ICS08L45N40A2PO
ICS08L45N40A2PO
    CARLOGAVAZZI
    Cylinder,Threaded-M8
    IND PROX M8 LONG PNP NO
ICS08L45N40A2PO 数据手册
 ICS08 IO-Link 3-wire DC Miniaturized proximity inductive sensors with IO-Link communication Benefits • A complete family. Available in M8 male thread robust stainless steel housings with an operating distance of 2 to 4 mm. • Easy to install. Both flush and non-flush construction are available. The user can choose between short and long body housings in 2 m PVC cable or M8-disconnect plug versions. • High precision. The onboard advanced microcontroller ensures better stability with respect to environmental influences, with highly repeatable measurements between -25 and +80°C. • Easy customization to specific OEM requests: different cable lengths and materials, special labelling, customized pig-tail solutions with special cables and connectors are possible on request. Only for IO-Link sensors Description ICS08 series represents the optimal solution for industrial automation equipment in applications where space is limited, but long switching distance is needed, including tool-selection and textile machines. The advanced electronics is encapsulated in a robust stainless steel housing. The availability of the M8-plug and 2m-PVC cable connection in short or long housing construction allows flexible mounting. On-board IO-Link communication opens up many possibilities, such as easy configuration and setup of the devices and advanced parameter setting. • The output can be operated either as a switching output or in IO-Link mode. • Fully configurable via IO-Link v1.1. Electrical outputs can be configured as PNP/NPN/Push-pull, normally open or normally closed. • Timer functions can be set, such as switch-on and switch-off delay • Adjustable sensing distance and hysteresis: sensing distance can be set to 50% or 100% of the maximum sensing distance • Temperature monitoring: over or under-run temperature alarms can be set • Applications • Non contact detection of metal objects in general position-sensing and presence-sensing in industrial applications • Particularly suitable for rotational speed monitoring thanks to the high operating frequency Main functions • Integrated diagnostic function with flashing LED in the event of a short circuit or overload 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Carlo Gavazzi Automation S.p.A. 1 ICS08 IO-Link 3-wire DC  IO-Link sensors • The devices can be operated in IO-Link mode once connected to an IO-Link master, or in standard I/O mode. • In IO-Link mode the switching signals of the sensor are made available in the process data via the IO-Link interface. • Several sensor functions can be set via the IO-Link interface: ►► Adjustable switching distance: 50% or 100% of the maximum switching distance. ►► Adjustable hysteresis: standard or increased value. ►► Divider function: the sensor gives a signal after a specified number of actuation pulses has been reached. ►► Switch-on delay: the switching pulse is generated after the sensor actuation. ►► Switch-off delay: the generation of the switch signal is delayed by the set time after sensor actuation. ►► Temperature error: temperature is out of specifications. ►► Temperature over-run and under-run: temperature is out of the limits defined by the user. References Order code I C S 08 Enter the code option instead of Code I C S 08 Option S30 L45 F N 20 40 M5 A2 NO NC PO PC IO Description Inductive sensor Cylindrical housing with threaded barrel Stainless steel housing M8 housing Short housing with thread barrel of 30 mm Long housing with thread length of 45 mm Flush Non-flush Sensing distance 2mm Sensing distance 4mm M8 plug 2 m PVC cable NPN – normally open output NPN – normally closed output PNP – normally open output PNP – normally closed output IO-Link programmable version Additional characters can be used for customized versions. 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Carlo Gavazzi Automation S.p.A. 2 ICS08 IO-Link 3-wire DC  Selection guide M8 extended range, short housing Connection Cable Plug Cable Plug Rated operating distance Sn Detection principle 2 mm Flush 4 mm Nonflush Ordering no. NPN, Normally open Ordering no. PNP, Normally open Ordering no. NPN, Normally closed Ordering no. PNP, Normally closed ICS08S30F20A2NO ICS08S30F20M5NO ICS08S30N40A2NO ICS08S30N40M5NO ICS08S30F20A2PO ICS08S30F20M5PO ICS08S30N40A2PO ICS08S30N40M5PO ICS08S30F20A2NC ICS08S30F20M5NC ICS08S30N40A2NC ICS08S30N40M5NC ICS08S30F20A2PC ICS08S30F20M5PC ICS08S30N40A2PC ICS08S30N40M5PC Ordering no. NPN, Normally open Ordering no. PNP, Normally open Ordering no. NPN, Normally closed Ordering no. PNP, Normally closed ICS08L45F20A2NO ICS08L45F20M5NO ICS08L45N40A2NO ICS08L45N40M5NO ICS08L45F20A2PO ICS08L45F20M5PO ICS08L45N40A2PO ICS08L45N40M5PO ICS08L45F20A2NC ICS08L45F20M5NC ICS08L45N40A2NC ICS08L45N40M5NC ICS08L45F20A2PC ICS08L45F20M5PC ICS08L45N40A2PC ICS08L45N40M5PC M8 extended range, long housing Connection Cable Plug Cable Plug Rated operating distance Sn Detection principle 2 mm Flush 4 mm Nonflush IO-Link types Connection Cable Plug Cable Plug Cable Plug Cable Plug Body style Short Long Detection principle Rated operating distance Sn Flush Configurable: 1 or 2mm Factory setting: 2mm Nonflush Configurable: 2 or 4mm Factory setting: 4mm Flush Configurable: 1 or 2mm Factory setting: 2mm Nonflush Configurable: 2 or 4mm Factory setting: 4mm 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Output type Ordering no. Configurable: NPN/PNP/ push-pull NO/NC Factory setting: PNP, NO ICS08S30F20A2IO ICS08S30F20M5IO ICS08S30N40A2IO ICS08S30N40M5IO ICS08L45F20A2IO ICS08L45F20M5IO ICS08L45N40A2IO ICS08L45N40M5IO Carlo Gavazzi Automation S.p.A. 3 ICS08 IO-Link 3-wire DC  Structure ICS08 A B C A B C D A B C D Element A B Component Sensing face 2 nuts C LED D M8, 3 pin, male connector 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Function Flush or non-flush For sensor mounting Yellow LED: Output flashing: short circuit or overload indication For plug versions only Carlo Gavazzi Automation S.p.A. 4 ICS08 IO-Link 3-wire DC  Sensing Detection Rated operating distance Sn 2 mm flush or 4 mm non-flush The operating distance is measured according to IEC 60947-5-2, using a standard target moving axially. This target is square shape 1 mm thickness, made of steel e.g. type Fe 360 as defined in ISO 630 and it shall be of the rolled finish. The length of the side of the square is equal to – the diameter of the circle inscribed on the active surface of the sensing face, or – three times the rated operating distance Sn whichever is greater Reference target Assured operating sensing distance (Sa) Effective operating distance (Sr) Usable operating distance (Su) Temperature drift Hysteresis (H) 0 ≤ Sa ≤ 0.81 x Sn (e.g. with Sn of 2 mm, Sa is 0 ... 1.62 mm) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr ≤ +/-10% 1...20% S S: sensor T: target Y T Distance [Thou] 12 20 28 36 44 Distance [Thou] 52 60 68 -19,7 76 197 4 [mm] 2 0 T S 131,3 4 65,6 2 0 -2 -4 0 0,2 0,4 0,6 0,8 1 1,2 1,4 1,6 1,8 2 19,7 39,4 59,1 78,8 98,5 118,2 137,9 157,6 276 207 138 T 69 S 0 -65,7 -2 -131,3 -4 -197 0 6 [mm] 4 [Thou] -4 0 -69 -138 -207 -6 -0,5 [Thou] X 0 0,5 1 1,5 2 2,5 3 3,5 4 -276 Distance [mm] Distance [mm] Fig. 1 Flush Fig. 2 Non-flush Sensors with IO-Link communication Rated operating distance Sn Hysteresis (H) Programmable via IO-Link: 50% or 100% of the maximum Sn Programmable via IO-Link: standard or increased Correction factors The specific operating distance Sn refers to defined measuring conditions. The following data have to be considered as general guidelines. 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Carlo Gavazzi Automation S.p.A. 5 ICS08 IO-Link 3-wire DC  Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance Fig. 3 The rated operating distance is reduced by the use of metals and alloys other than Fe360. The most important reduction factors for inductive proximity sensors are shown in the figure. Accuracy Repeat accuracy (R) ≤ 5% Features Power Supply Rated operational voltage (Ub) Ripple (Urpp) No load supply current (Io) Power ON delay (tv) 10 to 30 VDC (ripple included) ≤ 10% ≤ 17 mA ≤ 50 ms Outputs Standard sensors Output functions NPN or PNP by sensor type Output configuration N.O. and N.C. by sensor type Output current (Ie) OFF-state current (Ir) (only for PNP or NPN output) Voltage drop (Ud) Protection Voltage transient ≤ 100 mA 11/05/2018 ICS08 IO-Link 3-wire DC DS EN IO-Link sensors Configurable via IO-Link: PNP, NPN or push-pull Factory setting: PNP Configurable via IO-Link: N.O. or N.C. Factory setting: N.O. ≤ 100 μA Max. 1.2 VDC @ 100 mA Short-circuit, reverse polarity and transients 1 kV/0.5 J Carlo Gavazzi Automation S.p.A. 6 ICS08 IO-Link 3-wire DC  Response times Operating frequency (f) ≤ 2 KHz Indication Standard IO mode: Yellow LED Output OFF OFF ON ON Blinking f: 2Hz f: 1Hz Description N.O. output, target not present N.C. output, target present N.O. output, target present N.C. output, target not present Short-circuit or overload Temperature alarm (if enabled) IO-Link mode: • LED is ON for 0.75 s and OFF for 0.075 s • Possibility to disable the LED Environmental Ambient temperature Ambient humidity Vibration Shock Degree of protection Operating: -25° to +80°C (-13° to +176°F) Storage: -30° to +80°C (-22° to +176°F) Operating: 35% to 95% Storage: 35% to 95% 10 to 55 Hz, amplitude 1.0 mm; sweep cycle 5 IEC 60068-2-6 min; in X, Y and Z direction 30 G /11 ms. 10 shocks in X, Y and Z direction IEC 60068-2-27 IP67 IEC 60529; EN 60947-1 Compatibility and conformity IEC 61000-4-2 Electrostatic discharge EMC protection MTTFd Approvals IEC 61000-4-3 Radiated radiofrequency IEC 61000-4-4 Burst immunity IEC 61000-4-6 Conducted radio frequency IEC 61000-4-8 Power frequency magnetic fields 4513 years @ 50°C (122°F) 8 kV air discharge 4 kV contact discharge 3 V/m 2 kV 3V 30 A/m ® CCC is not required for products rated ≤ 36 V 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Carlo Gavazzi Automation S.p.A. 7 ICS08 IO-Link 3-wire DC  Mechanical data Weight (including 2 nuts and the packaging) max. Mounting Material Max tightening torque Cable version: short, flush: 44.8g; short, non-flush: 44.9g; long, flush: 47g; long, non-flush: 47.1g; Plug version: short, flush: 16g; short, non-flush: 16.1g; long, flush: 18.4g; long, non-flush: 18.5g. Flush mountable or non-flush mountable Housing: stainless steel AISI304 Front cap: Grey thermoplastic polyester 7 Nm Electrical connection Cable Plug 2m, 3 x 0.14 mm2, Ø3.2 mm, PVC, grey, oil proof M8 x 1 quick disconnect, 3 pin, male connector IO-Link version only Communication 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Via IO-Link V1.1 or via standard I/O Carlo Gavazzi Automation S.p.A. 8 ICS08 IO-Link 3-wire DC  Connection Diagrams 1 BN + 4 BK 4 BK 3 BU 3 BU - Fig. 4 NPN - Normally open 1 BN + 1 BN - Fig. 5 NPN - Normally closed + 1 BN + 4 BK 4 BK 3 BU 3 BU - Fig. 6 PNP - Normally open - Fig. 7 PNP - Normally closed 1 BN 4 BK 3 BU + Out/IO-Link - Fig. 8 IO-Link BN: brown 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Colour code BK: black BU: blue Carlo Gavazzi Automation S.p.A. 9 ICS08 IO-Link 3-wire DC  Dimensions [mm] ICS08 [mm] 4 4 SW13 SW13 LED 30 31 3 4 Ø2 LEDx4 M8x1 4 29 4 1 31 SW13 43 40 Fig. 11 Short body, flush version, plug 4 Ø2 LEDx4 4 7 29 3 7 3 M8x1 SW13 Fig. 10 Short body, non-flush version, cable M8x1 31 M8x1 4 4 1 30 34 3 Fig. 9 Short body, flush version, cable Ø3.2 Ø3.2 M8x1 M8x1 LED Fig. 12 Short body, non-flush version, plug 4 SW13 SW13 LED 45 46 4 1 3 Fig. 15 Long body, flush version, plug 46 SW13 4 1 3 Ø2 LEDx4 M8x1 M8x1 7 55 11/05/2018 ICS08 IO-Link 3-wire DC DS EN 4 Ø2 LEDx4 4 44 Fig. 14 Long body, non-flush version, cable M8x1 46 SW13 M8x1 4 45 49 3 Fig. 13 Long body, flush version, cable Ø3.2 Ø3.2 M8x1 M8x1 LED 3 4 7 44 58 Fig. 16 Long body, non-flush version, plug Carlo Gavazzi Automation S.p.A. 10 ICS08 IO-Link 3-wire DC  Installation M8 flush d ≥ 3 x Sn d d d ** Fig. 17 Flush sensor, when installed in damping material Fig. 18 Flush sensors, when installed together in damping material M8 non-flush ≥ 2 x Sn ≥ 3 x Sn ≥3xd d ** Fig. 19 Non-flush sensor, when installed in damping material 11/05/2018 ICS08 IO-Link 3-wire DC DS EN d d 2xd d d Fig. 20 Non-flush sensors, when installed together in damping material Carlo Gavazzi Automation S.p.A. 11 ICS08 IO-Link 3-wire DC  Sensors installed opposite each other ≥ 6 x Sn Fig. 21 For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed ** Free zone or non-damping material Sn: nominal sensing distance d: sensor diameter: 8 mm Delivery contents and compatible components Delivery contents • • • • Inductive proximity switch 2 fixing nuts 2 lock washers Packaging: plastic bag CARLO GAVAZZI compatible components • Mounting bracket AMB8... to be purchased separately • Connector type: CONB53... series to be purchased separately Further reading Information IO-Link manual Mounting brackets Connectors 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Where to find it QR http://www.productselection.net/MANUALS/UK/IOL_IM.pdf http://www.productselection.net/Pdf/UK/AMB8_30.pdf http://www.productselection.net/Pdf/UK/CONB5.pdf Carlo Gavazzi Automation S.p.A. 12  ICS08 IO-Link 3-wire DC COPYRIGHT ©2018 Content subject to change. Download the PDF: www.productselection.net 11/05/2018 ICS08 IO-Link 3-wire DC DS EN Carlo Gavazzi Automation S.p.A. 13
ICS08L45N40A2PO 价格&库存
很抱歉,暂时无法提供与“ICS08L45N40A2PO”相匹配的价格&库存,您可以联系我们找货
