ICB30L50N40POM1
ICB30L50N40POM1
    CARLOGAVAZZI
    Cylinder,Threaded-M30
    SENSOR PROX INDUCTIVE 40MM CYL
ICB30L50N40POM1 数据手册
ICB, M30 Proximity Inductive Sensors Increased Operating Distance, Nickel-Plated Brass Housing - Types ICB, M30 • Sensing distance: 22 to 40 mm • Quasi-flush or non-flush mountable • Short or long body versions • Rated operational voltage (Ub): 10 - 36 VDC • Output: DC 200 mA, NPN or PNP • Normally open or Normally closed • LED indication for output ON, short-circuit and overload • Protection: reverse polarity, short circuit, transients • Cable or M12 plug versions • According to IEC 60947-5-2 • Setup indicator • Laser engraved on front cap, permanently legible • CSA certified for Hazardous Locations Product Description A family of inductive proximity switches in industrial standard nickel-plated brass housings. They are able to handle applications where very long operating distance is requested. Ordering Key Output is open collector NPN or PNP transistors. Less machine downtime thanks to lower risk of mechanical damage. Type Housing style Housing material Housing size Housing length Thread length Detection principle Sensing distance Output type Output configuration Connection ICB30S35F22NOM1 Type Selection Connec- Body tion style Rated operating distance Sn Ordering no. NPN, Normally open Cable Cable Plug Plug Cable Cable Plug Plug 22 mm 1) 40 mm 2) 22 mm 1) 40 mm 2) 22 mm 1) 40 mm 2) 22 mm 1) 40mm 2) ICB30S35F22NO ICB30S35F22PO ICB30S35N40NO ICB30S35N40PO ICB30S35F22NOM1 ICB30S35F22POM1 ICB30S35N40NOM1 ICB30S35N40POM1 ICB30L50F22NO ICB30L50F22PO ICB30L50N40NO ICB30L50N40PO ICB30L50F22NOM1 ICB30L50F22POM1 ICB30L50N40NOM1 ICB30L50N40POM1 1) Short Short Short Short Long Long Long Long For quasi-flush mounting in metal 2) Ordering no. PNP, Normally open Ordering no. NPN, Normally closed Ordering no. PNP, Normally closed ICB30S35F22NC ICB30S35F22PC ICB30S35N40NC ICB30S35N40PC ICB30S35F22NCM1 ICB30S35F22PCM1 ICB30S35N40NCM1 ICB30S35N40PCM1 ICB30L50F22NC ICB30L50F22PC ICB30L50N40NC ICB30L50N40PC ICB30L50F22NCM1 ICB30L50F22PCM1 ICB30L50N40NCM1 ICB30L50N40PCM1 For non-flush mounting in metal Specifications Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.) Ripple ≤ 10% Output current (Ie) ≤ 200 mA @ 50°C (≤ 150 mA @ 50-70°C) OFF-state current (Ir) ≤ 50 μA No load supply current (Io) ≤ 15 mA Voltage drop (Ud) Max. 2.5 VDC @ 200 mA Protection Reverse polarity, short-circuit, transients Voltage transient 1 kV/0.5 J Power ON delay (tv) ≤ 20 ms Operating frequency (f) ≤ 100 Hz Specifications are subject to change without notice (16.01.2017) Indication for output ON Activated LED, yellow NO version Target present NC version Target not present Indication for short circuit/ overload LED blinking (f = 2 Hz) Assured operating sensing distance (Sa) 0 ≤ Sa ≤ 0.81 x Sn Effective operating distance (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating distance (Su) 0.9 x Sr ≤ Su ≤ 1.1 x Sr Repeat accuracy (R) ≤ 10% Differential travel (H) (Hysteresis) 1 to 20% of sensing dist. 1 ICB, M30 Specifications (cont.) Ambient temperature Operating Storage Shock and vibration Housing material Body Front Connection Cable Plug Degree of protection Weight (cable/nuts included) Cable Plug Dimensions Tightening torque Setup function NO version LED flashing (f=0.67 Hz) LED lights continuously NC version LED flashing (f=0.67 Hz) LED OFF -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IEC 60947-5-2/7.4 Nickel-plated brass Grey thermoplastic polyester Ø5.2 x 2 m, 3 x 0.34 mm2, grey PVC, oil proof M12 x 1 IP 67 Max. 220 g Max. 160 g See diagrams below 25 Nm 0.8 Sn < Sr ≤ Sn 0 ≤ Sr ≤ 0.8 Sn (*) Approvals cULus (UL508) cCSAus Note: The terminal connector (version ...M1) was not evaluated. The suitability of the terminal connector should be determined in the end-use application. EMC protection IEC 61000-4-2 (ESD) IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-6 IEC 61000-4-8 MTTFd As Process Control Equipment for Hazardous Locations. - Class I, Division 2, Groups A, B, C and D. - T5, Enclosure Type 4. Ambient temperature Ta: -25° to +60°C CCC is not required for products with a maximum operating voltage of ≤ 36 V According to IEC 60947-5-2 8 KV air discharge, 4 KV contact discharge 3 V/m 2 kV 3V 30 A/m 700 years @ 50°C (122°F) 0.8 Sn < Sr ≤ Sn 0 ≤ Sr ≤ 0.8 Sn (*) (*): safer installation Dimensions (mm) LED 35 12 Short body, quasi-flush version, cable 9.8 Short body, quasi-flush version, plug 2 35 Short body, non-flush version, cable LED (4 x 90°) 60 35 LED 47 LED (4 x 90°) 72 4 3 4 3 1 2 1 2 12 35 9.8 Short body, non-flush version, plug Specifications are subject to change without notice (16.01.2017) ICB, M30 Dimensions (mm) (cont.) LED 50 LED 62 50 12 Long body, non-flush version, cable Long body, quasi-flush version, cable LED (4 x 90°) 75 4 3 4 3 1 2 1 2 Long body, quasi-flush version, plug 9.8 50 12 9.8 50 LED (4 x 90°) 87 Long body, non-flush version, plug Installation Quasi-flush mountable proximity switches, when installed in damping material, must be according to Picture 1A. Picture 1A Non-flush mountable proximity switches, when installed in damping material, must be according to Picture 1B. Picture 1B d Sn : nominal sensing distance d : sensor diameter (30 mm) d ≥ 3 x Sn Sn : nominal sensing distance d : sensor diameter (30 mm) Quasi-flush mountable proximity switches, when installed together in damping material, must be according to Picture 2A. Picture 2A d ≥ 35 mm ≥ 3 x Sn 6 mm ≥ 5 x Sn Non-flush mountable proximity switches, when installed together in damping material, must be according to Picture 2B. Picture 2B d ≥ 3 x Sn d ≥ 5 x Sn d ≥ 3 x Sn 6 mm Sn : nominal sensing distance d : sensor diameter (30 mm) Specifications are subject to change without notice (16.01.2017) Sn : nominal sensing distance d : sensor diameter (30 mm) 3 ICB, M30 Installation (cont.) For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed (See Picture 3). Picture 3 ≥ 6 x Sn Sn : nominal sensing distance Wiring Diagram 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 2 BK 2 BK 4 BK 3 BU 3 BU - NPN - Normally open - NPN - Normally closed Reduction Factors The rated operating distance is reduced by the use of metals and alloys other than Fe360. Picture 4 3 BU PNP - Normally open - 3 BU - PNP - Normally closed Accessories for Plug Versions The most important reduction factors for inductive proximity sensors are shown in Picture 4. Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance Delivery Contents 3-wire angled connector, 2 m cable 3-wire angled connector, 5 m cable 3-wire angled connector, 10 m cable 3-wire angled connector, 15 m cable 3-wire straight connector, 2 m cable 3-wire straight connector, 5 m cable 3-wire straight connector, 10 m cable 3-wire straight connector, 15 m cable PVC PUR CONB13NF-A2 CONB13NF-A2P CONB13NF-A5 CONB13NF-A5P CONB13NF-A10 CONB13NF-A10P CONB13NF-A15 CONB13NF-A15P CONB13NF-S2 CONB13NF-S2P CONB13NF-S5 CONB13NF-S5P CONB13NF-S10 CONB13NF-S10P CONB13NF-S15 CONB13NF-S15P For any additional information or different options, please refer to the “General Accessories Connector Cables -Type CONB1...” datasheets. • Inductive proximity switch ICB. • 2 nuts NPB • 2 washers • Packaging: plastic bag 4 Specifications are subject to change without notice (16.01.2017)
ICB30L50N40POM1 价格&库存
很抱歉,暂时无法提供与“ICB30L50N40POM1”相匹配的价格&库存,您可以联系我们找货
