NBB1-4GM22-E2
NBB1-4GM22-E2
    PEPPERL+FUCHS(倍加福)
    Cylinder, Threaded - M4
    INDUCTIVE SEN 1MM PNP
NBB1-4GM22-E2 数据手册
Inductive sensor NBB1-4GM22-E2 < 1 mm flush < Miniature design 2 16.5 22 Dimensions 7 LED M4 x 0.5 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 206385_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation flush Output polarity Assured operating distance 1 mm DC sa 0 ... 0.81 mm Reduction factor rAl 0.4 Reduction factor rCu 0.29 Reduction factor r304 0.76 Reduction factor rBrass 0.46 Output type 3-wire Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 700 Hz Hysteresis H typ. 5% Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB1-4GM22-E2 Technical Data Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 100 mA Off-state current Ir 0 ... 0.1 mA typ. at 25 °C No-load supply current I0 ≤ 10 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 1340 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PUR , 2 m Core cross-section 0.055 mm2 Housing material Stainless steel 1.4305 / AISI 303 Sensing face PC Degree of protection IP67 Cable Cable diameter 2.6 mm ± 0.1 mm Bending radius > 10 x cable diameter Connection BN L+ Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 206385_eng.pdf BK BU L- Accessories BF 4 Mounting flange, 4 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB1-4GM22-E2 价格&库存
很抱歉,暂时无法提供与“NBB1-4GM22-E2”相匹配的价格&库存,您可以联系我们找货
