NMB5-18GM65-E2-C-FE-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    IND SEN 5MM PNP XYLAN COATED SS
NMB5-18GM65-E2-C-FE-V1 数据手册
Inductive sensor NMB5-18GM65-E2-C-FE-V1 < < < < < < Stainless steel sensing face Sensing range 5 mm 3-wire DC Weld field immune Weld slag resistant coating Ferrous targets 65 42 50 55 4 M18x1 2.5 Dimensions 24 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 908447_eng.pdf 6 LEDs M12x1 Technical Data General specifications Switching function Normally open (NO) Output type PNP Rated operating distance Installation sn 5 mm flush Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NMB5-18GM65-E2-C-FE-V1 Technical Data Output polarity DC Assured operating distance sa 0 ... 4.05 mm Actuating element Ferrous targets Reduction factor rAl 0 Reduction factor rCu 0 Reduction factor r304 0.6 - 0.8 Reduction factor rSt37 1 Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 5 Hz Hysteresis H 3 ... 15 typ. 5 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤2V Operating current IL 0 ... 200 mA Current consumption Off-state current < 14 mA Ir ≤ 10 µA Operating voltage indicator LED, green Switching state indicator Multihole-LED, yellow Mag. Field strength, AC fields 250 mT Mag. Field strength, DC fields 250 mT Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 908447_eng.pdf Mechanical specifications Connection type V1 connector (M12 x 1), 4-pin Housing material Xylan coated - Stainless steel 1.4305 / AISI 303 Sensing face Xylan coated - Stainless steel 1.4305 / AISI 303 Degree of protection IP67 / IP68 / IP69K - cordset dependent according to cable specification Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NMB5-18GM65-E2-C-FE-V1 Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Mounting aid V1-G-OR2M-POC Female cordset single-ended M12 A-coded 4-pin, TPE cable welding-bead resistant orange Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 908447_eng.pdf AB-18 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NMB5-18GM65-E2-C-FE-V1 价格&库存
很抱歉,暂时无法提供与“NMB5-18GM65-E2-C-FE-V1”相匹配的价格&库存,您可以联系我们找货
