NBN15-18GM60-US
NBN15-18GM60-US
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 15MM NO
NBN15-18GM60-US 数据手册
Inductive sensor NBN15-18GM60-US < 15 mm non-flush < 2-wire AC/DC Dimensions 63 45 62 4 40 10 M18 x 1 24 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 198082_eng.pdf LEDs Technical Data General specifications Switching function Normally open (NO) Output type Two-wire Rated operating distance sn 15 mm Installation non-flush Output polarity AC/DC Reduction factor rAl 0.45 Reduction factor rCu 0.4 Reduction factor r304 0.7 Output type 3-wire Nominal ratings Operating voltage UB 20 ... 250 V AC/20 ... 300 V DC Switching frequency f 30 Hz Hysteresis H 3 ... 15 typ. 5 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBN15-18GM60-US Technical Data Reverse polarity protection reverse polarity tolerant Short-circuit protection yes Voltage drop Ud ≤8V Operating current IL 4 ... 300 mA AC/DC Off-state current Ir ≤ 0.8 mA Operating voltage indicator LED, green Switching state indicator LED, yellow Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type cable PUR , 2 m Core cross-section 0.5 mm2 Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Connection BN AC/DC BU GN/YE Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 198082_eng.pdf Accessories BF 18 Mounting flange, 18 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBN15-18GM60-US
物料型号:NBN15-18GM60-US
器件简介:这是一个电感式传感器,具有2线制AC/DC输出,安装时不突出,尺寸小于15毫米。
引脚分配:文档中未明确列出引脚分配,但通常包括AC/DC电源输入、信号输出和地线。
参数特性: - 额定工作距离:15毫米 - 工作电压:20至250伏交流电或20至300伏直流电 - 开关频率:30赫兹 - 滞后:典型值为5% - 反向极性保护:具有反向极性容忍 - 短路保护:是 - 电压降:不超过8伏 - 工作电流:4至300毫安交流电/直流电 - 关闭状态电流:不超过0.8毫安
功能详解: - 传感器具有通常开启(NO)的开关功能 - 有绿色LED指示操作电压,黄色LED指示开关状态
应用信息:适用于需要小尺寸和非突出安装的感应应用。
封装信息: - 连接类型:2米PUR电缆 - 芯线截面积:0.5平方毫米 - 外壳材料:镀镍黄铜 - 感应面材料:PBT - 保护等级:IP67
NBN15-18GM60-US 价格&库存
很抱歉,暂时无法提供与“NBN15-18GM60-US”相匹配的价格&库存,您可以联系我们找货
