S-8204BAN-TCT1U
S-8204BAN-TCT1U
    ABLIC(艾普凌科)
    TSSOP16
    IC BATT PROT LI-ION 3-4C 16TSSOP
S-8204BAN-TCT1U 数据手册
S-8204B Series www.ablic.com www.ablicinc.com BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK © ABLIC Inc., 2008-2016 Rev.3.9_01 The S-8204B Series includes high-accuracy voltage detection circuits and delay circuits, in single use, makes it possible for users to monitor the status of 3-series or 4-series cell lithium-ion rechargeable battery. By switching the voltage level which is applied to the SEL pin, users are able to use the S-8204B Series either for 3-series or 4-series cell pack. By cascade connection using the S-8204B Series, it is also possible to protect 6-series or more cells*1 lithium-ion rechargeable battery pack. *1. Refer to the application note for connection examples of protection circuit for 6-series or more cells. In case of protecting 5-series cell lithium-ion rechargeable battery pack, contact our sales office.  Features  High-accuracy voltage detection function for each cell Overcharge detection voltage n (n = 1 to 4) 3.65 V to 4.6 V (50 mV step) Accuracy 25 mV Overcharge release voltage n (n = 1 to 4) 3.5 V to 4.6 V*1 Accuracy 50 mV Overdischarge detection voltage n (n = 1 to 4) 2.0 V to 3.0 V (100 mV step) Accuracy 80 mV *2 Accuracy 100 mV Overdischarge release voltage n (n = 1 to 4) 2.0 V to 3.4 V  Discharge overcurrent detection in 3-step Discharge overcurrent detection voltage 1 0.05 V to 0.30 V (50 mV step) Accuracy 15 mV Discharge overcurrent detection voltage 2 0.5 V (fixed) Accuracy 100 mV Load short-circuit detection voltage 1.0 V (fixed) Accuracy 300 mV  Settable by external capacitor; overcharge detection delay time, overdischarge detection delay time, discharge overcurrent detection delay time 1, discharge overcurrent detection delay time 2 (Load short-circuit detection delay time is internally fixed.)  Switchable between 3-series and 4-series cell by using the SEL pin  Independent charge and discharge control by the control pins  Power-down function "available" / "unavailable" is selectable  High-withstand voltage Absolute maximum rating: 24 V  Wide operation voltage range 2 V to 22 V  Wide operation temperature range Ta = 40C to 85C  Low current consumption During operation 33 A max. (Ta = 25C) During power-down 0.1 A max. (Ta = 25C) *3  Lead-free, Sn 100%, halogen-free *1. Overcharge hysteresis voltage n (n = 1 to 4) is selectable in 0 V, or in 0.1 V to 0.4 V in 50 mV step. (Overcharge hysteresis voltage = Overcharge detection voltage  Overcharge release voltage) *2. Overdischarge hysteresis voltage n (n = 1 to 4) is selectable in 0 V, or in 0.2 V to 0.7 V in 100 mV step. (Overdischarge hysteresis voltage = Overdischarge release voltage  Overdischarge detection voltage) *3. Refer to " Product Name Structure" for details.  Application  Rechargeable lithium-ion battery pack  Package  16-Pin TSSOP 1 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01  Block Diagram Control circuit COP Delay circuit Delay circuit CTLC Delay circuit CTLD RVMD VMP RVMS VDD Delay circuit Delay circuit Overcharge 1   Overdischarge 1   Overcharge 2   Overdischarge 2  DOP VINI       VC1 VC2  Discharge overcurrent 1 Discharge overcurrent 2 Load short circuit Overcharge 3   Overdischarge 3  VC3 Overcharge 4  VC4   Overdischarge 4   CDT CCT CIT VSS SEL Remark Diodes in the figure are parasitic diodes. Figure 1 2 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01  Product Name Structure 1. Product name S-8204B xx - xxxx x Environmental code U: Lead-free (Sn 100%), halogen-free S: Lead-free, halogen-free Package name (abbreviation) and packing specifications*1 TCT1: 16-Pin TSSOP, Tape Serial code*2 Sequentially set from AA to ZZ *1. Refer to the tape drawing. *2. Refer to "3. Product name list". 2. Package Table 1 Package Drawing Codes Package Name 16-Pin TSSOP Environmental code = S Environmental code = U Dimension Tape Reel FT016-A-P-SD FT016-A-P-SD FT016-A-C-SD FT016-A-C-SD FT016-A-R-SD FT016-A-R-S1 3 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 3. Product name list Table 2 Discharge Overcharge Overdischarge Overdischarge Overcurrent Release Detection Release Detection Voltage Voltage Voltage Voltage 1 [VCL] [VDL] [VDU] [VDIOV1] Product Name Overcharge Detection Voltage [VCU] S-8204BAB-TCT1y 4.350 V 4.150 V 2.00 V 2.70 V 0.250 V Available Available S-8204BAC-TCT1y 4.225 V 4.075 V 2.30 V 3.00 V 0.100 V Available Available S-8204BAD-TCT1y S-8204BAE-TCT1y S-8204BAF-TCT1y S-8204BAG-TCT1y S-8204BAH-TCT1y S-8204BAI-TCT1y S-8204BAJ-TCT1y S-8204BAK-TCT1y S-8204BAL-TCT1y S-8204BAM-TCT1y S-8204BAN-TCT1y S-8204BAO-TCT1y S-8204BAP-TCT1y S-8204BAQ-TCT1y S-8204BAR-TCT1y S-8204BAS-TCT1y S-8204BAT-TCT1y S-8204BAU-TCT1y S-8204BAV-TCT1y S-8204BAW-TCT1y S-8204BAX-TCT1y S-8204BAY-TCT1y S-8204BAZ-TCT1y S-8204BBA-TCT1y S-8204BBB-TCT1y S-8204BBC-TCT1y S-8204BBD-TCT1y S-8204BBE-TCT1y S-8204BBF-TCT1y S-8204BBG-TCT1y S-8204BBH-TCT1y S-8204BBI-TCT1U S-8204BBJ-TCT1U S-8204BBK-TCT1U S-8204BBL-TCT1U 3.800 V 4.350 V 4.350 V 4.350 V 4.200 V 3.900 V 4.300 V 3.650 V 4.200 V 4.400 V 4.100 V 3.900 V 4.320 V 3.800 V 3.850 V 4.250 V 3.650 V 4.200 V 3.900 V 3.800 V 4.250 V 3.900 V 4.250 V 4.250 V 4.250 V 4.250 V 4.300 V 3.800 V 3.800 V 4.250 V 4.250 V 4.250 V 4.250 V 4.250 V 4.230 V 3.600 V 4.150 V 4.150 V 4.150 V 4.000 V 3.800 V 4.100 V 3.500 V 4.100 V 4.200 V 4.100 V 3.600 V 4.120 V 3.600 V 3.650 V 4.150 V 3.500 V 4.100 V 3.600 V 3.650 V 4.250 V 3.600 V 4.100 V 4.150 V 4.150 V 4.100 V 4.200 V 3.600 V 3.600 V 4.100 V 4.150 V 4.150 V 4.150 V 4.190 V 4.230 V 2.00 V 2.50 V 2.30 V 2.80 V 2.60 V 2.00 V 2.50 V 2.40 V 2.70 V 2.00 V 2.00 V 2.50 V 2.40 V 2.00 V 2.50 V 2.80 V 2.00 V 2.70 V 2.00 V 2.20 V 2.00 V 2.30 V 3.00 V 2.50 V 2.70 V 2.80 V 2.30 V 2.00 V 2.00 V 2.80 V 2.70 V 2.70 V 2.70 V 2.80 V 2.80 V 2.30 V 3.00 V 3.00 V 3.30 V 3.00 V 2.00 V 2.90 V 3.00 V 2.90 V 2.70 V 2.50 V 2.70 V 3.00 V 2.30 V 2.70 V 3.00 V 2.70 V 2.90 V 2.70 V 2.50 V 2.00 V 2.50 V 3.30 V 3.00 V 3.00 V 3.20 V 3.00 V 2.30 V 2.30 V 3.30 V 3.00 V 3.00 V 3.00 V 3.00 V 3.00 V 0.300 V 0.250 V 0.100 V 0.100 V 0.100 V 0.150 V 0.250 V 0.100 V 0.250 V 0.250 V 0.150 V 0.100 V 0.100 V 0.150 V 0.150 V 0.150 V 0.100 V 0.100 V 0.100 V 0.100 V 0.100 V 0.100 V 0.100 V 0.100 V 0.250 V 0.250 V 0.100 V 0.100 V 0.050 V 0.100 V 0.125 V 0.125 V 0.150 V 0.150 V 0.150 V Available Available Available Available Available Unavailable Available Available Available Available Unavailable Unavailable Unavailable Available Available Available Available Available Available Available Unavailable Available Available Available Unavailable Unavailable Available Available Available Unavailable Unavailable Unavailable Unavailable Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Available Unavailable Unavailable Available Available S-8204BBU-TCT1U S-8204BBV-TCT1U 4.350 V 4.450 V 4.150 V 4.300 V 2.30 V 2.70 V 3.00 V 3.00 V 0.100 V 0.100 V Unavailable Unavailable Available Available 0 V Battery Charge Function Power-down Function Remark 1. Please contact our sales office for products with detection voltage values other than those specified above. 2. y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 4 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01  Pin Configuration 1. 16-Pin TSSOP Top view 1 2 3 4 5 6 7 8 16 15 14 13 12 11 10 9 Figure 2 Table 3 Pin No. Symbol Description 1 2 3 COP VMP DOP Connection pin of charge control FET gate (Pch open-drain output) Voltage detection pin between VDD pin and VMP pin Connection pin of discharge control FET gate (CMOS output) Voltage detection pin between VSS pin and VINI pin, discharge overcurrent 1 / 2 detection pin, load short-circuit detection pin 4 VINI 5 CDT Capacitor connection pin for delay for overdischarge detection 6 7 CCT CIT 8 SEL 9 VSS 10 VC4 11 VC3 12 VC2 13 VC1 14 VDD 15 16 CTLD CTLC Capacitor connection pin for delay for overcharge detection Capacitor connection pin for delay for discharge overcurrent 1 / 2 Pin for switching 3-series or 4-series cell  VSS level: 3-series cell  VDD level: 4-series cell Input pin for negative power supply, connection pin for negative voltage of battery 4 Connection pin for negative voltage of battery 3, connection pin for positive voltage of battery 4 Connection pin for negative voltage of battery 2, connection pin for positive voltage of battery 3 Connection pin for negative voltage of battery 1, connection pin for positive voltage of battery 2 Connection pin for positive voltage of battery 1 Input pin for positive power supply, connection pin for positive voltage of battery 1 Discharge FET control pin Charge FET control pin 5 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01  Absolute Maximum Ratings Table 4 Item Input voltage between VDD pin and VSS pin Input pin voltage Symbol Applied Pin (Ta = 25C unless otherwise specified) Absolute Maximum Rating Unit  VDS VC1, VC2, VC3, VC4, CTLC, CTLD, SEL, CCT, CDT, CIT, VINI VMP DOP COP    VIN VMP pin input voltage VVMP DOP pin output voltage VDOP COP pin output voltage VCOP Power dissipation PD Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm  76.2 mm  t1.6 mm (2) Board name: JEDEC STANDARD51-7 VSS  0.3 to VSS  24 V VSS  0.3 to VDD  0.3 V VSS  0.3 to VSS  24 VSS  0.3 to VDD  0.3 VDD  24 to VDD  0.3 1100*1 40 to 85 40 to 125 V V V mW C C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Power Dissipation (PD) [mW] 1200 1000 800 600 400 200 0 0 50 100 150 Ambient Temperature (Ta) [C] Figure 3 Power Dissipation of Package (When Mounted on Board) 6 Rev.3.9_01 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series  Electrical Characteristics Table 5 (1 / 2) Item Detection Voltage Overcharge detection voltage n (n = 1, 2, 3, 4) Overcharge release voltage n (n = 1, 2, 3, 4) Symbol Condition VCUn 3.65 V to 4.6 V, adjustable, 50 mV step VCLn 3.5 V to 4.6 V, adjustable, 50 mV step VCL  VCU VCL = VCU Overdischarge detection voltage n VDLn (n = 1, 2, 3, 4) 2.0 V to 3.0 V, adjustable, 100 mV step Overdischarge release voltage n (n = 1, 2, 3, 4) 2.0 V to 3.4 V, adjustable, 100 mV step Discharge overcurrent detection voltage 1 Discharge overcurrent detection voltage 2 Load short-circuit detection voltage Temperature coefficient 1*1 Temperature coefficient 2*2 Delay Time Function*4 VDUn VDIOV1 VDL  VDU VDL = VDU 0.05 V to 0.30 V, adjustable (Ta = 25C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VCUn  0.025 VCLn  0.05 VCLn  0.025 VDLn  0.08 VDUn  0.10 VDUn  0.08 VDIOV1  0.015 VCUn VCLn VCLn VDLn VDUn VDUn VDIOV1 VCUn  0.025 VCLn  0.05 VCLn  0.025 VDLn  0.08 VDUn  0.10 VDUn  0.08 VDIOV1  0.015 V 2 V 2 V 2 V 2 V 2 V 2 V 2 VDIOV2  0.4 0.5 0.6 V 2 VSHORT  0.7 1.0 1.3 V 2 TCOE1 TCOE2 Ta = 0°C to 50°C*3 Ta = 0°C to 50°C*3 1.0 0.5 0 0 1.0 0.5 mV/°C mV/°C 2 2 CCT pin internal resistance RINC V1 = 4.7 V, V2 = V3 = V4 = 3.5 V 6.15 8.31 10.2 M 3 CDT pin internal resistance RIND V1 = 1.5 V, V2 = V3 = V4 = 3.5 V 615 831 1020 k 3 CIT pin internal resistance 1 RINI1 V1 = V2 = V3 = V4 = 3.5 V 123 166 204 k 3 CIT pin internal resistance 2 RINI2 V1 = V2 = V3 = V4 = 3.5 V 12.3 16.6 20.4 k 3 CCT pin detection voltage VCCT VDS = 15.2 V, V1 = 4.7 V, V2 = V3 = V4 = 3.5 V VDS  0.68 VDS  0.70 VDS  0.72 V 3 CDT pin detection voltage VCDT VDS = 12.0 V, V1 = 1.5 V, V2 = V3 = V4 = 3.5 V VDS  0.68 VDS  0.70 VDS  0.72 V 3 CIT pin detection voltage VCIT VDS = 14.0 V, V1 = V2 = V3 = V4 = 3.5 V VDS  0.68 VDS  0.70 VDS  0.72 V 3 tSHORT FET gate capacitance = 2000 pF 100 300 600 s 3  1.2 2.0 V 2 0.4 0.7 1.1 V 2 0.5 1 1.5 M 4 450 900 1800 k 4 Load short-circuit detection delay time 0 V Battery Charge Function 0 V battery charge starting voltage 0 V battery charge inhibition battery voltage Internal Resistance Resistance between VMP pin and VDD pin Resistance between VMP pin and VSS pin V0CHA V0INH RVMD RVMS 0 V battery charge function "available" 0 V battery charge function "unavailable"  With power-down function 7 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 Table 5 (2 / 2) (Ta = 25C unless otherwise specified) Item Input Voltage Operation voltage between VDD pin and VSS pin CTLC pin input voltage "H" CTLC pin input voltage "L" CTLD pin input voltage "H" CTLD pin input voltage "L" Symbol VDSOP VCTLCH VCTLCL VCTLDH VCTLDL SEL pin input voltage "H" VSELH SEL pin input voltage "L" VSELL Input Current Current consumption during operation Current consumption during power-down Current consumption during overdischarge VC1 pin current VC2 pin current VC3 pin current VC4 pin current IVC1 IVC2 IVC3 IVC4 CTLC pin current "H" ICTLCH CTLC pin current "L" ICTLCL CTLD pin current "H" ICTLDH CTLD pin current "L" ICTLDL SEL pin current "H" ISELH SEL pin current "L" ISELL IOPE IPDN IOPED Condition Fixed output voltage of DOP pin and COP pin V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V VDS = 14.0 V, V1 = V2 = V3 = V4 = 3.5 V VDS = 14.0 V, V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V With power-down function, V1 = V2 = V3 = V4 = 1.5 V Without power-down function, V1 = V2 = V3 = V4 = 1.5 V V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V, VCTLC = VDD V1 = V2 = V3 = V4 = 3.5 V, maximum current flowing from CTLC pin V1 = V2 = V3 = V4 = 3.5 V, VCTLD = VDD V1 = V2 = V3 = V4 = 3.5 V, maximum current flowing from CTLD pin V1 = V2 = V3 = V4 = 3.5 V, VSEL = VDD V1 = V2 = V3 = V4 = 3.5 V, VSEL = VSS Min. Typ. Max. Unit Test Circuit 2  22 V 2  10.1  10.1 VDS  0.8     13.2  13.2  V V V V 2 2 2 2   V 2   VDS  0.2 V 2  15 33 A 1   0.1 A 1  14 32 A 1 0.5 0.3 0.3 0.3 1.5 0 0 0 3.0 0.3 0.3 0.3 A A A A 4 4 4 4 0.4 0.6 0.8 A 4 20.0 10.0 3.0 A 4 0.4 0.6 0.8 A 4 20.0 10.0 3.0 A 4   0.1 A 4 0.1   A 4 Output Current COP pin source current ICOH VCOP = VDD  0.5 V 10   A 4 COP pin leakage current ICOL VCOP = 0 V   0.1 A 4 DOP pin source current IDOH VDOP = VDD  0.5 V 10   A 4 DOP pin sink current IDOL VDOP = VSS  0.5 V 10   A 4 *1. Voltage temperature coefficient 1: Overcharge detection voltage *2. Voltage temperature coefficient 2: Discharge overcurrent detection voltage 1 *3. Since products are not screened at high and low temperature, the specification for this temperature range is guaranteed by design, not tested in production. *4. Details of delay time function is described in " Operation". 8 Rev.3.9_01 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series  Test Circuit This chapter describes how to test the S-8204B Series. In case of selecting to use it for 4-series cell battery, set SEL pin = VDD. For 3-series cell battery, set SEL pin = VSS and short between the VC4 pin and the VSS pin. 1. Current consumption during operation and power-down (Test circuit 1) 1. 1 Current consumption during operation (IOPE) The current at the VSS pin when V1 = V2 = V3 = V4 = 3.5 V and VVMP = VDD is the current consumption during operation (IOPE). 1. 2 Current Consumption during power-down (IPDN) (with power-down function) The current at the VSS pin when V1 = V2 = V3 = V4 = 1.5 V and VVMP = VSS is the current consumption during power-down (IPDN). 1. 3 Current consumption during overdischarge (IOPED) (without power-down function) The current at the VSS pin when V1 = V2 = V3 = V4 = 1.5 V and VVMP = VSS is the current consumption during overdischarge (IOPED). 2. Overcharge detection voltage, overcharge release voltage, overdischarge detection voltage, overdischarge release voltage, discharge overcurrent detection voltage 1, discharge overcurrent detection voltage 2, load short-circuit detection voltage, CTLC pin input voltage "H", CTLC pin input voltage "L", CTLD pin input voltage "H", CTLD pin input voltage "L", SEL pin input voltage "H", SEL pin input voltage "L" (Test circuit 2) Confirm both the COP pin and the DOP pin are in "H" (its voltage level is VDS  0.9 V or more) after setting VVMP = VSEL = VCTLC = VCTLD = VDD, VVINI = VSS, CCT pin = Open, CDT pin = Open, CIT pin = Open, V1 = V2 = V3 = V4 = 3.5 V. (This status is referred to as initial status.) 2. 1 Overcharge detection voltage (VCU1), overcharge release voltage (VCL1) The overcharge detection voltage (VCU1) is a voltage at V1; when the COP pin's voltage is set to "L" (its voltage level is VDD  0.1 V or less) after increasing a voltage at V1 gradually from the initial status. After that, decreasing a voltage at V1 gradually, a voltage at V1 when the COP pin's voltage is set to "H"; is the overcharge release voltage (VCL1). 2. 2 Overdischarge detection voltage (VDL1), overdischarge release voltage (VDU1) The overdischarge detection voltage (VDL1) is a voltage at V1; when the DOP pin's voltage is set to "L" after decreasing a voltage at V1 gradually from the initial status. After that, increasing a voltage at V1 gradually, a voltage at V1 when the DOP pin’s voltage is set to "H"; is the overdischarge release voltage (VDU1). By changing the voltage at Vn (n = 2 to 4), users can define the overcharge detection voltage (VCUn), the overcharge release voltage (VCLn), the overdischarge detection voltage (VDLn), the overdischarge release voltage (VDUn) as well when n = 1. 2. 3 Discharge overcurrent detection voltage 1 (VDIOV1) The discharge overcurrent detection voltage 1 (VDIOV1) is the VINI pin's voltage; when the DOP pin's voltage is set to "L" after increasing the VINI pin’s voltage gradually from the initial status. 2. 4 Discharge overcurrent detection voltage 2 (VDIOV2) The discharge overcurrent detection voltage 2 (VDIOV2) is a voltage at the VINI pin; when a flowing current from the CIT pin reaches 500 A or more after increasing the VINI pin's voltage gradually from the initial status. 2. 5 Load short-circuit detection voltage (VSHORT) The load short-circuit detection voltage (VSHORT) is the VINI pin's voltage; when the DOP pin's voltage is set to "L" after increasing the VINI pin's voltage gradually after setting the CIT pin's voltage VSS level from the initial status. 9 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 2. 6 CTLC pin input voltage "H" (VCTLCH), CTLC pin input voltage "L" (VCTLCL) The CTLC pin input voltage "L" (VCTLCL) is the CTLC pin's voltage; when the COP pin's voltage is set to "L" after decreasing the CTLC pin's voltage gradually from the initial status. After that, increasing the CTLC pin's voltage gradually, the CTLC pin's voltage when the COP pin's voltage is set to "H"; is the CTLC pin input voltage "H" (VCTLCH). 2. 7 CTLD pin input voltage "H" (VCTLDH), CTLD pin input voltage "L" (VCTLDL) The CTLD pin input voltage "L" (VCTLDL) is the CTLD pin's voltage; when the DOP pin's voltage is set to "L" after decreasing the CTLD pin's voltage gradually from the initial status. After that, increasing the CTLD pin's voltage gradually, the CTLD pin's voltage when the DOP pin's voltage is set to "H"; is the CTLD pin input voltage "H" (VCTLDH). 2. 8 SEL pin input voltage "H" (VSELH), SEL pin input voltage "L" (VSELL) Start from the initial status, set V4 = 0 V. Confirm the DOP pin is in "L". After that, decreasing the SEL pin's voltage gradually, the SEL pin's voltage when the DOP pin's voltage is set to "H"; is the SEL pin input voltage "L" (VSELL). After that, increasing the SEL pin's voltage gradually, the SEL pin's voltage when the DOP pin's voltage is set to "L"; is the SEL pin input voltage "H" (VSELH). 3. CCT pin internal resistance, CDT pin internal resistance, CIT pin internal resistance 1, CIT pin internal resistance 2, CCT pin detection voltage, CDT pin detection voltage, CIT pin detection voltage, load short-circuit detection delay time (Test circuit 3) Confirm both the COP pin and the DOP pin are in "H" (its voltage level is VDS  0.9 V or more) after setting VVMP = VSEL = VCTLC = VCTLD = VDD, VVINI = CCT = CDT = CIT = VSS, V1 = V2 = V3 = V4 = 3.5 V. (This status is referred to as initial status.) 3. 1 CCT pin internal resistance (RINC) The CCT pin internal resistance (RINC) is RINC = VDS / ICCT, ICCT is the current which flows from the CCT pin when setting V1 = 4.7 V from the initial status. 3. 2 CDT pin internal resistance (RIND) The CDT pin internal resistance (RIND) is RIND = VDS / ICDT, ICDT is the current which flows from the CDT pin when setting V1 = 1.5 V from the initial status. 3. 3 CIT pin internal resistance 1 (RINI1) The CIT pin internal resistance 1 (RINI1) is RINI1 = VDS / ICIT1, ICIT1 is the current which flows from the CIT pin when setting VVINI = VDIOV1 max.0.05 V from the initial status. 3. 4 CIT pin internal resistance 2 (RINI2) The CIT pin internal resistance 2 (RINI2) is RINI2 = VDS / ICIT2, ICIT2 is the current which flows from the CIT pin when setting VVINI = VDIOV2 max0.05 V from the initial status. 3. 5 CCT pin detection voltage (VCCT) The CCT pin detection voltage (VCCT) is the voltage at the CCT pin when the COP pin's voltage is set to "L" (voltage VDS  0.1 V or less) after increasing the CCT pin's voltage gradually, after setting V1 = 4.7 V from the initial status. 3. 6 CDT pin detection voltage (VCDT) The CDT pin detection voltage (VCDT) is the voltage at the CDT pin when the DOP pin's voltage is set to "L" (voltage VDS  0.1 V or less) after increasing the CDT pin's voltage gradually, after setting V1 = 1.5 V from the initial status. 10 Rev.3.9_01 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series 3. 7 CIT pin detection voltage (VCIT) The CIT pin detection voltage (VCIT) is the voltage at the CIT pin when the DOP pin's voltage is set to "L" (voltage VDS  0.1 V or less) after increasing the CIT pin's voltage gradually, after setting VVINI = VDIOV1 max.0.05 V from the initial status. 3. 8 Load short-circuit detection delay time (tSHORT) Load short-circuit detection delay time (tSHORT) is a period in which the VINI pin's voltage changes from "H" to "L" by changing the VINI pin's voltage instantaneously from the initial status to VSHORT max.0.05 V. 4. 0 V battery charge starting voltage (0 V battery charge function "available"), 0 V battery charge inhibition battery voltage (0 V battery charge function "unavailable") (Test circuit 2) Confirm both COP pin and DOP pin are in "H" (its voltage level is VDS  0.9 V or more) after setting VVMP = VSEL = VCTLC = VCTLD = VDD, VVINI = VSS, CCT pin = Open, CDT pin = Open, CIT pin = Open, V1 = V2 = V3 = V4 = 3.5 V. (This status is referred to as initial status.) According to user's selection of the function to charge 0 V battery, either function of voltage for start charging 0 V battery or battery voltage for inhibit charging 0 V battery is applied to each product. 4. 1 0 V battery charge starting voltage (V0CHA) (0 V battery charge function "available") 0 V battery charge starting voltage (V0CHA) is a voltage at V1; when a voltage at the COP pin is set to "H" after increasing a voltage at V1 gradually, after setting V1 = V2 = V3 = V4 = 0 V from the initial status. 4. 2 0 V battery charge inhibition battery voltage (V0INH) (0 V battery charge function "unavailable") 0 V battery charge inhibition battery voltage (V0INH) is a voltage at V1; when a voltage at the COP pin is set to "L" after decreasing a voltage at V1 gradually from the initial status. 5. Resistance between VMP pin and VDD pin, resistance between VMP pin and VSS pin, VC1 pin current, VC2 pin current, VC3 pin current, VC4 pin current, CTLC pin current "H", CTLC pin current "L", CTLD pin current "H", CTLD pin current "L", SEL pin current "H", SEL pin current "L", COP pin source current, COP pin leakage current, DOP pin source current, DOP pin sink current (Test circuit 4) Set VCTLC = VCTLD = VVMP = VSEL = VDD, VVINI = VSS, V1 = V2 = V3 = V4 = 3.5 V, set other pins open. (This status is referred to as initial status.) 5. 1 Resistance between VMP pin and VDD pin (RVMD) The value of resistance between VMP pin and VDD pin (RVMD) can be defined by RVMD = VDS / IVMD by using the VMP pin's current (IVMD) when VVINI = 1.5 V and VVMP = VSS after the initial status. 5. 2 Resistance between VMP pin and VSS pin (RVMS) The value of resistance between VMP pin and VSS pin (RVMS) can be defined by RVMS = VDS / IVMS by using the VMP pin's current (IVMS) when V1 = V2 = V3 = V4 = 1.8 V after the initial status. 5. 3 VC1 pin current (IVC1), VC2 pin current (IVC2), VC3 pin current (IVC3), VC4 pin current (IVC4) In the initial status, each current flows in the VC1 pin, VC2 pin, VC3 pin, VC4 pin is the VC1 pin current (IVC1), the VC2 pin current (IVC2), the VC3 pin current (IVC3), the VC4 pin current (IVC4), respectively. 5. 4 CTLC pin current "H" (ICTLCH), CTLC pin current "L" (ICTLCL) In the initial status, a current which flows in the CTLC pin is the CTLC pin current "H" (ICTLCH). After that, decreasing a voltage at the CTLC pin gradually, the maximum current which flows in the CTLC pin is; the CTLC pin current "L" (ICTLCL). 11 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 5. 5 CTLD pin current "H" (ICTLDH), CTLD pin current "L" (ICTLDL) In the initial status, a current which flows in the CTLD pin is the CTLD pin current "H" (ICTLDH). After that, decreasing a voltage at the CTLD pin gradually, the maximum current which flows in the CTLD pin is; the CTLD pin current "L" (ICTLDL). 5. 6 SEL pin current "H" (ISELH), SEL pin current "L" (ISELL) In the initial status, a current which flows in the SEL pin is the SEL pin current "H" (ISELH). After that, a current which flows in the SEL pin when setting VSEL = VSS is; the SEL pin current "L" (ISELL). 5. 7 COP pin source current (ICOH), COP pin leakage current (ICOL) Start from the initial status, set VCOP = VDD  0.5 V, a current which flows in the COP pin is the COP pin source current (ICOH). After that, a current which flows in the COP pin when setting V1 = V2 = V3 = V4 = 5.5 V, VCOP = VSS is; the COP pin leakage current (ICOL). 5. 8 DOP pin source current (IDOH), DOP pin sink current (IDOL) Start from the initial status, set VDOP = VDD  0.5 V, a current which flows in the DOP pin is the DOP pin source current (IDOH). After that, a current which flows in the DOP pin when setting V1 = V2 = V3 = V4 = 1.8 V, VDOP = VSS0.5 V is; the DOP pin sink current (IDOL). 12 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 S-8204B 1 COP CTLC 16 2 VMP CTLD 15 3 DOP VDD 14 4 VINI VC1 13 5 CDT VC2 12 6 CCT 7 CIT VC3 11 VC4 10 8 SEL VSS V1 V2 V3 9 A V4 C1 = 0.1 F Figure 4 Test Circuit 1 S-8204B V V 1 COP CTLC 16 2 VMP CTLD 15 3 DOP VDD 14 4 VINI VC1 13 5 CDT VC2 12 6 CCT VC3 11 7 CIT VC4 10 8 SEL VSS V1 V2 V3 V4 9 C1 = 0.1 F A Figure 5 Test Circuit 2 S-8204B A V V A 1 COP CTLC 16 2 VMP CTLD 15 3 DOP VDD 14 4 VINI VC1 13 5 CDT VC2 12 6 CCT VC3 11 7 CIT VC4 10 8 SEL VSS A V1 V2 V3 V4 9 C1 = 0.1 F Figure 6 Test Circuit 3 13 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 S-8204B A 1 COP CTLC 16 A A 2 VMP CTLD 15 A A 3 DOP VDD 14 4 VINI VC1 13 A 5 CDT VC2 12 A 6 CCT VC3 11 A 7 CIT VC4 10 A 8 SEL VSS A V1 V2 V3 V4 9 C1 = 0.1 F Figure 7 Test Circuit 4 14 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01  Operation Remark Refer to " Connection Examples of Battery Protection IC". 1. Normal status In the S-8204B Series, both of the COP pin and the DOP pin get the VDD level; when the voltage of each of the batteries is in the range of overdischarge detection voltage (VDLn) to overcharge detection voltage (VCUn), and due to the discharge current, the VINI pin's voltage is discharge overcurrent detection voltage (VDIOV1) or less. This is the normal status. At this time, the charge FET and discharge FET are on. 2. Overcharge status In the S-8204B Series, the voltage of one of the batteries increases to the level of more than VCUn, the COP pin is set in high impedance. This is the overcharge status. The COP pin is pulled down to EB by an external resistor so that the charge FET is turned off and it stops charging. This overcharge status is released if either condition mentioned below is satisfied; (1) In case that the VMP pin voltage is 39 / 40  VDS or more; the voltage of each of the batteries is in the level of overcharge release voltage (VCLn) or less. (2) In case that the VMP pin voltage is 39 / 40  VDS or less; the voltage of each of the batteries is in the level of VCUn or less. 3. Overdischarge status In the S-8204B Series, when the voltage of one of the batteries decreases to the level of less than VDLn, the DOP pin voltage gets the VSS level. This is the overdischarge status. The discharge FET is turned off and it stops discharging. This overcharge status is released if either condition mentioned below is satisfied; (1) To release; the VMP pin voltage is in the level of more than VDD, the voltage of each of the batteries is in the VDLn level or more. (2) To release; the VMP pin voltage is VDS / 2 or more and the VMP pin voltage is in the level of less than VDD, the voltage of each of the batteries is in the level of overdischarge release voltage (VDUn) or more. 3. 1 Power-down function In the S-8204B Series, power-down function "available" / "unavailable" is selectable. 3. 1. 1 With power-down function When the S-8204B Series reaches the overdischarge status, the VMP pin is pulled down to the VSS level by a resistor between the VMP pin and the VSS pin (RVMS). If the VMP pin voltage decreases to the level of VDS / 2 or less, the power-down function starts to operate and almost every circuit in the S-8204B Series stops working. The power-down function is released if the following condition is satisfied. (1) The VMP pin voltage gets VDS / 2 or more. 3. 1. 2 Without power-down function The VMP pin is not pulled down even when the S-8204B Series reaches the overdischarge status. The overdischarge status is maintained even If the VMP pin voltage decreases to the level of VDS / 2 or less, and the current consumption decreases to the level of current consumption during overdischarge (IOPED) or less. 15 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 4. Discharge overcurrent status In the S-8204B Series, in batteries in the normal status, the discharging current increases more than a certain value. As a result, if the status in which the VINI pin voltage increases to the level of VDIOV1 or more, the DOP pin gets the VSS level. This is the discharge overcurrent status. At this time, the discharge control FET is turned off and it stops discharging. The S-8204B Series has three levels for discharge overcurrent detection (VDIOV1, VDIOV2, VSHORT). In the status of discharge overcurrent, the COP pin is set in high impedance. The VMP pin is pulled up to the VDD level by a resistor between the VMP pin and the VDD pin (RVMD). The S-8204B Series' operations against discharge overcurrent detection voltage 2 (VDIOV2) and load short-circuit detection voltage (VSHORT) are as well in VDIOV1. The discharge overcurrent status is released if the following condition is satisfied. (1) The VMP pin voltage gets VDS 1.2 V (typ.) or more. 5. 0 V battery charge function In the S-8204B Series, regarding how to charge a discharged battery (0 V battery), users are able to select either function mentioned below. (1) Allow to charge a 0 V battery (enable to charge a 0 V battery) A 0 V battery is charged when the voltage between the VDD pin and the VSS pin (VDS) is 0 V battery charge starting voltage (V0CHA) or more. (2) Inhibit charging a 0 V battery (unable to charge a 0 V battery) A 0 V battery is not charged when the battery voltage is 0 V battery charge inhibition battery voltage (V0INH) or less. Caution 16 When the VDD pin voltage is less than the minimum value of operation voltage between the VDD pin and the VSS pin (VDSOP), the operation of the S-8204B Series is not assured. Rev.3.9_01 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series 6. Delay time setting In the S-8204B Series, users are able to set delay time for the period; from detecting the voltage of one of the batteries or detecting changes in the voltage at the VINI pin, to the output to the COP pin and the DOP pin. Each delay time is determined by a resistor in the S-8204B Series and an external capacitor. In the overchage detection, when the voltage of one of the batteries gets VCUn or more, the S-8204B Series starts charging to the CCT pin's capacitor (CCCT) via the CCT pin's internal resistor (RINC). After a certain period, the COP pin is set in high impedance if the voltage at the CCT pin reaches the CCT pin detection voltage (VCCT). This period is overcharge detection delay time (tCU). tCU is calculated using the following equation (VDS = V1V2V3V4). tCU [s] = ln (1VCCT / VDS )  CCCT [F]  RINC [M] = ln (10.7 (typ.))  CCCT [F]  8.31 [M] (typ.) = 10.0 [M] (typ.)  CCCT [F] Overdischarge detection delay time (tDL), discharge overcurrent detection delay time 1 (tDIOV1), discharge overcurrent detection delay time 2 (tDIOV2) are calculated using the following equations as well. tDL [ms] = ln (1VCDT / VDS)  CCDT [F]  RIND [k] tDIOV1 [ms] = ln (1VCIT / VDS)  CCIT [F]  RINI1 [k] tDIOV2 [ms] = ln (1VCIT / VDS)  CCIT [F]  RINI2 [k] In case CCCT = CCDT = CCIT = 0.1 [F], each delay time tCU, tDL, tDIOV1, tDIOV2 is calculated as follows. tCU [s] = 10.0 [M] (typ.)  0.1 [F] = 1.0 [s] (typ.) tDL [ms] = 1000 [k] (typ.)  0.1 [F] = 100 [ms] (typ.) tDIOV1 [ms] = 200 [k] (typ.)  0.1 [F] = 20 [ms] (typ.) tDIOV2 [ms] = 20 [k] (typ.)  0.1 [F] = 2.0 [ms] (typ.) Load short-circuit detection delay time (tSHORT) is fixed internally. 17 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 7. CTLC pin and CTLD pin The S-8204B Series has two pins to control. The CTLC pin controls the output voltage from the COP pin, the CTLD pin controls the output voltage from the DOP pin. Thus it is possible for users to control the output voltages from the COP pin and DOP pin independently. These controls precede the battery protection circuit. Table 6 Conditions Set by CTLC Pin CTLC Pin COP Pin "H"*1 Normal status*4 Open*2 "High-Z" "L"*3 "High-Z" *1. "H"; CTLC  VCTLCH *2. Pulled down by ICTLCH *3. "L"; CTLC  VCTLCL *4. The status is controlled by the voltage detection circuit. Table 7 Conditions Set by CTLD Pin CTLD Pin DOP Pin "H"*1 Normal status*4 Open*2 VSS level "L"*3 VSS level *1. "H"; CTLD  VCTLDH *2. Pulled down by ICTLDH *3. "L"; CTLD  VCTLDL *4. The status is controlled by the voltage detection circuit. Caution 18 Note that when the power supply fluctuates, unexpected behavior might occur if an electrical potential is generated between the potentials of "H" level input to the CTLC pin / the CTLD pin and IC's VDD by external filters RVDD1 and CVDD1. Rev.3.9_01 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series 8. SEL pin The S-8204B Series has a pin to switch-control the protection for 3-cell or 4-cell battery. The overdischarge detection for V4-cell is inhibited by setting the SEL pin "L", so that short-circuiting the V4 cell does not allow the overdischarge detection. This setting makes it possible to use the S-8204B Series for 3-cell protection. The control by this SEL pin precedes the battery protection circuit. Be sure to use the SEL pin in "H" or "L". Table 8 Conditions Set by SEL Pin SEL Pin "H"*1 Open "L"*2 *1. "H"; SEL  VSELH *2. "L"; SEL  VSELL Condition 4-cell protection Indefinite 3-cell protection In cascade connection, it is possible to use the S-8204B Series for protecting 6-cell, 7-cell or 8-cell battery by combining the electrical level of the SEL pin. Table 9 Conditions Set by SEL Pin in Cascade Connection SEL pin in S-8204B (1) "L"*1 "L"*1 "H"*2 *1. "L"; SEL  VSELL *2. "H"; SEL  VSELH SEL pin in S-8204B (2) "L"*1 "H"*2 "H"*2 Condition 6-series cell protection 7-series cell protection 8-series cell protection 19 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01  Timing Chart (Circuit in Figure 11) 1. Overcharge detection and overdischarge detection (with power-down function) VCUn VCLn Battery voltage VDUn VDLn (n = 1 to 4) VDD DOP pin voltage VSS VDD COP pin voltage High-Z High-Z VEB- VDD 39 / 40  VDD VMP pin voltage 1 / 2  VDD VSS Charger connection Load connection Status *1. *1 Overcharge detection delay time (tCU) (1) (2) Overdischarge detection delay time (tDL) (1) (3) (4) (3) (1) (1): Normal status (2): Overcharge status (3): Overdischarge status (4): Power-down status Remark The charger is assumed to charge with a constant current. VEB- indicates the open voltage of the charger. Figure 8 20 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 2. Overcharge detection and overdischarge detection (without power-down function) VCUn VCLn Battery voltage VDUn VDLn (n = 1 to 4) VDD DOP pin voltage VSS VDD COP pin voltage High-Z VEB- VDD 39 / 40VDD VMP pin voltage 1 / 2VDD VSS Charger connection Load connection Status *1. *1 Overcharge detection delay time (tCU) (1) Overdischarge detection delay time (tDL) (2) (1) (3) (1) (1): Normal status (2): Overcharge status (3): Overdischarge status Remark The charger is assumed to charge with a constant current. VEB- indicates the open voltage of the charger. Figure 9 21 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 3. Discharge overcurrent detection VHC VCUn VCLn Battery voltage VDUn VDLn VHD (n = 1 to 4) VDD DOP pin voltage VSS VDD High-Z COP pin voltage High-Z High-Z VEBVDD VMP pin voltage VSS VDD VSHORT V VINI pin voltage DIOV2 VDIOV1 VSS Charger connection Load connection Status *1. *1 Discharge overcurrent detecion delay time 1 (tDIOV1) (1) Discharge overcurrent detecion delay time 2 (tDIOV2) (2) (1) (2) Load short-circuit detecion delay time (tSHORT) (1) (2) (1) (1): Normal status (2): Discharge overcurrent status Remark The charger is assumed to charge with a constant current. VEB- indicates the open voltage of the charger. Figure 10 22 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01  Connection Examples of Battery Protection IC 1. 4-series cell (with overcurrent protection function) EB M1 RVMP RATL M2 1 COP CTLC 16 2 VMP CTLD 15 3 DOP VDD 14 4 VINI VC1 13 5 CDT CCDT CCCT CCIT S-8204B RCTLC RCTLD RVDD RVC1 CVC1 VC2 12 6 CCT VC3 11 7 CIT VC4 10 8 SEL VSS 9 CVC2 CVC3 RVC2 RVC3 RVC4 CVC4 CVDD RSEL ZD1 REB RCOP RDOP RVINI RSENSE EB Nch FET1 Nch FET2 (Charge FET) (Discharge FET) Figure 11 23 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 Table 10 Constants for External Components (Circuit in Figure 11) Symbol Min. Typ. Max. Unit RVC1*1 0.51 1 1 k RVC2*1 0.51 1 1 k RVC3*1 0.51 1 1 k RVC4*1 0.51 1 1 k RDOP 2 5.1 10 k RCOP 0.1 1 1 M RVMP 1 5.1 10 k RCTLC 1 1 10 k RCTLD 1 1 10 k RVINI 1 1 10 k RSEL 1 1 100 k *1 RVDD 22 47 100  *1 CVC1 0 47 100 nF *1 CVC2 0 47 100 nF CVC3*1 0 47 100 nF *1 CVC4 0 47 100 nF CCCT 0.01 0.1  F CCDT 0.01 0.1  F CVDD*1 0 1 2.2 F   CCIT 0.1 F     RSENSE     M1     M2     ZD1   REB 1 M   RATL 20 M     Nch FET1     Nch FET2 *1. Set up a filter constant to be RVDD  CVDD = 47 F   or more, and to be RVC1  CVC1 = RVC2  CVC2 = RVC3  CVC3 = RVC4  CVC4 = RVDD  CVDD. Caution 1. 2. 3. 24 The above constants may be changed without notice. It is recommended that filter constants between the VDD pin and the VSS pin should be set to approximately 47 F  . e.g., CVDD  RVDD = 1.0 F  47  = 47 F   Sufficient evaluation of transient power supply fluctuation and overcurrent protection function with the actual application is needed to determine the proper constants. Contact our sales office in case the constants should be set to other than 47 F  . It has not been confirmed whether the operation is normal in circuits other than the above example of connection. In addition, the example of connection shown above and the constants do not guarantee proper operation. Perform thorough evaluation using an actual application to set the constant. BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 2. 7-series cell (cascade connection without overcurrent protection function) EB+ RVMP1 RVINI1 CCDT1 CCCT1 RIFC RCIT1 RIFD 1 COP CTLC 16 2 VMP CTLD 15 3 DOP VDD 14 4 VINI VC1 13 5 CDT S-8204B VC2 12 (1) 6 CCT VC3 11 7 CIT VC4 10 8 SEL VSS 9 RCTLC RCTLD RVDD1 RVC1 CVC1 CVC2 CVC3 RVC2 RVC3 RVC4 CVDD1 RSEL1 RVMP2 RVINI2 CCDT2 CCCT2 1 COP CTLC 16 2 VMP CTLD 15 3 DOP VDD 14 4 VINI VC1 13 5 CDT S-8204B VC2 12 (2) 6 CCT VC3 11 7 CIT VC4 10 8 SEL VSS 9 RVDD2 RVC5 CVC5 CVC6 CVC7 RVC7 RVC8 CVC8 DCOP RDOP RVC6 CVDD2 RCIT2 RSEL2 RCOP EB Charge FET Discharge FET Figure 12 Caution 1. 2. It is recommended that filter constants between the VDD pin and the VSS pin should be set to approximately 47 F  . e.g., CVDD  RVDD = 1.0 F  47  = 47 F   Sufficient evaluation of transient power supply fluctuation and overcurrent protection function with the actual application is needed to determine the proper constants. Contact our sales office in case the constants should be set to other than 47 F  . It has not been confirmed whether the operation is normal in circuits other than the above example of connection. In addition, the example of connection shown above and the constants do not guarantee proper operation. Perform thorough evaluation using an actual application to set the constant. Remark Refer to the application note for constants of each external component. 25 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 3. 8-series cell (cascade connection with overcurrent protection function) EB+ M4 R1 RIFC RINV2 CTLC 16 2 VMP CTLD 15 3 DOP VDD 14 RCTLD RVDD1 RVC1 VC1 13 S-8204B 5 CDT (1) VC2 12 RVINI1 CCCT1 CCDT1 6 CCT VC3 11 7 CIT VC4 10 8 SEL VSS 9 CVC1 CVC2 CVC3 RVC2 RVC3 RVC4 CVC4 CVDD1 RCIT1 M3 RCTLC 4 VINI RIFD R2 1 COP RSEL1 M1 RINV1 RATL M2 CCDT2 CCCT2 CCIT2 1 COP CTLC 16 2 VMP CTLD 15 3 DOP VDD 14 4 VINI VC1 13 5 CDT S-8204B (2) VC2 12 6 CCT VC3 11 7 CIT VC4 10 8 SEL VSS 9 RVDD2 RVC5 CVC5 CVC6 CVC7 RVC6 RVC7 RVC8 CVC8 CVDD2 ZD1 RSEL2 DCOP REB EB RCOP RDOP RVINI2 RSENSE Charge FET Discharge FET Figure 13 Caution 1. 2. It is recommended that filter constants between the VDD pin and the VSS pin should be set to approximately 47 F  . e.g., CVDD  RVDD = 1.0 F  47  = 47 F   Sufficient evaluation of transient power supply fluctuation and overcurrent protection function with the actual application is needed to determine the proper constants. Contact our sales office in case the constants should be set to other than 47 F  . It has not been confirmed whether the operation is normal in circuits other than the above example of connection. In addition, the example of connection shown above and the constants do not guarantee proper operation. Perform thorough evaluation using an actual application to set the constant. Remark Refer to the application note for constants of each external component. 26 Rev.3.9_01 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series  Precautions  The application conditions for the input voltage, output voltage, and load current should not exceed the package power dissipation.  Batteries can be connected in any order; however, there may be cases when discharging cannot be performed when a battery is connected. In such a case, short the VMP pin and the VDD pin to return the IC to the normal mode.  If both an overcharge battery and an overdischarge battery are included among the whole batteries, the condition is set in overcharge status and overdischarge status. Therefore either charging or discharging is impossible.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 27 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01  Characteristics (Typical Data) 1. Current consumption 1. 2 IOPE vs. Ta 40 35 30 25 20 15 10 5 0 IOPE [μA] IOPE [μA] 1. 1 IOPE vs. VDS 0 5 10 VDS [V] 15 20 22 40 25 0 25 Ta [C] 50 75 85 0 25 Ta [C] 50 75 85 1. 4 IPDN vs. Ta 0.10 0.09 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0 IPDN [μA] IPDN [μA] 1. 3 IPDN vs. VDS 0 40 35 30 25 20 15 10 5 0 5 10 VDS [V] 15 0.10 0.09 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0 20 22 40 25 2. Overcharge detection / release voltage, overdischarge detection / release voltage, overcurrent detection voltage 4.375 4.370 4.365 4.360 4.355 4.350 4.345 4.340 4.335 4.330 4.325 2. 2 VCL vs. Ta 4.20 4.18 VCL [V] VCU [V] 2. 1 VCU vs. Ta 40 25 4.10 0 25 Ta [C] 50 75 85 40 25 40 25 0 25 Ta [C] 50 75 85 0 25 Ta [C] 50 75 85 2. 4 VDL vs. Ta VDL [V] VDU [V] 28 4.14 4.12 2. 3 VDU vs. Ta 2.80 2.78 2.76 2.74 2.72 2.70 2.68 2.66 2.64 2.62 2.60 4.16 0 25 Ta [C] 50 75 85 2.08 2.06 2.04 2.02 2.00 1.98 1.96 1.94 1.92 40 25 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 2. 6 VDIOV1 vs. Ta 0.29 0.28 0.27 0.26 0.25 0.24 0.23 0.22 0.21 VDIOV1 [V] VDIOV1 [V] 2. 5 VDIOV1 vs. VDS 10 11 12 13 VDS [V] 14 15 16 0.58 0.56 0.54 0.52 0.50 0.48 0.46 0.44 0.42 11 12 13 VDS [V] 14 15 0.58 0.56 0.54 0.52 0.50 0.48 0.46 0.44 0.42 16 2. 9 VSHORT vs. VDS 0 25 Ta [C] 50 75 85 40 25 0 25 Ta [C] 50 75 85 0 25 Ta [C] 50 75 85 2. 10 VSHORT vs. Ta 1.3 1.3 1.2 1.2 1.1 1.1 VSHORT [V] VSHORT [V] 40 25 2. 8 VDIOV2 vs. Ta VDIOV2 [V] VDIOV2 [V] 2. 7 VDIOV2 vs. VDS 10 0.29 0.28 0.27 0.26 0.25 0.24 0.23 0.22 0.21 1.0 0.9 0.8 1.0 0.9 0.8 0.7 0.7 10 11 12 13 VDS [V] 14 15 16 40 25 29 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 3. CCT pin internal resistance / detection voltage, CDT pin internal resistance / detection voltage, CIT pin internal resistance / detection voltage and load short-circuit detection delay time 3. 2 VCCT vs. Ta (VDS = 15.2 V) 12.0 10.9 11.0 10.8 10.0 VCCT [V] RINC [M] 3. 1 RINC vs. Ta 9.0 8.0 40 25 10.4 0 25 Ta [C] 50 75 85 3. 3 RIND vs. Ta VCDT [V] RIND [k] 900 800 40 25 25 Ta [C] 50 75 85 40 25 0 25 Ta [C] 50 75 85 3. 6 VCIT vs. Ta (VDS = 14.0 V) 10.0 240 220 9.9 200 VCIT [V] RINI1 [k] 75 85 8.4 8.2 0 3. 5 RINI1 vs. Ta 180 160 9.8 9.7 140 40 25 9.6 0 25 Ta [C] 50 75 85 3. 7 RINI2 vs. Ta 40 25 0 25 Ta [C] 50 75 85 0 25 Ta [C] 50 75 85 3. 8 tSHORT vs. Ta 24.0 600 22.0 500 20.0 400 tSHORT [μs] RINI2 [k] 50 8.3 700 18.0 16.0 14.0 30 25 Ta [C] 8.5 1000 12.0 0 8.6 1100 120 40 25 3. 4 VCDT vs. Ta (VDS = 12.0 V) 1200 600 10.6 10.5 7.0 6.0 10.7 300 200 100 40 25 0 0 25 Ta [C] 50 75 85 40 25 BATTERY PROTECTION IC FOR 3-SERIES OR 4-SERIES CELL PACK S-8204B Series Rev.3.9_01 4. COP pin / DOP pin 4. 1 ICOH vs. VCOP 4. 2 ICOL vs. VCOP 20 ICOL [μA] ICOH [mA] 25 15 10 5 0 0 3.5 7 VCOP [V] 10.5 14 4. 3 IDOH vs. VDOP IDOL [mA] IDOH [mA] 20 15 10 5 0 0 5 20 22 10 15 VCOP [V] 4. 4 IDOL vs. VDOP 25 0 0.10 0.09 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0.00 3.5 7 VDOP [V] 10.5 14 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 0 1.8 3.6 VDOP [V] 5.4 7.2 31 5.1±0.2 0.65 16 9 1 8 0.17±0.05 0.22±0.08 No. FT016-A-P-SD-1.2 TITLE TSSOP16-A-PKG Dimensions FT016-A-P-SD-1.2 No. ANGLE UNIT mm ABLIC Inc. +0.1 4.0±0.1 ø1.5 -0 0.3±0.05 2.0±0.1 8.0±0.1 1.5±0.1 ø1.6±0.1 (7.2) 4.2±0.2 +0.4 6.5 -0.2 1 16 8 9 Feed direction No. FT016-A-C-SD-1.1 TITLE TSSOP16-A-Carrier Tape No. FT016-A-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. 21.4±1.0 17.4±1.0 +2.0 17.4 -1.5 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FT016-A-R-SD-2.0 TITLE TSSOP16-A- Reel FT016-A-R-SD-2.0 No. ANGLE UNIT QTY. mm ABLIC Inc. 2,000 21.4±1.0 17.4±1.0 +2.0 17.4 -1.5 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FT016-A-R-S1-1.0 TITLE TSSOP16-A- Reel No. FT016-A-R-S1-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8204BAN-TCT1U
1. 物料型号:S-8204B系列电池保护IC,适用于3系列或4系列电池组。 2. 器件简介:S-8204B系列包括高精度电压检测电路和延时电路,可以监测3系列或4系列锂离子可充电电池的状态。通过改变SEL引脚上应用的电压水平,用户可以使用S-8204B系列用于3系列或4系列电池组。 3. 引脚分配:文档提供了详细的引脚配置表,包括16个引脚的符号和描述。 4. 参数特性:包括高精度的每个电池单元的过充检测电压、过放检测电压、放电过流检测电压等,以及可调节的延迟时间、独立充电和放电控制等特性。 5. 功能详解:文档详细描述了过充、过放、放电过流和短路等状态的检测和释放条件,以及如何通过外部电容设置延迟时间。 6. 应用信息:适用于锂离子电池组的保护,特别是可充电的3系列或4系列电池组。 7. 封装信息:16-Pin TSSOP封装。
S-8204BAN-TCT1U 价格&库存
很抱歉,暂时无法提供与“S-8204BAN-TCT1U”相匹配的价格&库存,您可以联系我们找货
