T30UXDAQ8
T30UXDAQ8
    BANNER(邦纳)
    Module
    ULTRASONIC 100MM-1M NPN/PNP
T30UXDAQ8 数据手册
U-GAGE® T30UX Series with Discrete Output Datasheet Ultrasonic sensor with TEACH-mode configuration • • • • • • • 1, 2, and 3 m (3.28, 6.56, and 9.84 ft) versions with short dead zones (10% of max range) Built-in temperature compensation Fast, easy-to-use TEACH-Mode programming; no potentiometer adjustments Remote TEACH for security and convenience Wide operating temperature range of –40 °C to +70 °C (–40 °F to +158 °F) Outputs can be set for either NPN or PNP, Normally Open (N.O.) or Normally Closed (N.C.) Compact, self-contained, right-angle sensor package with fully encapsulated electronics Models Range and Frequency Models Cable 1 Discrete Output Response Time 100 mm to 1 m (3.9 in to 39 in) T30UXDA 45 ms 224 kHz 200 mm to 2 m (7.8 in to 78 in) T30UXDB 174 kHz Standard 2 m (6.5 ft) cable NPN, PNP, NO, NC, Selectable 92 ms 300 mm to 3 m (11.8 in to 118 in) T30UXDC 135 ms 114 kHz WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Overview The U-GAGE® T30UX is an easy-to-use ultrasonic sensor with extended range and built-in temperature compensation. Simple push button configuration provides flexibility for a variety of applications. Easy-to-see indicator LEDs communicate the status of the sensor. The Green “Power” LED ON indicates that the sensor is in Run Mode (the sensor’s normal operating condition). The Red “Signal” LED indicates the target signal strength. The Amber “Output” LED indicates that the output is enabled and the sensor is receiving a signal within the window limits (depending on NO or NC). The Amber “Mode” LED indicates the currently selected mode. Figure 1. Features Power ON/OFF LED (Green) Signal Strength LED (Red) Discrete Output LED (Amber) Mode LEDs (Amber) 1 Only standard 2 m (6.5 ft) cable models are listed. To order the 4-pin M12 integral QD, add the suffix “Q8” to the model number (for example, T30UXDAQ8). To order the 150 mm (6 in) PUR cable with a 4-pin M12 QD, add the suffix “QPMA” to the model number (for example, T30UXDAQPMA). To order the 9 m (30 ft) cable, add the suffix “W/30” to the model number (for example, T30UXDA W/30). A model with a QD connector requires a mating cable. See Accessories on page 11. Original Document 138381 Rev. I 29 November 2021 138381 U-GAGE® T30UX Series with Discrete Output Principles of Operation Ultrasonic sensors emit one or multiple pulses of ultrasonic energy, which travel through the air at the speed of sound. A portion of this energy reflects off the target and travels back to the sensor. The sensor measures the total time required for the energy to reach the target and return to the sensor. The distance to the object is then calculated using the following formula: D = ct ÷ 2 D = distance from the sensor to the target c = speed of sound in air t = transit time for the ultrasonic pulse To improve accuracy, an ultrasonic sensor may average the results of several pulses before outputting a new value. Temperature Effects The speed of sound is dependent upon the composition, pressure and temperature of the gas in which it is traveling. For most ultrasonic applications, the composition and pressure of the gas are relatively fixed, while the temperature may fluctuate. In air, the speed of sound varies with temperature according to the following approximation: In metric units: In English units: Cm/s = 20 √273 + TC Cft/s = 49 √460 + TF Cm/s = speed of sound in meters per second Cft/s = speed of sound in feet per second TC = temperature in °C TF = temperature in °F Temperature Compensation Changes in air temperature affect the speed of sound, which in turn affects the total time for the echo measured by the sensor. An increase in air temperature shifts both sensing window limits closer to the sensor. Conversely, a decrease in air temperature shifts both limits farther away from the sensor. This shift is approximately 3.5% of the limit distance for a 20° C change in temperature. The T30UX series ultrasonic sensors are temperature compensated. This reduces the error due to temperature by about 90%. The sensor will maintain its window limits to within 2.2% over the -40° to +70° C (−40° to +158° F) operating range of the sensor. Note: • • Exposure to direct sunlight can affect the sensor’s ability to accurately compensate for changes in temperature. If the sensor is measuring across a temperature gradient, the compensation will be less effective. Configuration Instructions Sensor Configuration Two TEACH methods may be used to configure the sensor: • Teach individual minimum and maximum limits, or • Use Auto-Window feature to center a sensing window around the taught position. The sensor may be configured either via its push button, or via a remote switch. Remote configuration also may be used to disable the push button, preventing unauthorized personnel from adjusting the configuration settings. To access this feature, connect the white wire of the sensor to 0V dc, with a remote configuration switch between the sensor and the voltage. Configuration is accomplished by following the sequence of input pulses. The duration of each pulse (corresponding to a push button “click”), and the period between multiple pulses, are as “T”: 0.04 seconds < T < 0.8 seconds Remote line configuration requires a greater than 1 second pause between pulse sequences. Mode Setup - Output Configuration Sensors can be set up for either NPN (sinking) or PNP (sourcing). In addition, the user can select between Normally Open (N.O.) and Normally Closed (N.C.) operation. Normally Open is defined as the output energizing when the target is present. Normally Closed is defined as the output energizing when the target is absent (see Teaching Minimum and Maximum Limits on page 3). A button click or pulse on the remote line is: 0.04 s < T < 0.8 s. 1. Enter Output Configuration setup mode. Method Action Result Push Button Push and hold the MODE button for more than 2 seconds. Power LED: OFF T Remote Input Double-pulse the remote line. 2 T T www.bannerengineering.com - Tel: + 1 888 373 6767 Mode LED: Flashing Amber shows previously selected mode Power LED: OFF Mode LED: Flashing Amber shows previously selected mode P/N 138381 Rev. I U-GAGE® T30UX Series with Discrete Output 2. Select the output. Method Action Push Button Click the MODE button to cycle to select the output configuration: • NPN - Normally Open • NPN - Normally Closed • PNP - Normally Open • PNP - Normally Closed • • • • Remote Input Result Single-pulse for NPN - Normally Open Double-pulse for NPN - Normally Closed Triple-pulse for PNP - Normally Open Quad-pulse for PNP - Normally Closed Power LED: OFF Mode LED: Flashes to indicate currently selected mode (120 second time out 2) Power LED: ON Green Mode LED: ON to indicate currently selected mode (Sensor returns to RUN mode) 3. Save and return to Run mode. Method Action Result Power LED: ON Green Push Button Push and hold the MODE button for more than 2 seconds. Remote Input No action required; the sensor returns to Run Mode automatically. Mode LED: ON Amber for selected mode None Teaching Minimum and Maximum Limits General Notes on Teaching • The sensor returns to RUN mode if the first TEACH condition is not registered within 120 seconds after the initial 2 second hold on the Discrete button. • To exit TEACH mode without saving any changes, press and hold the Discrete button or remote line longer than 2 seconds (before teaching the second limit). The sensor reverts to the last saved limits. • After the first limit is taught, the sensor remains in TEACH mode until the TEACH sequence is finished or exited by a 2 second hold on the Discrete button or remote line. • A button click or pulse on the remote line is: 0.04 s < T < 0.8 s. Figure 2. Teaching independent minimum and maximum limits Normally Open Operation Minimum Limit Output OFF Maximum Limit Output ON Output OFF Normally Closed Operation Minimum Limit Output ON Maximum Limit Output OFF Output ON 1. Enter TEACH mode. Method Action Result Push Button Push and hold the Discrete push button longer than 2 seconds. Remote Input No action required; sensor is ready for first limit teach. Power LED: OFF Output LED: ON None 2 The sensor will revert to previously saved configuration and return to RUN mode if TEACH is inactive for 120 seconds after the initial 2 second hold on push button P/N 138381 Rev. I www.bannerengineering.com - Tel: + 1 888 373 6767 3 U-GAGE® T30UX Series with Discrete Output 2. Teach the first limit. Method Action Result Position the target for the first limit (120 second time out). Signal LED: Must be ON Red or Flashing Red 3 “Click” the Discrete button. Teach Accepted Power LED: OFF Output LED: Flashing Teach Not Accepted Output LED: ON Position the target for the first limit. Signal LED: Must be ON Red or Flashing Red 3 Push Button Remote Input T Single-pulse the remote line. Teach Accepted Power LED: OFF Output LED: Flashing Teach Not Accepted Power LED: ON 3. Teach the second limit. Method Push Button Action Result Position the target for the second limit (no time out). Signal LED: Must be ON Red or Flashing Red “Click” the Discrete button. Teach Accepted Output LED: ON or OFF, depending on NO or NC Mode Power LED: ON Teach Not Accepted Output LED: Flashing Power LED: OFF Position the target for the second limit (no time out). Signal LED: Must be ON Red or Flashing Red. Remote Input T Single-pulse the remote line. Teach Accepted Output LED: ON or OFF, depending on NO or NC Mode Power LED: ON Teach Not Accepted Output LED: Flashing Power LED: OFF Teaching Limits Using the Auto-Window Feature Teaching the same limit twice automatically centers a window on the taught position (see Figure 4 on page 5 for window sizes). General Notes on Teaching • The sensor returns to RUN mode if the TEACH condition is not registered within 120 seconds after the initial 2 second hold on the Discrete button. • To exit TEACH mode without saving any changes, press and hold the Discrete button or remote line longer than 2 seconds (before teaching the second limit). The sensor will revert to the last saved limits. • After the first limit is taught, the sensor remains in TEACH mode until the TEACH sequence is finished or exited by a 2 second hold on the Discrete button or remote line. • A button click or pulse on the remote line is: 0.04 s < T < 0.8 s. 3 Sensor will not Teach or indicate “Teach Not Accepted” when there is no signal present (Signal LED Red or Flashing Red) 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 138381 Rev. I U-GAGE® T30UX Series with Discrete Output Figure 3. Using the Auto-Window feature for teaching each output Figure 4. Window Size Normally Open Operation Models Window "A" suffix ± 10 mm (0.4 in) "B" suffix ± 20 mm (0.8 in) "C" suffix ± 30 mm (1.2 in) Taught Position Position Position Output OFF Output ON Output OFF Normally Closed Operation Taught Position Position Position Output ON Output OFF Output ON 1. Enter TEACH mode. Method Action Result Push Button Push and hold the Discrete button longer than 2 seconds. Remote Input No action required; the sensor is ready for the first limit teach. Power LED: OFF Output LED: ON None 2. Teach the first limit. Method Action Result Position the target for the center of window (120 second time out). Signal LED: Must be ON Red or Flashing Red 4 Click the Discrete push button. Teach Accepted Power LED: OFF Output LED: Flashing Teach Not Accepted Output LED: ON Position the target for the center of window. Signal LED: Must be ON Red or Flashing Red 4 Push Button Single-pulse the remote line. Remote Input T Teach Accepted Power LED: OFF Output LED: Flashing Teach Not Accepted Output LED: ON 3. Re-teach the limit. Method Push Button Action Result Without moving the target, “click” the Discrete push button again Teach Accepted Output LED: ON or OFF, depending on NO or NC Mode Power LED: ON Teach Not Accepted Output LED: Flashing Power LED: OFF Without moving the target, single-pulse the remote line again. Remote Input T Teach Accepted Output LED: ON or OFF, depending on NO or NC Mode Power LED: ON Teach Not Accepted Output LED: Flashing Power LED: OFF 4 Sensor will not Teach or indicate “Teach Not Accepted” when there is no signal present (Signal LED Red or Flashing Red) P/N 138381 Rev. I www.bannerengineering.com - Tel: + 1 888 373 6767 5 U-GAGE® T30UX Series with Discrete Output Figure 5. An application for the Auto-Window feature (retroreflective mode) Taught Position (background surface) Near Range Sensor Output ON Any object in this area will switch the output, whether or not the object returns a good signal to the sensor. Sensor Output OFF Output OFF Output ON Sensing Distance Remote Line TEACH General Notes • Run Mode is the sensor’s normal operating condition • • • • • 6 T The duration of each Pulse is defined as “T”: 0.04 < T < 0.8 s A Hold will exit TEACH MODE and return to Run Mode with previously saved changes. The duration of a Hold is: T > 2 s A Timeout will occur if a condition is not registered within 120 seconds, causing the sensor to return to Run Mode (during sensor configuration only) Sensor configuration user feedback shown on Green LED. See flowchart. The Red Signal LED will be ON whenever the target is in view. www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 138381 Rev. I U-GAGE® T30UX Series with Discrete Output Run Mode Power LED ON, All other LEDs in normal operating condition 1x Exit No valid target TEACH MODE (1 st pulse teaches 1st limit) Power LED OFF, Output LED Flashing 2 s Hold 1x Teach 2nd limit No valid target Power LED ON Output LED ON or OFF (depending on NO or NC) 2x Output Configuration Menu Power LED OFF. Mode LED Flashing 1x NPN/NO NPN/NO LED ON 2x NPN/NC NPN/NC LED ON 3x PNO/NO (default) , PNP/NO LED ON 4x PNP/NC PNP/NC LED ON 2 s Hold 120 second Timeout 3x Advanced Sensor Configuration Menu Power LED OFF, Mode LEDs OFF 1x Push button enabled (default ) Flash Power 1x, Repeat twice Push button disabled Flash Power 2x, Repeat twice Temp. comp enabled (default ) Flash Power 3x, Repeat twice Temp. comp disabled Flash Power 4x, Repeat twice 2x 3x 4x 2 s Hold 120 second Timeout 4x Toggle push button enable /disable (legacy method ) Flash Power: 1x for enabled , Repeat twice 2x for disabled, Repeat twice 8x Restore factory defaults P/N 138381 Rev. I All LEDs off f or 1 s www.bannerengineering.com - Tel: + 1 888 373 6767 7 U-GAGE® T30UX Series with Discrete Output Wiring Cabled and quick disconnect (QD) connector wiring is functionally identical. Shielded cordsets are recommended for all QD models. Figure 6. NPN (sinking) output selected 1 1 + 12-30V dc – 3 4 Figure 7. PNP (sourcing) output selected 2 + 12-30V dc – 3 4 Load Remote Programming (N.O.) Shield* Shield* * It is recommended that the shield wire be connected to either earth ground or DC common. * It is recommended that the shield wire be connected to either earth ground or DC common. 2 3 1 4 Load 2 Remote Programming (N.O.) Figure 8. 4-pin M12 male quick disconnect connector Wiring Key 1 = Brown 2 = White 3 = Blue 4 = Black Specifications Sensing Range “A” suffix models: 100 mm to 1 m (3.9 in to 39 in) “B” suffix models: 200 mm to 2 m (7.8 in to 78 in) “C” suffix models: 300 mm to 3 m (11.8 in to 118 in) Sensing Hysteresis “A” suffix models: 2 mm “B” suffix models: 3 mm “C” suffix models: 4 mm Ultrasonic Frequency “A” suffix models: 224 kHz “B” suffix models: 174 kHz “C” suffix models: 114 kHz Minimum Window Size 10 mm (0.4 in) Supply Voltage 10 to 30 V DC (10% maximum ripple) at 40 mA, exclusive of load Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Discrete (switched) output models: SPST solid-state switch. Configurable as NPN (sinking) or PNP (sourcing) via Mode push button. Normally Open (NO) or Normally Closed (NC) operation is also selectable via Mode push button (see Mode Setup - Output Configuration on page 2). The default setting is PNP/NO Output Rating Discrete output models: 100 mA max. OFF-state leakage current: NPN: < 200 μA at 30V dc (see NOTE 1); PNP: < 10 μA at 30V dc ON-state saturation voltage: NPN: < 1.6V at 100 mA; PNP: < 3V at 100 mA Output Protection Circuitry Protected against short circuit conditions Repeatability “A” suffix models: 0.1% of distance (0.5 mm min.) “B” suffix models: 0.1% of distance (1.0 mm min.) “C” suffix models: 0.1% of distance (1.5 mm min.) 8 Adjustments Sensing window limits: TEACH-Mode of near and far window limits may be set using the push button or remotely via TEACH input. Output Configuration: NPN, PNP, Normally Open (NO), Normally Closed (NC) select (see Mode Setup - Output Configuration on page 2 or Remote Line TEACH on page 6). Advanced configuration options: Push button enabled/disabled, temperature compensation enabled/disabled (see Remote Line TEACH on page 6) Construction Housing: PBT polyester Push buttons: polyester Transducer: epoxy /ceramic composite Environmental Rating Leakproof design, ratedIP67 (NEMA 6) Connections 2 m (6.5 ft) or 9 m (30 ft) shielded 4-conductor (with drain) PVC cable, 150 mm (6 in) PUR cable with an M12 connector (QPMA), or 4-pin integral M12 connector (Q8) Temperature Effect 0.02% of distance/°C Delay at Power-up 500 ms Output Response Time “A” suffix models: 45 ms “B” suffix models: 92 ms “C” suffix models: 135 ms www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 138381 Rev. I U-GAGE® T30UX Series with Discrete Output Required Overcurrent Protection Operating Conditions –40 °C to +70 °C (–40 °F to +158 °F) 95% at +50 °C maximum relative humidity (non-condensing) WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements method 201A (vibration: 10 to 60 Hz max., double amplitude 0.06 in, max acceleration 10G). Also meets IEC 947-5-2; 30G 11 ms duration, half sine wave Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Certifications Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Application Note The temperature warmup drift upon power-up is less than 1% of the sensing distance. NOTE 1: NPN < 200 μA for load impedance > 3 kΩ; for load current of 100 mA, leakage < 1% of load current Performance Curves With Plate Target (Typical) 1-Meter Models 2-Meter Models 200 mm 8.0" 150 mm 6.0" 100 mm 100 x 100 mm 2.0" 50 mm WIDTH 4.0" 0 0 50 mm 2.0" 100 mm 4.0" 150 mm 6.0" 200 mm 8.0" 1000 mm (40.0") 0 200 mm (8.0") 400 mm (16.0") 600 mm (24.0") 800 mm (32.0") Width 3-Meter Models 400 mm 16.0" 400 mm 16.0" 300 mm 12.0" 300 mm 12.0" 200 mm 8.0" 200 mm 100 mm 4.0" 100 mm 100 x 100 mm 0 0 Width 100 x 100 mm 8.0" 4.0" 0 0 100 mm 4.0" 100 mm 4.0" 200 mm 8.0" 200 mm 8.0" 300 mm 12.0" 300 mm 16.0" 2000 mm (80.0") 400 mm 400 mm 0 400 mm (16.0") 800 mm (32.0") 1200 mm (48.0") 1600 mm (64.0" 12.0" 0 600 mm (24.0") Distance DISTANCE 1200 mm (48.0") 1800 mm (72.0") 2400 mm (96.0") 16.0" 3000 mm (120.0") Distance With Rod Target (Typical) 1-Meter Models 2-Meter Models 200 mm 8.0" 150 mm 6.0" 25 mm Rod 100 mm WIDTH 50 mm 10 mm Rod 0 50 mm 2.0" 100 mm 4.0" 150 mm 200 mm 6.0" 0 200 mm (8.0") P/N 138381 Rev. I 400 mm 600 mm (16.0") (24.0") DISTANCE 800 mm (32.0") 8.0" 1000 mm (40.0") 400 mm 16.0" 300 mm 12.0" 300 mm 12.0" 8.0" 200 mm 4.0" 100 mm 25 mm Rod 100 mm 2.0" 0 16.0" 200 mm 4.0" 3-Meter Models 400 mm Width 10 mm Rod 0 0 Width 25 mm Rod 8.0" 4.0" 0 0 10 mm Rod 100 mm 4.0" 100 mm 4.0" 200 mm 8.0" 200 mm 8.0" 300 mm 12.0" 300 mm 12.0" 400 mm 16.0" 2000 mm (80.0") 400 mm 0 400 mm (16.0") 800 mm (32.0") 1200 mm (48.0") 1600 mm (64.0") Distance www.bannerengineering.com - Tel: + 1 888 373 6767 0 600 mm (24.0") 1200 mm (48.0") 1800 mm (72.0") 2400 mm (96.0") 16.0" 3000 mm (120.0") Distance 9 U-GAGE® T30UX Series with Discrete Output Maximum Target Rotation Angle 30 1 meter Target Rotation 2 meter Target Rotation 3 meter Target Rotation 20 10 Target Rotation (Degrees) 0 10 20 30 0 500 mm (20.0") 1000 mm (40.0") 1500 mm (60.0") 2000 mm (80.0") 2500 mm (100.0") 3000 mm (120.0") Distance Dimensions 45.0 [1.77"] 22.5 [0.89"] Ø40.2 [1.58"] 51.1 [2.01"] 63.6 [2.50"] 23.4 [0.92"] M12 x 1 M30 x 1.5 Max. Torque 2.3 Nm (20 in-lbs.) ø 15 [0.6"] Locknut (included with all models) Washer (included with all models) 10 [0.4"] M30 x 1.5 Ø40 [1.6"] Ø39.6 [1.56"] Ø30 [1.2"] 3x 36.1 [1.42"] 10 1.6 [0.06"] 5 [0.2"] www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 138381 Rev. I U-GAGE® T30UX Series with Discrete Output Accessories Quick-Disconnect Cables 4-Pin Threaded M12 Cordsets with Shield—Single Ended Model Length MQDEC2-406 2 m (6.56 ft) MQDEC2-415 5 m (16.4 ft) Style Dimensions Pinout (Female) 44 Typ. 1 Straight MQDEC2-430 9 m (29.5 ft) MQDEC2-406RA 2 m (6.56 ft) MQDEC2-415RA 5 m (16.4 ft) M12 x 1 ø 14.5 32 Typ. [1.26"] MQDEC2-430RA 3 4 2 30 Typ. [1.18"] Right-Angle 2 1 1 = Brown 2 = White 3 = Blue 4 = Black 3 4 9 m (29.5 ft) M12 x 1 ø 14.5 [0.57"] Brackets All measurements are in mm. SMB30A • Right-angle bracket with curved slot for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor • 12-ga. stainless steel 45 C 61 B A 69 B 39 A Hole center spacing: A = 36.0 Hole size: A = ø 5.0, B = ø 15.0 83.2 36.3 68.9 B SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included A Bolt thread: SMB30FA, A= 3/8 - 16 x 2 in; SMB30FAM10, A= M10 - 1.5 x 50 Hole size: B= ø 30.1 P/N 138381 Rev. I 51 25 Hole center spacing: A to B=40 Hole size: A=ø 6.3, B= 27.1 x 6.3, C=ø 30.5 SMB30FA • Swivel bracket with tilt and pan movement for precise adjustment • Mounting hole for 30 mm sensor • 12-ga. 304 stainless steel • Easy sensor mounting to extrude rail T-slot • Metric and inch size bolt available SMB1815SF • Swivel with set screws for mounting sensors by the cable hub • Black reinforced thermoplastic polyester • Stainless steel swivel locking hardware and hex wrench included 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 www.bannerengineering.com - Tel: + 1 888 373 6767 11 U-GAGE® T30UX Series with Discrete Output Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
T30UXDAQ8 价格&库存
很抱歉,暂时无法提供与“T30UXDAQ8”相匹配的价格&库存,您可以联系我们找货
