NBB10-30GM50-WS
NBB10-30GM50-WS
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    INDUCTIVE SEN 10MM NO
NBB10-30GM50-WS 数据手册
Inductive sensor NBB10-30GM50-WS < Basic series < 10 mm flush < 2-wire AC Dimensions 47 50 5 M30 x 1.5 36 LED(s) Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 801648_eng.pdf ø 28.2 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn Installation 10 mm flush Output polarity AC Assured operating distance sa 0 ... 8.1 mm Actual operating distance sr 9 ... 11 mm Reduction factor rAl 0.33 Reduction factor rCu 0.28 Reduction factor r304 0.81 Output type 2-wire Nominal ratings Operating voltage UB 20 ... 253 V Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB10-30GM50-WS Technical Data Switching frequency f 0 ... 20 Hz Hysteresis H typ. 5 % Reverse polarity protection reverse polarity tolerant Voltage drop Ud Momentary current (20 ms, 0.1 Hz) < 5 V (IL > 50 mA); < 8 V (IL < 50 mA) 0 ... 1600 mA Operating current IL 5 ... 200 mA Off-state current Ir 0 ... 1.7 mA Operating voltage indicator LED, green Switching state indicator LED, yellow Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.75 mm2 Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Cable Cable diameter 6.4 mm ± 0.2 mm Bending radius > 10 x cable diameter 1) Note In the temperature range below 0 °C, permissible operating voltage Ub 80...253 V Safety fuse ≤ 0.3 A (quick-blow) according to IEC 60127-2 Sheet 1 Recommendation: after a short circuit, check that the device is functioning correctly. Connection BN Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 801648_eng.pdf L BU N GN/YE Accessories BF 30 Mounting flange, 30 mm EXG-30 Quick mounting bracket with dead stop Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB10-30GM50-WS 价格&库存
很抱歉,暂时无法提供与“NBB10-30GM50-WS”相匹配的价格&库存,您可以联系我们找货
