NBB20-L2M-A2-V1
NBB20-L2M-A2-V1
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 20MM PNP
NBB20-L2M-A2-V1 数据手册
Inductive sensor NBB20-L2M-A2-V1 < < < < Sensor head bidirectional and rotatable 20 mm flush 4-wire DC 4-way LED indicator Dimensions LED gn LED ye 7 M12 x 1 20 30 28 LED ye 67 LED gn 40 40 Release date: 2020-03-21 Date of issue: 2020-03-30 Filename: 132358_eng.pdf 8 ø 5.5 46 60 Technical Data General specifications Switching function complementary Output type Rated operating distance PNP sn Installation 20 mm flush Output polarity DC Assured operating distance sa 0 ... 16.2 mm Actual operating distance sr 18 ... 22 mm Reduction factor rAl 0.33 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB20-L2M-A2-V1 Technical Data Reduction factor rCu 0.31 Reduction factor r304 0.74 Reduction factor rBrass 0.41 Output type 4-wire Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 440 Hz Hysteresis H typ. 5 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤2V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA No-load supply current I0 ≤ 20 mA Time delay before availability tv 80 ms Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 1289 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates EAC conformity TR CU 020/2011 Protection class II Rated insulation voltage Ui 253 V Rated impulse withstand voltage Uimp 4000 V UL approval cULus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 85 °C (-13 ... 185 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Release date: 2020-03-21 Date of issue: 2020-03-30 Filename: 132358_eng.pdf Mechanical specifications Connection type Connector plug M12 x 1 , 4-pin Housing material PA-GF35 metal base Xylan coated metal mounting flange Xylan coated. Sensing face PA-GF35 Degree of protection IP69K Cable Cable diameter Mass 3.3 mm ± 0.15 mm 155 g Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB20-L2M-A2-V1 Connection 1 L+ 4 2 3 L- Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Female cordset, M12, 4-pin, PUR cable V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable MHW 01 Modular mounting bracket MH 02-L Mounting aid Release date: 2020-03-21 Date of issue: 2020-03-30 Filename: 132358_eng.pdf V1-G-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB20-L2M-A2-V1 价格&库存
很抱歉,暂时无法提供与“NBB20-L2M-A2-V1”相匹配的价格&库存,您可以联系我们找货
