Inductive sensor
NBB20-U2-UU
< Sensor head bidirectional and rotatable
< NO/NC selectable
< Comfort series
Dimensions
½” NPT
40
LED ye
118
Release date: 2021-12-09 Date of issue: 2021-12-09 Filename: 248041_eng.pdf
40
5.3
60
30
46
LED gn
LED ye
Technical Data
General specifications
Switching function
Normally open/closed (NO/NC)
Output type
Two-wire
Rated operating distance
sn
20 mm
Installation
flush
Output polarity
AC/DC
Assured operating distance
sa
0 ... 16.2 mm
Actual operating distance
sr
18 ... 22 mm
Reduction factor rAl
0.4
Reduction factor rCu
0.3
Refer to "General Notes Relating to Pepperl+Fuchs Product Information".
Pepperl+Fuchs Group
USA: +1 330 486 0001
Germany: +49 621 776 1111
fa-info@de.pepperl-fuchs.com
www.pepperl-fuchs.com
fa-info@us.pepperl-fuchs.com
Singapore: +65 6779 9091
fa-info@sg.pepperl-fuchs.com
1
Inductive sensor
NBB20-U2-UU
Technical Data
Reduction factor r304
0.77
Reduction factor rFe
1
Reduction factor rBrass
0.43
Output type
2-wire
Nominal ratings
Switching frequency
f
AC, 0 ... 30 Hz
DC, 0 ... 100 Hz
Hysteresis
H
1 ... 10 typ. 5 %
Reverse polarity protection
reverse polarity tolerant
Short-circuit protection
Voltage drop
pulsing
Ud
Momentary current
(20 ms, 0.1 Hz)
≤ 5 V (typ. 2V) DC operation
≤ 8 V (typ. 3 V) AC operation
0 ... 3000 mA
Operating current
IL
5 ... 500 mA
Rated operating current
Ie
500 mA 50/60 Hz
Lowest operating current
Im
5 mA
Off-state current
Ir
≤ 1.5 mA
Usage category
Time delay before availability
AC12 , AC140 , DC12 , DC13
tv
≤ 300 ms
Operating voltage indicator
LED, green
Switching state indicator
LED, yellow
Error indicator
flashes when overcurrent
Functional safety related parameters
MTTFd
540 a
Mission Time (TM)
20 a
Diagnostic Coverage (DC)
0%
Electrical specifications
Rated operating voltage
Ue
24 ... 250 V DC / 24 ... 230 V AC
Operating voltage
UB
20 ... 275 V DC / 20 ... 253 V AC
Compliance with standards and directives
Standard conformity
Standards
EN 60947-5-2:2007
EN 60947-5-2/A1:2012
IEC 60947-5-2:2007
IEC 60947-5-2 AMD 1:2012
Approvals and certificates
Protection class
II
Rated insulation voltage
Ui
230 V
Rated impulse withstand voltage
Uimp
2.5 kV
UL approval
cULus Listed, General Purpose
"For use in NFPA 79 Applications only"
For overcurrent protection, install a fuse with a rated current of max. 3 A and at least
300 V AC/DC
CCC approval
Ue 75VDC - 250VDC Ue 75VAC - 230VAC
Ambient conditions
Ambient temperature
-25 ... 85 °C (-13 ... 185 °F)
Storage temperature
Pollution degree
3
Mechanical specifications
Connection type
terminal compartment
Information for connection
A maximum of two conductors with the same core cross section may be mounted on
one terminal connection!
tightening torque 1.2 Nm + 10 %
Core cross section
up to 2.5 mm2
Minimum core cross-section
without wire end ferrule 0.5 mm2 , with connector sleeves 0.34 mm2
Maximum core cross-section
without wire end ferrule 2.5 mm2 , with connector sleeves 1.5 mm2
Pepperl+Fuchs Group
2
Inductive sensor
NBB20-U2-UU
Technical Data
Housing material
PA 6.6 / metal
Sensing face
PA 6.6
Housing base
plastic
Degree of protection
IP67
Mass
255 g
Connection
NC
1
2
L
AC/DC
N
3
4
NO
1
2
3
4
L
AC/DC
N
Accessories
Modular mounting bracket
MHW 01
Pepperl+Fuchs Group
3
Inductive sensor
NBB20-U2-UU
Connection
Note
The sensor is designed for individual operation. A series or parallel connection of sensors is not permissible.
Pepperl+Fuchs Group
4
很抱歉,暂时无法提供与“NBB20-U2-UU”相匹配的价格&库存,您可以联系我们找货
