EI1805TBOPS
EI1805TBOPS
    CARLOGAVAZZI
    Cylinder,Threaded-M18
    SENSOR PROX INDUCTIVE 5MM CYLIND
EI1805TBOPS 数据手册
Proximity Sensors Inductive Thermoplastic Polyester Housing Types EI, AC, M18, M30 • Thermoplastic polyester housing, cylindrical • Diameter: M18 and M30 • Sensing distance: 5 to 15 mm • Power supply: 20 to 250 VAC • Output: SCR, make or break switching • Protection: Overvoltage • LED-indication for output ON • Long or short housing • 2 m cable or M12 plug (double keyed) Product Description AC proximity switches constructed in rugged thermoplastic polyester housings. Sizes available are M18 and M30. Length of housing is selectable with 30 mm thread or 50 mm thread. Ordering Key Bright LED ring utilizing a yellow LED clearly gives indication of output status. Protection rating IP 67 ensures environmental compatibility. EI 1808 TBCPL-6 Type Housing diameter (mm) Rated operating dist. (mm) Output type Housing material Body style Plug Type Selection AC Types, Cable and M12 Plug Housing diameter Body style Connection Rated operating dist. (Sn) Ordering no. SCR NO M18 M18 M18 M18 Short Long Long Long Cable Cable Cable Plug 5 mm 1) 5 mm 1) 8 mm 2) 8 mm 2) EI 1805 TBOPS EI 1805 TBOPL EI 1808 TBOPL M30 M30 Long Long Cable Cable 10 mm 1) 15 mm 2) EI 3010 TBOPL EI 3015 TBOPL 1) 2) Ordering no. SCR NC EI 1808 TBCPL EI 1808 TBCPL-6 For flush mounting in metal For non-flush mounting in metal Specifications Rated operational volt. (Ue) (UB) Rated operational current (Ie) Continuous Short-time Minimum load current OFF-state current (Ir) Voltage drop (Ud) Protection Transient voltage Power ON delay Frequency of operating cycles (f) 24 to 240 VAC 20 to 265 VAC, 50 to 60 Hz 10 - 500 mA ≤ 2.5 A, max. 20 ms 10 mA ≤ 2 mA ≤ 8 VAC at max. load Transients Level 3, 2.5 kV, acc. to IEC 60255-5 (500 Ω, 0.5 J) (prepared) ≤ 100 ms 25 Hz Specifications are subject to change without notice (30.04.10) Indication for output ON Assured operating dist. (Sa) Repeat accuracy (R) Hysteresis (H) (Differential travel) Effective operating dist. (Sr) Usable operating dist. (S) Ambient temperature Operating Storage Degree of protection Housing material Body Back LED, yellow 0 ≤ Sa ≤ 0.81 Sn ≤ 5% 3 to 20% of sensing distance 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IP 67 (Nema 1, 3, 4, 6, 13) Grey thermoplastic polyester Black thermoplastic Polyester 1 EI, AC, M18, M30 Specifications (cont.) Tightening torque Connection Cable 2 m, 2 x 0.50 mm2 grey PVC, oil proof M12 x 1 (double keyed) CONH6A-xx EI 18 110 g EI 30 180 g Plug Cables for plug (-6) Weight (cable excluded) EI 18 2.6 Nm EI 30 7.5 Nm UL, CSA Yes Approvals CE-marking Dimensions Type A B (mm) C (mm) EI 1805 TB..S EI 1805 TB..L EI 1808 TB..L EI 1808 TB..L-6 57 77 85 83 0 0 8 8 M 18 x 1 x 30 M 18 x 1 x 50 M 18 x 1 x 50 M 18 x 1 x 50 Type A B (mm) C (mm) EI 3010 TB..L EI 3015 TB..L 79 91 0 12 M 30 x 1.5 x 50 M 30 x 1.5 x 50 A A 3 1 2 M12x1 B C B LED Cable type C LED Plug type Wiring Diagrams 2 BN 2 BN 3 BU 3 BU TBOS TBCS Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Power Supplies Power supplies VAC: 2 > SS 110 Specifications are subject to change without notice (30.04.10)
EI1805TBOPS 价格&库存
很抱歉,暂时无法提供与“EI1805TBOPS”相匹配的价格&库存,您可以联系我们找货
