NJ2-12GM40-E2-V1
NJ2-12GM40-E2-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M12
    INDUCTIVE SEN 2MM PNP
NJ2-12GM40-E2-V1 数据手册
Inductive sensor NJ2-12GM40-E2-V1 < 2 mm flush Dimensions 50 28 4 M12x1 17 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 282942_eng.pdf LED Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation 2 mm flush Output polarity DC Assured operating distance sa 0 ... 1.62 mm Actual operating distance sr 1.8 ... 2.2 mm typ. Reduction factor rAl 0.23 Reduction factor rCu 0.21 Reduction factor r304 0.7 Output type 3-wire Nominal ratings Operating voltage UB 10 ... 60 V Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NJ2-12GM40-E2-V1 Technical Data Switching frequency f 0 ... 3000 Hz Hysteresis H 1 ... 10 typ. 3 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Ud 1.2 ... 2.5 V Operating current IL 0 ... 200 mA Off-state current Ir ≤ 0.5 mA No-load supply current I0 ≤ 9 mA Time delay before availability tv ≤ 20 ms Voltage drop at IL Voltage drop IL = 100 mA, switching element on Switching state indicator LED, yellow Functional safety related parameters MTTFd 750 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type Connector plug M12 x 1 , 4-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face PBT Degree of protection IP67 General information Scope of delivery 2 self locking nuts in scope of delivery Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 282942_eng.pdf Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NJ2-12GM40-E2-V1 Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Mounting flange, 12 mm EXG-12 Quick mounting bracket with dead stop V1-G-2M-PUR Female cordset single-ended M12 straight A-coded, 4-pin, PUR cable grey V1-W-2M-PUR Female cordset single-ended M12 angled A-coded, 4-pin, PUR cable grey Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 282942_eng.pdf BF 12 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NJ2-12GM40-E2-V1 价格&库存
很抱歉,暂时无法提供与“NJ2-12GM40-E2-V1”相匹配的价格&库存,您可以联系我们找货
