Proximity Sensors Inductive
Short body, Stainless Steel Housing
Types IA, M8
• Miniature stainless steel housing M8
• Short body
• Sensing distance: 1.5 mm or 2.5 mm
• Power supply: 10 to 30 VDC
• Output: Transistor NPN/PNP, normally open or normally
closed
• Protection: Short-circuit
• LED-indication for output ON
• 2 m PVC cable or M8 plug
Product Description
Ordering Key
Miniature inductive proximity
sensor with reduced body
length. Output configuration
for NPN/PNP with both NO
Ind. prox. switch
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Connection
and NC types as standard.
M8 stainless steel housing.
Connection with 2 m PVC
cable or M8 plug.
IA 08 BSF 15 NO M5
Type Selection
Rated
Conn.
operating type
dist. (Sn)
Ordering no.
Transistor NPN
Normally open
Ordering no.
Transistor NPN
Normally closed
Ordering no.
Transistor PNP
Normally open
Ordering no.
Transistor PNP
Normally closed
1.5 mm 1)
1.5 mm 1)
Cable
Plug
IA 08 BSF 15 NO
IA 08 BSF 15 NO M5
IA 08 BSF 15 NC
IA 08 BSF 15 NC M5
IA 08 BSF 15 PO
IA 08 BSF 15 PO M5
IA 08 BSF 15 PC
IA 08 BSF 15 PC M5
2.5 mm
2.5 mm
Cable
Plug
IA 08 BSN 25 NO
IA 08 BSN 25 NO M5
IA 08 BSN 25 NC
IA 08 BSN 25 NC M5
IA 08 BSN 25 PO
IA 08 BSN 25 PO M5
IA 08 BSN 25 PC
IA 08 BSN 25 PC M5
1)
For flush mounting in metal
Specifications
Rated operational volt. (UB)
Ripple
Rated operational current (Ie)
Continuous
No-load supply current (Io)
Voltage drop (Ud)
Protection
Frequency of operating
cycles (f)
Indication for output ON
Repeat Accuracy
Effective operating dist. (Sr)
Usable operating dist. (Su)
10 to 30 VDC (ripple included)
≤ 10%
≤ 200 mA @ + 25°C (+75°F)
≤ 10 mA (ON)
< 2,5 V (@ Imax)
Short circuit
2000 Hz
LED, yellow
≤ 5%
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.85 x Sr ≤ Su ≤ 1.15 x Sr
Specifications are subject to change without notice (26.08.10)
Ambient temperature
Operating
Storage
Degree of protection
Housing material
Approvals
CE-marking
Connection
Cable
Plug
-25° to +70°C (-13° to +158°F)
-30° to +75°C (-22° to +167°F)
IP 67 (Nema 1, 3, 4, 6, 13)
Stainless steel, AISI 303
UL, CSA
Yes
2 m, PVC, AWG 26, oil proof
M8, CONH5A-xxx Serie
1
IA, M8
Dimensions
M8 x 1
M8 x 1
M8 x 1
M8 x 1
3
3
22
30
25
30
30
30
45
45
LED x 4
LED x 4
LED
LED
M8 x 1
M8 x 1
IA 08 BSF 15 ..
IA 08 BSN 25 ..
IA 08 BSF 15 .. M5
IA 08 BSN 25 .. M5
Wiring Diagrams
1 BN
1 BN
1 BN
1 BN
4 BK
2 WH
2 WH
4 BK
3 BU
3 BU
NPN - Normally open
NPN - Normally closed
3 BU
3 BU
PNP - Normally open
PNP - Normally closed
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
2
很抱歉,暂时无法提供与“IA08BSN25NOM5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+993.23819
- 5+931.71016
