NJ15-M1-E2-V1
NJ15-M1-E2-V1
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 15MM PNP
NJ15-M1-E2-V1 数据手册
Inductive sensor NJ15-M1-E2-V1 < 15 mm non-flush < 3-wire DC 15 Dimensions 30 4.3 x 5.3 M12 x 1 30 20/22 LEDs 41 62 72 Technical Data Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 222495_eng.pdf General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation 15 mm non-flush Output polarity DC Assured operating distance sa 0 ... 12.15 mm Actual operating distance sr 13.5 ... 16.5 mm typ. 15 mm Reduction factor rAl 0.39 Reduction factor rCu 0.36 Reduction factor r304 0.73 Output type 3-wire Nominal ratings Operating voltage UB 10 ... 60 V DC Switching frequency f 0 ... 200 Hz Hysteresis H typ. 5 % Reverse polarity protection yes Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NJ15-M1-E2-V1 Technical Data Short-circuit protection pulsing Voltage drop Ud ≤ 2.5 V Ud 1 ... 2.5 V typ. 2.2 V Rated insulation voltage UBIS 500 V Operating current IL 0 ... 200 mA No-load supply current I0 ≤ 14 mA Time delay before availability tv ≤ 50 ms Voltage drop at IL Voltage drop IL = 200 mA, switching element on Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 932 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates EAC conformity TR CU 020/2011 CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector plug M12 x 1 , 4-pin Housing material PBT/metal RAL 7011 Sensing face PBT Degree of protection IP67 Connection 1 L+ 4 3 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 222495_eng.pdf L- Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NJ15-M1-E2-V1 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Female cordset single-ended M12 angled A-coded, 4-pin, PUR cable grey V1-G-2M-PUR Female cordset single-ended M12 straight A-coded, 4-pin, PUR cable grey Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 222495_eng.pdf V1-W-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NJ15-M1-E2-V1 价格&库存
很抱歉,暂时无法提供与“NJ15-M1-E2-V1”相匹配的价格&库存,您可以联系我们找货
