NBB5-18GM60-A0
NBB5-18GM60-A0
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 5MM NPN
NBB5-18GM60-A0 数据手册
Inductive sensor NBB5-18GM60-A0 < 5 mm flush Dimensions 60 4 M18 x 1 24 Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 083765_eng.pdf LED Technical Data General specifications Switching function complementary Output type Rated operating distance NPN sn Installation flush Output polarity Assured operating distance 5 mm DC sa 0 ... 4.05 mm Reduction factor rAl 0.25 Reduction factor rCu 0.15 Reduction factor r304 0.66 Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 800 Hz Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB5-18GM60-A0 Technical Data Hysteresis H Reverse polarity protection typ. 5% reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 20 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 1050 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.34 mm2 Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Connection BN L+ BK WH BU Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 083765_eng.pdf L- Accessories BF 18 Mounting flange, 18 mm EXG-18 Quick mounting bracket with dead stop Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB5-18GM60-A0 价格&库存
很抱歉,暂时无法提供与“NBB5-18GM60-A0”相匹配的价格&库存,您可以联系我们找货
