S-8533A125FT-TB-U
S-8533A125FT-TB-U
    ABLIC(艾普凌科)
    TSSOP8
    IC REG CTRLR BUCK 8TSSOP
S-8533A125FT-TB-U 数据手册
S-8533 Series www.ablic.com www.ablicinc.com STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER © ABLIC Inc., 2002-2010 Rev.3.0_02 The S-8533 Series is a synchronous PWM control CMOS step-down switching regulator controller that includes a reference voltage source, synchronous circuit, oscillation circuit, error amplifier, phase compensation circuit, and PWM controller. An efficient step-down switching regulator can be realized simply by adding external P-channel and N-channel power MOS FETs, one coil, and three capacitors. Since the oscillation frequency is a high 300 kHz, the S-8533 can be used to configure a high efficiency step-down switching regulator capable of driving high output current using small external parts and a 3 to 10% increase in efficiency is obtained compared to conventional step-down switching regulators. The 8-Pin TSSOP package and high oscillation frequency make the S-8533 ideal as the main power supply for portable devices.  Features  Synchronous rectification system realizing high efficiency (typ. 94%)  Use at maximum duty ratio = 100% and use of a battery up to maximum life is possible by using P-channel and Nchannel power MOS FETs externally.  Oscillation frequency : 300 kHz typ.  Input voltage : 2.7 to 16.0 V  Output voltage : 1.25 V 1.3 to 6.0 V, selectable in 0.1 V steps  Output voltage accuracy : 2.0%  Soft-start function set by an external capacitor (CSS)  Shutdown function  Lead-free, Sn 100%, halogen-free*1 *1. Refer to “ Product Name Structure” for details.  Applications     Constant voltage power supply for hard disks and DVD drivers Power supplies for portable devices, such as digital cameras, PDAs, electronic organizers, and cellular phones Main or sub power supply for notebook PCs and peripherals Constant voltage power supply for cameras, video equipment, and communication equipment  Package  8-Pin TSSOP 1 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Block Diagram L Tr VIN PDRV NDRV  VIN CIN CSS Oscillation circuit VOUT  PWM control circuit P.N feed-through prevention circuit   Tr CSS Reference voltage source with soft start VSS ON / OFF Remark All the diodes in the figure are parasitic diodes. Figure 1 2 COUT STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Product Name Structure The output voltage for the S-8533 Series can be selected depending on usage. Refer to “1. Product Name” for the definition of the product name, “2. Package” regarding the package drawings and “3. Product Name List” for the full product names. 1. Product Name S-8533A xx x FT – TB – x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) IC direction in tape specifications*1 Package name (abbreviation) FT : 8-Pin TSSOP Output voltage A : 1.3 to 6.0 V 5 : 1.25 V Output voltage 13 to 60 (E.g., when the output voltage is 1.5 V, it is expressed as 15.) The product whose output voltage is 1.25 V expresses 12. *1. Refer to the tape specifications. 2. Package Package Name 8-Pin TSSOP Environmental code = G Environmental code = U Package Drawing Code Tape Reel FT008-A-P-SD FT008-A-P-SD FT008-E-C-SD FT008-E-C-SD FT008-E-R-SD FT008-E-R-S1 3 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series 3. Product Name List Output Voltage Product Name 1.25 V S-8533A125FT-TB-x 1.3 V S-8533A13AFT-TB-x 1.4 V S-8533A14AFT-TB-x 1.5 V S-8533A15AFT-TB-x 1.8 V S-8533A18AFT-TB-x 2.5 V S-8533A25AFT-TB-x 2.7 V S-8533A27AFT-TB-x 2.8 V S-8533A28AFT-TB-x 3.0 V S-8533A30AFT-TB-x 3.3 V S-8533A33AFT-TB-x 3.9 V S-8533A39AFT-TB-x 4.1 V S-8533A41AFT-TB-x 4.5 V S-8533A45AFT-TB-x 4.8 V S-8533A48AFT-TB-x 4.9 V S-8533A49AFT-TB-x 5.0 V S-8533A50AFT-TB-x 5.2 V S-8533A52AFT-TB-x 5.5 V S-8533A55AFT-TB-x 6.0 V S-8533A60AFT-TB-x Remark 1. Contact the ABLIC Inc. marketing department for the availability of product samples other than those specified above. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 4 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Pin Configurations Table 1 8-Pin TSSOP Top view 1 2 3 4 8 7 6 5 Figure 2 Pin No. 1 2 Symbol NC*1 VOUT Pin Description No connection Output voltage pin Shutdown pin H : Normal operation (step-down operation) 3 ON/ OFF L : Step-down operation stopped (all circuits deactivated) 4 CSS Soft start capacitor connection pin 5 VSS GND pin 6 NDRV External N-channel connection pin 7 PDRV External P-channel connection pin 8 VIN IC power supply pin *1. The NC pin is electrically open. Connection of this pin to VIN or VSS is allowed. 5 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Absolute Maximum Ratings Table 2 Parameter VIN pin voltage VOUT pin voltage ON/OFF pin voltage CSS pin voltage NDRV pin voltage PDRV pin voltage NDRV pin current PDRV pin current Symbol VIN VOUT VON/OFF VCSS VNDRV VPDRV INDRV IPDRV Power dissipation PD Operating ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size : 114.3 mm  76.2 mm  t1.6 mm (2) Board name : JEDEC STANDARD51-7 (Ta = 25C unless otherwise specified) Absolute Maximum Rating Unit VSS  0.3 to VSS  18 V VSS  0.3 to VSS  18 V VSS  0.3 to VSS  18 V VSS  0.3 to VIN  0.3 V VSS  0.3 to VIN  0.3 V VSS  0.3 to VIN  0.3 V 100 mA 100 mA 300 (When not mounted on board) mW 700*1 mW 40 to 85 C 40 to 125 C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. (2) When not mounted on board 800 Power dissipation (PD) [mW] Power dissipation (PD) [mW] (1) When mounted on board 700 600 500 400 300 200 100 0 0 50 100 150 Ambient temperature (Ta) [C] 400 300 200 100 0 0 50 150 Ambient temperature (Ta) [C] Figure 3 Power Dissipation of Package 6 100 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Electrical Characteristics Table 3 VIN = VOUT  1.5 V, IOUT = VOUT/50 A (In case VOUT  1.8 V, VIN = 2.7 V) (Ta = 25C unless otherwise specified) Parameter Output voltage Symbol *1 VOUT(E) Input voltage VIN Conditions Min. Measurement Typ. Max. Unit  VOUT(S)  0.98 VOUT(S) VOUT(S)  1.02 V 2  Circuit 2.7  16.0 V 1  30 70 A 1   1.0 A 1 Current consumption 1 ISS1 No external parts, VOUT = VOUT(S)  0.95 (Duty ratio 100%) Current consumption during power-off ISSS VON/OFF = 0 V IPDRVH No external parts, VOUT = VOUT(S)  1.5, VIN = 9.0 V, VPDRV = VIN  0.2 V 12 18  mA 1 IPDRVL No external parts, VOUT = VOUT(S)  0.95, VIN = 9.0 V, VPDRV = 0.2 V 19 27  mA 1 INDRVH No external parts, VOUT = VOUT(S)  1.5, VIN = 9.0 V, VNDRV = VIN  0.2 V 10 14  mA 1 INDRVL No external parts, VOUT = VOUT(S)  0.95, VIN = 9.0 V, VNDRV = 0.2 V 35 50  mA 1 S-8533A125, S-8533A13A to 29A  VOUT(E)  1.0% VOUT(E)  2.5% V 2 S-8533A30A to 60A  VOUT(E)  1.0% VOUT(E)  2.0% V 2 PDRV pin output current NDRV pin output current Line regulation VOUT1 VIN = VOUT(S)  1.2 to 16 V *2 Load regulation VOUT2 IOUT = 10 A to IOUT (see above)  1.25  VOUT(E)  0.5% VOUT(E)  1.0% V 2 Output voltage temperature coefficient VOUT Ta  VOUT Ta = 40 to 85C  100  ppm/C  Oscillation frequency fOSC Measure waveform at the PDRV pin. 255 300 345 kHz 2 Maximum duty ratio MaxDuty The same condition as lSS1. Measure waveform at the PDRV pin. 100   % 1 VOUT pin input current IVOUT VOUT = 5.0 V 0.01 0.1 4.0 A 1 VSH The same condition as ISS1. VIN = 2.7 V and check that PDRV pin = "L". 1.8   V 1 VSL The same condition as ISS1. VIN = 16.0 V and check that PDRV pin = "H".   0.3 V 1 ON/ OFF pin input voltage ISH The same condition as ISS1. VON/OFF = VIN 0.1  0.1 A 1 ISL The same condition as ISS1. VON/OFF = 0 V 0.1  0.1 A 1 Soft-start time tSS The same condition as ISS1. Measure time until PDRV pin oscillates. 5.0 8.0 16.0 ms 1 Efficiency EFFI *3, IOUT = 200 to 400 mA, S-8533A33A  94  % 3 ON/ OFF pin input leakage current External parts : CD105 (22 H) Coil : Sumida Corporation Diode : Matsushita Electric Industrial Co., Ltd. MA737 (Schottky diode) Capacitor : Nichicon Corporation F93 (16 V, 47 F, tantalum)  2 Transistor : Toshiba Corporation 2SA1213 Base resistance : 1 k Base capacitor : 2200 pF CSS : 4700 pF CNDRV : 1000 pF *1. VOUT(S) : Nominal output voltage value VOUT(E) : Actual output voltage value : VIN = VOUT  1.5 V, IOUT = VOUT/50 A (If VOUT  1.8 V, VIN = 2.7 V.) *2. In case VOUT(S)  2.2 V, VIN = 2.7 to 16 V *3. External parts Coil : Sumida Corporation CDRH104R (22 H) Capacitor : Nichicon Corporation F93 (16 V, 47 F, tantalum)  2 P-channel power MOS FET : Sanyo Electric Co., Ltd. CPH6303 (VGS = 10 V max.) N-channel power MOS FET : Sanyo Electric Co., Ltd. CPH6403 (VGS = 10 V max.) CSS : 4700 pF 7 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Measurement Circuits 1. A 0.1 F VIN CSS PDRV A VOUT A NDRV A 4700 pF A ON/OFF VSS Figure 4 2. 2200 pF A F93 22 F  3  0.1 F VIN PDRV 1 k  F93 22 F  3 2SA1213 CSS 4700 pF MA737 ON/OFF CD105 22 H VOUT VSS   F93 F93 47 F 47 F CNDRV 1000 pF NDRV Figure 5 3.  A CPH6303 0.1 F F93 22 F VIN PDRV CSS CDRH104R 22 H 4700 pF ON/OFF VOUT VSS NDRV Figure 6 8 CPH6403   F93 F93 47 F 47 F IOUT STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Operation 1. Synchronous PWM Control Step-down DC-DC Converter 1. 1 Synchronous Rectification A synchronous rectifying DC-DC converter enables a greater reduction in the power consumption of the external rectifying element compared with a conventional DC-DC converter. In addition, incorporating a P and N feedthrough prevention circuit reduces the feed-through current during operation of external transistors (P-channel and N-channel), making the operating power consumption extremely low. 1. 2 PWM Control The S-8533 Series is a DC-DC converter that uses pulse width modulation (PWM) and is characterized by its low current consumption. In conventional modulation PFM system DC-DC converters, pulses are skipped when they are operated with a low output load current, causing variations in the ripple frequency of the output voltage and an increase in the ripple voltage. Both of these effects constitute inherent drawbacks to those converters. In the S-8533 Series, the pulse width varies in the range from 0 to 100% according to the load current, yet the ripple voltage produced by the switching can easily be eliminated by a filter since the switching frequency is always constant. When the pulse width is 0% (when there is no load or the input voltage is high), current consumption is low since pulses are skipped. 2. Soft-Start Function The S-8533 Series has a built-in soft-start circuit. This circuit enables the output voltage (VOUT) to rise gradually over the specified soft-start time (tSS) to suppress the overshooting of the output voltage, when the power is switched on or the ON/OFF pin is set “H”. The soft-start time can be set with an external capacitance (CSS). The time needed for the output voltage to reach 95% of the set output voltage value is calculated by the following formula. tSS [ms] = 0.002  CSS [pF] Soft-start time (t SS) [ms] 60 50 40 30 20 10 0 0 5000 10000 15000 External capacitance (CSS) [pF] 20000 Figure 7 Soft-Start Time The value for CSS should be selected to give enough margin to the soft-start time against the power supply rise time. If the soft-start time is short, possibility for output voltage overshoot, input current rush, and malfunction of the IC increases. 9 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series 3. ON/OFF Pin (Shutdown Pin) This pin is used to activate and deactivate the step-down operation. When the ON/OFF pin is set to “L”, all the internal circuits stop working, and substantial savings in current consumption are thus achieved. The voltage of the PDRV pin goes to VIN level and voltage of the NDRV pin goes to VSS level to shut off the respective transistors. The ON/OFF pin is configured as shown in Figure 8. Since pull-up or pull-down is not performed internally, operation where the ON/OFF pin is in a floating state should be avoided. Application of a voltage of 0.3 to 1.8 V to the pin should also be avoided lest the current consumption increases. When the ON/OFF pin is not used, it should be connected to the VIN pin. VIN ON/OFF Pin CR Oscillation Circuit Output Voltage “H” “L” Active Non-active Set value Open ON/OFF VSS Figure 8 ON/OFF Pin Structure 4. 100% Duty Cycle The S-8533 Series operates with a maximum duty cycle of 100%. The switching transistor can be kept on to supply current to the load continually, even in cases where the input voltage falls below the preset output voltage value. The output voltage under these circumstances is equal to the subtraction of the lowering due to the DC resistance of the coil and the on-resistance of the switching transistor from the input voltage. 5. Back-Flow Current Since the S-8533 Series performs PWM synchronous rectification under a light load, current flows backward in the VIN direction. The back-flow current therefore reaches its peak when there is no load (see Figure 9). Pay attention to the maximum back-flow current value, which can be calculated from the following expressions. Duty (IOUT = 0) = VOUT/VIN Example : VIN = 5 V, VOUT = 3 V, Duty = 60% IL = V/L  ton = (VIN  VOUT)  Duty/(L  fOSC)  1.2 Example : VIN = 5 V, VOUT = 3 V, fOSC = 300 kHz, L = 22 H, IL = 218 mA ILmax. = IL/2 = 109 mA, ILmin. = IL/2 = 109 mA When there is no load, the current waveform becomes a triangular wave with the maximum, ILmax., and the minimum, ILmin., which is negative. The negative current, shaded regions in Figure 10, flows backward. When the output current (IOUT) is approximately 109 mA under the above conditions, the current does not flow backward since the minimum value (ILmin) of the triangular wave becomes 0 mA. When an input capacitor (CIN) is installed, back-flow current to the power source is negligible since the back-flow current is absorbed by the input capacitor. The input capacitor is indispensable to reduce back-flow current to the power source. 10 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series Though the conditions mentioned above are required to prevent back-flow current, they are guidelines. Check the validity by measuring the prototype or the actual device. Back-flow current VIN CIN  VIN PDRV NDRV L VOUT Coil current IL  VSS Figure 9 Back-Flow Current Coil current under no load IL 218 mA IL 109 mA 0 mA IOUT 109 mA Coil current when 109 mA flows as a load ILmax. IL Back-flow current ILmin. ILmax. IL 109 mA IOUT ILmin. 0 mA Back-flow current = 0 mA Figure 10 Example for No Back-Flow Current 11 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  External Parts Selection 1. Inductor The inductance value (L) greatly affects the maximum output current (IOUT) and the efficiency (). As the L value is reduced gradually, the peak current (IPK) increases, the stability of the circuit is improved, and IOUT increases. As the L value is made even smaller, the efficiency is lowered, and IOUT decreases since the current driveability of the switching transistor is insufficient. As the L value is increased, the dissipation in the switching transistor due to IPK decreases, and the efficiency reaches the maximum at a certain L value. As the L value is made even larger, the efficiency degrades since the dissipation due to the series resistance of the coil increases. IOUT also decreases. An inductance of 22 H is recommended for the S-8533 Series. When choosing an inductor, attention to its allowable current should be paid since the current exceeding the allowable value will cause magnetic saturation in the inductor, leading to a marked decline in efficiency and the breakdown of the IC due to large current. An inductor should therefore be selected so that IPK does not surpass its allowable current. IPK is expressed by the following equation : IPK  IOUT  VOUT  (VIN  VOUT) 2  fOSC  L  VIN where fOSC (= 300 kHz) is the oscillation frequency. 2. Capacitors (CIN, COUT) The capacitor (CIN) inserted on the input side serves to lower the power impedance, average input current, and suppress back-flow current to the power source. Select the CIN value according to the impedance of the power supplied, and select a capacitor that has low ESR (Equivalent Series Resistance) and large capacitance. It should be approximately 47 to 100 F, although the actual value depends on the impedance of the power source used and load current value. When the input voltage is low and the load is large, the output voltage may become unstable. In this case, increase the input capacitance. For the output side capacitor (COUT), select a large capacitance with low ESR (Equivalent Series Resistance) to smoothen the ripple voltage. When the input voltage is extremely high or the load current is extremely large, the output voltage may become unstable. In this case, the unstable area will become narrow by selecting a large capacitance for an output side capacitor. A tantalum electrolytic capacitor is recommended since the unstable area widens when a capacitor with a large ESR, such as an aluminum electrolytic capacitor, or a capacitor with a small ESR, such as a ceramic capacitor, is chosen. The range of the capacitance should generally be approximately 47 to 100 F. Fully evaluate input and output capacitors under the actual operating conditions to determine the best value. 12 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series 3. External Transistor Enhancement (P-channel, N-channel) MOS FETs can be used as external switching transistors for the S-8533 Series. 3. 1 Enhancement (P-channel, N-channel) MOS FET The PDRV/NDRV pin of the S-8533 Series is capable of directly driving a P-channel or N-channel MOS FET with a gate capacity around 1000 pF. When P-channel/N-channel MOS FETs are chosen, efficiency will be 2 to 3% higher than that achieved by a PNP/NPN bipolar transistor since MOS FET switching speeds are higher than PNP/NPN bipolar transistors and power dissipation due to the base current is avoided. The important parameters in selecting MOS FETs include the threshold voltage, breakdown voltage between gate and source, breakdown voltage between drain and source, total gate capacity, on-resistance, and the current ratings. The PDRV and NDRV pins swing from voltage VIN over to voltage VSS. If the input voltage is low, a MOS FET with a low threshold voltage has to be used so that the MOS FET will turn on as required. If, conversely, the input voltage is high, select a MOS FET whose gate-source breakdown voltage is higher than the input voltage by at least several volts. Immediately after the power is turned on, or when the power is turned off (that is, when the step-down operation is terminated), the input voltage will be imposed across the drain and the source of the MOS FET. The transistor therefore needs to have drain-source breakdown voltage that is also several volts higher than the input voltage. The total gate capacity and the on-resistance affect the efficiency. The power dissipation for charging and discharging the gate capacity by switching operation will affect the efficiency especially at low load current region when the total gate capacity becomes larger and the input voltage becomes higher. If the efficiency under light loads is a matter of particular concern, select a MOS FET with a small total gate capacity. In regions where the load current is high, the efficiency is affected by power dissipation caused by the on-resistance of the MOS FET. If the efficiency under heavy loads is particularly important in the application, choose a MOS FET with as low an on-resistance as possible. As for the current rating, select a MOS FET whose maximum continuous drain current rating is higher than IPK. If an external P-channel MOS FET has much different characteristics (input capacitance, threshold value, etc.) from an external N-channel MOS FET, they turn ON at the same time, flowing a through current and reducing efficiency. If a MOS FET with a large input capacitance is used, switching dissipation increases and efficiency decreases. If it is used at several hundreds of mA or more, the dissipation at the MOS FET increases and may exceed the permissible dissipation of the MOS FET. To select P-channel and N-channel MOS FETs, evaluate the performance by testing under the actual condition. Caution If the load current is large, the P-channel MOS FET dissipation increases and heat is generated. Pay attention to dissipate heat from the P-channel MOS FET. Efficiency data using Sanyo Electric Co., Ltd. CPH6303, CPH6403, and Vishay Siliconix Si3441DV and Si3442DV for applications with an input voltage range of 6 to 8 V or less is included for reference. For applications with an input voltage range of 6 to 8 V or more, efficiency data using Sanyo Electric Co., Ltd. CPH6302, CHP6402, and Vishay Siliconix Si3454DV and Si3455DV is included. Refer to “ Reference Data”. Current flow in the parasitic diode is not allowed in some MOS FETs. In this case, a Schottky diode must be connected in parallel to the MOS FET. The Schottky diode must have a low forward voltage, a high switching speed, a reverse-direction withstand voltage of VIN or higher, and a current rating of IPK or higher. 13 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Standard Circuit  Using MOS FET VOUT L Pch Power MOS FET Nch Power MOS FET 1 8  VON / OFF 4 CSS S-8533 CIN  VIN COUT 5 Figure 11 Caution The above connection diagram does not guarantee correct operation. Perform sufficient evaluation using the actual application to set the constants. 14 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Precautions  Install the external capacitors, diode, coil, and other peripheral parts as close to the IC as possible, and make a onepoint grounding.  Normally, the P-channel and N-channel MOS FETs do not turn ON at the same time. However, if the external Pchannel MOS FET has much different characteristics (input capacitance, Vth, etc.) from the external N-channel MOS FET, they may turn ON at the same time, flowing a through current. Select P-channel and N-channel transistors with similar characteristics.  Characteristics ripple voltage and spike noise occur in IC containing switching regulators. Moreover rush current flows at the time of a power supply injection. Because these largely depend on the coil, the capacitor and impedance of power supply used, fully check them using an actually mounted model.  If the input voltage is high and output current is low, pulses with a low duty ratio may be output, and then the duty ratio may be 0% for several clocks.  The PDRV and NDRV oscillation frequencies may be an integer fraction of 300 kHz at some input voltage and load conditions. In this case, the ripple voltage may increase.  The through current prevention circuit reduces through current by shifting the P-channel and N-channel transistor on timing. It does not suppress the through current in the external transistors completely.  Since PWM synchronous rectification is performed even when the load is light, current flows back to VIN. Check whether the back-flow occurs and whether it affects the performance. (See “5. Back-Flow Current” in “ Operation”.)  The PDRV or NDRV oscillation frequency may vary in a voltage range, depending on input voltage.  When decreasing the power supply voltage slowly, the IC operation may be undefined if the voltage falls below the minimum operating voltage.  Make sure that dissipation of the switching transistor especially at high temperature will not surpass the power dissipation of the package.  Switching regulator performance varies depending on the design of PCB patterns, peripheral circuits and parts. Thoroughly evaluate the actual device when setting. When using parts other than those which are recommended, contact the ABLIC Inc. marketing department.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 15 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Characteristics (Typical Data) 1. Examples of Major Characteristics (1) Current Consumption 1 (ISS1) vs. Input Voltage (VIN) (2) Oscillation Frequency (fOSC) vs. Input Voltage (VIN) 100 360 90 Ta 25C 80 340 Ta 85C 70 ISS1 (A) 320 60 fOSC (kHz) 300 50 Ta 85C 40 Ta 40C 280 30 Ta 40C 20 Ta 25C 260 10 240 0 2 4 6 8 10 12 14 16 2 4 6 8 VIN (V) 10 12 14 16 VIN (V) (3) PDRV Pin Output Current “H” (IPDRVH) vs. Input Voltage (VIN) (4) PDRV Pin Output Current “L” (IPDRVL) vs. Input Voltage (VIN) 70 70 60 60 50 50 Ta = 40C Ta = 40C IPDRVH 40 (mA) 30 IPDRVL 40 (mA) 30 20 Ta = 85C 10 0 2 4 6 8 10 12 14 Ta = 25C 20 Ta = 25C Ta = 85C 10 0 16 2 4 6 8 VIN (V) (5) NDRV Pin Output Current “H” (INDRVH) vs. Input Voltage (VIN) 14 16 120 60 100 Ta = 40C 50 80 Ta = 40C INDRVH 40 (mA) 30 INDRVL (mA) 60 Ta = 25C 40 20 Ta = 25C 10 Ta = 85C 20 Ta = 85C 2 4 6 8 10 12 14 0 16 2 4 6 8 VIN (V) 10 12 14 16 VIN (V) (7) ON/OFF Pin Input Voltage “H” (VSH) vs. Input Voltage (VIN) (8) ON/OFF Pin Input Voltage “L” (VSL) vs. Input Voltage (VIN) 1.7 1.8 1.6 1.5 1.4 Ta = 40C 1.3 1.2 VSH 1.0 (V) 0.8 VSL (V) Ta = 25C 1.1 Ta = 40C 0.9 Ta = 85C 0.6 0.7 0.4 Ta = 25C 0.5 0.2 0 2 4 6 8 10 VIN (V) 16 12 (6) NDRV Pin Output Current “L” (INDRVL) vs. Input Voltage (VIN) 70 0 10 VIN (V) 12 14 16 0.3 Ta = 85C 2 4 6 8 10 VIN (V) 12 14 16 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series (9) Soft-Start Time (tSS) vs. Input Voltage (VIN) 16 14 Ta = 40C 12 10 tSS (ms) 8 6 Ta = 85C Ta = 25C 4 2 0 2 4 6 8 10 12 14 16 VIN (V) (10) Output Voltage (VOUT) vs. Input Voltage (VIN) (1.5 V : S-8533A15AFT) (11) Output Voltage (VOUT) vs. Input Voltage (VIN) (3.3 V : S-8533A33AFT) 1.53 3.37 IOUT = 100 mA 3.35 1.52 IOUT = 0.1 mA 3.33 1.51 VOUT (V) 1.50 VOUT 3.31 (V) 3.29 IOUT = 400 mA IOUT = 400 mA IOUT = 100 mA 1.49 3.27 1.48 1.47 IOUT = 0.1 mA 3.25 2 4 6 8 10 12 14 16 VIN (V) 3.23 2 4 6 8 10 12 14 16 VIN (V) (12) Output Voltage (VOUT) vs. Input Voltage (VIN) (5.0 V : S-8533A50AFT) 5.08 5.06 5.04 IOUT = 100 mA 5.02 VOUT (V) 5.00 IOUT = 0.1 mA 4.98 4.96 IOUT = 400 mA 4.94 4.92 2 4 6 8 10 12 14 16 VIN (V) 17 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series 2. Examples of Transient Response Characteristics (1) Power-on (VIN : 0 V  2.7 V or 5.0 V or 7.5 V, 0 V  9.0 V, IOUT : 10 mA) S-8533A15AFT (VIN : 0 V  2.7 V) S-8533A15AFT (VIN : 0 V  9.0 V) 10 V 10 V Input voltage (2.5 V/div) Input voltage (2.5 V/div) 0V 3V Output voltage (1 V/div) 0V 0V 3V Output voltage (1 V/div) 0V t (2 ms/div) S-8533A33AFT (VIN : 0 V  5.0 V) t (2 ms/div) S-8533A33AFT (VIN : 0 V  9.0 V) 10 V 10 V Input voltage (2.5 V/div) Input voltage (2.5 V/div) 0V 3V Output voltage (1 V/div) 0V 3V Output voltage (1 V/div) 0V 0V t (2 ms/div) t (2 ms/div) S-8533A50AFT (VIN : 0 V  7.5 V) S-8533A50AFT (VIN : 0 V  9.0 V) 10 V 10 V Input voltage (2.5 V/div) Input voltage (2.5 V/div) 0V 4.5 V Output voltage (1.5 V/div) 0V 0V 4.5 V Output voltage (1.5 V/div) 0V t (2 ms/div) 18 t (2 ms/div) STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series (2) ON/OFF Pin Response (VON/OFF : 0 V  1.8 V, IOUT : 10 mA) S-8533A15AFT (VIN : 2.7 V) S-8533A15AFT (VIN : 9.0 V) 4V 4V ON/OFF pin voltage (1 V/div) ON/OFF pin voltage (1 V/div) 0V 3V Output voltage (1 V/div) 0V 3V Output voltage (1 V/div) 0V 0V t (2 ms/div) S-8533A33AFT (VIN : 5.0 V) t (2 ms/div) S-8533A33AFT (VIN : 9.0 V) 4V 4V ON/OFF pin voltage (1 V/div) ON/OFF pin voltage (1 V/div) 0V 3V Output voltage (1 V/div) 0V 3V Output voltage (1 V/div) 0V 0V t (2 ms/div) S-8533A50AFT (VIN : 7.5 V) t (2 ms/div) S-8533A50AFT (VIN : 9.0 V) 4V 4V ON/OFF pin voltage (1 V/div) ON/OFF pin voltage (1 V/div) 0V 4.5 V Output voltage (1.5 V/div) 0V 4.5 V Output voltage (1.5 V/div) 0V 0V t (2 ms/div) t (2 ms/div) 19 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series (3) Load Fluctuations (IOUT : 0.1 mA  500 mA, 500 mA  0.1 mA, VIN : 2.7 V or 5.0 V or 7.5 V) S-8533A15AFT (VIN : 2.7 V) S-8533A15AFT (VIN : 2.7 V) 500 mA Output current 0.1 mA 500 mA Output current 0.1 mA Output voltage (0.1 V/div) Output voltage (0.1 V/div) t (0.1 ms/div) t (0.1 ms/div) S-8533A33AFT (VIN : 5.0 V) S-8533A33AFT (VIN : 5.0 V) 500 mA Output current 0.1 mA 500 mA Output current 0.1 mA Output voltage (0.1 V/div) Output voltage (0.1 V/div) t (0.1 ms/div) t (0.1 ms/div) S-8533A50AFT (VIN : 7.5 V) S-8533A50AFT (VIN : 7.5 V) 500 mA Output current 0.1 mA 500 mA Output current 0.1 mA Output voltage (0.1 V/div) Output voltage (0.1 V/div) t (0.1 ms/div) 20 t (0.1 ms/div) STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series (4) Input Voltage Fluctuations (VIN : 2.7 V  9.0 V  2.7 V, 5.0 V  9.0 V  5.0 V, 7.5 V  9.0 V  7.5 V) S-8533A15AFT (IOUT : 10 mA) S-8533A15AFT (IOUT : 500 mA) 10 V 10 V Input voltage (2.5 V/div) Input voltage (2.5 V/div) 0V 0V Output voltage (0.1 V/div) Output voltage (0.1 V/div) t (0.5 ms/div) t (0.5 ms/div) S-8533A33AFT (IOUT : 10 mA) S-8533A33AFT (IOUT : 500 mA) 10 V 10 V Input voltage (2.5 V/div) Input voltage (2.5 V/div) 0V 0V Output voltage (0.1 V/div) Output voltage (0.1 V/div) t (0.5 ms/div) S-8533A50AFT (IOUT : 10 mA) t (0.5 ms/div) S-8533A50AFT (IOUT : 500 mA) 10 V 10 V Input voltage (2.5 V/div) Input voltage (2.5 V/div) 0V 0V Output voltage (0.1 V/div) Output voltage (0.1 V/div) t (0.5 ms/div) t (0.5 ms/div) 21 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series  Reference Data Reference data are intended for use in selecting peripheral parts to the IC. The information therefore provides characteristic data in which external parts are selected with a view of wide variety of IC applications. All data show typical values. 1. External Parts for Reference Data Table 4 External Parts List for Output Current vs. Efficiency Characteristics No. (1) (2) Product Name S-8533A15AFT Output Voltage Inductor 1.5 V Transistor Transistor Output Input P-channel N-channel Capacitor Capacitor Application Condition CPH6303 CPH6403 IOUT  2 A, VIN  8 V Si3441DV Si3442DV IOUT  1.4 A, VIN  6 V (3) CPH6303 CPH6403 IOUT  2 A, VIN  8 V (4) Si3441DV Si3442DV IOUT  1.4 A, VIN  6 V CPH6302 CPH6402 IOUT  2 A, VIN  16 V (6) Si3455DV Si3454DV IOUT  1.6 A, VIN  16 V (7) CPH6302 CPH6402 IOUT  2 A, VIN  16 V Si3455DV Si3454DV IOUT  1.6 A, VIN  16 V (5) (8) (9) (10) S-8533A33AFT 3.3 V S-8533A50AFT 5.0 V S-8533A15AFT 1.5 V CDRH104R/22 H CPH6303 CPH6403 IOUT  2 A, VIN  8 V Si3441DV Si3442DV IOUT  1.4 A, VIN  6 V (11) CPH6303 CPH6403 IOUT  2 A, VIN  8 V (12) Si3441DV Si3442DV IOUT  1.4 A, VIN  6 V (13) S-8533A33AFT 3.3 V CDRH104R/47 H (14) (15) (16) (17) (18) S-8533A50AFT S-8533A15AFT 5.0 V 1.5 V (19) (20) (21) S-8533A33AFT 3.3 V CDRH104R/10 H (22) (23) (24) (25) (26) 22 S-8533A50AFT 5.0 V S-8533A33AFT 3.3 V CDRH125/10 H IOUT  2 A, VIN  16 V CPH6302 CPH6402 Si3455DV Si3454DV CPH6302 CPH6402 IOUT  2 A, VIN  16 V Si3455DV Si3454DV IOUT  1.6 A, VIN  16 V CPH6303 CPH6403 IOUT  2 A, VIN  8 V Si3441DV Si3442DV IOUT  1.4 A, VIN  6 V CPH6303 CPH6403 IOUT  2 A, VIN  8 V Si3441DV Si3442DV IOUT  1.4 A, VIN  6 V CPH6302 CPH6402 IOUT  2 A, VIN  16 V Si3455DV Si3454DV IOUT  1.6 A, VIN  16 V 47 F  2 47 F, 0.1 F IOUT  1.6 A, VIN  16 V CPH6302 CPH6402 IOUT  2 A, VIN  16 V Si3455DV Si3454DV IOUT  1.6 A, VIN  16 V CPH6303 CPH6403 IOUT  3 A, VIN  8 V CPH6302 CPH6402 IOUT  3 A, VIN  16 V STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series External Parts List for Ripple Data Table 5 External Parts for Input Voltage vs. Ripple Voltage Characteristics Data No. (27) (28) Product Name Output Inductor Voltage S-8533A15AFT 1.5 V (29) (30) (31) S-8533A33AFT 3.3 V CDRH104R/22 H (32) (33) (34) S-8533A50AFT 5.0 V Transistor Transistor Output Input P-channel N-channel Capacitor Capacitor Application Condition CPH6303 CPH6403 IOUT  2 A, VIN  8 V Si3441DV Si3442DV IOUT  1.4 A, VIN  6 V CPH6303 CPH6403 IOUT  2 A, VIN  8 V Si3441DV Si3442DV CPH6302 CPH6402 Si3455DV Si3454DV 47 F  2 47 F, 0.1 F IOUT  1.4 A, VIN  6 V IOUT  2 A, VIN  16 V IOUT  1.6 A, VIN  16 V CPH6302 CPH6402 IOUT  2 A, VIN  16 V Si3455DV Si3454DV IOUT  1.6 A, VIN  16 V Performance Data for Parts The following shows the performance of external parts. Table 6 Performance of External Parts Parts Product Name Manufacturer Characteristics L Value DC Resistance Maximum Current 10 H 0.019  4.0 A 12.0 mm typ. 8.0 mm max. 12.3 mm max. 47 H 22 H 10 H 0.095  0.054  0.026  1.9 A 2.5 A 3.8 A 10.2 mm typ. 4.0 mm max. 10.5 mm max. CDRH125 Sumida Corporation Inductor CDRH104R Diameter Height Matsushita Electric Forward current 1.5 A (@VF = 0.5 V) Industrial Co., Ltd Nichicon Output F93 Corporation Capacity VGS = 10 V max., ID = 4 A max., Vth = 0.4 V min., CPH6303 Ciss = 820 pF typ., RDS(ON) = 0.090  max. (VGS = 4 V), CPH6 package Sanyo Electric Co., Ltd VGS = 20 V max., ID = 3 A max., Vth = 1.0 V min., External Ciss = 300 pF typ., RDS(ON) = 0.145  max. (VGS = 10 V), CPH6302 transistor CPH6 package (P-channel FET) VGS = 8 V max., ID = 3.3 A max., Vth = 0.45 V min., Si3441DV RDS(ON) = 0.10  max. (VGS = 4.5 V), TSOP-6 package Vishay Silliconix VGS = 20 V max., ID = 3.5 A max., Vth = 1.0 V min., Si3455DV RDS(ON) = 0.100  max. (VGS = 10 V), TSOP-6 package VGS = 10 V max., ID = 6 A max., Vth = 0.4 V min., CPH6403 Ciss = 700 pF typ., RDS(ON) = 0.038  max. (VGS= 4 V), CPH6 package Sanyo Electric Co., Ltd VGS = 24 V max., ID = 4 A max., Vth = 1.0 V min., External Ciss = 240 pF typ., RDS(ON) = 0.75  max. (VGS= 10 V), CPH6402 transistor CPH6 package (N-channel FET) VGS = 8 V max., ID = 4.0 A max., Vth = 0.6 V min., Si3442DV RDS(ON) = 0.07  max. (VGS = 4.5 V), TSOP-6 package Vishay Silliconix VGS = 20 V max., ID = 4.2 A max., Vth = 1.0 V min., Si3454DV RDS(ON) = 0.065  max. (VGS = 10 V), TSOP-6 package Caution The value of each characteristic in Table 6 depends on the materials prepared by each manufacturer, however, confirm the specifications by referring to respective materials when using any of the above. Diode MA737 23 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series 2. Output Current (IOUT) vs. Efficiency () Characteristics The following shows the actual output current (IOUT) vs. efficiency (η) characteristics when the S-8533 Series is used under conditions (1) to (26) in Table 4. 100 95 90 85 80 75 70 65 60 55 50 (2) S-8533A15AFT (Si3441DV/Si3442DV) V IN  2.7 V Efficiency  (%) Efficiency  (%) (1) S-8533A15AFT (CPH6303/CPH6403) 5.0 V 1 10 100 Output current (mA) 1000 Efficiency  (%) Efficiency  (%) 7.0 V 4.95 V 100 Output current (mA) 1000 10000 100 95 90 85 80 75 70 65 V IN  4.0 V 4.95 V 60 55 50 10 100 Output current (mA) 100 95 90 1000 10000 10 V 60 55 50 1 10 100 Output current (mA) 1000 Efficiency  (%) 16 V 10 100 Output current (mA) 1000 10000 10 V 10 100 Output current (mA) 1000 10000 (8) S-8533A50AFT (Si3454DV/Si3455DV) 10 V 1 1000 V IN  4.95 V 1 V IN  6.0 V 7.5 V 100 95 90 85 80 75 70 65 60 55 50 10000 (7) S-8533A50AFT (CPH6302/CPH6402) 100 95 90 85 80 75 70 65 60 55 50 100 Output current (mA) (6) S-8533A33AFT (Si3454DV/Si3455DV) V IN  4.95 V 85 80 75 70 65 10 1 Efficiency  (%) Efficiency  (%) 10 (4) S-8533A33AFT (Si3441DV/Si3442DV) (5) S-8533A33AFT (CPH6302/CPH6402) Efficiency  (%) 5.0 V 1 V IN  4.0 V 1 24 V IN  2.7 V 10000 (3) S-8533A33AFT (CPH6303/CPH6403) 100 95 90 85 80 75 70 65 60 55 50 100 95 90 85 80 75 70 65 60 55 50 10000 100 95 90 85 V IN  6.0 V 80 75 70 65 60 55 50 7.5 V 16 V 10 V 1 10 100 Output current (mA) 1000 10000 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series (9) S-8533A15AFT (CPH6303/CPH6403) (10) S-8533A15AFT (Si3441DV/Si3442DV) 100 100 95 95 90 Efficiency  (%) 85 Efficiency  (%) 90 V IN  2.7 V 80 75 70 65 5.0 V 60 55 75 70 65 10 100 Output current (mA) 1000 10000 (11) S-8533A33AFT (CPH6303/CPH6403) 1 Efficiency  (%) V IN  4.0 V 95 90 85 80 75 70 65 60 55 50 7.0 V 4.95 V 1 10 100 Output current (mA) 1000 10 100 Output current (mA) 1000 10000 (12) S-8533A33AFT (Si3441DV/Si3442DV) 100 100 95 90 85 80 75 70 65 60 55 50 10000 (13) S-8533A33AFT (CPH6302/CPH6402) V IN  4.0 V 4.95 V 1 10 100 Output current (mA) 1000 10000 (14) S-8533A33AFT (Si3454DV/Si3455DV) 100 100 V IN  4.95 V 95 90 85 80 Efficiency  (%) Efficiency  (%) 5.0 V 60 50 1 Efficiency  (%) 80 55 50 10 V 75 70 65 60 55 50 10 1 100 Output current (mA) 1000 100 95 90 85 80 75 70 65 60 55 50 Efficiency  (%) 16 V 10 100 Output current (mA) 1000 10 V 10 100 Output current (mA) 1000 10000 (16) S-8533A50AFT (Si3454DV/Si3455DV) 10 V 1 V IN  4.95 V 1 V IN  6.0 V 7.5 V 95 90 85 80 75 70 65 60 55 50 10000 (15) S-8533A50AFT (CPH6302/CPH6402) Efficiency  (%) V IN  2.7 V 85 10000 100 95 90 85 80 75 70 65 60 55 50 V IN  6.0 V 7.5 V 16 V 10 V 1 10 100 Output current (mA) 1000 10000 25 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series (17) S-8533A15AFT (CPH6303/CPH6403) V IN  2.7 V Efficiency  (%) Efficiency  (%) 100 95 90 85 80 75 70 65 60 55 50 (18) S-8533A15AFT (Si3441DV/Si3442DV) 5.0 V 1 10 100 Output current (mA) 1000 10000 (19) S-8533A33AFT (CPH6303/CPH6403) 7.0 V 4.95 V 55 50 10 1 100 Output current (mA) 1000 Efficiency  (%) Efficiency  (%) 10 V 100 Output current (mA) 1000 10 100 Output current (mA) 1000 10000 V IN  4.95 V 10 V 10 1 100 Output current (mA) 1000 10000 (24) S-8533A50AFT (Si3454DV/Si3455DV) 100 100 95 90 85 80 75 70 65 60 55 50 V IN  6.0 V 7.5 V Efficiency  (%) Efficiency  (%) 10000 4.95 V 100 95 90 85 80 75 70 65 60 55 50 10000 (23) S-8533A50AFT (CPH6302/CPH6402) 16 V 10 V 1 10 100 Output current (mA) 26 1000 (22) S-8533A33AFT (Si3454DV/Si3455DV) V IN  4.95 V 10 100 Output current (mA) V IN  4.0 V 1 100 1 10 100 95 90 85 80 75 70 65 60 55 50 10000 (21) S-8533A33AFT (CPH6302/CPH6402) 95 90 85 80 75 70 65 60 55 50 5.0 V (20) S-8533A33AFT (Si3441DV/Si3442DV) V IN  4.0 V 85 80 75 70 65 60 V IN  2.7 V 1 Efficiency  (%) Efficiency  (%) 100 95 90 100 95 90 85 80 75 70 65 60 55 50 1000 10000 95 90 85 80 75 70 65 60 55 50 V IN  6.0 V 7.5 V 16 V 10 V 1 10 100 Output current (mA) 1000 10000 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series (25) S-8533A33AFT (CPH6303/CPH6403) (26) S-8533A33AFT (CPH6302/CPH6402) 100 100 95 V IN  10 V 90 85 Efficiency  (%) Efficiency  (%) 95 V IN  4.95 V 90 80 75 70 65 60 7.0 V 85 80 75 70 65 13 V 60 55 55 50 50 1 10 100 Output current (mA) 1000 10000 1 10 100 Output current (mA) 1000 10000 27 STEP-DOWN, SYNCHRONOUS PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.3.0_02 S-8533 Series 3. Output Current (IOUT) vs. Ripple Voltage (Vr) Characteristics The following shows the actual output current (IOUT) vs. ripple voltage (Vr) characteristics when the S-8533 Series is used under conditions (27) to (34) in Table 5. (27) S-8533A15AFT (CPH6303/CPH6403) 50 5.0 V V IN  2.7 V 25 20 15 10 5 0 Ripple voltage Vr( mV) Ripple voltage Vr (mV) 50 45 40 35 30 (28) S-8533A15AFT (Si3441DV/Si3442DV) 1 10 100 Output current (mA) 1000 10000 4.95 V V IN  4.0 V 1 10 100 Output current (mA) 7.0 V 1000 10000 Ripple voltage Vr( mV) Ripple voltage Vr (mV) 10 V 5 0 10 100 Output current (mA) 1000 1 28 10 100 Output current (mA) 1000 10000 100 Output current (mA) 1000 10000 50 45 40 35 30 10 V V IN  4.95 V 25 20 15 10 5 0 10 100 Output current (mA) 1000 10000 (34) S-8533A50AFT (Si3454DV/Si3455DV) 16 V 10 V 10 1 Ripple voltage Vr( mV) Ripple voltage Vr (mV) V IN  6.0 V 7.5 V 1000 4.95 V V IN  4.0 V 10000 (33) S-8533A50AFT (CPH6302/CPH6402) 50 45 40 35 30 25 20 15 10 5 0 100 Output current (mA) (32) S-8533A33AFT (Si3454DV/Si3455DV) 20 15 10 1 50 45 40 35 30 25 20 15 10 5 0 1 50 45 V IN  4.95 V 10 (30) S-8533A33AFT (Si3441DV/Si3442DV) (31) S-8533A33AFT (CPH6302/CPH6402) 40 35 30 25 5.0 V V IN  2.7 V 1 Ripple voltage Vr( mV) Ripple voltage Vr (mV) (29) S-8533A33AFT (CPH6303/CPH6403) 50 45 40 35 30 25 20 15 10 5 0 45 40 35 30 25 20 15 10 5 0 10000 50 45 40 35 30 25 20 15 10 5 0 V IN  6.0 V 1 10 7.5 V 16 V 10 V 100 Output current (mA) 1000 10000 +0.3 3.00 -0.2 8 5 1 4 0.17±0.05 0.2±0.1 0.65 No. FT008-A-P-SD-1.2 TITLE TSSOP8-E-PKG Dimensions No. FT008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.05 ø1.55±0.05 0.3±0.05 +0.1 8.0±0.1 ø1.55 -0.05 (4.4) +0.4 6.6 -0.2 1 8 4 5 Feed direction No. FT008-E-C-SD-1.0 TITLE TSSOP8-E-Carrier Tape FT008-E-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 13.4±1.0 17.5±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.5 No. FT008-E-R-SD-1.0 TITLE TSSOP8-E-Reel No. FT008-E-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 13.4±1.0 17.5±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.5 No. FT008-E-R-S1-1.0 TITLE TSSOP8-E-Reel FT008-E-R-S1-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8533A125FT-TB-U
物料型号:S-8533 Series 器件简介:S-8533系列是一款同步整流系统的PWM控制CMOS降压开关稳压器控制器,具有高效率(典型值94%)和高振荡频率(典型值300kHz),适用于实现高效率的降压开关稳压器,适合用于便携式设备的主电源。
引脚分配:S-8533采用8引脚TSSOP封装,包括输出电压引脚(VOUT)、关闭引脚(ON/OFF)、软启动电容连接引脚(CSS)、地引脚(VSS)、外部N沟道连接引脚(NDRV)、外部P沟道连接引脚(PDRV)、供电引脚(VIN)和一个无连接引脚(NC)。
参数特性: - 输入电压范围:2.7V至16.0V - 输出电压:1.25V至6.0V,可步进0.1V选择 - 输出电压精度:±2.0% - 软启动功能:由外部电容(CSS)设置 - 关闭功能:通过ON/OFF引脚控制
功能详解: - 同步整流系统:实现高效率,最大占空比可达100% - PWM控制:具有低电流消耗,通过脉宽调制减少开关时的纹波电压 - 软启动功能:防止开机或ON/OFF引脚设置为高时输出电压过冲 - 关断功能:通过ON/OFF引脚实现,可大幅降低电流消耗
应用信息: - 硬盘和DVD驱动器的恒压电源 - 便携式设备的电源,如数码相机、PDA、电子记事本和手机 - 笔记本电脑和外围设备的主电源或辅助电源 - 相机、视频设备和通信设备的恒压电源
封装信息:8-Pin TSSOP封装,具有铅免费、100%锡和无卤化物的特点。
S-8533A125FT-TB-U 价格&库存
很抱歉,暂时无法提供与“S-8533A125FT-TB-U”相匹配的价格&库存,您可以联系我们找货
