
LED (4 x 90°)
LED (4 x 90°)
4
3
4
3
1
2
1
2
1.0
30.0
30.0
54.0
Short body, quasi-flush version, plug
2
10.0
54.0
Short body, non-flush version, plug
ICB, M18
Dimensions (mm) (cont.)
LED
1.0
LED
7.5
7.5
50.0
50.0
73.1
73.1
10.0
Long body, quasi-flush version, cable
Long body, non-flush version, cable
LED (4 x 90°)
LED (4 x 90°)
4
3
4
3
1
2
1
2
1.0
50.0
50.0
10.0
74.0
74.0
Long body, quasi-flush version, plug
Long body, non-flush version, plug
Installation
Quasi-flush mountable proximity switches, when installed in
damping material, must be according to Picture 1A.
Picture 1A
Non-flush mountable proximity switches, when installed in
damping material, must be according to Picture 1B.
Picture 1B
d
≥2xd
Sn : nominal sensing distance
d : sensor diameter (18 mm)
d
≥2xd
together in damping material, must be according to Picture
2A.
Picture 2A
d
≥ 2 x Sn
≥4 mm
4 mm
≥2xd
2B.
Picture 2B
d
≥2xd
d
≥3xd
d
≥2xd
4 mm
4 mm
3
ICB, M18
Installation
For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed (See
Picture 3).
Picture 3
≥ 6 x Sn
Wiring Diagram
1 BN
1 BN
1 BN
1 BN
4 BK
2 BK
2 BK
4 BK
3 BU
3 BU
NPN - Normally open
NPN - Normally closed
Reduction Factors
The rated operating distance
is reduced by the use of
metals and alloys other than
Fe360.
Picture 4
PNP - Normally open
3 BU
PNP - Normally closed
Accessories for Plug Versions
The most important reduction factors for inductive
proximity sensors are shown
in Picture 4.
Fe360 : Steel
CrNi : Chrome-nickel
CuZn : Brass
Al : Aluminium
Cu : Copper
Sr : Effective operating distance
Delivery Contents
• Inductive proximity switch ICB.
• 2 nuts NPB
• 2 washers
• Packaging: plastic bag
4
3 BU
3-wire angled connector,
2 m cable
5 m cable
10 m cable
15 m cable
3-wire straight connector,
2 m cable
5 m cable
10 m cable
15 m cable
PVC PUR
CONB13NF-A2 CONB13NF-A2P
CONB13NF-A5 CONB13NF-A5P
CONB13NF-A10 CONB13NF-A10P
CONB13NF-A15 CONB13NF-A15P
CONB13NF-S2 CONB13NF-S2P
CONB13NF-S5 CONB13NF-S5P
CONB13NF-S10 CONB13NF-S10P
CONB13NF-S15 CONB13NF-S15P
For any additional information
or different options,
please refer to the
“General Accessories Connector Cables -Type CONB1...”
datasheets.
