Level Sensors
Capacitive Level Detector
Type CD50 CNF 06 NO
• Basic capacitive water level sensor
• For water storage tanks in mini-pools and whirlpools
• Detection of excess water in the whirlpool tub
• Safety device to control the operation of the pump
• Mounting by screws or glued on the outside of any
non-metallic tank
• Supply 10-30 VDC or 5 VDC
Product Description
Ordering Key
Capacitive level detectors.
3-wire DC sensors with
open collector NPN or PNP
transistor output. The sensors is available in a 5 VDC
version and a 10-30 VDC
version.
Capacitive proximity switch
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
The sensing distance is fixed
and works through a nonmetallic wall of up to 20 mm
of thickness.
CD50 CNF 06 NO
Type Selection
Supply
Housing
Rated
Mounting
size (mm)
operating
distance (Sn)
10-30 VDC
10-30 VDC
10-30 VDC
5 VDC
50 x 30 x 7
50 x 30 x 7
50 x 30 x 7
50 x 30 x 7
10 mm
7 mm
6 mm
5 mm
Ordering no.
Ordering no.
Ordering no.
Transistor NPN/ Transistor NPN/ Transistor PNP/
cable, make
cable, break
cable, make
switching switching switching
M3 screws or glued
CD50CNF10NO CD50CNF10NC CD50CNF10PO
M3 screws or glued
CD50CNF07NC CD50CNF07PO
M3 screws or glued CD50CNF06NO
M3 screws or glued
CD50CNF05NO
Specifications
Rated operation dist. (Sn)
Fixed CD50CNF10XX 10 mm (ref. st. 37 grounded)
Fixed CD50CNF07XX 7 mm (ref. st. 37 grounded)
Fixed CD50CNF06NO 6 mm (ref. st. 37 grounded)
Fixed CD50CNF05NO 5 mm (ref. st. 37 grounded)
Rated operational volt. (Ue)
Fixed CD50CNF10-07-06XX 10-30 VDC ± 10%
(ripple included)
Fixed CD50CNF05NO 5 VDC ± 10%
(ripple included)
Ripple ≤ 10%
Rated operational current (Ie)
Continuous ≤ 50 mA
No-load supply current (Io) ≤ 10 mA
Leakage current < 100 μ A
Voltage drop (Ud) @ 50 mA 1.5 V
Frequency of operating
cycles (f)
CD50CNF10XX 10 Hz
CD50CNF07XX 10 Hz
CD50CNF06XX 10 Hz
CD50CNF05XX 10 Hz
Specifications are subject to change without notice (04.08.2014)
Output
CD50CNFXXNO Open collector, NPN,
make switching
CD50CNFXXNC Open collector, NPN,
breake switching
CD50CNFXXPO Open collector, PNP,
make switching
Environment
Degree of protection IP 67
Operating temperature 0 to +60°C (32 to +140°F)
Storage temperature -30 to +75°C (-22 to +167°F)
Housing material Noryl, grey
Connection
Cable
2.0 m, 3 x 0.25 mm2
grey PVC, oil proof
Weight
120 g
CE-marking
Yes
1
CD50CNFXX
Wiring Diagram
NPN NC
NPN NO
BN
PNP NO
BN
BN
BK
BK
BK
BU
BU
BU
Dimensions
R1.75
50
3.5 12
3.7
7
3
14
22
30
Delivery Contents
• Capacitive switch
• Packaging: Plastic bag
2
很抱歉,暂时无法提供与“CD50CNF06NO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+430.751481+55.79738
- 5+409.214435+53.00758
- 10+396.2911410+51.33357
- 25+383.3687125+49.65966
