S-8366ABABA-M5T1U2
S-8366ABABA-M5T1U2
    ABLIC(艾普凌科)
    SC74A
    IC REG CTRLR BOOST SOT23-5
S-8366ABABA-M5T1U2 数据手册
S-8365/8366 Series www.ablic.com www.ablicinc.com STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 © ABLIC Inc., 2009-2015 The S-8365/8366 Series is a CMOS step-up switching regulator controller which mainly consists of a reference voltage source, an oscillation circuit, an error amplifier, a phase compensation circuit, a timer latch short-circuit protection circuit, a PWM control circuit (S-8365 Series) and a PWM / PFM switching control circuit (S-8366 Series). With an external low-ON-resistance Nch Power MOS FET, this product is ideal for applications requiring high efficiency and a high output current. The S-8365 Series efficiently works on voltage’s condition of large I/O difference due to the PWM control circuit linearly varies the duty ratio to 90%. During light-load, the S-8366 Series switches its operation to the PFM control by the PWM / PFM switching control circuit in order to prevent efficiency decline due to the IC operating current. Ceramic capacitors can be used for output capacitor. Small packages SNT-6A, SOT-23-5 and SOT-23-6 enable high-density mounting.  Features  Low operation voltage  Input voltage range  Oscillation frequency  Reference voltage  Soft start function  Low current consumption  Duty ratio  Shutdown function  External parts  Timer latch short-circuit protection circuit  UVLO (under-voltage lockout) function  Lead-free, Sn 100%, halogen-free*1 : Start at 1.1 V (1 mA) guaranteed (in the product without UVLO function) : 1.8 V to 5.5 V : 1.2 MHz, 600 kHz : 0.6 V2.0% : 7 ms typ. : 70 A typ. at switching off : Built-in PWM / PFM switching control circuit (S-8366 Series) 28% to 85% (1.2 MHz product) 28% to 90% (600 kHz product) : Current consumption 1.0 A max. at shutdown : Inductor, diode, capacitor, transistor : Selectable with / without short-circuit protection circuit for each product Settable delay time by external capacitor (in the product with short-circuit protection) : Selectable with / without UVLO for each product *1. Refer to “ Product Name Structure” for details.  Applications  MP3 players, digital audio players  Digital cameras, GPS, wireless transceiver  Portable devices  Packages  SNT-6A  SOT-23-5  SOT-23-6 1 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Block Diagram 1. With UVLO function and short-circuit protection L VDD M1 EXT VIN VOUT SD CIN ON/OFF Triangular Wave Oscillation Circuit PWM Comparator Error PWM control, or Amplifier PWM / PFM   Switching Control  Circuit  Timer Latch Short-Circuit Protection Reference Voltage ON/OFF with Soft-Start Circuit Circuit UVLO CSP CFB RFB1 FB RFB2 COUT VSS Figure 1 2. With UVLO function, without short-circuit protection L SD VOUT Triangular Wave Oscillation Circuit UVLO VDD PWM Comparator M1 PWM control, or PWM / PFM Switching Control Circuit EXT VIN CIN ON/OFF   Error Amplifier   VSS Figure 2 2 RFB1 FB Reference Voltage with Soft-Start Circuit ON/OFF Circuit CFB RFB2 COUT STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 3. Without UVLO and short-circuit protection L SD VOUT IC Internal Power Supply Triangular Wave Oscillation Circuit PWM Comparator M1 PWM control, or PWM / PFM Switching Control Circuit EXT VIN CIN ON/OFF   Error Amplifier   CFB RFB1 FB Reference Voltage with Soft-Start Circuit ON/OFF Circuit VDD RFB2 COUT VSS Figure 3 Caution To stabilize the output voltage and oscillation frequency of the S-8365/8366 Series, the input voltage of 1.8 V  VDD  5.5 V is necessary. When connecting the VOUT output to the VDD pin, set the input voltage (VOUT) as to satisfy the above range, including the spike voltage generated in VOUT. 3 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Product Name Structure Users can select the control system, oscillation frequency, short-circuit protection, UVLO function, packages for the S-8365/8366 Series. Refer to “1. Product name” regarding the contents of product name, “2. Packages” regarding the package drawings and “3. Product list” regarding the product type. 1. Product name (1) SNT-6A S-836 x A x x x x - I6T1 U 2 Environmental code U: Lead-free (Sn 100%), halogen-free Package name (abbreviation) and IC packing specification*1 I6T1: SNT-6A, Tape ON/OFF pin pull-down A: B: Unavailable Available UVLO function A: Unavailable B: Available Short-circuit protection A: Unavailable B: Available Oscillation frequency A: 1.2 MHz B: 600 kHz Control system 5: PWM control 6: PWM / PFM switching control *1. Refer to the tape drawing. 4 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series (2) SOT-23-5, SOT-23-6 S-836 x A x x x x - xxxx x 2 Environmental code U: Lead-free (Sn 100%), halogen-free S: Lead-free, halogen-free Package name (abbreviation) and IC packing specification*1 M5T1: SOT-23-5, Tape M6T1: SOT-23-6, Tape ON/OFF pin pull-down A: B: Unavailable Available UVLO function A: Unavailable B: Available Short-circuit protection A: Unavailable (SOT-23-5) B: Available (SOT-23-6) Oscillation frequency A: 1.2 MHz B: 600 kHz Control system 5: PWM control 6: PWM / PFM switching control *1. Refer to the tape drawing. 2. Packages Package name Drawing code Package Tape Reel Land SNT-6A PG006-A-P-SD PG006-A-C-SD PG006-A-R-SD PG006-A-L-SD SOT-23-5 MP005-A-P-SD MP005-A-C-SD MP005-A-R-SD  SOT-23-6 MP006-A-P-SD MP006-A-C-SD MP006-A-R-SD  5 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 3. Product list (1) S-8365 Series (PWM control) Table 1 SOT-23-5  SOT-23-6 SNT-6A S-8365AABBA-M6T1y2 S-8365AABBA-I6T1U2 Oscillation Short-circuit frequency protection UVLO function ON / OFF pin pull-down 1.2 MHz Available Available Unavailable Available Unavailable S-8365AAABA-M5T1y2  S-8365AAABA-I6T1U2 1.2 MHz Unavailable S-8365AAAAA-M5T1y2  S-8365AAAAA-I6T1U2 1.2 MHz Unavailable Unavailable Unavailable S-8365ABBBA-M6T1y2 S-8365ABBBA-I6T1U2 600 kHz Available Available Unavailable 600 kHz Unavailable Available Unavailable  S-8365ABABA-M5T1y2  S-8365ABABA-I6T1U2 S-8365ABAAA-M5T1y2  S-8365ABAAA-I6T1U2 600 kHz Unavailable Unavailable Unavailable Remark 1. Contact our sales office for S-8365AxBAA (without UVLO function, with short-circuit protection). 2. Contact our sales office for S-8365AxxxB ( ON/OFF pin pull-down). 3. y: S or U 4. Please select products of environmental code = U for Sn 100%, halogen-free products. (2) S-8366 Series (PWM / PFM switching control) Table 2 SOT-23-5  S-8366AAABA-M5T1y2 S-8366AAAAA-M5T1y2  S-8366ABABA-M5T1y2 1.2 MHz Available Available ON / OFF pin pull-down Unavailable 1.2 MHz Unavailable Available Unavailable S-8366AAAAA-I6T1U2 1.2 MHz Unavailable Unavailable Unavailable S-8366ABBBA-M6T1y2 S-8366ABBBA-I6T1U2  S-8366ABABA-I6T1U2 600 kHz Available Available Unavailable 600 kHz Unavailable Available Unavailable SOT-23-6 SNT-6A S-8366AABBA-M6T1y2 S-8366AABBA-I6T1U2  S-8366AAABA-I6T1U2   S-8366ABAAA-I6T1U2 Oscillation Short-circuit frequency protection UVLO function 600 kHz Unavailable Unavailable Unavailable S-8366ABAAA-M5T1y2 Remark 1. Contact our sales office for S-8366AxBAA (without UVLO function, with short-circuit protection). 2. Contact our sales office for S-8366AxxxB ( ON/OFF pin pull-down). 3. y: S or U 4. Please select products of environmental code = U for Sn 100%, halogen-free products. 6 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Pin Configurations 1. SNT-6A Table 3 Top view 1 2 3 6 5 4 Figure 4 With Short-Circuit Protection Pin No. 1 2 Symbol EXT VSS 3 ON / OFF 4 FB 5 CSP 6 VDD Table 4 Pin No. 1 2 Description External transistor connection pin GND pin Power-off pin “H” : Power-on (normal operation) “L” : Power-off (standby) Output voltage feedback pin Delay time setting pin for short-circuit protection IC power supply pin Without Short-Circuit Protection Symbol Description External transistor connection pin GND pin Power-off pin “H” : Power-on (normal operation) 3 ON / OFF “L” : Power-off (standby) 4 FB Output voltage feedback pin *1 NC 5 No connection 6 VDD IC power supply pin *1. The NC pin indicates electrically open. The NC pin can be connected to VDD or VSS. 2. EXT VSS SOT-23-5 Top view 5 Table 5 Pin No. Without Short-Circuit Protection Symbol 4 1 2 3 Figure 5 1 ON / OFF 2 3 4 5 VSS EXT VDD FB Description Power-off pin “H” : Power-on (normal operation) “L” : Power-off (standby) GND pin External transistor connection pin IC power supply pin Output voltage feedback pin 7 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 3. SOT-23-6 Table 6 Top view 6 5 4 8 Pin No. 1 With Short-Circuit Protection Symbol VDD 2 CSP 3 FB 1 2 3 4 ON / OFF Figure 6 5 6 VSS EXT Description IC power supply pin Delay time setting pin for short-circuit protection Output voltage feedback pin Power-off pin “H” : Power-on (normal operation) “L” : Power-off (standby) GND pin External transistor connection pin STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Absolute Maximum Ratings Table 7 Absolute Maximum Ratings (Ta = 25C, VSS = 0 V unless otherwise specified) Symbol Absolute Maximum Ratings Unit VDD VSS0.3 to VSS6.0 V VFB VSS0.3 to VDD0.3 V VEXT VSS0.3 to VDD0.3 V VON / OFF VSS0.3 to VDD0.3 V VCSP VSS0.3 to VDD0.3 V 400*1 mW 600*1 PD mW 650*1 mW Topr 40 to 85 C Tstg 40 to 125 C Item VDD pin voltage FB pin voltage EXT pin voltage ON/OFF pin voltage CSP pin voltage SNT-6A SOT-23-5 SOT-23-6 Operating ambient temperature Storage temperature *1. When mounted on board [Mounted board] (1) Board size : 114.3 mm  76.2 mm  t1.6 mm (2) Name : JEDEC STANDARD51-7 Power dissipation The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 700 Power Dissipation (PD) [mW] Caution SOT-23-5 600 SOT-23-6 500 400 300 200 SNT-6A 100 0 0 50 100 150 Ambient Temperature (Ta) [C] Figure 7 Package Power Dissipation (When Mounted on Board) 9 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Electrical Characteristics 1. 1.2 MHz product Table 8 Item Input voltage*1 Operating start *2 voltage Oscillation start voltage Operation holding voltage FB voltage FB voltage temperature coefficient FB pin input current Current consumption *3 at operation Current consumption at switching off Current consumption at shutdown EXT pin output current Oscillation frequency Maximum duty ratio PWM / PFM switching *4 Duty ratio Short-circuit protection *5 delay time UVLO release voltage UVLO hysteresis width High level input voltage Low level input voltage Symbol VDD VST1 VST2 VHLD VFB VFB Ta IFB ISS1 Electrical Characteristics (VDD = 3.3 V, Ta = 25C unless otherwise specified) Conditions Typ. Max. Unit Test Circuit  5.5 V 2  1.1 V 3  1.0 V 1   V 3 0.6 0.612 V 1  100  ppm/C 1 -0.1  0.1 A 1  500  A 1 Min.  1.8 Product without UVLO function,  IOUT = 1 mA No external parts  for product without UVLO function, Product without UVLO function, IOUT = 1 mA, Determined by decreasing 0.8 VDD gradually  0.588 Ta = 40C to 85C VDD = 1.8 V to 5.5 V, FB pin At switching operation, no load VFB = VFB(S)  0.95 ISS2 At switching stop, VFB = VFB(S)  1.5  70 120 A 1 ISSS VON / OFF = 0 V   1.0 A 1 IEXTH IEXTL fosc Max Duty PFM Duty VEXT = VDD  0.4 V VEXT = 0.4 V  100 1.0 130 200 1.2 60  1.4 mA mA MHz 1 1 1 VFB = VFB(S)  0.95 80 85 90 % 1 VDD = VOUT(S)  0.1 V, no load 20 28 36 % 2 37.5 50 75 ms 1 1.60 0.05 0.75  1.70 0.10   1.78 0.15  0.3 V V V V 1 1 1 1 0.1  0.1 A 1 0.2 1.0 2.5 A 1 tPRO VUVLO VUVLOHYS VSH VSL High level input current ISH  Product with short-circuit protection, At CSP = 0.1 F Product with UVLO function Product with UVLO function VDD = 1.8 V to 5.5 V, ON/OFF pin VDD = 1.8 V to 5.5 V, ON/OFF pin Product without ON/OFF pin pull-down, VDD = 1.8 V to 5.5 V, ON/OFF pin Product with ON/OFF pin pull-down, VDD = 1.8 V to 5.5 V, ON/OFF pin VDD = 1.8 V to 5.5 V, ON/OFF pin Low level input current ISL 0.1  0.1 A 1 Soft-start time tSS  5 7 10 ms 2 *1. The S-8365/8366 Series steps up from VDD = 1.1 V, but set the input voltage as to 1.8 V  VDD  5.5 V for stabilizing the output voltage and oscillation frequency. *2. This is the guaranteed value measured with external parts shown in “Table 10 External Parts List” and with test circuits shown in Figure 10. The operating start voltage varies largely depending on diode’s forward voltage. Evaluate sufficiently with actual device. *3. VFB(S) is a setting value for FB voltage. *4. VOUT(S) is a setting value for output voltage. VOUT is the typical value of actual output voltage. VOUT(S) can be set by using the rate of VFB and the output voltage setting resistors (RFB1, RFB2). For details, refer to “ External Parts Selection”. *5. The short-circuit protection time can be set by the external capacitor, and the maximum set value by the external capacitor is unlimited when an ideal case is assumed. But use CSP = approximately 0.47 F as a target maximum value due to the need to consider the discharge time of the capacitor. For details, refer to “ External Parts Selection”. 10 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 2. S-8365/8366 Series 600 kHz product Table 9 Item *1 Input voltage Operating start *2 voltage Oscillation start voltage Operation holding voltage FB voltage FB voltage temperature coefficient FB pin input current Current consumption *3 at operation Current consumption at switching off Current consumption at shutdown EXT pin output current Oscillation frequency Maximum duty ratio PWM / PFM switching *4 Duty ratio Short-circuit protection *5 delay time UVLO release voltage UVLO hysteresis width High level input voltage Low level input voltage Symbol VDD VST1 VST2 VHLD VFB VFB Ta IFB ISS1 Electrical Characteristics (VDD = 3.3 V, Ta = 25C unless otherwise specified) Test Conditions Min. Typ. Max. Unit Circuit  1.8 Product without UVLO function,  IOUT = 1 mA No external parts  for product without UVLO function, Product without UVLO function, IOUT = 1 mA, Determined by decreasing 0.8 VDD gradually  0.588 Ta = 40C to 85C VDD = 1.8 V to 5.5 V, FB pin At switching operation, no load VFB = VFB(S)  0.95  5.5 V 2  1.0 V 3  0.9 V 1   V 3 0.6 0.612 V 1  100  ppm/C 1 0.1  0.1 A 1  300  A 1 ISS2 At switching stop, VFB = VFB(S)  1.5  70 120 A 1 ISSS VON / OFF = 0 V   1.0 A 1 IEXTH IEXTL fosc Max Duty PFM Duty VEXT = VDD  0.4 V VEXT = 0.4 V  100 510 130 200 600 60  690 mA mA kHz 1 1 1 VFB = VFB(S)  0.95 85 90 95 % 1 VDD = VOUT(S)  0.1 V, no load 20 28 36 % 2 37.5 50 75 ms 1 1.60 0.05 0.75  1.70 0.10   1.78 0.15  0.3 V V V V 1 1 1 1 0.1  0.1 A 1 0.2 1.0 2.5 A 1 tPRO VUVLO VUVLOHYS VSH VSL High level input current ISH  Product with short-circuit protection, At CSP = 0.1 F Product with UVLO function Product with UVLO function VDD = 1.8 V to 5.5 V, ON/OFF pin VDD = 1.8 V to 5.5 V, ON/OFF pin Product without ON/OFF pin pull-down, VDD = 1.8 V to 5.5 V, ON/OFF pin Product with ON/OFF pin pull-down, VDD = 1.8 V to 5.5 V, ON/OFF pin VDD = 1.8 V to 5.5 V, ON/OFF pin 0.1  0.1 A 1 Low level input current ISL Soft-start time tSS  5 7 10 ms 2 *1. The S-8365/8366 Series steps up from VDD = 1.0 V, but set the input voltage as to 1.8 V  VDD  5.5 V for stabilizing the output voltage and oscillation frequency. *2. This is the guaranteed value measured with external parts shown in “Table 10 External Parts List” and with test circuits shown in Figure 10. The operating start voltage varies largely depending on diode’s forward voltage. Evaluate sufficiently with actual device. *3. VFB(S) is a setting value for FB voltage. *4. VOUT(S) is a setting value for output voltage. VOUT is the typical value of actual output voltage. VOUT(S) can be set by using the rate of VFB and the output voltage setting resistors (RFB1, RFB2). For details, refer to “ External Parts Selection”. *5. The short-circuit protection time can be set by the external capacitor, and the maximum set value by the external capacitor is unlimited when an ideal case is assumed. But use CSP = approximately 0.47 F as a target maximum value due to the need to consider the discharge time of the capacitor. For details, refer to “ External Parts Selection”. 11 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  External Parts List When Measuring Electrical Characteristics Table 10 Element Name External Parts List Inductor L Transistor M1 Q1 Consonants 2.2 H (1.2 MHz product) 3.3 H (600 kHz product)   Diode SD  Input capacitor Output capacitor CIN COUT 10 F 22 F FB pin capacitor CFB 47 pF CSP pin capacitor Speed-up capacitor Base resistor Output voltage setting resistor 1 Output voltage setting resistor 2 CSP Cb Rb 0.1 F 2200 pF 1 k C3225X7R1E106MB C4532X7R1E226MB GRM1882C1H Murata Manufacturing Co., Ltd. series TDK Corporation C1220X7R1E104MB TDK Corporation C1005X7R1H222K ROHM Co., Ltd. MCR03 series RFB1 220 k ROHM Co., Ltd. MCR03 series RFB2 30 k ROHM Co., Ltd. MCR03 series 12 Symbol Manufacturer TAIYO YUDEN Co., Ltd. TDK Corporation Vishay Intertechnology, Inc. TOSHIBA CORPORATION SHINDENGEN ELECTRIC MANUFACTURING CO.,LTD TDK Corporation TDK Corporation Part Number NR6028T LTF5022 Si3460BDV 2SD2652 D1FH3 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Test Circuits 1. A VDD EXT FB CIN ON/OFF A S-8365/8366 Series CSP VSS A CSP ↓ V Figure 8 2. L SD M1 VDD RFB1 EXT CIN ON/OFF A S-8365/8366 Series VSS VOUT CFB COUT FB CSP V ↓ IOUT RFB2 CSP Figure 9 3. L SD Cb VDD Q1 RFB1 EXT CIN ON/OFF A S-8365/8366 Series VOUT CFB Rb COUT FB V ↓ IOUT RFB2 VSS Figure 10 13 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER S-8365/8366 Series Rev.2.1_02  Operation 1. Switching control method 1.1 PWM control (S-8365 Series) The S-8365 Series is a switching regulator controller that uses a pulse width modulation method (PWM). In conventional PFM control switching regulators, pulses are skipped when the output load current is small, causing a fluctuation in the ripple frequency of the output voltage, resulting in increased ripple voltage. For the S-8365 Series, although the pulse width changes from 0% to 90% in accordance with each load current (or 0% to 85% for 1.2 MHz products), since the switching frequency does not change, the ripple voltage generated due to switching can be eliminated by filtering. The ripple voltage can thus be lowered in the wide input voltage and load current ranges. 1.2 PWM / PFM switching control (S-8366 Series) The S-8366 Series switching regulator controller automatically switches between the pulse width modulation method (PWM) and pulse frequency modulation method (PFM) according to the load current. A low ripple power can be supplied by operating on PWM control for which the pulse width changes from 28% to 90% (or 28% to 85% for 1.2 MHz products) in the range where the output load current is large. The S-8366 Series operates on PFM control when the output load current is small and the fixed pulses which have the width of 28% are skipped according to the load current amount. Therefore, the oscillation circuit intermittently oscillates, reducing the self-current consumption. This avoids decreased efficiency when the output load current is small. The point at which PWM control switches to PFM control varies depending on the external element (inductor, diode, etc.), input voltage value, and output voltage value, and this method achieves high efficiency in the output load current of about 100 A. 2. Soft-start function The S-8365/8366 Series has a soft-start circuit. The output voltage (VOUT) gradually rises after power-on or startup when the ON/OFF pin is set to high, suppressing rush current and overshooting the output voltage. The soft-start time (tSS) for the S-8365/8366 Series is defined as the time from startup until VOUT reaches 90% of the output set voltage value (VOUT(S)). A reference voltage adjustment method is used as the soft-start method and the reference voltage gradually rises from 0 V after soft-start. A soft-start performs by controlling the FB pin voltage so that it follows the rise of the reference voltage. After the reference voltage rises once, it is reset to 0 if the ON/OFF pin voltage drops to low, the power supply voltage drops to the UVLO detection voltage, or the S-8365/8366 Series enters the short-circuit protection latch status. A soft-start is performed regardless of conditions when resuming step-up operation. 14 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 3. Shutdown pin This pin stops or starts step-up operations. 3.1 Without ON/OFF pin pull-down When this pin is set to the low level, the voltage of the EXT pin is fixed to 0 V, and the external transistor and all internal circuits stop, substantially reducing the current consumption. Do not use the ON/OFF pin in a floating state because it is set up as shown in Figure 11 and is not internally pulled up or down. Do not apply a voltage of between 0.3 V and 0.75 V to the ON/OFF pin because applying such a voltage increases the current consumption. If the ON/OFF pin is not used, connect it to the VDD pin. Table 11 CR Oscillation Output Voltage Circuit “H” Operates Set value VIN*1 “L” Stops Voltage obtained by subtracting the voltage drop due to the DC resistance of the inductor and the diode forward voltage from VIN. ON/OFF pin *1. VDD ON/OFF VSS Figure 11 3.2 With ON/OFF pin pull-down When the ON/OFF pin is set to the low level, the voltage of the EXT pin is fixed to 0 V, and the external transistor and all internal circuits stop substantially reducing the current consumption. The ON/OFF pin is set up as shown in Figure 12 and is internally pulled down by using the depression transistor, so all circuits stop even if this pin is floating. Do not apply a voltage of between 0.3 V and 0.75 V to the ON/OFF pin because applying such a voltage increases the current consumption. If the ON/OFF pin is not used, connect it to the VDD pin. Table 12 CR Oscillation Output Voltage Circuit “H” Operates Set value VIN*1 “L” Stops VIN*1 High-Z Stops Voltage obtained by subtracting the voltage drop due to the DC resistance of the inductor and the diode forward voltage from VIN. ON/OFF Pin *1. VDD ON/OFF VSS Figure 12 15 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 4. Timer latch type short-circuit protection (products with short-circuit protection function) The S-8365/8366 Series incorporates a timer latch type short-circuit protection circuit that stops switching operation if the output short circuits for a certain time or more. Connect a capacitor (CSP) to the CSP pin to set the delay time of this circuit. The S-8365/8366 Series operates on the maximum duty if the output voltage drops due to output short-circuiting or other factors. When it enters the maximum duty status, charging the constant current to CSP is started. If this status is held for the short-circuit protection delay time or more, the voltage of the CSP pin exceeds the reference voltage and the IC enters the latch mode. Note that switching operation stops in latch mode but the internal circuits normally operate, which differs from the power-off status. The constant current is continuously charged to CSP even in latch mode, so the voltage of the CSP pin rises to the VDD level. To reset the latch mode of short-circuit protection, lower VDD to the UVLO detection voltage or lower or set the ON/ OFF pin to the low level. Input voltage (VDD) UVLO release UVLO detection Short-circuit state Output load CSP pin voltage (VCSP) Reference voltage 50 ms (CSP = 0.1 F) Latch mode Normal state Short circuit protection delay time Latch period Short-circuit protection Short-circuit protection delay time delay time Reset period Reset period Figure 13 5. UVLO function (products with UVLO function) The S-8365/8366 Series has a UVLO (undervoltage lockout) circuit for avoiding IC malfunctions due to power supply voltage drops. The S-8365/8366 Series stops switching operation upon UVLO detection and retains the external transistor in the off state. After entering the UVLO detection status once, the soft-start function is reset. Note, however, that the other internal circuits operate normally and that the status differs from the power-off status. 16 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Operation Principles The S-8365/8366 Series is a step-up switching regulator controller. Figure 14 shows the basic circuit diagram. Step-up switching regulators start current supply by the input voltage (VIN) when the Nch power MOS FET is turned on and holds energy in the inductor at the same time. When the Nch power MOS FET is turned off, the CONT pin voltage is stepped up to discharge the energy held in the inductor and the current is discharged to VOUT through the diode. When the discharged current is stored in CL, a voltage is generated, and the potential of VOUT increases until the voltage of the FB pin reaches the same potential as the internal reference voltage. For the PWM control method, the switching frequency (fOSC) is fixed and the VOUT voltage is held constant according to the ratio of the ON time and OFF time (ON duty) of the Nch power MOS FET in each period. For the PWM control method, the VOUT voltage is held constant by controlling the ON time. In the S-8366 Series, the Nch power MOS FET is turned on when the fixed duty cycle is 28% for the PFM control method. When energy is discharged to VOUT once and the VOUT potential exceeds the set value, the Nch power MOS FET stays in the off status until VOUT decreases to the set value or less due to the load discharge. Time VOUT decreases to the set value or less depends on the amount of load current, so, the switching frequency varies depending on this current. CONT L IOUT I2 SD VOUT VIN I1 Nch power MOS FET EXT FB COUT VSS Figure 14 RL Basic Circuit of Step-up Switching Regulator The ON duty in the current continuous mode can be calculated by using the equation below. Use the S-8365/8366 Series in the range where the ON duty is less than the maximum duty. Note that the products with short-circuit protection is set in the timer-latch status if the maximum duty lasts the short-circuit protection delay time (tPRO) or more. The maximum duty is 85% typ. for 1.2 MHz products and 90% for 600 kHz products. ON duty = (1  VIN VOUT + VD*1 )  100 [%] The ON time (tON) can be calculated by using the following equation : 1  ON duty tON = f OSC VIN 1 =  1 ······ (1) V + VD*1 OUT f OSC ( ) *1. VD : Forward voltage of diode 17 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER S-8365/8366 Series Rev.2.1_02 1. Continuous current mode The following explains the current that flows into the inductor when the step-up operation stabilizes in a certain status and IOUT is sufficiently large. When the Nch power MOS FET is turned on, current (I1) flows in the direction shown in Figure 14. The inductor current (IL) at this time gradually increases in proportion with the ON time (tON) of the Nch power MOS FET. Current change of inductor within tON : IL(ON) = IL max.  IL min. VIN = L  tON When the Nch power MOS FET is turned off, the voltage of the CONT pin is stepped up to VOUT + VD and the voltage on both ends of the inductor becomes VOUT + VD  VIN. However, it is assumed here that VOUT >> VD and VD is ignored. Current change of inductor within tOFF : VOUT  VIN IL(OFF) =  tOFF L The input power equals the output power in an ideal situation where there is no loss by components. IIN(AV) : PIN = POUT IIN(AV)  VIN = IOUT  VOUT VOUT  IOUT .................. (2) IIN(AV) = V IN The current that flows in the inductor consists of a ripple current that changes due to variation over time and a direct current. From Figure 15 : IIN(AV) : IL 2 VOUT  VIN = IIN(DC) +  tOFF 2L VIN = IIN(DC) +  tON.......... (3) 2L IIN(AV) = IIN(DC) + Above, the continuous mode is the operation mode when IIN(DC) > 0 as shown in Figure 15 and the inductor current continuously flows. While the output current (IOUT) continues to decrease, IIN(DC) reaches 0 as shown in Figure 16. This point is the critical point of the continuous mode. As shown in equations (2) and (3), the direct current component (IIN(DC)) depends on IOUT. IOUT(0) when IIN(DC) reaches 0 (critical point) : IOUT(0) = tON  VIN2 2  L  VOUT tON can be calculated using equation (1). When the output current decreases below IOUT(0), the current flowing in the inductor stops flowing in the tOFF period as shown in Figure 17. This is the discontinuous mode. 18 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series IL IL max. IIN(AV) IL min. IIN(DC) t tON tOFF t = 1 / fOSC Figure 15 Continuous Mode (Current Cycle of Inductor Current IL) IL IL max. IL min. t tON tOFF t = 1 / fOSC Figure 16 Critical Point (Current Cycle of Inductor Current IL) IL IL max. IL min. t tON tOFF t = 1 / fOSC Figure 17 Discontinuous Mode (Current Cycle of Inductor Current IL) 19 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  External Parts Selection 1. Inductor The recommended L value of the S-8365/8366 Series is 2.2 H for 1.2 MHz products and 3.3 H for 600 kHz products. Note the following when changing the inductance. The inductance (L) has a strong influence on the maximum output current (IOUT) and efficiency (). The inductor peak current (IPK) increases when L is decreased, which improves the circuit stability and increases the IOUT users can obtain. If L is decreased further, the ability of the external transistor to drive the current becomes insufficient, reducing the efficiency and decreasing IOUT. The loss due to the IPK of the switching transistor is decreased by increasing L and the efficiency maximizes at a certain L value. If L is increased further, the loss due to the serial resistance of the inductor increases, lowering the efficiency. Caution When selecting an inductor, be careful about its allowable current. If a current exceeding the allowable current flows through the inductor, magnetic saturation occurs, substantially lowering the efficiency and destroying ICs due to large current. Therefore, select an inductor such that IPK does not exceed the allowable current. The following equations express IPK in the ideal statuses in the discontinuous and continuous modes : 2  IOUT  (VOUT + VD*2  VIN) fOSC*1  L *2 VOUT + VD (VOUT + VD*2  VIN)  VIN  I IPK = OUT + VIN 2  (VOUT + VD*2)  fOSC*1  L IPK = *1. *2. (Continuous mode) fOSC : oscillation frequency VD is the forward voltage of a diode. The reference value is 0.4 V. However, current exceeding the above equation flows because conditions are practically not ideal. Perform sufficient evaluation with actual application. Table 13 Manufacture TDK Corporation Coilcraft, Inc. Taiyo Yuden Co., Ltd. Sumida Corporation Manufacture TDK Corporation Coilcraft, Inc. Taiyo Yuden Co., Ltd. Typical Inductors (for Small Low-Profile Devices) Product Name L Value DC Resistance Rated Current Dimensions (L  W  H) [mm] VLF3010ST-2R2M VLF3010ST-3R3M VLS252010-2R2M VLS252010-3R3M LPS3008-222ML LPS3008-332ML NR3010T2R2M NR3010T3R3M CDRH2D11BNP-2R2N CDRH2D11BNP-3R3N 2.2 H 3.3 H 2.2 H 3.3 H 2.2 H 3.3 H 2.2 H 3.3 H 2.2 H 3.3 H 0.092  max. 0.130  max. 0.190  max. 0.304  max. 0.175  max. 0.285  max. 0.114  max. 0.168  max. 0.0955  max. 0.154  max. 1.1 A max. 0.88 A max. 1.2 A max. 1.0 A max. 1.1 A max. 0.88 A max. 1.1 A max. 0.87 A max. 1.4 A max. 1.0 A max. 2.8  3.0  1.0 2.8  3.0  1.0 2.5  2.0  1.0 2.5  2.0  1.0 3.0  3.0  0.8 3.0  3.0  0.8 3.0  3.0  1.0 3.0  3.0  1.0 3.0  3.0  1.2 3.0  3.0  1.2 Table 14 20 (Discontinuous mode) Typical Inductors (for Large Current, High Step-up Rate) Product Name LTF5022T-2R2M LTF5022T-3R3M LPS6225-222ML LPS6225-332ML NR6028T2R2M L Value DC Resistance Rated Current Dimensions (L  W  H) [mm] 2.2 H 3.3 H 2.2 H 3.3 H 2.2 H 0.040  max. 0.060  max. 0.045  max. 0.055  max. 0.020  max. 3.4 A max. 2.7 A max. 4.1 A max. 3.6 A max. 4.2 A max. 5.0  5.2  2.2 5.0  5.2  2.2 6.0  6.0  2.4 6.0  6.0  2.4 6.0  6.0  2.8 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 2. Diode Use an externally mounted that meets the following conditions.  Low forward voltage (Schottky barrier diode or similar type)  High switching speed  Reverse withstand voltage of VOUT + spike voltage or more  Rated current of IPK or more 3. Input capacitor (CIN) and output capacitor (COUT) To improve efficiency, an input capacitor (CIN) lowers the power supply impedance and averages the input current. Select CIN according to the impedance of the power supply used. The recommended capacitance is 10 F for the S-8365/8366 Series. An output capacitor (COUT), which is used to smooth the output voltage, requires a capacitance larger than that of the step-down type because the current is intermittently supplied from the input to the output side in the step-up type. A 22 F ceramic capacitor is recommended for the S-8365/8366 Series. However, a higher capacitance is recommended if the output voltage is high or the load current is large. If the output voltage or load current is low, about 10 F can be used without problems. Select COUT after sufficient evaluation with actual application. A ceramic capacitor can be used for both the input and output. 4. Capacitor for setting short-circuit protection delay time (CSP) (products with short-circuit protection) For the S-8365/8366 Series, the short-circuit protection delay time can be set to any value by using an external capacitor. Connect the capacitor between the CSP and VSS pins. Select the capacitor value according to the equation below and Figure 18. Note, however, that the equation and figure show a theoretical value assuming an ideal capacitor value and typ. IC conditions. Variations of the capacitor and IC are not considered. For the IC variations, see the short-circuit protection delay time (tPRO) in “ Electrical Characteristics”. tPRO [ms]  1.2  103 0.6 120 100 tPRO [ms] CSP [F]  80 60 40 20 0 0 0.05 0.10 0.15 0.20 0.25 CSP [F] Figure 18 CSP vs. tPRO 21 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 5. External transistor A bipolar (NPN) or enhanced (Nch) MOS FET transistor can be used as an external transistor. 5.1 Bipolar NPN type The driving ability to increase output current by using a bipolar transistor is determined based on the hFE value and Rb value of the bipolar transistor. Figure 19 shows the peripheral circuit. VDD Cb 2200 pF Pch EXT Nch Figure 19 IPK Rb 1 k External Transistor Peripheral Circuit The recommended Rb value is around 1 k. Calculate the required base current (Ib) based on the hFE value of IPK , and then select an Rb value smaller than that determined using: the bipolar transistor by using Ib = h FE VDD  0.7 0.4 Rb = - Ib I EXTH Smaller Rb values increase the output current, but decrease the efficiency. Actually, the current might flow on pulses or the VDD or VSS voltage might drop due to wiring resistance, so determine the optimum value based on experimentation. Inserting a speed-up capacitor (Cb) in parallel with the Rb resistor as shown in Figure 19 reduces switching loss and increases efficiency. 1 . Select a speed-up capacitor for which the Cb value satisfies Cb  2    Rb  fOSC  0.7 Actually, however, the optimum Cb value varies depending on the characteristics of the bipolar transistor used, so determine the optimum value based on experimentation. 5.2 Enhanced MOS FET type Use an Nch power MOS FET. A MOS FET that has low ON-resistance (RON) and input capacitance (CISS) is ideal for gaining efficiency. The ON-resistance and input capacitance generally have a tradeoff relationship. ON-resistance is efficient in the range where the output current is high with relatively low frequency switching, and input capacitance is efficient in the range where the output current is medium to low with high frequency switching. Therefore, select a MOS FET for which the ON-resistance and input capacitance are optimum under your usage conditions. The input voltage (VDD) is supplied as the gate voltage of a MOS FET, so select a MOS FET for which the gate withstand voltage is higher than the maximum value used for the input voltage, and for which the drain withstand voltage is greater than or equal to the output voltage (VOUT) + the forward voltage of the diode (VD). If a MOS FET for which the threshold value is near the UVLO detection voltage is used, a high current flows upon power-on, and, in the worst case, the output voltage might not increase and the timer latch type short-circuit protection circuit might operate. Therefore, select a MOS FET for which the threshold value is sufficiently lower than the UVLO detection voltage. 22 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 6. Output voltage setting resistors (RFB1, RFB2), capacitor for phase compensation (CFB) For the S-8365/8366 Series, VOUT can be set to any value by using external divider resistors. Connect the divider resistors between the VOUT and VSS pins. Because VFB = 0.6 V typ., VOUT can be calculated by using the following equation : VOUT = RFB1 + RFB2  0.6 RFB2 Connect divider resistors RFB1 and RFB2 as close to the IC as possible to minimize the effects of noise. If noise has an effect, adjust the values of RFB1 and RFB2 so that RFB1 + RFB2 < 100 k. CFB, which is connected in parallel with RFB1, is a capacitor for phase compensation. By setting the zero point (the phase feedback) by adding capacitor CFB to output voltage setting resistor RFB1 in parallel, the phase margin increases, improving the stability of the feedback loop. To effectively use the feedback portion of the phase based on the zero point, define CFB by using the following equation : CFB  L  COUT VOUT  V 3  RFB1 DD This equation is only a guide. The following explains the optimum setting. To efficiently use the feedback portion of the phase based on the zero point, specify settings so that the phase feeds back at the zero point frequency (fzero) of RFB1 and CFB according to the phase delay at the pole frequency (fpole) of L and COUT. The zero point frequency is generally set slightly higher than the pole frequency. The following equations are used to determine the pole frequency of L and COUT and the zero point frequency set using RFB1 and CFB. 1 VDD  V OUT L  COUT 1 fzero  2    RFB1  CFB fpole  2 The transient response can be improved by setting the zero point frequency in a lower frequency range. If, however, the zero point frequency is set in a significantly lower range, the gain increases in the range of high frequency and the phase margin decreases. This might result in unstable operation. Determine the proper value after sufficient evaluation with actual application. The typical constants based on our evaluation are shown in Table 15. Table 15 Example of Constant for External Parts VOUT(S) [V] VDD [V] RFB1 [k] RFB2 [k] CFB [pF] L [H] COUT [F] 1.8 1.8 3.32 3.32 5.0 5.0 9.0 9.0 15.0 15.0 1.2 1.2 1.2 1.2 1.8 1.8 3.3 3.3 3.3 3.3 30 30 68 68 110 110 210 210 360 360 15 15 15 15 15 15 15 15 15 15 100 82 82 68 68 56 39 33 39 33 3.3 2.2 3.3 2.2 3.3 2.2 3.3 2.2 3.3 2.2 10 10 10 10 22 22 22 22 22 22 23 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Standard Circuit (1) With short-circuit protection (SNT-6A, SOT-23-6) L SD VDD VOUT Triangular wave oscillation circuit UVLO circuit PWM comparator M1 PWM control, or PWM / PFM switching control circuit EXT   Error amplifier   CFB RFB1 FB Timer latch short-circuit protection circuit VIN CIN 0.1 F ON/OFF RFB2 Reference voltage with soft-start circuit ON/OFF circuit COUT VSS CSP Ground point Figure 20 (2) Without short-circuit protection (SOT-23-5) L SD VDD VOUT Triangular wave oscillation circuit UVLO circuit PWM comparator M1 EXT VIN CIN 0.1 F ON/OFF PWM control, or PWM / PFM switching control circuit   Error amplifier   VSS Ground point Figure 21 24 RFB1 FB Reference voltage with soft-start circuit ON/OFF circuit CFB RFB2 COUT STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series (3) Low input voltage (SOT-23-5) L SD IC internal power supply Q1 VIN CIN ON/OFF Triangular wave oscillation circuit PWM comparator Cb Rb EXT VOUT PWM control, or PWM / PFM switching control circuit   Error amplifier   CFB RFB1 FB Reference voltage with soft-start circuit ON/OFF circuit VDD RFB2 COUT 0.1 F VSS Ground point Figure 22 Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constants.  Precaution  Mount external capacitors and inductor as close as possible to the IC. Set single point ground.  Characteristics ripple voltage and spike noise occur in IC containing switching regulators. Moreover rush current flows at the time of a power supply injection. Because these largely depend on the inductor, the capacitor and impedance of power supply used, fully check them using an actually mounted model.  The 0.1 F capacitor connected between the VDD and VSS pins is a bypass capacitor. It stabilizes the power supply in the IC when application is used with a heavy load, and thus effectively works for stable switching regulator operation. Allocate the bypass capacitor as close to the IC as possible, prioritized over other parts.  Although the IC contains a static electricity protection circuit, static electricity or voltage that exceeds the limit of the protection circuit should not be applied.  The power dissipation of the IC greatly varies depending on the size and material of the board to be connected. Perform sufficient evaluation using an actual application before designing.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 25 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Application Circuits Application circuits are examples. They may always not guarantee successful operation. 1. External parts for application circuits Table 16 Part Part Name NR6028T-2R2M LTF5022T-3R3M Inductor VLF3010ST-2R2M VLF3010ST-3R3M RB070M-30TR Diode RB050LA-30 Si2312BDS Transistor 2SD2652 JMK107BJ106MA-T LMK212BJ106KD-T EMK316BJ106KF-T Capacitor TMK325B7106MN-T C2012X5R1A106KT C1005X7R1C104KT GRM31CR71A106KA * 1. DCR : * 2. IMAX : * 3. VF : * 4. IF : * 5. VR : * 6. VDSS : * 7. VGSS : * 8. ID : * 9. QG : *10. RDS(ON ): *11. VGS : *12. VCEO : *13. VEBO : *14. IC : *15. hFE : *16. EDC : 26 Characteristics of External Parts Manfuacturer Characteristics *1 2.2 H, DCR = 0.020 , IMAX*2 = 4.2 A, Taiyo Yuden Co., Ltd. L  W  H = 6.0  6.0  2.8 mm *1 *2 3.3 H, DCR = 0.060 , IMAX = 2.7 A, L  W  H = 5.0  5.2  2.2 mm 2.2 H, DCR*1 = 0.114 , IMAX*2 = 1.1 A, TDK Corporation L  W  H = 3.0  3.0  1.0 mm 3.3 H, DCR*1 = 0.168 , IMAX*2 = 0.87 A, L  W  H = 3.0  3.0  1.0 mm VF*3 = 0.44 V, IF*4 = 1.5 A, VR*5 = 30 V L  W  H = 3.5  1.6  0.9 mm Rohm Co., Ltd. VF*3 = 0.45 V, IF*4 = 3.0 A, VR*5 = 30 V L  W  H = 4.7  2.6  1.05 mm VDSS*6 = 20 V, VGSS*7 = ±8 V, ID*8 = 5.0 A, VISHAY QG*9 = 12 nC max. INTERTECHNOLOGY, RDS(ON)*10 = 0.047  max. (VGS*11 = 2.5 V) INC. L  W  H = 2.9  2.64  1.12 mm *12 *13 *14 VCEO = 12 V, VEBO = 6 V, IC = 1.5 A, *15 hFE = 270 min./680 max. (VCE/IC = 2 V/200 mA) Rohm Co., Ltd. L  W  H = 2.0  1.25  0.9 mm *16 10 F, EDC = 6.3 V, X5R, L  W  H = 1.6  0.8  0.95 mm 10 F, EDC*16 = 10 V, X5R, L  W  H = 2.0  1.25  0.95 mm Taiyo Yuden Co., Ltd. 10 F, EDC*16 = 16 V, X5R, L  W  H = 3.2  1.6  1.25 mm 10 F, EDC*16 = 25 V, X7R, L  W  H = 3.2  2.5  2.1 mm 10 F, EDC*16 = 10 V, X5R, L  W  H = 2.0  1.25  1.45 mm TDK Corporation 0.1 F, EDC*16 = 16 V, X7R, L  W  H = 1.0  0.5  0.55 mm Murata Manufacturing, 10 F, EDC*16 = 10 V, X7R, Co., Ltd. L  W  H = 3.2  1.6  1.6 mm DC resistance Maximum allowable current Forward voltage Forward current Reverse voltage Drain-source voltage (during short-circuiting between the gate and source) Gate-source voltage (during short-circuiting between the drain and source) Drain current Gate charge On-resistance between the drain and source Gate-source voltage Collector-emitter voltage Emitter-base voltage Collector current Direct current gain Rated voltage STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 2. Power supply for LCD Following shows a circuit example and its characteristics for driving an LCD panel (with 9 V and 15 V outputs). L SD M1 VDD EXT CIN CDD VOUT ON/OFF S-8365/8366 Series CFB RFB1 COUT FB CSP RFB2 CSP VSS Figure 23 Table 17 Circuit Example (Power Supply for LCD) External Part Examples (Power Supply for LCD) (1 / 2) Output IC Product Voltage Name 9V S-8365AABBA 2 9V 3 15 V 4 15 V Condition 1 Table 17 M1 Product SD Product Name Name NR6028T2R2M Si2312BDS RB050LA-30 S-8366AABBA NR6028T2R2M Si2312BDS RB050LA-30 S-8365AABBA NR6028T2R2M Si2312BDS RB050LA-30 S-8366AABBA NR6028T2R2M Si2312BDS RB050LA-30 L Product Name External Part Examples (Power Supply for LCD) (2 / 2) Condition CIN Product Name COUT Product Name RFB1 RFB2 CFB CDD 1 LMK212BJ106KG-T EMK316BJ106KF-T  2 280 k 20 k 22 pF 0.1 F 2 LMK212BJ106KG-T EMK316BJ106KF-T  1 280 k 20 k 27 pF 0.1 F 3 LMK212BJ106KG-T TMK325B7106MN-T  2 360 k 15 k 27 pF 0.1 F 4 LMK212BJ106KG-T TMK325B7106MN-T  1 360 k 15 k 33 pF 0.1 F Caution The above connection will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constant. 27 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 3. Output Characteristics of Power Supply for LCD Following shows the output current (IOUT) vs. efficiency () and output current (IOUT) vs. output voltage (VOUT) characteristics for conditions 1 to 4 in Table 17. VIN = 2.0 V VIN = 3.3 V VIN = 3.6 V 0.1 η [%] Condition 2 100 90 80 70 60 50 40 30 20 10 0 0.1 1   100 90 80 70 60 50 40 30 20 10 0 10 IOUT [mA] 100 1000 VOUT [V] η [%] Condition 1 VIN = 2.0 V VIN = 3.3 V VIN = 3.6 V 1 10 IOUT [mA] 100                    9.2 9.0 8.8 8.6 8.4 8.2 8.0 7.8 1000      VIN = 2.0 V VIN = 3.3 V VIN = 3.6 V 0.1 1 10 IOUT [mA] 100 1000 15.5 VIN = 3.3 V VIN = 3.6 V VIN = 5.5 V VIN = 3.3 V VIN = 3.6 V VIN = 5.5 V 14.5 14.0 13.5 0.1 1 10 IOUT [mA] 100 13.0 1000 0.1 1 10 IOUT [mA] 100 1000 100 1000 15.5 15.0 VIN = 5.5 V VIN = 3.6 V VIN = 3.3 V η [%] Condition 4 100 90 80 70 60 50 40 30 20 10 0 0.1 28 15.0 VOUT [V] 100 90 80 70 60 50 40 30 20 10 0 VOUT [V] η [%] Condition 3 14.5 VIN = 3.3 V VIN = 3.6 V VIN = 5.5 V 14.0 13.5 13.0 1 10 IOUT [mA] 100 1000 0.1 1 10 IOUT [mA] STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 4. Power supply for high output current Following shows a circuit example and its characteristics for outputting 3.3 V from two dry cells (1.8 V) and satisfying IOUT = 800 mA. L SD M1 VDD CFB EXT CIN CDD ON/OFF VOUT S-8365/8366 Series RFB1 COUT FB CSP RFB2 CSP VSS Figure 24 Table 18 Condition Circuit Example (Power Supply for High Output Current) External Part Examples (Power Supply for High Output Current) (1 / 2) Output Voltage IC Product Name L Product Name M1 Product SD Product Name Name 1 3.32 V S-8365AABBA NR6028T2R2M Si2312BDS RB050LA-30 2 3.32 V S-8365ABBBA LTF5022-3R3M Si2312BDS RB050LA-30 3 3.32 V S-8366AABBA NR6028T2R2M Si2312BDS RB050LA-30 4 3.32 V S-8366ABBBA LTF5022-3R3M Si2312BDS RB050LA-30 Table 18 External Part Examples (Power Supply for High Output Current) (2 / 2) Condition CIN Product Name COUT Product Name RFB1 RFB2 CFB CDD 1 C2012X5R1A106KT GRM31CR71A106KA  2 68 k 15 k 68 pF 0.1 F 2 C2012X5R1A106KT GRM31CR71A106KA  2 68 k 15 k 82 pF 0.1 F 3 C2012X5R1A106KT GRM31CR71A106KA  2 68 k 15 k 68 pF 0.1 F 4 C2012X5R1A106KT GRM31CR71A106KA  2 68 k 15 k 82 pF 0.1 F Caution The above connection will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constant. 29 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 5. Output characteristics of power supply for high output current Following shows the output current (IOUT) vs. efficiency () and output current (IOUT) vs. output voltage (VOUT) characteristics for conditions 1 to 4 in Table 18. VIN = 1.8 V VIN = 2.7 V 0.1 1 VOUT [V] 100 90 80 70 60 50 40 30 20 10 0 10 100 IOUT [mA] η [%] Condition 2 100 VIN = 1.8 V 90 80 VIN = 2.7 V 70 60 50 40 30 20 10 0 0.1 1 10 100 IOUT [mA] 1000 10000 VIN = 1.8 V VIN = 2.7 V 30 10 100 IOUT [mA] 1000 VIN = 1.8 V VIN = 2.7 V 1 10 100 IOUT [mA] 1000            10000 VIN = 1.8 V VIN = 2.7 V 1  1000 10000        1000 10000   VIN = 1.8 V VIN = 2.7 V 0.1            10 100 IOUT [mA]       3.5 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2.5 10000    1 η [%] Condition 4 100 90 80 70 60 50 40 30 20 10 0 0.1 10000 VOUT [V] η [%] Condition 3 100 90 80 70 60 50 40 30 20 10 0 0.1 1000 3.5 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2.5 0.1    η [%] Condition 1 1 10 100 IOUT [mA]             STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 6. Circuit for low power supply voltage applications Following shows a circuit example that starts up by using a dry cell (1.2 V) and its characteristics. L SD Cb VDD EXT ON/OFF CIN CDD S-8365/8366 Series VOUT Q1 CFB RFB1 Rb COUT FB RFB2 VSS Figure 25 Table 19 Circuit Example (Circuit for Low Power Supply Voltage Applications) External Part Examples (Circuit for Low Power Supply Voltage Applications) (1 / 2) Q1 Output IC Product Voltage Name 1 3.32 V S-8366AAAAA VLF3010ST-2R2M 2SD2652 RB070M-30TR 2 3.32 V S-8366ABAAA VLF3010ST-3R3M 2SD2652 RB070M-30TR Condition Table 19 L Product Name Product SD Product Name Name External Part Examples (Circuit for Low Power Supply Voltage Applications) (2 / 2) Condition CIN Product Name COUT Product Name RFB1 RFB2 CFB CDD 1 JMK107BJ106MA-T LMK212BJ106KD-T  1 68 k 15 k 68 pF 0.1 F 2 JMK107BJ106MA-T LMK212BJ106KD-T  1 68 k 15 k 82 pF 0.1 F Caution The above connection will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constant. 31 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 7. Output characteristics of circuits for low power supply voltage applications Following shows the output current (IOUT) vs. efficiency () and output current (IOUT) vs. output voltage (VOUT) characteristics for conditions 1 and 2 in Table 19. VIN = 0.9 V VIN = 1.2 V VIN = 1.5 V 0.1 1 10 IOUT [mA] 100 1000 η [%] Condition 2 90 80 VIN = 0.9 V 70 VIN = 1.2 V 60 VIN = 1.5 V 50 40 30 20 10 0 0.1 1    90 80 70 60 50 40 30 20 10 0 VOUT [V] η [%] Condition 1 32 10 IOUT [mA] 100 1000                       3.5 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2.5      100 1000 VIN = 0.9 V VIN = 1.2 V VIN = 1.5 V 0.1 1 10 IOUT [mA] STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Characteristics (Typical Data) 1. Examples of Major Power Supply Dependence Characteristics (Ta = 25C) (2) Current consumption during shutdown (ISSS) vs. Input voltage (VIN) 1.0 0.8 ISSS [μA] ISS1 [μA] (1) Current consumption during operation (ISS1) vs. Input voltage (VIN) 700 600 1.2 MHz 500 400 300 600 kHz 200 100 0 1.8 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VIN [V] 0.0 1.8 2.0 1.1 1.0 1.8 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 600 kHz 90 85 1.2 MHz 80 75 70 1.8 2.0 2.5 3.0 3.5 4.0 VIN [V] 3.5 4.0 VIN [V] 4.5 5.0 5.5 650 600 550 500 1.8 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 (5) Soft-start time (tSS) vs. Input voltage (VIN) 10 9 8 7 6 5 4 3 2 1 0 1.8 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VIN [V] tSS [ms] MaxDuty [%] 95 3.0 fOSC = 600 kHz 5.5 (4) Maximum duty ratio (MaxDuty) vs. Input voltage (VIN) 100 2.5 700 fOSC [kHz] fOSC [MHz] 1.2 0.4 0.2 (3) Oscillation frequency (fosc) vs. Input voltage (VIN) fOSC = 1.2 MHz 1.4 1.3 0.6 4.5 5.0 5.5 PFMDuty [%] (6) PWM / PFM switching duty ratio (PFMDuty) vs. Input voltage (VIN) 40 35 30 25 20 15 10 5 0 1.8 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VIN [V] 33 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series (8) Low level input voltage (VSL) vs. Input voltage (VIN) 0.8 0.7 0.7 0.6 0.6 VSL [V] VSH [V] (7) High level input voltage (VSH) vs. Input voltage (VIN) 0.8 0.5 0.4 0.3 1.8 2.0 0.4 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 0.8 0.6 0.5 0.4 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 (11) EXT pin output current “H” (IEXTH) vs. Input voltage (VIN) −300 4.5 5.0 5.5 (12) EXT pin output current “L” (IEXTL) vs. Input voltage (VIN) 300 IEXTH [mA] IEXTH [mA] 3.5 4.0 VIN [V] 250 −200 −150 −100 −50 34 3.0 (10) Short-circuit protection delay time (tPRO) vs. Input voltage (VIN) CSP = 0.1 F 80 70 60 50 40 30 20 10 0 1.8 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VIN [V] −250 0 1.8 2.0 2.5 tPRO [ms] 0.7 VFB [V] 0.3 1.8 2.0 5.5 (9) FB voltage (VFB) vs. Input voltage (VIN) 0.3 1.8 2.0 0.5 200 150 100 50 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 0 1.8 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 2. Examples of Major Temperature Characteristics (Ta = 40 to 85C) fOSC = 600 kHz ISS1 [μA] ISS1 [μA] (1) Current consumption during operation (ISS1) vs. Temperature (Ta) fOSC = 1.2 MHz 700 700 VDD = 5.5 V 600 600 VDD = 5.5 V VDD = 3.6 V 500 500 VDD = 2.0 V VDD = 3.6 V 400 400 300 300 VDD = 2.0 V 200 200 100 100 0 0 −40 −25 0 25 50 75 85 −40 −25 0 Ta [C] 25 Ta [C] 50 75 85 ISSS [μA] (2) Current consumption during shutdown (ISSS) vs. Temperature (Ta) 1.0 0.9 0.8 0.7 0.6 VDD = 5.5 V 0.5 0.4 VDD = 3.6 V 0.3 VDD = 2.0 V 0.2 0.1 0.0 −40 −25 0 25 50 75 85 Ta [C] 1.1 1.0 −40 −25 25 Ta [C] 50 MaxDuty [%] 75 550 25 Ta [C] 50 75 85 −40 −25 0 25 Ta [C] 50 75 85 fOSC = 600 kHz 100 95 90 85 80 75 70 0 VDD = 5.5 V VDD = 3.6 V VDD = 2.0 V 600 75 85 80 −40 −25 650 500 0 (4) Maximum duty ratio (MaxDuty) vs. Temperature (Ta) fOSC = 1.2 MHz 100 VDD = 5.5 V 95 VDD = 3.6 V 90 VDD = 2.0 V 85 70 fOSC [kHz] 1.2 fOSC = 600 kHz 700 MaxDuty [%] fOSC [MHz] (3) Oscillation frequency (fOSC) vs. Temperature (Ta) fOSC = 1.2 MHz 1.4 VDD = 5.5 V VDD = 3.6 V 1.3 VDD = 2.0 V VDD = 5.5 V VDD = 3.6 V VDD = 2.0 V −40 −25 0 25 Ta [C] 50 75 85 35 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 10 9 8 7 6 5 4 3 VDD = 5.5 V VDD = 3.6 V VDD = 2.0 V −40 −25 0 25 Ta [C] 50 75 85 (7) High level input voltage (VSH) vs. Temperature (Ta) 0.8 0.6 VDD = 5.5 V VDD = 3.6 V VDD = 2.0 V (8) Low level input voltage (VSL) vs. Temperature (Ta) 0.8 0.7 VSL [V] VSH [V] 0.7 (6) PWM / PFM switching duty ratio (PFMDuty) vs. Temperature (Ta) 36 34 32 30 28 VDD = 5.5 V 26 VDD = 3.6 V 24 VDD = 2.0 V 22 20 −40 −25 0 25 50 75 85 Ta [C] PFMDuty [%] tSS [ms] (5) Soft-start time (tSS) vs. Temperature (Ta) 0.5 0.4 0.3 0.6 VDD = 5.5 V VDD = 3.6 V VDD = 2.0 V 0.5 0.4 −40 −25 0.3 0 25 Ta [C] 50 75 85 −40 −25 0 25 Ta [C] 50 75 85 (11) FB voltage (VFB) vs. Temperature (Ta) (12) Short-circuit protection delay time (tPRO) vs. Temperature (Ta) CSP = 0.1 F 80 VFB [V] 0.61 VDD = 5.5 V VDD = 3.6 V VDD = 2.0 V 70 tPRO [ms] 0.62 0.60 0.59 0.58 36 VUVLOHYS [V] (10) UVLO hysteresis width (VUVLOHYS) vs. Temperature (Ta) 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0.00 −40 −25 0 25 50 75 85 Ta [C] VUVLO+ [V] (9) UVLO release voltage (VUVLO+) vs. Temperature (Ta) 1.80 1.75 1.70 1.65 1.60 1.55 1.50 1.45 1.40 −40 −25 0 25 50 75 85 Ta [C] 60 VDD = 5.5 V VDD = 3.6 V VDD = 2.0 V 50 40 −40 −25 30 0 25 Ta [C] 50 75 85 −40 −25 0 25 Ta [C] 50 75 85 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series (14) EXT pin output current “L” (IEXTL) vs. Temperature (Ta) IEXTL [mA] IEXTH [mA] (13) EXT pin output current “H” (IEXTH) vs. Temperature (Ta) −350 VDD = 5.5 V −300 VDD = 3.6 V −250 VDD = 2.0 V −200 −150 −100 −50 0 −40 −25 0 25 50 75 85 Ta [C] 0.6 S-8366 Series 0.4 25 Ta [C] 50 75 85 S-8365 Series 0.8 −40 −25 0.6 S-8366 Series 0.4 0.0 0 25 Ta [C] 50 75 85 −40 −25 0 25 Ta [C] 50 75 85 fOSC = 600 kHz VST2 [V] VST2 [V] 0 0.2 (16) Oscillation start voltage (VST2) vs. Temperature (Ta) fOSC = 1.2 MHz 1.4 1.2 1.0 S-8365 Series 0.8 0.6 0.4 S-8366 Series 0.2 0.0 −40 −25 0 25 50 75 85 Ta [C] VHLD [V] (17) Operation holding voltage (VHLD) vs. Temperature (Ta) fOSC = 1.2 MHz 1.4 1.2 1.0 S-8365 Series 0.8 S-8366 Series 0.6 0.4 0.2 0.0 −40 −25 0 25 50 75 85 Ta [C] VHLD [V] −40 −25 fOSC = 600 kHz 0.2 0.0 VDD = 5.5 V VDD = 3.6 V VDD = 2.0 V 1.0 VST1 [V] VST1 [V] (15) Operating start voltage (VST1) vs. Temperature (Ta) fOSC = 1.2 MHz 1.0 S-8365 Series 0.8 350 300 250 200 150 100 50 0 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 S-8365 Series S-8366 Series −40 −25 0 25 Ta [C] 50 75 85 fOSC = 600 kHz 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 S-8365 Series S-8366 Series −40 −25 0 25 Ta [C] 50 75 85 37 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 3. Examples of Transient Response Characteristics Unless otherwise specified, the used parts are those in Table 10 External Parts List. At power-on (VOUT(S) = 5.0 V, VIN = 0 V  3.3 V, PWM control, Ta = 25C)           4.0 3.0 VIN 3.0 2.0 IL 2.0 IL [A] VIN, VOUT [V] 4.0 1.0 0.0 0 5 10 t [ms] 15 (4) fOSC = 600 kHz, IOUT = 600 mA 6.0 5.0 20 S-8365ABBBA 6.0 5.0 VOUT 4.0 4.0 3.0 VIN 3.0 2.0 IL 2.0 1.0 1.0 0.0 0.0 0 5 10 t [ms] 15 20 At power-on (VOUT(S) = 5.0 V, VIN = 0 V  3.3 V, PWM / PFM switching control, Ta = 25C))       5.0   3.0 2.0 IL 0.0 5 10 t [ms] 15 20 6.0 5.0 VOUT 4.0 3.0 4.0 3.0 VIN 2.0 2.0 IL 1.0 1.0 0.0 0 5 10 t [ms] (4) fOSC = 600 kHz, IOUT = 600 mA 6.0 4.0 3.0 S-8366AABBA 0.0 5.0 VIN 0 5.0 6.0 2.0 1.0 (2) fOSC = 1.2 MHz, IOUT = 600 mA 6.0 S-8366ABBBA VOUT 4.0        5.0 15 20 S-8366ABBBA 6.0 5.0 VOUT 4.0 4.0 3.0 VIN 3.0 2.0 IL 2.0 1.0 1.0 0.0 0.0 IL [A] S-8366AABBA 1.0 0.0 0 5 10 t [ms] 15 20 IL [A]        (3) fOSC = 600 kHz, IOUT = 1 mA 6.0 38        5.0 VOUT 1.0 VIN, VOUT [V]    S-8365ABBBA  (1) fOSC = 1.2 MHz, IOUT = 1 mA VIN, VOUT [V]  6.0 0.0 VIN, VOUT [V]            5.0 S-8365AABBA IL [A]  (2) fOSC = 1.2 MHz, IOUT = 600 mA 6.0 VIN, VOUT [V]            (3) fOSC = 600 kHz, IOUT = 1 mA 3.2 S-8365AABBA               (1) fOSC = 1.2 MHz, IOUT = 1 mA IL [A] 3.1 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 Shutdown pin response (VOUT = 5.0 V, VIN = 3.3 V, VON/OFF = 0 V  3.3 V, PWM control, Ta = 25C) 1.0 IL 5 10 t [ms] (3) fOSC = 600 kHz, IOUT = 1 mA 6.0 5.0 0.0 15 4.0 3.0 5.0 4.0 3.0 2.0 0.0 0 5 0.0 10 t [ms] 15 20 2.0 1.0 IL [A] 2.0 IL 1.0 0.0 5 10 t [ms]        15 20 S-8365ABBBA                3.0 4.0 3.0 VON/OFF 2.0 2.0 1.0 1.0 IL 0.0 0.0 0 5 10 t [ms] (3) fOSC = 600 kHz, IOUT = 1 mA 6.0 5.0 15 3.0 4.0 3.0 1.0 IL 0.0 0.0 0 5 10 t [ms] 15 20 4.0 3.0 VON/OFF 2.0 2.0 IL 1.0 1.0 0.0 5 10 t [ms] (4) fOSC = 600 kHz, IOUT = 600 mA 6.0 5.0 2.0 1.0 3.0 0 6.0 VON/OFF 5.0 0.0 S-8366ABBBA 2.0 6.0 VOUT 4.0 20 VOUT 4.0 5.0 S-8366AABBA IL [A] 5.0 VOUT 4.0 (2) fOSC = 1.2 MHz, IOUT = 600 mA 6.0 6.0 5.0 15 20 S-8366ABBBA 6.0 5.0 VOUT 4.0 3.0 4.0 3.0 VON/OFF 2.0 2.0 IL 1.0 1.0 0.0 0.0 0 5 10 t [ms] 15 20 39 IL [A] 5.0 S-8366AABBA VON/OFF, VOUT [V] (1) fOSC = 1.2 MHz, IOUT = 1 mA 6.0 VON/OFF, VOUT [V] 3.0 Shutdown pin response (VOUT = 5.0 V, VIN = 3.3 V, VON/OFF = 0 V  3.3 V, PWM / PFM switching control, Ta = 25C) VON/OFF, VOUT [V] 3.4 1.0 IL 4.0 VON/OFF (4) fOSC = 600 kHz, IOUT = 600 mA 6.0 2.0 1.0 3.0 0 S-8365ABBBA VON/OFF 5.0 VOUT 4.0 20 VOUT 6.0 0.0    1.0 5.0 S-8365AABBA   2.0 2.0 VON/OFF, VOUT [V] 3.0 VON/OFF 0 VON/OFF, VOUT [V] 4.0 IL [A] 3.0 0.0 VON/OFF, VOUT [V] 5.0 VOUT 4.0 (2) fOSC = 1.2 MHz, IOUT = 600 mA 6.0 6.0 IL [A] 5.0 S-8365AABBA IL [A] VON/OFF, VOUT [V] (1) fOSC = 1.2 MHz, IOUT = 1 mA 6.0 IL [A] 3.3 S-8365/8366 Series STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series Power supply voltage fluctuations (VOUT = 5.0 V, IOUT = 1 mA, PWM control, Ta = 25C) 4.90 8 6 VIN 4.85 4 4.80 2 4.75 0 0 2 4 6 8 10        t [ms]                 (4) fOSC = 600 kHz, VIN = 3.8 V  2.8 V                           (2) fOSC = 1.2 MHz, VIN = 3.8 V  2.8 V 5.15 5.10 8 5.05 VOUT 5.00 4.95 6 4 VIN 0 2 4 6 8 VOUT [V] 10 5.05 4.85   4.95 4.90 0 4.85 10 (3) fOSC = 600 kHz, VIN = 2.8 V  3.8 V 5.15 8 6 5.00 4.95 4 VIN 4.90 2 0 4.85 0 2 4 6 t [ms] 8 10   VOUT 5.05 VIN [V] 10 5.10 4 2 0 0.4 0.8 1.2 t [ms] (4) fOSC = 600 kHz, VIN = 3.8 V  2.8 V        6 VIN 0.0 S-8366ABBBA 12 8 VOUT 5.00 2 S-8366AABBA 12 10 t [ms] VOUT [V] S-8365ABBBA VIN [V] S-8366AABBA 12 5.10 4.90 40   Power supply voltage fluctuations (VOUT = 5.0 V, IOUT = 1 mA, PWM / PFM switching control, Ta = 25C) (1) fOSC = 1.2 MHz, VIN = 2.8 V  3.8 V 5.15 VOUT [V]         1.6 2.0 S-8366ABBBA                  3.6 S-8365ABBBA           VIN [V]   (3) fOSC = 600 kHz, VIN = 2.8 V  3.8 V S-8365AABBA   10 VOUT 4.95 (2) fOSC = 1.2 MHz, VIN = 3.8 V  2.8 V   VOUT [V] 5.00 S-8365AABBA 12   (1) fOSC = 1.2 MHz, VIN = 2.8 V  3.8 V 5.05 VIN [V] 3.5 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 Power supply voltage fluctuations (VOUT = 5.0 V, IOUT = 500 mA, PWM control, Ta = 25C) (3) fOSC = 600 kHz, VIN = 2.8 V  3.8 V (4) fOSC = 600 kHz, VIN = 3.8 V  2.8 V S-8365ABBBA 16 5.60 5.40 14 5.20 12 VOUT 5.00 10 4.80 8 4.60 6 4.40 4 VIN 4.20 2 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms]                             VOUT [V] VIN [V] VOUT [V] (4) fOSC = 600 kHz, VIN = 3.8 V  2.8 V S-8366ABBBA 16 5.60 5.40 14 5.20 12 5.00 10 4.80 8 4.60 6 4.40 4 4.20 2 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms] VIN [V] (3) fOSC = 600 kHz, VIN = 2.8 V  3.8 V S-8366ABBBA 16 5.60 5.40 14 5.20 12 VOUT 5.00 10 4.80 8 4.60 6 VIN 4.40 4 4.20 2 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms] VOUT [V] (2) fOSC = 1.2 MHz, VIN = 3.8 V  2.8 V S-8366AABBA 16 5.60 5.40 14 5.20 12 VOUT 5.00 10 4.80 8 4.60 6 4.40 4 VIN 4.20 2 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms] 41 VIN [V] Power supply voltage fluctuations (VOUT = 5.0 V, IOUT = 500 mA, PWM / PFM switching control, Ta = 25C) (1) fOSC = 1.2 MHz, VIN = 2.8 V  3.8 V S-8366AABBA 16 5.60 5.40 14 5.20 12 VOUT 5.00 10 4.80 8 4.60 6 VIN 4.40 4 4.20 2 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms] VOUT [V]   S-8365AABBA VIN [V]                  VOUT [V] VIN [V] 3.8 S-8365ABBBA                  (2) fOSC = 1.2 MHz, VIN = 3.8 V  2.8 V VOUT [V] (1) fOSC = 1.2 MHz, VIN = 2.8 V  3.8 V S-8365AABBA 16 5.60 5.40 14 5.20 12 VOUT 5.00 10 4.80 8 4.60 6 VIN 4.40 4 4.20 2 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms] VIN [V] 3.7 S-8365/8366 Series STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series Load fluctuations (VOUT = 5.0 V, VIN = 3.3 V, IOUT = 0.1 mA  100 mA  0.1 mA, PWM control, Ta = 25C) VOUT [V]        (4) fOSC = 600 kHz, IOUT = 100 mA  0.1 mA S-8366ABBBA 1600 5.40 5.30 1400 5.20 1200 5.10 1000 VOUT 5.00 800 4.90 600 4.80 400 4.70 200 IOUT 0 4.60 0 5 10 15 20 25 30 35 40 t [ms] IOUT [mA]       (3) fOSC = 600 kHz, IOUT = 0.1 mA  100 mA S-8366ABBBA 1600 5.40 5.30 1400 5.20 1200 5.10 1000 VOUT 5.00 800 4.90 600 4.80 400 IOUT 4.70 200 0 4.60 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 t [ms] 42  (2) fOSC = 1.2 MHz, IOUT = 100 mA  0.1 mA S-8366AABBA           IOUT [mA]   (1) fOSC = 1.2 MHz, IOUT = 0.1 mA  100 mA S-8366AABBA                          Load fluctuations (VOUT = 5.0 V, VIN = 3.3 V, IOUT = 0.1 mA  100 mA  0.1 mA, PWM / PFM switching control, Ta = 25C) VOUT [V] 3.10              (4) fOSC = 600 kHz, IOUT = 100 mA  0.1 mA S-8365ABBBA   VOUT [V] (3) fOSC = 600 kHz, IOUT = 0.1 mA  100 mA S-8365ABBBA 1600 5.40 5.30 1400 5.20 1200 5.10 1000 VOUT 5.00 800 4.90 600 4.80 400 IOUT 4.70 200 0 4.60 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 t [ms] (2) fOSC = 1.2 MHz, IOUT = 100 mA  0.1 mA S-8365AABBA IOUT [mA] VOUT [V] (1) fOSC = 1.2 MHz, IOUT = 0.1 mA  100 mA S-8365AABBA 1600 5.40 5.30 1400 5.20 1200 5.10 1000 VOUT 5.00 800 4.90 600 4.80 400 IOUT 4.70 200 0 4.60 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 t [ms] IOUT [mA] 3.9 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02         (4) fOSC = 600 kHz, IOUT = 300 mA  0.1 mA S-8366ABBBA 5.60 5.40 5.20 VOUT 5.00 4.80 4.60 4.40 4.20 IOUT 4.00 0 10 20 30 40 50 t [ms] 1600 1400 1200 1000 800 600 400 200 0 43 IOUT [mA] IOUT [mA] IOUT [mA] IOUT [mA]              (2) fOSC = 1.2 MHz, IOUT = 300 mA  0.1 mA S-8366AABBA 1600 5.60 5.40 1400 5.20 1200 5.00 1000 VOUT 4.80 800 4.60 600 4.40 400 4.20 200 IOUT 0 4.00 0 5 10 15 20 25 30 35 40 t [ms] VOUT [V] VOUT [V] (3) fOSC = 600 kHz, IOUT = 0.1 mA  300 mA S-8366ABBBA   VOUT [V] Load fluctuations (VOUT = 5.0 V, VIN = 3.3 V, IOUT = 0.1 mA  300 mA  0.1 mA, PWM / PFM switching control, Ta = 25C) (1) fOSC = 1.2 MHz, IOUT = 0.1 mA  300 mA S-8366AABBA 1600 5.60 5.40 1400 5.20 1200 VOUT 5.00 1000 4.80 800 4.60 600 IOUT 4.40 400 4.20 200 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms]            (4) fOSC = 600 kHz, IOUT = 300 mA  0.1 mA S-8365ABBBA 1600 5.60 5.40 1400 5.20 1200 5.00 1000 VOUT 4.80 800 4.60 600 4.40 400 4.20 200 IOUT 0 4.00 0 5 10 15 20 25 30 35 40 t [ms] VOUT [V] 3.12 (2) fOSC = 1.2 MHz, IOUT = 300 mA  0.1 mA S-8365AABBA 1600 5.60 5.40 1400 5.20 1200 5.00 1000 VOUT 4.80 800 4.60 600 4.40 400 4.20 200 IOUT 0 4.00 0 5 10 15 20 25 30 35 40 t [ms] VOUT [V] VOUT [V] (3) fOSC = 600 kHz, IOUT = 0.1 mA  300 mA S-8365ABBBA 1600 5.60 5.40 1400 5.20 1200 VOUT 5.00 1000 4.80 800 4.60 600 IOUT 4.40 400 4.20 200 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms] IOUT [mA] VOUT [V] (1) fOSC = 1.2 MHz, IOUT = 0.1 mA  300 mA S-8365AABBA 1600 5.60 5.40 1400 5.20 1200 VOUT 5.00 1000 4.80 800 4.60 600 IOUT 4.40 400 4.20 200 0 4.00 0.0 0.2 0.4 0.6 0.8 1.0 t [ms] IOUT [mA] Load fluctuations (VOUT = 5.0 V, VIN = 3.3 V, IOUT = 0.1 mA  300 mA  0.1 mA, PWM control, Ta = 25C) IOUT [mA] 3.11 S-8365/8366 Series STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Reference Data Reference data is provided to determine specific external components. Therefore, the following data shows the characteristics of the recommended external components selected for various applications. 1. External parts Table 20 Efficiency vs. Output Current Characteristics and Output Voltage vs. Output Current Characteristics for External Parts (1 / 2) Oscillation Control Output L M1 SD Condition Product Name Frequency System Voltage 1 2 3 4 5 6 7 8 9 10 11 12 S-8365AABBA S-8365ABBBA S-8366AABBA S-8366ABBBA S-8365AABBA S-8365ABBBA S-8366AABBA S-8366ABBBA S-8365AABBA S-8365ABBBA S-8366AABBA S-8366ABBBA 1.2 MHz 600 kHz 1.2 MHz 600 kHz 1.2 MHz 600 kHz 1.2 MHz 600 kHz 1.2 MHz 600 kHz 1.2 MHz 600 kHz PWM PWM PWM / PFM PWM / PFM PWM PWM PWM / PFM PWM / PFM PWM PWM PWM / PFM PWM / PFM 2.5 V 2.5 V 2.5 V 2.5 V 3.3 V 3.3 V 3.3 V 3.3 V 5.0 V 5.0 V 5.0 V 5.0 V NR6028T-2R2M LTF5022T-3R3M NR6028T-2R2M LTF5022T-3R3M NR6028T-2R2M LTF5022T-3R3M NR6028T-2R2M LTF5022T-3R3M NR6028T-2R2M LTF5022T-3R3M NR6028T-2R2M LTF5022T-3R3M MCH3406 MCH3406 MCH3406 MCH3406 MCH3406 MCH3406 MCH3406 MCH3406 MCH3406 MCH3406 MCH3406 MCH3406 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 RB050LA-30 Table 20 Efficiency vs. Output Current Characteristics and Output Voltage vs. Output Current Characteristics for External Parts (2 / 2) Condition CIN COUT RFB1 RFB2 CFB CDD 1 C2012X5R1A106KT GRM31CR71A106KA  2 47 k 15 k 68 pF 0.1 F 2 C2012X5R1A106KT GRM31CR71A106KA  2 47 k 15 k 82 pF 0.1 F 3 C2012X5R1A106KT GRM31CR71A106KA  2 47 k 15 k 68 pF 0.1 F 4 C2012X5R1A106KT GRM31CR71A106KA  2 47 k 15 k 82 pF 0.1 F 5 C2012X5R1A106KT GRM31CR71A106KA  2 68 k 15 k 68 pF 0.1 F 6 C2012X5R1A106KT GRM31CR71A106KA  2 68 k 15 k 82 pF 0.1 F 7 C2012X5R1A106KT GRM31CR71A106KA  2 68 k 15 k 68 pF 0.1 F 8 C2012X5R1A106KT GRM31CR71A106KA  2 68 k 15 k 82 pF 0.1 F 9 C2012X5R1A106KT GRM31CR71A106KA  2 110 k 15 k 56 pF 0.1 F 10 C2012X5R1A106KT GRM31CR71A106KA  2 110 k 15 k 68 pF 0.1 F 11 C2012X5R1A106KT GRM31CR71A106KA  2 110 k 15 k 56 pF 0.1 F 12 C2012X5R1A106KT GRM31CR71A106KA  2 110 k 15 k 68 pF 0.1 F 44 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series The properties of the external parts are shown below. Table 21 Part Part Name NR6028T-2R2M Inductor LTF5022T-3R3M Diode RB050LA-30 Transistor MCH3406 C2012X5R1A106KT Capacitor C1005X7R1C104KT GRM31CR71A106KA * 1. DCR : * 2. IMAX : * 3. VF : * 4. IF : * 5. VR : * 6. VDSS : * 7. VGSS : * 8. ID : * 9. QG : *10. RDS(ON ): *11. VGS : *12. EDC : Characteristics of External Parts Manfuacturer Characteristics 2.2 H, DCR*1 = 0.020 , IMAX*2 = 4.2 A, Taiyo Yuden Co., Ltd. L  W  H = 6.0  6.0  2.8 mm 3.3 H, DCR*1 = 0.060 , IMAX*2 = 2.7 A, TDK Corporation L  W  H = 5.0  5.2  2.2 mm VF*3 = 0.45 V, IF*4 = 3.0 A, VR*5 = 30 V Rohm Co., Ltd. L  W  H = 4.7  2.6  1.05 mm VDSS*6 = 20 V, VGSS*7 = 10 V, ID*8 = 3.0 A, QG*9 = 8.8 nC typ., Sanyo Semiconductor Co., Ltd. RDS(ON)*10 = 0.082  max. (VGS*11 = 2.5 V) L  W  H = 2.1  2.0  0.85 mm 10 F, EDC*12 = 10 V, X5R, L  W  H = 2.0  1.25  1.45 mm TDK Corporation 0.1 F, EDC*12 = 16 V, X7R, L  W  H = 1.0  0.5  0.55 mm 10 F, EDC*12 = 10 V, X7R, Murata Manufacturing, Co., Ltd. L  W  H = 3.2  1.6  1.6 mm DC resistance Maximum allowable current Forward voltage Forward current Reverse voltage Drain-source voltage (during short-circuiting between the gate and source) Gate-source voltage (during short-circuiting between the drain and source) Drain current Gate charge On-resistance between the drain and source Gate-source voltage Rated voltage Caution The values shown in the characteristics column of Table 21 above are based on the materials provided by each manufacture. However, consider the characteristics of the original materials when using the above products. 45 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 2. Output Current (IOUT) vs. Efficiency () Characteristics, Output Current (IOUT) vs. Output Voltage (VOUT) Characteristics Following shows the actual output current (IOUT) vs. efficiency () and output current (IOUT) vs. output voltage (VOUT) characteristics for conditions 1 to 12 in Table 20. 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V 0.1 100 90 80 70 60 50 40 30 20 10 0 1000 10000 1 1 10 100 IOUT [mA] 1000 10000 10 100 IOUT [mA] 1000 2.60 2.55 2.50 2.45 2.40 2.35 2.30 2.25 2.20 2.15 2.10 2.05 2.00 10000 1000 10000 1000 10000 1000 10000 VIN = 1.8 V 0.1 1 10 100 IOUT [mA] S-8366AABBA (VOUT(S) = 2.5 V) 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V 0.1 Condition 4 VIN = 1.8 V 0.1 VOUT [V] VIN = 1.8 V Condition 3 η [%] 10 100 IOUT [mA] 2.60 2.55 2.50 2.45 2.40 2.35 2.30 2.25 2.20 2.15 2.10 2.05 2.00 S-8365ABBBA (VOUT(S) = 2.5 V) 0.1 η [%] 1 1 10 100 IOUT [mA] VOUT [V] η [%] Condition 2 1000 2.60 2.55 2.50 2.45 2.40 2.35 2.30 2.25 2.20 2.15 2.10 2.05 2.00 10000 VIN = 1.8 V 0.1 1 10 100 IOUT [mA] S-8366ABBBA (VOUT(S) = 2.5 V) 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V 0.1 46 VOUT [V] S-8365AABBA (VOUT(S) = 2.5 V) 1 10 100 IOUT [mA] 1000 VOUT [V] η [%] Condition 1 10000 2.60 2.55 2.50 2.45 2.40 2.35 2.30 2.25 2.20 2.15 2.10 2.05 2.00 VIN = 1.8 V 0.1 1 10 100 IOUT [mA] STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 10 100 IOUT [mA] 1000 10000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 1 1 10 100 IOUT [mA] 1000 10000 10 100 IOUT [mA] 1000 3.5 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2.5 10000 1000 10000 1000 10000 1000 10000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 1 10 100 IOUT [mA] S-8366AABBA (VOUT(S) = 3.3 V) 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 Condition 8 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 VOUT [V] 100 90 80 70 60 50 40 30 20 10 0 Condition 7 3.5 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2.5 S-8365ABBBA (VOUT(S) = 3.3 V) 0.1 η [%] 1 VOUT [V] η [%] Condition 6 η [%] VOUT [V] S-8365AABBA (VOUT(S) = 3.3 V) 1 10 100 IOUT [mA] 1000 3.5 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2.5 10000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 1 10 100 IOUT [mA] S-8366ABBBA (VOUT(S) = 3.3 V) 100 90 80 70 60 50 40 30 20 10 0 VOUT [V] η [%] Condition 5 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 1 10 100 IOUT [mA] 1000 10000 3.5 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2.5 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 1 10 100 IOUT [mA] 47 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 10000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V Condition 11 η [%] 1000 1 10 100 IOUT [mA] 1000 1 1 10 100 IOUT [mA] 1000 10000 5.2 5.1 5.0 4.9 4.8 4.7 4.6 4.5 4.4 4.3 4.2 1000 10000 1000 10000 1000 10000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 0.1 1 10 100 IOUT [mA] 10 100 IOUT [mA] 1000 5.2 5.1 5.0 4.9 4.8 4.7 4.6 4.5 4.4 4.3 4.2 10000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 0.1 1 10 100 IOUT [mA] S-8366ABBBA (VOUT(S) = 5.0 V) 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 0.1 0.1 10000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V Condition 12 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V S-8366AABBA (VOUT(S) = 5.0 V) 100 90 80 70 60 50 40 30 20 10 0 0.1 5.2 5.1 5.0 4.9 4.8 4.7 4.6 4.5 4.4 4.3 4.2 S-8365ABBBA (VOUT(S) = 5.0 V) 100 90 80 70 60 50 40 30 20 10 0 0.1 η [%] 10 100 IOUT [mA] VOUT [V] η [%] Condition 10 1 VOUT [V] 0.1 48 VOUT [V] S-8365AABBA (VOUT(S) = 5.0 V) 1 10 100 IOUT [mA] VOUT [V] η [%] Condition 9 1000 10000 5.2 5.1 5.0 4.9 4.8 4.7 4.6 4.5 4.4 4.3 4.2 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 0.1 1 10 100 IOUT [mA] STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 3. Output Current (IOUT) vs. Ripple Voltage (Vr) Characteristics Following shows the actual output current (IOUT) vs. ripple voltage (Vr) characteristics for conditions of 1 to 12 in Table 20. Vr [V] 1 10 100 IOUT [mA] 1000 100 90 80 70 60 50 40 30 20 10 0 Condition 4 VIN = 1.8 V 0.1 Condition 5 1 10 100 IOUT [mA] 1000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 Condition 7 1 10 100 IOUT [mA] 1000 100 90 80 70 60 50 40 30 20 10 0 0.1 1 10 100 IOUT [mA] 1000 10000 1000 10000 S-8366ABBBA (VOUT(S) = 2.5 V) 1 10 100 IOUT [mA] 1000 Condition 6 S-8365ABBBA (VOUT(S) = 3.3 V) 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 Condition 8 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 10 100 IOUT [mA] VIN = 1.8 V 0.1 10000 S-8366AABBA (VOUT(S) = 3.3 V) 1 100 90 80 70 60 50 40 30 20 10 0 10000 S-8365AABBA (VOUT(S) = 3.3 V) 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V 0.1 Vr [V] S-8366AABBA (VOUT(S) = 2.5 V) S-8365ABBBA (VOUT(S) = 2.5 V) 100 90 80 70 60 50 40 30 20 10 0 10000 Vr [V] Vr [V] Condition 3 Vr [V] Condition 2 VIN = 1.8 V 0.1 Vr [V] S-8365AABBA (VOUT(S) = 2.5 V) 100 90 80 70 60 50 40 30 20 10 0 Vr [V] Vr [V] Condition 1 1 10 100 IOUT [mA] 1000 10000 10000 S-8366ABBBA (VOUT(S) = 3.3 V) 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V 0.1 1 10 100 IOUT [mA] 1000 10000 49 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series Condition 11 Vr [V] Condition 10 100 90 80 70 60 50 40 30 20 10 0 1 10 100 IOUT [mA] Vr [V] VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 0.1 1000 S-8366AABBA (VOUT(S) = 5.0 V) 1 10 100 IOUT [mA] 1000 10000 S-8365ABBBA (VOUT(S) = 5.0 V) 100 90 80 70 60 50 40 30 20 10 0 10000 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 0.1 50 S-8365AABBA (VOUT(S) = 5.0 V) 100 90 80 70 60 50 40 30 20 10 0 VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 0.1 Condition 12 Vr [V] Vr [V] Condition 9 100 90 80 70 60 50 40 30 20 10 0 1 10 100 IOUT [mA] 1000 10000 S-8366ABBBA (VOUT(S) = 5.0 V) VIN = 1.8 V VIN = 2.4 V VIN = 3.0 V VIN = 4.2 V 0.1 1 10 100 IOUT [mA] 1000 10000 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series  Marking Specifications 1. SNT-6A Top view 6 5 (1) to (3): (4) to (6): 4 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) (5) (6) 1 2 3 Product name vs. Product code (a) S-8365 Series (b) S-8366 Series Product code (1) (2) (3) U Q A U Q C U Q G U Q I U Q K U Q O Product name S-8365AAAAA-I6T1U2 S-8365AAABA-I6T1U2 S-8365AABBA-I6T1U2 S-8365ABAAA-I6T1U2 S-8365ABABA-I6T1U2 S-8365ABBBA-I6T1U2 2. Product name S-8366AAAAA-I6T1U2 S-8366AAABA-I6T1U2 S-8366AABBA-I6T1U2 S-8366ABAAA-I6T1U2 S-8366ABABA-I6T1U2 S-8366ABBBA-I6T1U2 (1) U U U U U U Product code (2) (3) Q R Q T Q X Q Z Q 3 Q 7 SOT-23-5 Top view 5 (1) to (3): (4): 4 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code (a) S-8365 Series Product name S-8365AAAAA-M5T1y2 S-8365AAABA-M5T1y2 S-8365ABAAA-M5T1y2 S-8365ABABA-M5T1y2 (b) S-8366 Series Product code (1) (2) (3) U Q A U Q C U Q I U Q K Product name S-8366AAAAA-M5T1y2 S-8366AAABA-M5T1y2 S-8366ABAAA-M5T1y2 S-8366ABABA-M5T1y2 (1) U U U U Product code (2) (3) Q R Q T Q Z Q 3 Remark 1. y: S or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 51 STEP-UP, SUPER-SMALL PACKAGE, 1.2 MHz PWM CONTROL or PWM/PFM SWITCHABLE SWITCHING REGULATOR CONTROLLER Rev.2.1_02 S-8365/8366 Series 3. SOT-23-6 Top view 6 5 (1) to (3) : (4) : 4 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code (a) S-8365 Series Product name S-8365AABBA-M6T1y2 S-8365ABBBA-M6T1y2 (b) S-8366 Series Product code (1) (2) (3) U Q G U Q O Product name S-8366AABBA-M6T1y2 S-8366ABBBA-M6T1y2 (1) U U Product code (2) (3) Q X Q 7 Remark 1. y: S or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 52 1.57±0.03 6 1 5 4 2 3 +0.05 0.08 -0.02 0.5 0.48±0.02 0.2±0.05 No. PG006-A-P-SD-2.1 TITLE SNT-6A-A-PKG Dimensions No. PG006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 0.25±0.05 +0.1 1.85±0.05 ø0.5 -0 4.0±0.1 0.65±0.05 3 2 1 4 5 6 Feed direction No. PG006-A-C-SD-2.0 TITLE SNT-6A-A-Carrier Tape No. PG006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PG006-A-R-SD-1.0 SNT-6A-A-Reel TITLE No. PG006-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 5,000 0.52 1.36 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package ( 1.30 mm ~ 1.40 mm ). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) No. PG006-A-L-SD-4.1 TITLE SNT-6A-A -Land Recommendation No. PG006-A-L-SD-4.1 ANGLE UNIT mm ABLIC Inc. 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 2.9±0.2 1.9±0.2 6 0.95 4 5 1 2 3 +0.1 0.15 -0.05 0.95 0.35±0.15 No. MP006-A-P-SD-2.1 TITLE SOT236-A-PKG Dimensions No. MP006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 6 Feed direction No. MP006-A-C-SD-3.1 TITLE SOT236-A-Carrier Tape No. MP006-A-C-SD-3.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP006-A-R-SD-2.1 TITLE SOT236-A-Reel No. MP006-A-R-SD-2.1 ANGLE QTY UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8366ABABA-M5T1U2 价格&库存
很抱歉,暂时无法提供与“S-8366ABABA-M5T1U2”相匹配的价格&库存,您可以联系我们找货
