NBB2-12GM30-E2-2M-PUR
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M12
    INDUCTIVE SEN 2MM PNP
NBB2-12GM30-E2-2M-PUR 数据手册
Inductive sensor NBB2-12GM30-E2-2M-PUR < 2 mm flush < Hard-wearing PUR cable Dimensions 40 M12 x 1 27 4 LED 17 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 220107_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation flush Output polarity Assured operating distance 2 mm DC sa 0 ... 1.62 mm Reduction factor rAl 0.3 Reduction factor rCu 0.2 Reduction factor r304 0.7 Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 800 Hz Hysteresis H typ. 10 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB2-12GM30-E2-2M-PUR Technical Data Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 15 mA Functional safety related parameters MTTFd 1260 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PUR , 2 m Core cross-section 0.14 mm2 Cable diameter 3.5 mm Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Mass 30 g Connection BN L+ BK BU Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 220107_eng.pdf L- Accessories EXG-12 Quick mounting bracket with dead stop Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB2-12GM30-E2-2M-PUR 价格&库存
很抱歉,暂时无法提供与“NBB2-12GM30-E2-2M-PUR”相匹配的价格&库存,您可以联系我们找货
