TS78M05CP ROG
TS78M05CP ROG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-252(DPAK)
    5V 500MA 35V
TS78M05CP ROG 数据手册
TS78M00 Series Taiwan Semiconductor 3-Terminal 500mA Positive Voltage Regulator FEATURES The TS78M00 Series positive voltage regulators are ● Output Voltage Range 5V & 12V identical to the popular TS7800 Series devices, except ● Output current up to 500mA that they are specified for only half the output current. ● No external components required Like the TS7800 devices, the TS78M00 Series 3- ● Internal thermal overload protection Terminal regulators are intended for local, on-card ● Internal short-circuit current limiting voltage regulation. Internal current limiting, thermal ● ● ● Output transistor safe-area compensation Output voltage offered in 4% tolerance Compliant to RoHS Directive 2011/65/EU and WEEE 2002/96/EC Halogen-free according to IEC 61249-2-21 shutdown circuitry and safe-area compensation for the internal pass transistor combine to make these devices en de d DESCRIPTION remarkably rugged under most operating conditions. Maximum output current with adequate heatsink is 500mA ● APPLICATION Switching power supply ● Home appliance mm ● Pin Definition: 1. Input 2. Ground (Tab) 3. Output eco TO-252 (DPAK) tR Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020 No TYPICAL APPLICATION CIRCUIT A common ground is required between the input and the output voltages. The input voltage must remain typically 2.0V above the output voltage even during the low point on the Input ripple voltage. XX = these two digits of the type number indicate voltage. * = Cin is required if regulator is located an appreciable distance from power supply filter. ** = Co is not needed for stability; however, it does improve transient response. 1 Version: F1512 TS78M00 Series Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL LIMIT UNIT DC Input Voltage VIN 35 V Power Dissipation PD Internally Limited W Operating Junction Temperature Range TJ 0 ~ +150 o TSTG -65~+150 o SYMBOL LIMIT Storage Temperature Range C C THERMAL PERFORMANCE RӨJC Junction to Ambient Thermal Resistance RӨJA 10 °C/W 100 °C/W de Junction to Case Thermal Resistance UNIT d PARAMETER Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board en design. RӨJA shown below for single device operation on FR-4 PCB in still air. ELECTRICAL SPECIFICATIONS TS78M05 o o PARAMETER mm (VIN=10V, IOUT=350mA, 0 C≤TJ≤125 C, CIN=0.33µF, COUT=0.1µF, unless otherwise noted) SYMBOL CONDITION MIN TYP MAX 4.80 5 5.20 4.75 5 5.25 -- 3 100 -- 1 50 5mA≤IOUT≤500mA -- 15 100 5mA≤IOUT≤200mA -- 5 50 IOUT=0, TJ=25°C -- 3 6 7.5V≤VIN≤25V -- -- 0.8 5mA≤IOUT≤350mA -- -- 0.5 TJ=25°C Line Regulation 7.5V≤VIN≤20V 5mA≤IOUT≤350mA 7.5V≤VIN≤25V TJ=25°C 8V≤VIN≤12V REGLINE REGLOAD TJ=25°C tR Load Regulation VOUT e co Output voltage Quiescent Current Quiescent Current Change IQ ΔIQ UNIT V mV mA VN 10Hz≤f≤100KHz, TJ=25°C -- 40 -- µV Ripple Rejection Ratio RR f=120Hz, 8V≤VIN≤18V 62 78 -- dB VDROP IOUT=500mA, TJ=25°C -- 2 -- V ROUT f=1kHz -- 17 -- mΩ IOS TJ=25°C -- 50 -- mA IO peak TJ=25°C -- 0.7 -- A IOUT= 5mA, 0°C≤TJ≤125°C -- -0.2 -- mV/°C No Output Noise Voltage Voltage Drop Output Resistance Output Short Circuit Current Peak Output Current Temperature Coefficient of Output Voltage ΔVOUT/ΔTJ Note: 1. Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible, and thermal effects must be taken into account separately 2. This specification applies only for DC power dissipation permitted by absolute maximum ratings. 2 Version: F1512 TS78M00 Series Taiwan Semiconductor ELECTRICAL SPECIFICATIONS TS78M05 o o (VIN=19V, IOUT=350mA, 0 C≤TJ≤125 C, CIN=0.33µF, COUT=0.1µF, unless otherwise noted) SYMBOL CONDITION TJ=25°C Output voltage VOUT Line Regulation REGLINE REGLOAD Quiescent Current IQ Quiescent Current Change TJ=25°C MAX 11.53 12 12.48 11.42 12 12.60 -- 10 240 -- 3 120 -- 12 240 5mA≤IOUT≤500mA 5mA≤IOUT≤200mA IOUT=0, TJ=25°C 14.5V≤VIN≤27V ΔIQ TYP -- 4 120 -- 3 6 -- -- 0.8 -- -- 0.5 de Load Regulation 14.5V≤VIN≤27V 5mA≤IOUT≤350mA 14.5V≤VIN≤30V TJ=25°C 15V≤VIN≤19V MIN 5mA≤IOUT≤350mA UNIT V mV d PARAMETER mA VN 10Hz≤f≤100KHz, TJ=25°C -- 75 -- µV Ripple Rejection Ratio RR f=120Hz, 15V≤VIN≤25V -- 80 -- dB VDROP IOUT=500mA, TJ=25°C -- 2 -- V f=1kHz -- 18 -- mΩ TJ=25°C -- 50 -- mA TJ=25°C -- 0.7 -- A IOUT= 5mA, 0°C≤TJ≤125°C -- -0.3 -- mV/°C Output Resistance ROUT Output Short Circuit Current Peak Output Current IOS IO peak ΔVOUT/ΔTJ e co Temperature Coefficient of Output Voltage mm Voltage Drop en Output Noise Voltage tR Note: 1. Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible, and thermal effects must be taken into account separately 2. This specification applies only for DC power dissipation permitted by absolute maximum ratings. No ORDERING INFORMATION OUTPYT VOLTAGE PART NO. PACKAGE PACKING 5V TS78M05CP ROG TO-252 (DPAK) 2,500pcs / 13" Reel 12V TS78M12CP ROG TO-252 (DPAK) 2,500pcs / 13" Reel 3 Version: F1512 TS78M00 Series Taiwan Semiconductor de d ELECTRICAL CHARACTERISTIC CURVE Figure 2. Dropout Voltage vs. Junction Temperature e co mm en Figure 1. Bias Current vs. Input Voltage Figure 4. Ripple Rejection vs. Frequency No tR Figure 3. Bias Current vs. Output Current Figure 6. Peak Output Current vs. Dropout Voltage 4 Version: F1512 TS78M00 Series Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) tR e co mm SUGGESTED PAD LAYOUT (Unit: Millimeters) en de d TO-252 (DPAK) MARKING DIAGRAM = Output Voltage 05 =5V 12 =12V = Year Code = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec = Lot Code No XX Y M L 5 Version: F1512 TS78M00 Series No tR e co mm en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: F1512
TS78M05CP ROG 价格&库存
很抱歉,暂时无法提供与“TS78M05CP ROG”相匹配的价格&库存,您可以联系我们找货
