Proximity Sensors Inductive
Extended Range, Nickel Plated Brass Housing
Types IA, DC, M12, M18 and M30, 2-wire
Product Description
Proximity switch M12, M18
and M30 in nickel-plated
brass housings. Made in
Sensing distance: 4 to 22 mm
Flush and non-flush types
Power supply: 10 to 40 VDC
Output: Transistor
Make or break switching
Protection: Reverse polarity, short-circuit and transients
2 m cable or plug M12
Diameter: M12, M18, M30
Ordering Key
accordance with Euronorm
EN 60 947-5-2.
IA12ASF04DOM1
Cap. proximity switch
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection
Type Selection
Housing
diameter
Body
style
Connection
Rated
operating
dist. (Sn)
Ordering no.
2 wire DC
Normally open
Ordering no.
2 wire DC
Normally closed
M12
M12
M12
M12
Short
Short
Short
Short
Cable
Plug
Cable
Plug
4 mm 1)
4 mm 1)
8 mm 2)
8 mm 2)
IA 12 DSF 04 DO
IA 12 ASF 04 DO M1
IA 12 DSN 08 DO
IA 12 ASN 08 DO M1
IA 12 DSF 04 DC
IA 12 ASF 04 DC M1
IA 12 DSN 08 DC
IA 12 ASN 08 DC M1
M18
M18
M18
M18
Short
Short
Short
Short
Cable
Plug
Cable
Plug
8 mm 1)
8 mm 1)
14 mm 2)
14 mm 2)
IA 18 DSF 08 DO
IA 18 ASF 08 DO M1
IA 18 DSN 14 DO
IA 18 ASN 14 DO M1
IA 18 DSF 08 DC
IA 18 ASF 08 DC M1
IA 18 DSN 14 DC
IA 18 ASN 14 DC M1
M30
M30
M30
M30
Short
Short
Short
Short
Cable
Plug
Cable
Plug
15 mm 1)
15 mm 1)
22 mm 2)
22 mm 2)
IA 30 DSF 15 DO
IA 30 ASF 15 DO M1
IA 30 DSN 22 DO
IA 30 ASN 22 DO M1
IA 30 DSF 15 DC
IA 30 ASF 15 DC M1
IA 30 DSN 22 DC
IA 30 ASN 22 DC M1
1)
2)
For flush mounting in metal
For non-flush mounting in metal
Specifications
Rated operational volt. (Ue)
(UB)
Ripple
Rated operational current (Ie)
Continuous
No-load supply current (I)
Voltage drop (Ud)
Protection
12 to 36 VDC
10 to 40 VDC (ripple included)
≤ 10%
≤ 5-100 mA
≤ 0.8 mA
≤ 3 VDC at max. load
Reverse polarity,
short-circuit, transients
Specifications are subject to change without notice (06.06.05)
Transient voltage
EMC
Power ON delay
Frequency of operating
cycles (f)
≤ 1 kV/0.5 J
Approved according to
EN 50 080, EN 50 081
< 50 ms
IA12xSF
1000 Hz
IA12xSN
800 Hz
IA18xSF
500 Hz
IA18xSN
400 Hz
IA30xSF
400 Hz
IA30xSN
200 Hz
1
Specifications (cont.)
Indication
Repeat accuracy (R)
Hysteresis (H) (Differential travel)
Assured operating dist. (Sa)
Effective operating dist. (Sr)
Usable operating dist. (S)
Ambient temperature
Operating
Storage
Degree of protection
Housing material
Body
Front
Back
Connection
Cable
LED, yellow
≤ 10%
1 to 20% of sensing distance
0 ≤ Sa ≤ 0.77 Sn
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.85 x Sr ≤ Su ≤ 1.15 x Sr
2 m, 2 x 0.5 mm2,
grey PVC, oil proof
M12 x 1
CONH1A serie
IA 12xxx
20 g
IA 18xxF
26 g
IA 18xxN
30 g
IA 30xxF
50 g
IA 30xxN
80 g
IA 12 (x)
7 Nm
15 Nm
IA 18
27.5 Nm
IA 30
50 Nm
CSA, UL
Yes
Plug
Cables for plug (-1)
Weight (cable excluded)
-25° to +70°C (-13° to +158°F)
-30° to +80°C (-22° to +176°F)
IP 67 (Nema 1, 3, 4, 6, 13)
Tightening torque
In nickel-plated brass
Grey thermoplastic polyester
Black polyester (cable)
In nickel-plated brass (plug)
Approvals
CE-marking
Dimensions
Type
A
B
C
Ø mm mm
D
mm
E
mm
IA 12 DSF 04 D.
IA 12 ASF 04 D. M1
IA 12 DSN 08 D.
IA 12 ASN 08 D. M1
M 12 x 1 x 38
M 12 x 1 x 38
M 12 x 1 x 38
M 12 x 1 x 38
10.7
10.7
10.7
10.7
38
38
42
42
11
25.2
11
25.2
5.0
IA 18 DSF 08 D.
IA 18 ASF 08 D. M1
IA 18 DSN 14 D.
IA 18 ASN 14 D. M1
M 18 x 1 x 30
M 18 x 1 x 30
M 18 x 1 x 30
M 18 x 1 x 30
16.7
16.7
16.7
16.7
30
30
38
38
11.6
25.0
11.6
25.0
15.4
IA 30 DSF 15 D.
IA 30 ASF 15 D. M1
IA 30 DSN 22 D.
IA 30 ASN 22 D. M1
M 30 x 1.5 x 30
M 30 x 1.5 x 30
M 30 x 1.5 x 30
M 30 x 1.5 x 30
28
28
28
28
30
30
42
42
13.6
25.0
13.6
25.0
15.4
C
5.0
15.4
15.4
F SW
mm mm
4
4
4
4
17
17
17
17
4
4
4
4
24
24
24
24
5
5
5
5
36
36
36
36
C
E
D
B
B
D
F
F
Cable type
SW
LED
A
Plug type
M12 x 1 x 9.5
LEDs
SW A
Wiring Diagrams
“NPN”
“PNP”
1
LOAD
4
BU-
1
DC 2-wire
break switching (NC)
2
LOAD
BU-
BU-
1
BN+
DC 2-wire
BN+
LOAD
DC 2-wire
make switching (NO)
4
2
1
BN+
DC 2-wire
make switching (NO)
BN+
LOAD
2
BU-
Power Supplies
Power supplies VDC:
> SS 130/140.
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
3
很抱歉,暂时无法提供与“IA30DSF15DO”相匹配的价格&库存,您可以联系我们找货
