Proximity Sensors Inductive
Extended Range, Aluminium Micro Switch Housing
Type IG12FSF04DO, DC, 2-wire
Sensing distance: 4 mm
Flush type
Power supply: 10 to 40 VDC
Output: Transistor
Make or Break switching
Protection: Reverse polarity, short-circuit and transients
2 m cable - PUR/PVC
Dimensions:
Body: 30 x 19 x 15 mm
Tip: Ø12 x 16 mm
Product Description
Ordering Key
Flush mountable inductive
proximity switch in micro
switch aluminium housing
with 2 m PUR cable. This
type of sensor can replace
mechanical limit switches.
Ind. proximity switch
Housing style
Sensing surface size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
The sensor has an extreme
low No-load supply current
of typical 0.3 mA. Mounting
with 4 mm captive screws or
3 mm screws (front mounted).
IG12FSF04DO
Type Selection
Housing
dimensions
Connection
Rated
operating dist. (Sn)
Ordering no.
2 wire DC, Normally open
Ordering no.
2 wire DC, Normally closed
30 x 19 x 15 mm
Cable
4 mm 1)
IG 12 FSF 04 DO
IG 12 FSF 04 DC
1)
For flush mounting in metal
Specifications
Rated operational volt. (Ue)
(UB)
Ripple
Rated operational current (Ie)
Continuous
No-load supply current (I)
Voltage drop (Ud)
Protection
12 to 36 VDC
10 to 40 VDC (ripple included)
≤ 10%
≤ 5-100 mA
≤ 0.4 mA
≤ 3 VDC at max. load
Reverse polarity,
short-circuit, transients
Transient voltage
≤ 1 kV/500 Ω
Power ON delay
< 100 ms
Frequency of op. cycles (f)
1 kHz
Repeat accuracy (R)
≤ 10%
Hysteresis (H) (Differential travel) 1 to 20% of sensing distance
Assured operating dist. (Sa)
0 ≤ Sa ≤ 0.81 Sn
Effective operating dist. (Sr)
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
Usable operating dist. (Sm)
0.9 x Sr ≤ Su ≤ 1.1 x Sr
Ambient temperature
Operating
-25° to +70°C (-13° to +158°F)
Storage
-30° to +80°C (-22° to +176°F)
Specifications are subject to change without notice (07.03.05)
Degree of protection
Housing material
Body
Front
Connection
Cable
Mounting
Weight (cable included 2 m)
IP 67 (Nema 1, 3, 4, 6, 13)
Anodized Aluminium, type
EN AW-6802
Anodized Aluminium and
grey thermoplastic polyester
(CPBT)
2 m, 2 x 0.34 mm2, Ø5.1 mm
grey PUR/PVC, oil proof
2 x M4 screws for side
mounting or
2 x M3 screws for front
mounting
Approx. 85 g
1
IG12FSF04D., DC, 2-wire
Dimensions
Wiring Diagram
5
5
LOAD
16
BN
BU
9
51
19
15
30
7.5
6
12
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
Delivery Contents
Inductive proximity switch IG12FSF04D.
Packaging: plastic bag
2
很抱歉,暂时无法提供与“IG12FSF04DC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1641.815941+205.16084
- 5+1559.737355+194.90432
- 10+1510.4785210+188.74896
- 25+1461.2226625+182.59396
