S-8225B Series
www.ablic.com
BATTERY MONITORING IC
FOR 3-SERIAL TO 5-SERIAL CELL PACK
© ABLIC Inc., 2012-2019
Rev.1.6_00
The S-8225B Series includes high-accuracy voltage detection circuits and delay circuits, and can monitor the status of
3-serial to 5-serial cell lithium-ion rechargeable battery in single use. By switching the voltage level which is applied to the
SEL1 pin and SEL2 pin, users are able to use the S-8225B Series for 3-serial to 5-serial cell pack.
Features
• High-accuracy voltage detection function for each cell
Overcharge detection voltage n (n = 1 to 5)
3.5 V to 4.4 V (50 mV step)
Accuracy ±20 mV (Ta = +25°C), ±30 mV (Ta = 0°C to +60°C)
Overcharge release voltage n (n = 1 to 5)
3.3 V to 4.4 V*1
Accuracy ±50 mV
Overdischarge detection voltage n (n = 1 to 5)
2.2 V to 3.2 V (100 mV step)
Accuracy ±80 mV
Overdischarge release voltage n (n = 1 to 5)
2.2 V to 3.4 V*2
Accuracy ±100 mV
Overcharge detection delay time and overdischarge detection delay time can be set by external capacitor.
Switchable between 3-serial to 5-serial cell by using the SEL1 pin and the SEL2 pin
The CO pin and the DO pin are controlled by the CTLC pin and the CTLD pin, respectively.
Output voltage of the CO pin and the DO pin is limited to 12 V max.
Output logic is selectable.
Active "H", active "L"
High-withstand voltage
Absolute maximum rating: 28 V
Wide operation voltage range
4 V to 26 V
Wide operation temperature range
Ta = −40°C to +85°C
Low current consumption
During operation (V1 = V2 = V3 = V4 = V5 = 3.4 V)
20 μA max. (Ta = +25°C)
During power-down (V1 = V2 = V3 = V4 = V5 = 1.6 V) 3.0 μA max. (Ta = +25°C)
Lead-free (Sn 100%), halogen-free
*1. Overcharge hysteresis voltage n (n = 1 to 5) is selectable in 0 V, or in 0.1 V to 0.4 V in 50 mV step.
(Overcharge hysteresis voltage = Overcharge detection voltage − Overcharge release voltage)
*2. Overdischarge hysteresis voltage n (n = 1 to 5) is selectable in 0 V, or in 0.2 V to 0.7 V in 100 mV step.
(Overdischarge hysteresis voltage = Overdischarge release voltage − Overdischarge detection voltage)
Application
• Lithium-ion rechargeable battery pack
Package
• 16-Pin TSSOP
1
BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK
S-8225B Series
Rev.1.6_00
Block Diagram
VDD
CTLD
Control circuit
CTLC
Delay circuit
Delay circuit
CO pin output
voltage limit circuit
CO
DO pin output
Overcharge 1
Overdischarge 1+
VC1
Overcharge 2
Overdischarge 2 +
VC2
Overcharge 3
Overdischarge 3 +
DO
Overcharge 4
Overdischarge 4
VC3
VC4
SEL1
SEL2
Overcharge 5 −
Overdischarge 5 +
VC5
VC6
CDT
CCT
VSS
Remark Diodes in the figure are parasitic diodes.
Figure 1
2
S-8225B Series
Rev.1.6_00
Product Name Structure
1. Product name
S-8225B
xx
TCT1
U
Environmental code
U:
Package abbreviation and IC packing specifications*1
TCT1: 16-Pin TSSOP, Tape
*2
Serial code
Sequentially set from AA to ZZ
*1. Refer to the tape drawing.
*2. Refer to "3. Product name list".
2. Package
Table 1 Package Drawing Codes
Package Name
16-Pin TSSOP
Dimension
FT016-A-P-SD
Tape
FT016-A-C-SD
Reel
FT016-A-R-S1
Table 2
Overcharge Overcharge Overdischarge Overdischarge
Release
Detection
Release
Detection
Product Name
Voltage
Voltage
Voltage
Voltage
[VCL]
[VDL]
[VDU]
[VCU]
S-8225BAA-TCT1U
4.220 V
4.170 V
2.30 V
2.30 V
S-8225BAB-TCT1U
3.600 V
3.550 V
2.20 V
2.20 V
S-8225BAC-TCT1U
4.450 V
4.050 V
2.50 V
2.70 V
S-8225BAE-TCT1U
4.250 V
4.200 V
2.70 V
3.00 V
S-8225BAF-TCT1U
4.250 V
4.200 V
2.50 V
2.70 V
S-8225BAG-TCT1U
4.275 V
4.225 V
2.30 V
2.80 V
S-8225BAH-TCT1U
3.900 V
3.600 V
2.20 V
2.40 V
S-8225BAI-TCT1U
4.195 V
4.195 V
2.50 V
3.00 V
S-8225BAJ-TCT1U
4.170 V
4.170 V
2.50 V
3.00 V
S-8225BAK-TCT1U
4.225 V
4.025 V
2.20 V
2.90 V
Remark Please contact our sales office for products other than the above.
CO Pin
Output
Logic
DO Pin
Output
Logic
0 V Battery
Detection
Function
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "L"
Active "L"
Active "L"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Unavailable
Unavailable
Unavailable
Unavailable
Unavailable
Unavailable
Available
Available
Available
Unavailable
3
S-8225B Series
Rev.1.6_00
Pin Configuration
1.
16-Pin TSSOP
Top view
1
2
3
4
5
6
7
8
16
15
14
13
12
11
10
9
Figure 2
Table 3
Pin No.
1
2
3
4
5
6
7
8
Symbol
CTLD
CTLC
CO
DO
SEL1
SEL2
CDT
CCT
Description
DO control pin
CO control pin
Output pin for overcharge detection
Output pin for overdischarge detection
Switching pins for 3-serial to 5-serial cell*1
Capacitor connection pin for delay for overdischarge detection voltage
Capacitor connection pin for delay for overcharge detection voltage
Input pin for negative power supply,
9
VSS
connection pin for negative voltage of battery 5
10
VC6
Connection pin for negative voltage of battery 5
Connection pin for negative voltage of battery 4,
11
VC5
connection pin for positive voltage of battery 5
Connection pin for negative voltage of battery 3,
12
VC4
connection pin for positive voltage of battery 4
Connection pin for negative voltage of battery 2,
13
VC3
connection pin for positive voltage of battery 3
Connection pin for negative voltage of battery 1,
14
VC2
connection pin for positive voltage of battery 2
15
VC1
Connection pin for positive voltage of battery 1
Input pin for positive power supply,
16
VDD
connection pin for positive voltage of battery 1
*1. Refer to "7. SEL pin" in " Operation" for setting of the SEL1 pin and the SEL2 pin.
4
Rev.1.6_00
S-8225B Series
Absolute Maximum Ratings
Table 4
(Ta = +25°C unless otherwise specified)
Item
Input voltage between
VDD pin and VSS pin
Input pin voltage
Symbol
Applied Pin
VDS
VDD
VC1, VC2, VC3, VC4, VC5, VC6,
SEL1, SEL2, CTLC, CTLD,
CCT, CDT
DO, CO
VIN
Output pin voltage
VOUT
Power dissipation
PD
Operation ambient temperature Topr
Storage temperature
Tstg
*1. When mounted on board
[Mounted board]
(1) Board size:
114.3 mm × 76.2 mm × t1.6 mm
(2) Board name:
JEDEC STANDARD51-7
Unit
VSS − 0.3 to VSS + 28
V
VSS − 0.3 to VDD + 0.3
V
1100*1
−40 to +85
−40 to +125
V
mW
°C
°C
Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical
damage. These values must therefore not be exceeded under any conditions.
Power dissipation (PD) [mW]
1200
1000
800
600
400
200
100
150
Ambient temperature (Ta) [°C]
Figure 3 Power Dissipation of Package (When Mounted on Board)
5
S-8225B Series
Rev.1.6_00
Electrical Characteristics
Table 5 (1 / 2)
Item
(Ta = +25°C, VDS = VDD − VSS = V1 + V2 + V3 + V4 + V5 unless otherwise specified)
Test
Symbol
Condition
Min.
Typ.
Max.
Unit
Circuit
Detection Voltage
(n = 1, 2, 3, 4, 5)
(n = 1, 2, 3, 4, 5)
(n = 1, 2, 3, 4, 5)
(n = 1, 2, 3, 4, 5)
0 V battery detection voltage n
(n = 1, 2, 3, 4, 5)
Delay Time Function*2
delay time
delay time
VCUn
Ta = +25°C
V1 = V2 = V3 = V4 = V5 = VCU − 0.05 V
Ta = 0°C to +60°C*1
VCLn
VDLn
VDUn
VCUn
− 0.020
VCUn
− 0.030
VCLn
− 0.050
VDLn
− 0.08
VDUn
− 0.10
VCUn
VCUn
VCLn
VDLn
VDUn
VCUn
+ 0.020
VCUn
+ 0.030
VCLn
+ 0.050
VDLn
+ 0.08
VDUn
+ 0.10
V
1
V
1
V
1
V
1
V
1
V0INHn
0 V battery detection function
"available"
0.4
0.7
1.1
V
1
tCU
CCCT = 0.1 μF
0.67
1.00
1.33
s
2
tDL
CCDT = 0.1 μF
0.67
1.00
1.33
s
2
CCT pin voltage
VCCT
1.5
5.0
V
2
CDT pin voltage
VCDT
1.5
5.0
V
2
4
26
V
VDS − 4.0
0.5
VDS − 4.0
0.5
VDS − 0.5
4.0
VDS − 0.5
4.0
V
V
V
V
3
3
3
3
Input Voltage
Fixed output voltage of CO pin and
DO pin
Operation voltage between
VDD pin and VSS pin
CTLC pin voltage "H"
CTLC pin voltage "L"
CTLD pin voltage "H"
CTLD pin voltage "L"
VDSOP
SEL1 pin voltage "H"
VSELH1
VDS × 0.8
V
3
SEL2 pin voltage "H"
VSELH2
VDS × 0.8
V
3
SEL1 pin voltage "L"
VSELL1
VDS × 0.2
V
3
SEL2 pin voltage "L"
VSELL2
VDS × 0.2
V
3
VCOH
VDOH
5.0
5.0
8.0
8.0
12.0
12.0
V
V
4
4
Output Voltage
CO pin voltage "H"
DO pin voltage "H"
Input Current
Current consumption
during operation
Current consumption
during power-down
VCTLCH
VCTLCL
VCTLDH
VCTLDL
IOPE
12
μA
5
IPDN
1.6
3.0
μA
5
0.4
0.8
μA
6
−1.0
1.0
μA
6
−3.0
−1.0
μA
6
0.1
μA
6
−0.1
μA
6
VC1 pin current
IVC1
VC2 to VC5 pins current
IVC2 to
IVC5
VC6 pin current
IVC6
CTLC pin current "H"
ICTLCH
CTLC pin current "L"
ICTLCL
6
V1 = V2 = V3 = V4 = V5 = 3.4 V,
V6 = V7 = VDS, V8 = V9 = 0 V
V7 = VDS, V6 = V8 = V9 = 0 V
Rev.1.6_00
S-8225B Series
Table 5 (2 / 2)
Test
Item
Symbol
Condition
Min.
Typ.
Max.
Unit
Circuit
μA
CTLD pin current "H"
ICTLDH
0.1
6
−0.1
μA
CTLD pin current "L"
ICTLDL
6
V6 = VDS, V7 = V8 = V9 = 0 V
μA
SEL1 pin current "H"
ISELH1
0.1
6
V6 = V7 = V8 = VDS, V9 = 0 V
μA
SEL2 pin current "H"
ISELH2
0.1
6
V6 = V7 = V9 = VDS, V8 = 0 V
−0.1
μA
SEL1 pin current "L"
ISELL1
6
−0.1
μA
SEL2 pin current "L"
ISELL2
6
Output Current (CO Pin Output Logic Active "H")
CO pin source current
ICOH
7
μA
−10
CO pin sink current
ICOL
7
μA
10
Output Current (CO Pin Output Logic Active "L")
ICOH
CO pin sink current
ICOL
10
−10
μA
μA
7
7
Output Current (DO Pin Output Logic Active "H")
DO pin source current
IDOH
DO pin sink current
IDOL
10
−10
μA
μA
7
7
Output Current (DO Pin Output Logic Active "L")
IDOH
DO pin sink current
IDOL
*1.
*2.
7
μA
−10
7
μA
10
Since products are not screened at high and low temperature, the specification for this temperature range is guaranteed
by design, not tested in production.
Refer to "6. Delay time setting" in " Operation" for details of the delay time function.
7
S-8225B Series
Rev.1.6_00
Test Circuits
1.
Overcharge detection voltage (VCUn), overcharge release voltage (VCLn), overdischarge detection
voltage (VDLn), overdischarge release voltage (VDUn)
(Test circuit 1)
VCU1 is defined as the voltage V1 when V1 is gradually increased and the CO pin output becomes detection status
after setting V1 = V2 = V3 = V4 = V5 = VCU − 0.05 V. After that, VCL1 is defined as the voltage V1 when V1 is
gradually decreased and the CO pin output becomes release status after setting V2 = V3 = V4 = V5 = 3.2 V.
Moreover, VDL1 is defined as the voltage V1 when V1 is gradually decreased and the DO pin output becomes
detection status after setting V1 = V2 = V3 = V4 = V5 = 3.5 V. After that, VDU1 is defined as the voltage V1 when V1
is gradually increased and the DO pin output becomes release status.
Similarly, VCUn, VCLn, VDLn and VDUn can be defined by changing Vn (n = 2 to 5).
2. 0 V battery detection voltage (V0INHn) (0 V battery detection function "available")
(Test circuit 1)
V0INH1 is defined as the voltage V1 when V1 is gradually decreased and the CO pin output becomes detection
status after setting V1 = V2 = V3 = V4 = V5 = 3.4 V.
Similarly, V0INHn can be defined by changing Vn (n = 2 to 5).
3. Overcharge detection delay time (tCU), overdischarge detection delay time (tDL)
(Test circuit 2)
tCU is defined as the time period from when V1 changes from 3.4 V to 4.5 V to when the CO pin output becomes
detection status after setting V1 = V2 = V3 = V4 = V5 = 3.4 V.
Moreover, tDL is defined as the time period from when V1 changes from 3.4 V to 1.6 V to when the DO pin output
becomes detection status after setting V1 = V2 = V3 = V4 = V5 = 3.4 V.
4. CCT pin voltage (VCCT), CDT pin voltage (VCDT)
(Test circuit 2)
VCCT is defined as the voltage between the CCT pin and the VSS pin during the time period when V1 changes from
3.4 V to 4.5 V to when the CO pin output becomes detection status after setting V1 = V2 = V3 = V4 = V5 = 3.4 V.
Moreover, VCDT is defined as the voltage between the CDT pin and the VSS pin during the time period when V1
changes from 3.4 V to 1.6 V to when the DO pin output becomes detection status after setting V1 = V2 = V3 = V4 =
V5 = 3.4 V.
5. CTLC pin voltage "H" (VCTLCH), CTLC pin voltage "L" (VCTLCL), CTLD pin voltage "H" (VCTLDH), CTLD
pin voltage "L" (VCTLDL)
(Test circuit 3)
VCTLCL is defined as the voltage V6 when V6 is gradually decreased and the CO pin output becomes detection
status after setting V1 = V2 = V3 = V4 = V5 = 3.4 V, V6 = V7 = VDS (= V1 + V2 + V3 + V4 + V5), V8 = V9 = 0 V. After
that, VCTLCH is defined as the voltage V6 when V6 is gradually increased and the CO pin output becomes release
status. Moreover, VCTLDL is defined as the voltage V7 when V7 is gradually decreased and the DO pin output
becomes detection status after setting V1 = V2 = V3 = V4 = V5 = 3.4 V, V6 = V7 = VDS (= V1 + V2 + V3 + V4 + V5),
V8 = V9 = 0 V. After that, VCTLDH is defined as the voltage V7 when V7 is gradually increased and the DO pin output
8
Rev.1.6_00
S-8225B Series
6. SEL1 pin voltage "H" (VSELH1), SEL2 pin voltage "H" (VSELH2), SEL1 pin voltage "L" (VSELL1), SEL2
pin voltage "L" (VSELL2)
(Test circuit 3)
VSELH1 is defined as the voltage V8 when V8 is gradually increased and the DO pin output becomes release status
after setting V1 = V2 = V3 = V5 = 3.5 V, V4 = 0 V, V6 = V7 = VDS (= V1 + V2 + V3 + V4 + V5), V8 = V9 = 0 V. After
that, VSELL1 is defined as the voltage V8 when V8 is gradually decreased and the DO pin output becomes detection
status.
Moreover, VSELH2 is defined as the voltage V9 when V9 is gradually increased and the DO pin output becomes
release status after setting V1 = V2 = V3 = V4 = 3.5 V, V5 = 0 V, V6 = V7 = VDS (= V1 + V2 + V3 + V4 + V5), V8 =
V9 = 0 V. After that, VSELL2 is defined as the voltage V9 when V9 is gradually decreased and the DO pin output
becomes detection status.
7. CO pin voltage "H" (VCOH), DO pin voltage "H" (VDOH)
(Test circuit 4)
7. 1 CO pin output logic active "H"
VCOH is defined as the voltage between the CO pin and the VSS pin when V1 = 6.8 V, V2 = 0 V, V3 = V4 = V5 =
3.4 V.
7. 2 CO pin output logic active "L"
VCOH is defined as the voltage between the CO pin and the VSS pin when V1 = V2 = V3 = V4 = V5 = 3.4 V.
7. 3 DO pin output logic active "H"
VDOH is defined as the voltage between the DO pin and the VSS pin when V1 = 6.8 V, V2 = 0 V, V3 = V4 = V5 =
3.4 V.
7. 4 DO pin output logic active "L"
VDOH is defined as the voltage between the DO pin and the VSS pin when V1 = V2 = V3 = V4 = V5 = 3.4 V.
8.
CO pin source current (ICOH), CO pin sink current (ICOL), DO pin source current (IDOH), DO pin sink
current (IDOL)
(Test circuit 7)
8. 1 CO pin output logic active "H"
ICOH is defined as the CO pin current when V1 = 6.8 V, V2 = 0 V, V3 = V4 = V5 = 3.4 V, V6 = VCOH − 0.5 V.
ICOL is defined as the CO pin current when V1 = V2 = V3 = V4 = V5 = 3.4 V, V6 = 0.5 V.
8. 2 CO pin output logic active "L"
ICOH is defined as the CO pin current when V1 = V2 = V3 = V4 = V5 = 3.4 V, V6 = VCOH − 0.5 V.
ICOL is defined as the CO pin current when V1 = 6.8 V, V2 = 0 V, V3 = V4 = V5 = 3.4 V, V6 = 0.5 V.
8. 3 DO pin output logic active "H"
IDOH is defined as the DO pin current when V1 = 6.8 V, V2 = 0 V, V3 = V4 = V5 = 3.4 V, V7 = VDOH − 0.5 V.
IDOL is defined as the DO pin current when V1 = V2 = V3 = V4 = V5 = 3.4 V, V7 = 0.5 V.
8. 4 DO pin output logic active "L"
IDOH is defined as the DO pin current when V1 = V2 = V3 = V4 = V5 = 3.4 V, V7 = VDOH − 0.5 V.
IDOL is defined as the DO pin current when V1 = 6.8 V, V2 = 0 V, V3 = V4 = V5 = 3.4 V, V7 = 0.5 V.
9
S-8225B Series
V
1
2
3
4
5
6
7
8
V
VDD 16
VC1 15
VC2 14
VC3 13
VC4 12
VC5 11
VC6 10
VSS 9
CTLD
CTLC
CO
DO
SEL1
SEL2
CDT
CCT
1
2
3
4
5
6
7
8
V1
V2
V3
V4
V5
V V
0.1 μF V
Figure 4 Test Circuit 1
V6 V7
V V
V8 V9
1
2
3
4
5
6
7
8
CTLD
CTLC
CO
DO
SEL1
SEL2
CDT
CCT
Rev.1.6_00
CTLD
CTLC
CO
DO
SEL1
SEL2
CDT
CCT
VDD 16
VC1 15
VC2 14
VC3 13
VC4 12
VC5 11
VC6 10
VSS 9
V1
V2
V3
V4
V5
0.1 μF V
Figure 5 Test Circuit 2
VDD 16
VC1 15
VC2 14
VC3 13
VC4 12
VC5 11
VC6 10
VSS 9
V1
V2
V3
V4
V5
V
1
2
3
4
5
6
7
8
V
1 MΩ
Figure 6 Test Circuit 3
CTLD
CTLC
CO
DO
SEL1
SEL2
CDT
CCT
VDD 16
VC1 15
VC2 14
VC3 13
VC4 12
VC5 11
VC6 10
VSS 9
V1
V2
V3
V4
V5
1 MΩ
Figure 7 Test Circuit 4
IOPE, IPDN
1
2
3
4
5
6
7
8
CTLD
CTLC
CO
DO
SEL1
SEL2
CDT
CCT
VDD 16
VC1 15
VC2 14
VC3 13
VC4 12
VC5 11
VC6 10
VSS 9
A
V1
V2
V3
V4
V5
A
V6
A
V7
CTLD
CTLC
CO
DO
SEL1
SEL2
CDT
CCT
VDD 16
VC1 15
VC2 14
VC3 13
VC4 12
VC5 11
VC6 10
VSS 9
Figure 10 Test Circuit 7
10
A A A A
V6 V7 V8 V9
Figure 8 Test Circuit 5
1
2
3
4
5
6
7
8
V V
1
2
3
4
5
6
7
8
CTLD
CTLC
CO
DO
SEL1
SEL2
CDT
CCT
VDD
VC1
VC2
VC3
VC4
VC5
VC6
VSS
16
15
14
13
12
11
10
9
Figure 9 Test Circuit 6
V1
V2
V3
V4
V5
A
A
A
A
A
A
V1
V2
V3
V4
V5
Rev.1.6_00
S-8225B Series
Operation
Remark Refer to " Connection Examples of Battery Monitoring IC".
1. Normal status
When the voltage of each of the batteries is in the range from overcharge detection voltage (VCUn) to overdischarge
detection voltage (VDLn), and the CTLC pin input voltage (VCTLC) and the CTLD pin input voltage (VCTLD) are higher
than the CTLC pin voltage "H" (VCTLCH) and the CTLD pin voltage "H" (VCTLDH), respectively, the S-8225B Series
defines the CO pin output voltage (VCO) and the DO pin output voltage (VDO) as "L" (output logic active "H") or "H"
(output logic active "L"). This is called normal status.
VCO is defined as the CO pin voltage "H" (VCOH) when it is "H". Similarly, VDO is defined as the DO pin voltage "H"
(VDOH) when it is "H".
2. Overcharge status
When the voltage of one of the batteries becomes VCUn or higher, the CO pin output inverts and the S-8225B Series
becomes detection status. This is called overcharge status.
When the voltage of each of the batteries becomes overcharge release voltage (VCLn) or lower, the overcharge status
is released and the S-8225B Series returns to normal status.
3. Overdischarge status
When the voltage of one of the batteries becomes VDLn or lower, the DO pin output inverts and the S-8225B Series
becomes detection status. This is called overdischarge status.
When the voltage of each of the batteries becomes overdischarge release voltage (VDUn) or higher, the overdischarge
status is released and the S-8225B Series returns to normal status.
4. CTLC pin and CTLD pin
The S-8225B Series has two pins to control.
The CTLC pin controls the output voltage from the CO pin; the CTLD pin controls the output voltage from the DO pin.
Thus it is possible for users to control the output voltages from the CO pin and DO pin, respectively. These controls
precede the battery protection circuit.
Table 6 Status Set by CTLC Pin
CTLC Pin
CO Pin
"H"*1
Normal status*3
"L"*2
Detection status
*1. "H": CTLC ≥ VCTLCH
*2. "L": CTLC ≤ VCTLCL
*3. The status is controlled by the voltage detection circuit.
Table 7 Status Set by CTLD Pin
CTLD Pin
DO Pin
"H"*1
Normal status*3
"L"*2
Detection status
*1. "H": CTLD ≥ VCTLDH
*2. "L": CTLD ≤ VCTLDL
11
S-8225B Series
Rev.1.6_00
5. 0 V battery detection function
In the S-8225B Series, users are able to select a 0 V battery detection "available" function.
If this optional function is selected, the CO pin becomes detection status when the voltage of one of the batteries
becomes 0 V battery detection voltage (V0INHn) or lower.
When the voltage of one of the batteries becomes VCUn or higher, the S-8225B Series charges the capacitor
connected to the CCT pin rapidly up to the CCT pin voltage (VCCT). After that, The S-8225B Series discharges the
capacitor with the constant current of 100 nA, and the CO pin output is defined as detection status at the time when
the CCT pin voltage falls to a certain level or lower. The overcharge detection delay time (tCU) changes depending on
the capacitor connected to the CCT pin.
tCU is calculated by the following formula.
Min. Typ. Max.
tCU [s] = (6.7, 10, 13.3) × CCCT [μF]
Similarly, the overdischarge detection delay time (tDL) changes depending on the capacitor connected to the CDT pin.
tDL is calculated by the following formula.
Min. Typ. Max.
tDL [s] = (6.7, 10, 13.3) × CCDT [μF]
Since the S-8225B Series charges the capacitor for delay rapidly, the voltage of the CCT pin and the CDT pin
becomes large if the capacitance value is small. As a result, a variation between the calculated value of the delay
time and the actual delay time is generated.
If the capacitance value is so large that the rapid charging can not be finished within the internal delay time, the
output pin becomes detection status simultaneously with the end of internal delay time.
In addition, the charging current to the capacitor for delay passes through the VDD pin. Therefore, a large resistor
connected to the VDD pin results in a big drop of the power supply voltage at the time of rapid charging which causes
malfunction.
Regarding the recommended values for external components, refer to "Table 9 Constants for External
Components".
7. SEL pin
In the S-8225B Series, switchable monitoring control between 3-cell to 5-cell is possible by using the SEL1 pin and
the SEL2 pin. For example, since the overdischarge detection of V4 or V5 is prohibited and the overdischarge is not
detected even if V4 or V5 is shorted when the SEL1 pin is "H" and the SEL2 pin is "L", the S-8225B Series can be
used for 3-cell monitoring.
Be sure to use the SEL1 pin and the SEL2 pin at "H" or "L" potential.
Table 8 Settings of SEL1 Pin and SEL2 Pin
SEL1 pin
"H"*1
SEL2 pin
"H"*1
"H"*1
"L"*2
*2
"L"
"H"*1
*2
"L"
"L"*2
*1. "H": SEL1 ≥ VSELH1 and SEL2 ≥ VSELH2
*2. "L": SEL1 ≤ VSELL1 and SEL2 ≤ VSELL2
12
Setting
Prohibition
3-cell monitoring
4-cell monitoring
5-cell monitoring
S-8225B Series
Rev.1.6_00
Timing Charts
1. Overcharge detection and overdischarge detection
VCUn
VCLn
Battery voltage
VDUn
VDLn
(n = 1 to 5)
VCOH
CO pin voltage
(Active "L")
VSS
VDOH
DO pin voltage
(Active "L")
VSS
Charger connection
Load connection
Status
*1
(1)
(2)
Overdischarge detection delay time (tDL)
(1)
(3)
(1)
*1. (1): Normal status
(2): Overcharge status
(3): Overdischarge status
Figure 11
13
S-8225B Series
Rev.1.6_00
2. Overcharge detection delay
VCUn
(n = 1 to 5)
Battery voltage
VCOH
CO pin voltage
(Active "L")
VSS
CCT pin voltage
VCCT
VSS
Charger connection
Less than tCU
Status
*1
(1)
Figure 12
14
tCU
(2)
S-8225B Series
Rev.1.6_00
3. Overdischarge detection delay
(n = 1 to 5)
Battery voltage
VDLn
VDOH
DO pin voltage
(Active "L")
VSS
CDT pin voltage
VCDT
VSS
Charger connection
Less than tDL
Status*1
(1)
tDL
(2)
(2): Overdischarge status
Figure 13
15
S-8225B Series
Rev.1.6_00
1. 5-serial cell
EB+
RCTLD
CTLD
CTLC
RCTLC
2 CTLC
VC1 15
3 CO
VC2 14
RVDD
CVDS
VC3 13
S-8225B
5 SEL1
VC4 12
RSEL2
OC
VDD 16
4 DO
RSEL1
OD
1 CTLD
CCDT
6 SEL2
VC5 11
7 CDT
VC6 10
8 CCT
VSS 9
CVDD
RVC1
CVC1
RVC2
CVC2
RVC3
CVC3
RVC4
CVC4
RVC5
CVC5
RVC6
CVC6
CCCT
EB−
Figure 14
2. 4-serial cell
EB+
RCTLD
CTLD
CTLC
OD
OC
RCTLC
1 CTLD
VDD 16
2 CTLC
VC1 15
3 CO
VC2 14
4 DO
VC3 13
S-8225B
5 SEL1
VC4 12
RSEL1
RSEL2
CCDT
6 SEL2
VC5 11
7 CDT
VC6 10
8 CCT
VSS 9
RVDD
CVDS
CVDD
RVC1
CVC1
RVC2
CVC2
RVC3
CVC3
RVC4
CVC4
RVC5
CVC5
CCCT
EB−
Figure 15
Remark Regarding the recommended values for external components, refer to "Table 9 Constants for External
Components".
16
S-8225B Series
Rev.1.6_00
3. 3-serial cell
EB+
RCTLD
CTLD
CTLC
RCTLC
RSEL2
OC
VDD 16
2 CTLC
VC1 15
3 CO
VC2 14
4 DO
VC3 13
RVDD
CVDS
S-8225B
5 SEL1
VC4 12
RSEL1
OD
1 CTLD
CCDT
6 SEL2
VC5 11
7 CDT
VC6 10
8 CCT
VSS 9
CVDD
RVC1
CVC1
RVC2
CVC2
RVC3
CVC3
RVC4
CVC4
CCCT
EB−
Figure 16
Components".
Table 9 Constants for External Components
Symbol
RVDD
RVCn
CVDS
CVDD
CVCn
CCCT
CCDT
RCTLC, RCTLD
RSEL1, RSEL2
Min.
50
0.5
0.01
0.01
0.001
0.001
0.5
Typ.
100
1
0.1
0.1
0.1
1
1
Max.
1000
2
1
1
1
0.22
0.22
Unit
Ω
kΩ
μF
μF
μF
μF
μF
kΩ
kΩ
Caution 1. The above constants may be changed without notice.
2. The example of connection shown above and the constants do not guarantee proper operation.
Perform thorough evaluation using the actual application to set the constants.
3. RVC1 to RVC6 and CVC1 to CVC6 should be the same constant, respectively.
4. Set up RVCn and CVCn as RVCn × CVCn ≥ 50 × 10-6.
5. Set up RVDD and CVDS as 5 × 10-6 ≤ RVDD × CVDS ≤ 100 × 10-6.
6. Set (RVDD × CVDS) / (RVCn × CVCn) = 0.1.
Remark n = 1 to 6
17
S-8225B Series
Rev.1.6_00
Precautions
18
The application conditions for the input voltage, output voltage, and load current should not exceed the package
power dissipation.
If both an overcharge battery and an overdischarge battery are included among the whole batteries, the condition is
set in overcharge status and overdischarge status. Therefore either charging or discharging is impossible.
Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic
protection circuit.
ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products
including this IC of patents owned by a third party.
S-8225B Series
Rev.1.6_00
Characteristics (Typical Data)
1. Detection voltage
1. 1 VCU vs. Ta
1. 2 VCL vs. Ta
VCL = 4.170 V
4.24
4.22
4.23
4.20
VCL [V]
VCU [V]
VCU = 4.220 V
4.22
4.21
4.20
1. 3
4.18
4.16
4.14
−40 −25
4.12
Ta [°C]
75 85
50
VDL vs. Ta
−40 −25
Ta [°C]
VDU = 2.30 V
2.40
2.38
2.35
2.34
VDU [V]
VDL [V]
75 85
1. 4 VDU vs. Ta
VDL = 2.30 V
2.30
2.25
2.20
50
2.30
2.26
−40 −25
2.22
Ta [°C]
75 85
50
−40 −25
Ta [°C]
50
75 85
2. Current consumption
2. 1 IOPE vs. Ta
2. 2 IPDN vs. Ta
VDD = 8.0 V
15
3
IPDN [μA]
IOPE [μA]
VDD = 17.0 V
10
5
−40 −25
2
1
Ta [°C]
75 85
50
−40 −25
Ta [°C]
50
75 85
2. 3 IOPE vs. VDD
Ta = +25°C
50
IOPE [μA]
40
30
10
15
VDD [V]
25
30
19
S-8225B Series
Rev.1.6_00
3. Delay time
3. 1 tCU vs. Ta
3. 2 tDL vs. Ta
VDD = 15.2 V
2.0
2.0
1.5
1.5
tDL [s]
tCU [s]
VDD = 18.1 V
1.0
0.5
0.0
1.0
0.5
−40 −25
0.0
Ta [°C]
75 85
50
−40 −25
Ta [°C]
75 85
50
4. Output current
4. 1 ICOL vs. VDD
4. 2 ICOH vs. VDD
Ta = +25°C
500
−20
ICOH [μA]
ICOL [μA]
Ta = +25°C
300
200
100
5
10
15
VDD [V]
25
30
4. 3 IDOL vs. VDD
−60
−80
−40
10
15
VDD [V]
Ta = +25°C
500
−20
IDOH [μA]
IDOL [μA]
30
4. 4 IDOH vs. VDD
Ta = +25°C
300
200
100
5
10
15
VDD [V]
25
−40
−60
−80
30
10
15
VDD [V]
25
30
5. Output voltage
5. 1 VCOH vs. VDD
5. 2 VDOH vs. VDD
Ta = +25°C, DO pin output logic active "L"
VDL = 2.30 V
12
12
10
10
8
8
VDOH [V]
VCOH [V]
Ta = +25°C, CO pin output logic active "L", VCU = 4.220 V
0 V battery detection function "unavailable"
6
4
2
4
2
5
10
15
VDD [V]
30
10
15
VDD [V]
30
5.1±0.2
0.65
16
9
1
8
0.17±0.05
0.22±0.08
No. FT016-A-P-SD-1.2
TITLE
TSSOP16-A-PKG Dimensions
FT016-A-P-SD-1.2
No.
ANGLE
UNIT
mm
ABLIC Inc.
+0.1
4.0±0.1
ø1.5 -0
0.3±0.05
2.0±0.1
8.0±0.1
1.5±0.1
ø1.6±0.1
(7.2)
4.2±0.2
+0.4
6.5 -0.2
1
16
8
9
Feed direction
No. FT016-A-C-SD-1.1
TITLE
TSSOP16-A-Carrier Tape
No.
FT016-A-C-SD-1.1
ANGLE
UNIT
mm
ABLIC Inc.
21.4±1.0
17.4±1.0
+2.0
17.4 -1.5
Enlarged drawing in the central part
ø21±0.8
2±0.5
ø13±0.2
No. FT016-A-R-S1-1.0
TITLE
TSSOP16-A- Reel
No.
FT016-A-R-S1-1.0
ANGLE
QTY.
UNIT
mm
ABLIC Inc.
4,000
Disclaimers (Handling Precautions)
1.
All the information described herein (product data, specifications, figures, tables, programs, algorithms and
application circuit examples, etc.) is current as of publishing date of this document and is subject to change without
notice.
2.
The circuit examples and the usages described herein are for reference only, and do not guarantee the success of
any specific mass-production design.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products
described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other
right due to the use of the information described herein.
3.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described
herein.
4.
Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute
maximum ratings, operation voltage range and electrical characteristics, etc.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to
the use of the products outside their specified ranges.
5.
Before using the products, confirm their applications, and the laws and regulations of the region or country where they
are used and verify suitability, safety and other factors for the intended use.
6.
When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related
laws, and follow the required procedures.
7.
The products are strictly prohibited from using, providing or exporting for the purposes of the development of
weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands
caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear,
biological or chemical weapons or missiles, or use any other military purposes.
8.
The products are not designed to be used as part of any device or equipment that may affect the human body, human
life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control
systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment,
aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by
ABLIC, Inc. Do not apply the products to the above listed devices and equipments.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of
the products.
9.
In general, semiconductor products may fail or malfunction with some probability. The user of the products should
therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread
prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social
damage, etc. that may ensue from the products' failure or malfunction.
The entire system in which the products are used must be sufficiently evaluated and judged whether the products are
allowed to apply for the system on customer's own responsibility.
10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the
product design by the customer depending on the intended use.
11. The products do not affect human health under normal use. However, they contain chemical substances and heavy
metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be
careful when handling these with the bare hands to prevent injuries, etc.
12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used.
13. The information described herein contains copyright information and know-how of ABLIC Inc. The information
described herein does not convey any license under any intellectual property rights or any other rights belonging to
ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this
document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express
permission of ABLIC Inc.
14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales
representative.
15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into
the English language and the Chinese language, shall be controlling.
2.4-2019.07
www.ablic.com
