NBN8-18GM60-WS-V12
NBN8-18GM60-WS-V12
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 8MM NO
NBN8-18GM60-WS-V12 数据手册
Inductive sensor NBN8-18GM60-WS-V12 < 8 mm non-flush < 2-wire AC Dimensions 60 50 4 39 10 M18 x 1 ø16.5 24 LEDs 1/2" -20 UN / 2A Technical Data General specifications Switching function Normally open (NO) Output type Two-wire Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 131309_eng.pdf Rated operating distance sn Installation 8 mm non-flush Output polarity AC Assured operating distance sa 0 ... 6.48 mm Actual operating distance sr 7.2 ... 8.8 mm typ. 8 mm Reduction factor rAl 0.4 Reduction factor rCu 0.4 Reduction factor r304 0.7 Output type 2-wire Nominal ratings Operating voltage UB 20 ... 253 V Switching frequency f 0 ... 20 Hz Hysteresis H typ. 7.5 % Reverse polarity protection Voltage drop Momentary current (20 ms, 0.1 Hz) reverse polarity tolerant Ud < 5 V (IL > 50 mA); < 8 V (IL < 50 mA) 0 ... 1600 mA Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBN8-18GM60-WS-V12 Technical Data Operating current IL 5 ... 200 mA Off-state current Ir 0 ... 1.7 mA typ. Time delay before availability tv ≤ 30 ms Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 1103 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector plug 1/2"-20 UN , 3-pin Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Note 1) In the temperature range below 0 °C, permissible operating voltage Ub 80...253 V Safety fuse ≤ 0.8 A (quick-blow) according to IEC 60127-2 Sheet 1 Recommendation: after a short circuit, check that the device is functioning correctly. Connection 2 L 3 N Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 131309_eng.pdf 1 Connection Assignment 1 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBN8-18GM60-WS-V12 Wire colors 1 2 3 GN (green) RD/BK (red/black) RD/WH (red/white) Accessories Mounting flange, 18 mm V12-G-YE2M-PVC Connecting cable, 1/2" - 20 UNF, 3-pin, PVC cable Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 131309_eng.pdf BF 18 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBN8-18GM60-WS-V12 价格&库存
很抱歉,暂时无法提供与“NBN8-18GM60-WS-V12”相匹配的价格&库存,您可以联系我们找货
