NBB2-8GM40-E0-V3
NBB2-8GM40-E0-V3
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M8
    INDUCTIVE SENSOR
NBB2-8GM40-E0-V3 数据手册
Inductive sensor NBB2-8GM40-E0-V3 < 2 mm flush < Increased operating distance < Extended temperature range -40 ... +85 °C Dimensions 4 M8 x 1 55 40 13 6 LED M8 x 1 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 304615-0054_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance NPN sn Installation flush Output polarity Assured operating distance 2 mm DC sa 0 ... 1.62 mm Actuating element mild steel, e. g. 1.0037, SR235JR (formerly St37-2) 8 mm x 8 mm x 1 mm Reduction factor rAl 0.4 Reduction factor rCu 0.3 Reduction factor r304 0.75 Reduction factor rBrass 0.45 Output type 3-wire Nominal ratings Operating voltage UB 5 ... 30 V Switching frequency f 0 ... 6000 Hz Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB2-8GM40-E0-V3 Technical Data Hysteresis H Reverse polarity protection typ. 5% reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤ 1.5 V Operating current IL 0 ... 100 mA Off-state current Ir 0 ... 0.2 mA No-load supply current I0 ≤ 10 mA Time delay before availability tv ≤ 100 ms Switching state indicator Multihole-LED, yellow Functional safety related parameters MTTFd 960 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose, Class 2 Power Source CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -40 ... 85 °C (-40 ... 185 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type Connector plug M8 x 1 , 3-pin Housing material brass, nickel-plated Sensing face LCP Degree of protection IP67 General information Scope of delivery 2 hex nuts included Connection 1 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 304615-0054_eng.pdf L+ 4 3 L- Connection Assignment 4 1 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB2-8GM40-E0-V3 Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) Accessories Mounting flange, 8 mm EXG-08 Quick mounting bracket with dead stop V3-WM-2M-PUR Female cordset single-ended, M8, 3-pin, PUR cable Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 304615-0054_eng.pdf BF 8 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB2-8GM40-E0-V3
物料型号:NBB2-8GM40-E0-V3
器件简介:这是一个感应传感器,具有2毫米的平齐安装距离,扩展的工作温度范围为-40至+85°C。
引脚分配:根据EN 60947-5-2标准,1号引脚为棕色(BN),3号引脚为蓝色(BU),4号引脚为黑色(BK)。
参数特性: - 切换功能:常开(NO) - 输出类型:NPN - 额定工作距离:2mm - 安装方式:平齐安装 - 输出极性:直流 - 保证工作距离:0...1.62 mm - 驱动元件:例如1.0037, SR235JR(旧称St37-2)的8mmx8mmx1mm的软钢 - 多种降低因子 - 输出类型:3线 - 额定值:工作电压5...30V,切换频率0...6000Hz
功能详解: - 滞后性:典型值5% - 防反接保护:具有反接保护 - 短路保护:脉冲式 - 电压降:≤1.5V - 工作电流:0...100mA - 关断状态电流:0...0.2mA - 无负载供电电流:≤10mA - 可用前的时间延迟:≤100ms - 切换状态指示:多孔LED,黄色
应用信息: - 环境条件:环境温度-40...85°C,存储温度-40...85°C - 机械规格:连接类型为M8x1的3针连接器插头,外壳材料为镀镍黄铜,感应面为LCP,防护等级为IP67 - 一般信息:包括2个六角螺母
封装信息:提供了连接分配和配件信息,例如8mm安装法兰、快速安装支架和M8, 3针PUR电缆的母线束。
NBB2-8GM40-E0-V3 价格&库存
很抱歉,暂时无法提供与“NBB2-8GM40-E0-V3”相匹配的价格&库存,您可以联系我们找货
